- ? about es motor mounts
- Today's adventure...motor mounts(pics)
- Beep to lock/unlock - Installed with pics and video
- Turbo Automatic...Won't move in reverse
- Maxspeed springs w/ stock struts v. Tein SS coilovers - My impressions
- Sidemarker rewire to blink with signal....
- Is bedding modern brake pads still needed?
- maxima=pathfinder?
- 5.5gen Pulley Install - Annoying Problem!!
- Transmission Flush
- Is this a dead battery or something else?
- 5 to 5.5 gen fogs
- off/on front vibration
- vafc help !!
- Evap canister & valve, are these correct?
- Codes...
- Tranny Drain plug -magnet super clean
- Head scractcher P-0420 & P-0420 PD
- HELP SES light
- Emergency alternator removal!
- pkn2 / remote start question
- vias block plate, intake and throttle body spacers questions
- z tube for intake
- Filling up bushing with polyurethane
- 2002 Maxima SE tune-up
- Your opinion on a transaction
- Immobilizer Module
- Transmission Problems.
- Headlight conversion 2002 to 2000
- shifter knob
- Need to swap out my exhaust, anyone done it on their own?
- 2003 SE Heated Mirrors?
- AEM vs. Apex'i Dry Filters
- Looking at getting a 2003 6-speed...
- what should i expect to pay for a 5.5 gen??
- Looking for a dual tip axle back
- Rattle while engine is under vacuum
- Need opinions on replacement engines for my 5.5:
- How to bypass BOSE???
- Thinking of selling my 2002 max.. worth it?
- My ride is horrible (help please)
- any one hav this write up
- Smoke sidemarkers....
- sunroof issue
- O2 Sim installed and yet...P0158 still exists?!
- weird interior lights issue???
- Engine Covers
- Trunk Open Light
- Engine missing until totally warmed up
- MY D*MN SUNROOF WON'T OPEN!!!
- Car Trouble
- 6-speed tranny info; which years compatible?
- How much are you guys paying for 00/01 dark tail lights?
- higher wattage fogs
- Glove Box Rattle
- What do you think about this deal?
- 20x10
- Which of these can be done in the driveway?
- Stuck fog light
- Feels like braking on ice
- Starting To Mod
- Has any1 blacked out their tail lights this way?
- HOW-TO: Black-Out & Add Audi LED strips to your headlights
- Body werk Gurus
- air condition only works on high
- RIMS
- Need help on my damn power steering pump belt!
- DIY Fuel Filter Replacement
- Car doesnt shift out of first gear. 2 tranny's, same problem
- any original owners left?
- I NEED SOME GUIDANCE
- Threw PO138 P0158 and P0159!
- Fender Bender ...
- Bad experience with Monroe Strut Mounts (pics)
- Brake/battery light.
- bad alternator?
- Question: BBK ROTORS & PADS
- Re-threading 6MT Shifter
- A/C issue
- White Smoke Under My Hood at Startup???
- Headlight and taillights match
- Mesh Grill
- any1 got the chrome mesh ebay grill
- My Weekend Project
- abs lights up on dash
- fog lights 5.5 gen
- Oxidized coolant
- Rear Brakes Relined?
- Any new electronics for performance, mileage?
- Possible problem with Clutch & Aluminum Flywheel - Need Input!
- Struts any good replacements?
- Removing the A/C
- Just ripped out the stillen hi flow intake
- I CAN'T FIND THE TPS ON MY 2002 MAX!!!
- 5.5Gen STS question
- Starter Grinding
- Porting and Polishing the IMs
- 5.5 vs 6th Generation
- What's our headliner made of?
- Tranny Problem
- SSV4 Suprastick
- Transmisson Problem
- new jack w/questions
- START-UP ISSUES - YOUR THOUGHTS?
- Need some help on P0420 please.
- Car Over Heating, Please help.
- differences in 4th gen and 5th gen motor/trans
- Those with Cattman B-Pipe and Stock Muffler....
- True Duals on a Maxima??
- Tuning programs
- Adjusting Backing plate
- Squeak in the wiper motor.
- Throttle valve buzzing noise?
- Will 15" 4th gen wheels fit a 5.5 Gen?
- 2003 SE (Auto) Unplug Engine Mounts?
- *New* Pioneer AVIC - U310BT CD w/ Navi [Demo Video]
- p0105 questions
- Caliper/Rotor question
- OBX Headers fitment problem!
- 5.5 Fog light spec
- Looking for new OEM pedals
- long checklist to do-- want some advice...
- 5.5 Gen Fender Removal
- performance mods
- wow
- New Problem..Tranny not wanting to shift!
- Caliper covers vs paint?
- 5 speed troubles. fml
- Leaking Rack & Pinion
- God I love county trucks
- VQ35DE sound
- How to FIX your DRL
- Bleh Alignment Issues orr?
- HELP! backed up into a fence! pictures
- pinging and knocking sound from engine? need help
- :D Lemme hear it
- I have a dumb question
- Hawk Performance Brake Deal
- Tranny Problem...
- Aftermarket steering wheel
- ebay fstb vs stillen
- Pass side engine mount replace. How hard ?
- Really bad mpg after CAI..
- Good Deal on I35?
- Please help!! cleaned TB now p1102
- Brake Question
- PPL w/ Roof Overlay's (5.5 gen)...QUESTION:
- KYB's Strut mounts Suck
- Rough/Loud Engine Noise
- Megan racing catback WTH??
- NYC potholes-- girlfriend driving...oh g*d!!
- Crack noise every time I accelerate VERY loud on hills
- did i get taken or what?
- Putting my car on a Diet. come in, n help.
- Are all 5.5's prewired for heated seats?
- how many miles after gas light
- Climate control on 5th gen GLE
- carfax report
- O2 sensor/ running rich question
- Ball-joint/wheel-bearing/tie-rod test via wheel play
- Please Help, Problems and P0113 codes...
- Ticking noise, cyl 2
- Interior bulbs
- how do i replace teh lights in the instrument cluster + climate control
- Stock 2002 GXE and $3k
- can you adjust headlights right to left ?
- Headlights went out
- Misfire Code for Cylinder 3
- Odd tranny fluid experience
- Exhaust gurus, input welcomed
- Whats the website with Maxima DIYs?
- Replacing a 2002 Se door with a 2001 GLE door
- Intake...will it fit?
- 6MT Polyurethane Shifter Bushings
- Gauge set.
- Rear Suspension Blown??
- Quick T-Stat Q
- Making the clutch engage sooner
- Do I need a rear camber kit?
- rear wheel hub wont budge
- 3M Headlight Lens Restoration Kit
- Installed new plugs yesterday now car chokes upon start up
- Cattman 2.5" vs 3" or others?
- When to replace belts and is it DYI??
- break pedal problem...
- wheres the thread for replacing the instrument cluster climate control,clock to LEDs
- Good idea?
- 7443 Bulbs discontinued
- what type of intake?
- General Hesitation
- 2000-2001 OEM Tailpipe Shroud
- Toyo Proxes 4 vs Goodyear Assurance Tripletread
- Progress pictures of my new headlights.
- need help to sale stuff to someone on the org
- y-pipe change
- Maxima Folding LED Turn signal Mirrors HELP !
- start issue
- few more questions
- Stillen Classic (Aero) Lip for 2000 max pics requested....
- Wheel hopping
- Introduction
- need some help... location of speed sensor
- Darkening/tinting/blackening emblems/badges
- bose rear deck?
- 5.5 gen hid high beam?
- rear tires worn out before front?
- ECU reflash to cure odd problems?
- Problem with passenger side speakers (but not tweeter)-base system
- 5th Gen Rear Valence Install
- Wierd HID Problem
- Coolant Prices
- Need help replacing the B-pillar trim in a 5.5 gen.
- Frankencar Intake
- Stripped crossmember bolts
- How To Advance Timing?
- Silverstar headlight bulbs problem or a normal electical issue that happens with age?
- Where Do You Hide Your HID Ballasts?
- Does the dealership fix TSBs for free???
- Any BC Racing Coilover Users?
- Camry bbs wheels on my sheer silver Maxima?
- Need advice, 2001 20th Maxima, P1126 & P0430
- Suspension Upgrade - Parts List
- What color wheels for grey lustre?
- Annihilated Maxima
- ebay headers+link.. opinions?
- Installed - BRAND NEW Cattman Y-pipe.
- cattman catback wo cat.
- Temporarily Losing Clutch on Hot Days?
- New exhaust I call it Cattman knockoff. Check it out(video)
- Power Steering fluid leak. Please Help?
- Ypipe, Bpipe, RLKYM..WTHpipes? Im confused
- Change in stock tire size
- Stupid floor mat clip... any ideas?
- Umnitza angel eye upgrade, and clear spoiler light
- Got Rid of My Front End Clunking, Rattle, and Squeak
- What color caliper on a silver/chrome max? silver or red?
- black out badges?
- Time To Replace Rear Struts?
- Any videos of 5.5 maxima with 4th/5th Gen Maxima headers.
- 01 clutch issue, non-returning pedal
- Replaced IACV now rpm gets stuck arnd 1500
- 2002 SE headunit swap
- How does the reliability of an 02 Max compare to 1997 Max?
- 6 speed mileage, 31MPG?
- Quick Question
- sunroof stopped working?
- Car Won't Start, Suspect Bad Gas (Vid Inside)
- Looking for someone who can RR Trailing ARM Bushings NY/NJ/CT
- Figure out what's missing thread.. Yup.. Prize
- Resonator Jig!
