- cheap fun easy creative mods.
- Intermittent slow cranking issue 2000 SE auto
- Polishing Timing Cover
- NEED HELP!
- What does this plug into?
- Is this an ideal buy?
- Oil Light
- Automatic Transmission Question P0745
- Car stalled with AC on or feels like it is losing power
- Harness connector to intake control valve Bank 2 broken!
- MAF Replaced, Still No Improvement. I'm Stumped.
- Back In The Game!
- Problem with cooling system
- Codes P0134 & P0160...HELP!
- Strut Assembly
- How does the black air intake thing reassemble without gaps?
- Eibach Pro Kit
- window regulator?
- 2000 model Gen 5 Aussie Springs?
- Oil usage?
- Mysterious coolant leak...
- 2002 Maxima Auto - line pressure solenoid spring
- Rear View Mirror Swap
- Which other key fobs and keys will work?
- 300zx brake issue
- Dont know what these are but the fell off my wheel
- Max's with aftermarket radios check in please
- typical price to have shop due 1 o2 sensor?
- Radio problem
- car barely runs after new cam sensors
- Mystery Problem Eludes Mechanics
- i made a stupid mistake please help.ATF
- Courtesy LED conversion issue
- 5th gen power steering pressure switch
- Question on buying remote 2000 Max on ebay....
- Time for upgrades, can anyone help?
- Need new tires, help with sizes?
- Need some Exhaust Advice...
- 2k3 Car starts dies right away won't rev
- 5th gen 2000 max intake question!!
- Wierd AC issue
- ebay engine mount?
- Automatic woes
- QT Adjustable Link
- 09 intake manifold and tb swap?
- Does anyone sell a interior light kit?
- Help, maxspeed/tokico hp harsh, rough ride!
- Car bucks
- LED Footwells
- Cruise Contol Not Working - Set Light Blinks
- Help Needed with Tail Light Socket
- Please help with sometimes malfunctioning AT
- Tranny Swap Anniversary Ed.
- Help with LSD swap please
- need help chosing shocks for the area i live in..
- Another cheap OEM parts site!!
- car rpm goes up and down with ac on...
- Ignition Coil Connector is Stuck?
- p1320/p0420
- Possible issues with TPS or Accelator Pedal Sensor
- Removed my BOP...
- Hello, Everyone.
- Need a Shift Knob for n '02 Max SE Manual
- Engine cooling fans
- My 02 Max intermittently won't start.
- I'm Feeling... Inspired
- whirring/humming noise when clutch is depressed - throw out bearing?
- Transmission slip when engine heats up? Speed stuck at <20mph.
- How to clean residue from SimpleGreen on clear lens etc
- Ballpoint Replacement Question
- Need help 2001 SE loss of power and pinging badly...
- Lower Engine Knock when engine hot at start up.
- ABS, Slip & TCS Lights Are On - HELP!
- 02 Max rear strut question
- SEEKING HELP WITH MY CAR PLEASE
- Painted Bug Deflector
- Alternator pivot arm bolt size?
- Color Combo Thread- Will be put into effect this time, not Hypothetical
- Advise on CPR job
- 03 SE AT no Start no Gauges
- question for those who have replaced the front wheel bearings
- can't raise window up on 2002 maxima
- Are both front shocks the same?
- bad mpg on a 2001 maxima
- 02 maxima tune up
- Humming noise on start up
- Battery Question (add battery or replace)
- 00 - 03 muffler question
- Smokes when put in park
- Help: Suspension Setup
- SES Light Code P1800 and P0011
- Got just a little sweet white smoke from 2000 I30T
- What have you done about your leaking trailing arm bushings?
- the infamous p1320
- Adios Maxima.org
- $1200 deal ??
- Power window motor test
- Finally, I figure out how to do diag in a free way
- Car moves to side when accelerating
- AMB front sensor wiring
- P1320 With hesitation underload
- P1320 code, but..
- CEL not illuminating
- Differnces in flywheels?
- Starting car after 4 months: damage prevention?
- good car alarm
- Does this mean I need a new MAF sensor?
- Started with TPS disconnected - dies on idle.
- Car feels wobbly
- My ownership cost for a 2002 GLE from 07 to current
- ABS/TCS lights on, NO speedo, or Odometer.
- 2000/2001 Maxima - How to replace knock sensor
- Alternator Replacement Issues
- How many AMPS are the OEM Alternators on the maxima?
- Tire pressure ?
- 2000 Maxima Tail Lights
- Front Speakers for Bose System?
- Keyless Entry Control Unit went out. Questions
- Radiator cooling fan question
- Changing ignition coils and spark plugs. Any good vendors?
- Car battery was installed on wrong
- Bought myself an I35..Pictures
- Nonfunctional Fog Lights
- P0325, P0138, & P0139
- Consult II Timing Advance Question!!!
- Car just died. Supplemental air bag light went on!! HELP!!!
- Sensors on Default?
- Power steering pump
- Help?
- 2001
- ES Control Arm Bushings
- G35 coupe 18s rubbing , need help
- Seeking Advice: Aluminium Radiator & Upgrade Fan
- How bad is a cracked intake manifold collector?
- The P1440 That just wont go away !
- AC is warm
- Fog Light Adjustment
- 2001 i30 lowering needs?
- Inner Tie Rod Part Help
- 1320 code still kicking my butt
- hot import nights car show, what happened? PA
- shift knob
- 2000 Maxima. Hard start. No CEL. Please help me Troubleshoot!
- Thank you maxima.org
- Need Advice - Looking to buy a 2002
- 02 Maxima Manual Transmission Removal
- Maxed out alignment and still not close to specs
- Replacing Clutch which Product Best
- FSM/wiring diagram needed
- will my max make 260+hp
- 2001 Maxima fast idle fix??
- SSIM
- s2000 projectors or not?
- How to Repair Your Damaged Wheels *PICS*
- maxima driving me nutssss keep diying
- All 6 coils from China = no power???
- aaaaaaaargh!!!! Headwork problem
- Where to run wires to an amp
- Anyone gotten an ebay rear spoiler?
- Rotor Advice Needed
- Amp wires to battery?
- Codes 328 & 345
- Transmission swap?
- 2000 maxima had codes p0138 and p0139. Now p0161
- How low is too LOW before stuff starts breaking?
- TV antenna installation?
- Rattling in Engine--"Timing Chain"
- How long does it take for computer to be done testing all the systems?
- Remote Start and Auto Adjusting Driver Seat issue
- Problem Fuse keeps blowing "ENG CONT"
- Engine has hard knock, won't crank...
- Code P0430 Need more advice
- intake question 2012
- looking to sell my Maxima.
- Tire size question
- Key Question
- Fuel pump replacement: Safe practices
- rough starting
- Removal of Uneven Pad Deposits with Aggressive Friction
- Red Valet Key
- Part number for air filter holder
- Tranny issue
- AFM power limits
- Squeaky Nosie when Turning my Steering Wheel
- Warpspeed Y Sound
- How much power wire?
- Paint & Body Experts! What is this junk and how do I get it off?
- Steering Wheel Removal
- Broke a bolt installing subframe collars... Does it matter?
- 2002 Max throwing P1147 and P0139
- Jerky tachometer
- boost sensor (map/baro)
- HELP with Product
- Can't get my torque converter back on :(
- Maxima Wont rev past 2500
- Replacing 02 maxima headlights to 00 maxima headlights, question?
- Broken CV bearing support
- Question regarding stalling
- Sunglass holder is dripping wet from rain!
- Steering wheel position after hitting a curb
- P0340 code for camshaft positioning sensor
- Front brake hardware kit - Oem or Beck Arnley
- Should I buy a clutch kit and have a shop install it? Or just have them order parts?
- Another P0455 thread....
- Radio/CD problem "VEr 6.12"
- EGR system Incomplete / Secondary Air Incomplete
- P0420, Ive been reading for 2 hours now, still have a question
- Is the car worth more if I just part it out or sell as whole?
- Looking for ignition coil connector
- Having a really weird cooling issue.
- Airflow: Fluid Dynamics Question
- Bad Wheel Alignment?
- ABS problem
- torque link for front engine mount
- just something to kill time
- Ignition Switch Harness Location
- Speedometer Issues **PLEASE HELP**
- 3.5" Speakers in Rear Deck
- o2 sensor wiring question
- Just graduated from 4th gen to 5th gen today...
- VIAS plate orientation question ( searched )
- Body Damage! How much would it cost
- Just picked up 2001 5spd SE 240k!
- Old Maxima's commercial
- Pretty sure i killed my VQ30
- Car stalls in the morning - Please read
- intake question
- Manual to Digital Climate Write-Up (pre-swap)
- 4th Gen coils on 5th gen?
- fuel pressure
- 2002 Problem - Sunroof and reverse lights not working
- Mystery Leak
- Clutch replaced ... pedal feels soft!
- 01 Maxima - harmonic balancer bolt torque spec please
- NO reverse or first gear HELP (Imma SHOOT this B)
- To those looking to convert their clusters to RED LEDs (Pics)
- aftermarket angel eyes headlights or oem customized headlights??
- What axles for i30 vlsd swap
- I need a new engine??
- 5.5 gen auto to 6spd swap write up
- Megan Or Cattman EXHAUST? That is the question
- 02 03 6spd Shifter Cables bad? HOW TO swap 04 6th gen cables! Save $$$
- avpro company ecu repair
- Ground Control Conversation Kits?
- Raxles Axles!!!
- Code P1320 after replacing spark plugs
- Need part # for license plate bulbs
- Auto transmission DIY
- Shes getting old, what kind of maintainance?
- radiator leak
