- Axle nut size
- something is wrong with my infiniti i35. read
- VQ35 heads on VQ30DEK ?
- Bose head unit in 2k
- Flashing airbag light
- MAF Sensor Electrical connector removal
- Grounding Kit Complication
- Is this normal? problem with locks
- Dismantling Home Depot Flood Light
- Peel 'N' Seal as sound deadener
- 4th gen--->5th gen but Need help!
- Update: Later guys
- I'm in ur forumz... fixing ur Stickeez...
- guage cluster
- LED interior
- Dropped it + painted front grill body color
- Have a Greddy Evo 2? Help??
- Parts
- Tachometer lighting problems ???
- Ordering parts TODAY. Need a few quick answers.
- Need some people's opinion
- I love raccoons...
- Tranny slipping... next step??
- Typical Noise for a 02SE?
- Rattling noise
- Weird Sound
- Front Left Speaker Problem
- diagnose question
- BBS rims on Maxima?
- Brake Warning and Charge (Battery) Warning Lights
- Power Leather Seat Upgrade
- Cricket in the car
- Check Enginge Light
- starter housing broken, lodged into transmission?
- Automatic seat stuck...
- Stock HID problem!!
- Will this exhaust setup work
- Misfiring
- Officially in the 150K club!!
- Replacing High Pressure Pwr Steering Hose 02
- Loud Gurgle when engine starts
- Can lug nuts/studs flare from use??
- 2K Front Grills: What are the options??
- Exhaust Question
- wierd noises commin from drivers side!!
- A/C Condensation...on the inside
- Ok, exhaust help (unique setup)
- Any have the Stillen BBK?
- HELP!!! Suspension Problem
- D2 Coilovers --> Progress/Illumina review.
- Skyline R33 Caliper for BBK?
- need help guys...big time
- pulley question
- Gonna buy a new car, which one is better?
- FSTB causes understeer?
- Ok I think I have a problem here...someone help
- Memory Seats
- Merlot Maximas Please Post
- New 5.5 Gen in Town
- SES question
- new 03' se te owner
- Does Hitachi make Maxima Starters?
- My 3.5 now officialy has full bolt ons :-D
- Anti-freeze
- question before a 4hr drive to miami
- Electrical Issue
- Should I buy?
- SES Light Came On First Time
- strut Bar/Rear sway Bar?
- Clearing Headlights & Side Markers on Black 5.5
- Starter starting to fail?
- Valve Cover Torque Spec (Search is not working)
- Just bought 01 Max
- FRONT BUCKET SEAT ISSUES
- Ported/Polished Headers For VQ35
- how to...
- GRILL INSERT UPGRADE 2K TO 2K2 TRENZ
- Tranny Flush... found a problem
- Replacing Steering Wheel Audio Controls
- Fuel filter location
- CV Axle
- 02 sensor bank 2, rear
- sorry another front end noise problem
- VQ30 Rods & Pistons
- Hotshot headers installed on 03 max...problems
- Spark plugs?
- Fuel Door Issue
- found possible cause of rattle in dash over bumps
- clicking during steering!
- Engine dead in the water..... HELP Starter?
- Engine trouble. Whats the culprit?
- Cheapest place to get 5.5 gen SE TE OEM rim?
- Best process for paint touch-ups?
- resonator-2003 exhaust
- Odd Engine Noise
- How much is my car worth? (Chicago, IL) 2kSE5spd bk/bk
- 5th gen lights (In cabin)
- Anyone has a 02 FSM for download? G20.net doesn't work
- Need Help Nowww!
- Help: Used 02 Maxima GLE but fogs not working
- rear question...
- Power supply to lights cut off
- Airbag Light Again!!!!!!!!!!!!!!!!!
- questions about 5th gen and 5.5 gen
- Starting Issue...Help Please
- Installed a test pipe :-)
- Why does everyone sell their k-sports after theybuy them
- Finally got my Max! Need advice!
- Need Advice On Front Axle And Belts
- BBK question
- Replacing plugs and found this.....
- Which nissan/infinity ECU harneses are 5th gen compat?
- Stupid Exhaust Question
- Purchasing a new max. NEED OPINION
- mobil 1. unsettling engine noise after switch.
- Please help anyone know how to fix a vibrating hood 02-03 Maxima
- 350Z clutch kit installed in 5.5 gen. Where?
- Ground control Coilovers or others?
- looking for How-to for ES control arm bushings install
- TL rims on Maxima!
- First ever - Modified Axle Bracket
- Leds????????
- Who running E-85?
- A/T Tranny not changing properly
- Possible new shift knob for 6spd guys.
- Installed new blower motor! ONLY $66 shipped!!
- Mods and Dealership Warranty advice
- help with LED angel eyes
- How to repair body scratches....
- AC Gave Out
- A new noise! Sounds like studded snows! Any suggestions?
- How to replace ball joints
- Why are the back of these two headunits different if they are the same year? LOOK!
- How happy are you with your fogs & which do you have?
- Will 02-03 Stock headunit work and fit properly in a 2000/2001 maxima? Quick Question
- My 01 got smashed tonight
- Stillen Y-pipe...Y not?
- Broken fan
- 5th gen hotness
- Need HElP ASAP please!!
- Bose Screen Display
- Bose stereo issues
- SHIFT_whistle
- in need of some help
- Time for Alternator replacement?
- JWT Popcharger, ES Shifter Bushings, Redline MT-90, Free STS Install and REVIEW
- What is this plastic jug?
- shifter knob
- 150K approaching... looking at some options
- Fog light rewire
- Land rover MAF housing
- Pulse plugs vs Spark plugs
- Help/Suggestion For Removing O2 Sensor
- Engine Noise
- A way to extend the Rear windows all the way down?
- Interior speakers
- Aftermarket ECU?
- VQ35DE A/C problems
- Need Help From A Fellow 5th Gen Owner / Someone With Some 5th Gen Knowledge
- ABS Light On - Not sure why
- should i get clear tint all around?
- Monroe brake pads
- I Need Motor Mounts
- 2002 SE Alarm Horn Keeps Beeping
- problem with spark plugs
- Shift interlock questions
- MAF housing direction
- approaching 140k miles and need paint job...advice
- Your Opinions Needed
- Engine is stopped in 10-20 seconds after ignition.
- My best upgrade yet...
- 2000 Knock Sensor
- Torque Specs
- Brake & Battery Light
- Could it be alternator?
- Programming the fob/keyless entry
- AE shift knob removal & leather boot ?
- Need Exhaust.... Y pipe or not??
- Service Engine Soon light - O2 sensor
- Engine Shuts Off!! Help!
- Wix filters compared to dealer sold OEM filters
- 350z wheels on 00 Max
- ...this is weird.
- Power steering problem????
- Recall on 5.5 gen
- 5gen 00-01 owner with warpspeed y-pipe how's fitment and are there any noise?
- Wanna see engine bay naked ? Pics inside.
- Car is playing tricks on me
- FYI: How to know alternator is charging properly?
- The Max Died...
- Help My bumper Fell off
- a/c problems
- Low Timing
- P0223 - TPS Sensor issue after replacing spark plugs
- Need help with Tires wearing out on the inside.
- spring struct qustion
- P0744 - Is it OK to drive?
- This Got me ConfuseD.. Oil Prob.. cattman headers prob.
- fuse keeps blowing
- Driver's side window won't close
- VQ35DE swap, which WAI to use?
- windshield wiper fluid pressure
- Need Help ASAP My A/C doesn't blow air out!!!!!!!!
- After Illuminas install.....rear squeak-squeak-squeak. why?
- Help!...thumping over potholes!
- Goodbye and hello!
- SES light after Spark plug change on VQ35
- Possible test pipe fitment issues? ***Pic***
- 3.5 L. oil burner
- help,...i need to pass emissions
- P0032 - Need Help
- rear brakes
- 00-01 Tcm
- Is oil on spark plug normal? (large pic in thread, to show detail)
- engine stabalizer
- Pressure sensor valve stem question
- VIAS power rod modifications?
- intsalled cattman headers and udp...now have problems.
- Motor Mount Question?
- Windshield fogging up problem
- How I Improved My Maximas Ride Quality For Free
- Steering Wheel Radio Buttons.
- New paint job
- How much to torque?
- Cabin Temp Gauge
- Led marker light question
- Mechanical gurus , I beseech you!
- How much is this Maxima worth?
- 3rd gear at slips when cold
- Changing up the suspension advice needed
- Did All 2002 SE Trim come with a Sunroof?
- New Clutch Cost- Dave B. vs Queens, NY
- Strut Bar Question
- 4th gen maxima alt fit a 2000?
- Anybody know How to install ES shifter bushing on 5 speed.
- Which alternator do I need 110 or 100 amp
- 2002 exhaust on a 2000?
- Hard Steering
- LED Lights
- Any body modded rear windows??
- ES Rear Trailing arm Bushings = PITA!!
- Question about "Banks"
- Cat Converter ?
- Trunk Wont Close-Help Please
- Delayed Throttle Response
- anyone have any knowledge of these?
- Life Expectancy for Stock Muffler
- 2000 Maxima SE and broken wheel studs
- Shifter Question
