PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 [133] 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Wheel Bearing Preload?
  2. Screeching Noise At Start Up
  3. ECU-to-main harness connector pics?
  4. Question about stock SE springs from 2002 on 2000 Maxima
  5. Slight vibration on the highway what is it?
  6. check engine light after cleaning throttle body
  7. short shifter problem
  8. i35 front end conversion
  9. Body Control Module (BCM). What is it and what does it do?
  10. 2000 max fog lights
  11. Front strut bar install??
  12. Rain in the radio
  13. MOMO Stealth Pedals *Installed*
  14. 03 Alternater----looks tight to replace???
  15. clear corner lighting
  16. Difference between 00-01 from 02-03 fogs
  17. New MAF.... let's see how good it is.
  18. WTF is going on?
  19. I Hate Stupid People
  20. Rear Rotor
  21. Warning!!!!!!!!
  22. any body bought the silver corner lights for 00-01
  23. New Brake kit found.
  24. HID bulb question
  25. To Weld or Bolt on Exhaust
  26. Ingalls Camber kit?
  27. Any tips on removing shifter trim to get to stereo?
  28. Want to see S-Tech/Illuminas on stock 17's
  29. threw a code need help?
  30. weekend forum
  31. Exhaust Question Greddy Magnaflow
  32. Do 5th gens (2k) come with a factory Alarm?
  33. motion sensor
  34. borla exhaust
  35. center bore hub diameter
  36. Is it possible to have a bad MAF, but no "Check Engine" light?
  37. Pic of nissan emblem on steering wheel on 2001.
  38. Hitched?
  39. Aftermarket headlights...
  40. The DEFINITIVE Maxspeed vs. H&R Thread
  41. Finally done with the modded stock spoiler *pics*
  42. anyone upgrade to digital climate control?
  43. Where do I get bumpstops/dust boots for my illuminas?
  44. Ignition Coil Replacements
  45. clear corners question
  46. A'PEXi S-AFC II install and tuning questions.
  47. 04 max bose w/screen in 03 max?
  48. All Red Tails 5.5gen
  49. Front Strut Brace on 03 with HLSD?
  50. Your update on CE rear smoked sidemarkers
  51. how to turn off airbag light?
  52. front lip
  53. 350z Rims, Everyone Said It Woundt Work, It Did
  54. 04 rotors interchangable ?
  55. Front, passenger side axle.
  56. quicky coil question
  57. Where to buy...
  58. burning my tires
  59. Comments please on H&R springs.
  60. How do I know if my car has the sport Package?
  61. Curious
  62. Sterling Mist with Smoked 5.5 gen headlights...
  63. Does ECU store info a/t mileage?
  64. Budget bpipe= teh ghey
  65. the rarest 2k2-2k3 color out there?
  66. avatar
  67. 5gen owner with aftermarket wheels, where to buy hubcentric rings?
  68. bought a hks rear section today
  69. 3M clear tape, where to buy ?
  70. Cracked Windshield from Heat
  71. replacing evap canister
  72. should i buy a car that's been in an accident?
  73. Another stupid headlight question...
  74. clunking or knocking sound
  75. Help with loud CREAKING noise.
  76. Front passenger shock noise
  77. Back deck sub question
  78. Helios H3 micro fog kit
  79. 2k2 clicking sensation in steering
  80. yikes...
  81. Rotor Stud replacement
  82. Factory Fogs
  83. Squeaking clutch pedal...
  84. Fogs keep blowing fuse URRRRR
  85. Hard Drive for music in 03 Max with Navi?
  86. Nissan extended warranty..anyone got it?
  87. ••ü•• Tutorial/Lighting FAQ
  88. Quick Flashin Blinker??
  89. Post Pics of your Custom Trunk Setup (not commentary)
  90. 5spd tranny ratios?
  91. newbee need help install rear spoiler
  92. good deal / fair price?
  93. Brake pedal drill
  94. how can i fix/rig this???
  95. 02 auto tranny question
  96. Nifty camera mount for autocross....
  97. Painted EyeLids and CutDownShifter pics
  98. Just installed the Rear sway bar and
  99. ABS Rear Lip Fitment *PICS*
  100. Radar hardwire to sunroof switches??
  101. Which tires for 2001 Maxima?
  102. Towing with a maxima??!?!?! possible? or na?
  103. What fog lights????
  104. More brake woes....
  105. Looking for the HID write up
  106. can we have a sticky that summarizes all good mods for both auto/man for 5gen/5.5gen?
  107. Help! Need advice w/ Lighting setup for my '03
  108. Left Rear Tire Angled IN, any suggestions?
  109. Rattle--possibly timing chain
  110. Brakes squeaking when not engaged?
  111. Muffler?
  112. new pics of my ride!!!
  113. 2002 Antenna Hook up help needed.....
  114. Headlight question
  115. Drive by Wire
  116. climate control
  117. Anyone out there with KYB-GR2's with stock springs?
  118. robbing a dealership?
  119. Power Windows and Moonroof Problem HELP NEEDED
  120. Where do you have your car inspected?
  121. 5th gen tranny stronger?
  122. Dyno numbers with Cattman Headers!!!!!
  123. 2001 fuse link and fuse off of positive terminal
  124. Rotors: Brembo vs. Frozen
  125. Replacing 2002 Non-Bose Headunit options....
  126. What do they do when thet rebuild trannys?
  127. Help w/ repairing 03 Titanium Edition Dash
  128. Transmission flushes and fill
  129. With new MAF is reprogramming necessarily needed?
  130. How much money do you have in your max
  131. Do they still sell PIAA Super Plasma's anywhere?
  132. What do you recommend
  133. ipod connectivity
  134. Energy Suspension Engine Mounts
  135. Headlight issues.
  136. Need "How-to" for HP Autoworks STS...
  137. Bose Head Unit
  138. Bad camber adjustment?
  139. the new car
  140. TCM reset procedure for 5.0th gen?
  141. heard chunks fall off of car
  142. Where to get HID Kits??
  143. Resetting the CPU???
  144. software
  145. 18X9 wheels?
  146. Safc?????
  147. Can you help me figure out if these are authentic titanium rims?
  148. More info than you ever thought you needed to know about Oxygen Sensors
  149. Brake part pricing info
  150. oil catch can and 3.5 ping / knock
  151. RSB Installed On Lowered Max
  152. Which aftermarket shocks best for stock struts, while still maintaining a good drop?
  153. 2000 coil pack removal
  154. water in headlights?
  155. Gen 2 and Gen 1 HP Autowork STS...
  156. Brake Line Help!
  157. Passenger seat creaks...
  158. Rotor and Caliper Weight
  159. '00 plenum
  160. S-afc Install, Someone, Please Help!!!
  161. engine cover emblem
  162. CE Light always on??
  163. Color spray paint used on turn signals......
  164. Installing new fuel filter cause check engine light to come on?
  165. LED's in Gauges...again
  166. How do I remove my seatbelts?
  167. sleeve cylinder
  168. MaX TuNiNg LiP
  169. 19", difficulty balancing
  170. Running Light Rewire - Anyone Done It?
  171. childseat ***hor covers
  172. seat handle??
  173. Help with #!%@%^ tranny
  174. b-pipe question??
  175. aluminized warpspeed y pipe...
  176. Has anyone installed after market fogs?
  177. Car works strange after changing o2 sensor.
  178. Illuminas and H-Techs are finally on
  179. Help with O2 sensors
  180. Tint: Reflective, Black, Smoke
  181. about intake spacer will this idea work
  182. What size transmission cooler?
  183. Any member here have just stillen front and rear lip?
  184. Pics of 5th gen with Konig Absolutes?
  185. question on indigo door sills
  186. Is 5th gen engine, etc... reliable??
  187. 5th gen carpeting?....
  188. Check engine light question......
  189. Vias Help
  190. Help w/ new fog light install
  191. Sawblades
  192. tune up blues$$$$. i mean... help
  193. Projector question.... Not the usual question (more advanced).
  194. front clear markers
  195. Ignition Coil Issues
  196. HS Headers Installed!!!
  197. Levoc shift knob
  198. Replacing key and keyless remotes.....
  199. Is an Alignment Kit needed with Tein S Springs?
  200. auto shifter problem
  201. Where does this vacuum line connect to?
  202. What is the real fix for front brakes on 2000 Max SE? Getting frustrated
  203. Clutch halfway to floor.....help anyone!!
  204. Hot Shot
  205. how much would a camber kit....
  206. Please help it sounds like a screw is in my engine
  207. question on oem body kit
  208. Whats the deal w/ RedLineMax.com
  209. D2S vs D2R in Stock 02-03 Headlights
  210. do i need illuminas for H&R springs or will KYB GR2 work?
  211. Uninstall HIDS and Install Halogen...
  212. New Pics of my Maxima on 19" rims (plus pics of 2 bent 18's)
  213. Automatic transmission Fcking up
  214. How the heck does this button work?
  215. CV boot questions, mine ripped
  216. broken axle bracket
  217. Interior Lighting problem
  218. Batteries for the remotes
  219. A/C Problem?!?
  220. Can a 2002 non-bose radio work in a 2000?
  221. Hey whats the part number for KYB frount strut mounts
  222. My speedomer needle is stuck on 70: what can I do?
  223. grinding the clutch
  224. At start up...
  225. What tire size for 18x8 350z rims?
  226. Steering wheel shakes when braking - not rotors
  227. heatwrap on exhaust
  228. Not That Impressed
  229. Dynamat Under Hood and Sound Deadening
  230. Where to find Passcetter STS
  231. Static shocks from a maxima everytime?
  232. 2003 kelvin temp?
  233. Is it possible???
  234. Does your auto tranny do this?
  235. Walbro fuel pump??
  236. 2000/2001 : GXE vs SE ????
  237. Leather 01 Gle Kits?????
  238. I think I'm coming bacckkkkkkkkk
  239. High octane (100-105) fuel found in SLC
  240. Yellow fog lights...
  241. Update on Lexan Fog light replacements
  242. What's quieter, Cattman or Frankencar?
  243. Where can i buy oem side skirts
  244. Power window cable snapped
  245. Anybody been successful putting 00/01 fogs on a 02/03?
  246. Question about our 3 cat. converters
  247. How to Remove Rear Brake...
  248. weird burning smell when flooring/reving up
  249. Brake gurus, need some guidance
  250. has anyone added auto up/down feature to rest of windows?
