PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Recent Road Trip and Check Engine Light
  2. Alternator voltage regulator?
  3. Check Engine Light- Kind of on...
  4. Great Head.....s......
  5. so no one has "WHITE" rims?
  6. Clutch howling on an 03
  7. header setup/o2 sim question
  8. coils
  9. need help
  10. jeff92se bracket?
  11. Anyone interested in full taillight overlays?
  12. New Cattman Headers - Comments from installation
  13. Exhaust Question
  14. Resetting Flashing Airbag light
  15. What level do you set your volume to?
  16. Suspension mod Question
  17. Anyone wonder how to rip your entire bumper clean off?
  18. Brakes
  19. 40 series on 19inch rims (please help)
  20. Installing replacement ECU
  21. Its Here!!!!
  22. Fixing an AE headlight mod gone bad...
  23. Awesome deal for any 5th genners looking for 19s!
  24. Coil pack problem? Looking for verification.
  25. Cali Max cat ox issues
  26. Computer reflash questions.....
  27. lip on wheel wells
  28. SIDE MIRRORS swap
  29. The Starter failed again!
  30. JIC coilover
  31. So Long Maxima
  32. cattman cat back loud as hell
  33. Advice on new muffler
  34. simulated 02 sensor
  35. took stage 2 LTB off.....yuk!
  36. Injen intake -- how long between filter cleanings?
  37. Squeak from front end...
  38. Projector Head Lights
  39. booo injen warm air intake
  40. Replaced IACV-AAC Valve, Now My Car Doesn't Start
  41. Read the ignition coil resistance thread - but got strange results
  42. Pot holes!!!!
  43. Coolant replacement...should i pay or do it myself
  44. Ignition misfire codes, need some recommendation!
  45. Check engine light wont go out
  46. 00 Max wont stay started - all advice wanted
  47. Anyone have the NAV upgrade disc?
  48. Air Blower Issues
  49. Has anyone tried these fog housings for the 5.5 gen?
  50. How to inspect Swaybar endlinks ?
  51. Quick Y-pipe and ECU question...
  52. Need your opinions...
  53. Short Shifter
  54. Merry Xmas!
  55. Where to find part #s.
  56. Question to everyone with 3.5L engine
  57. HELP... really screw up my car... really really need your help!!
  58. 02 I35 side skirts forsale
  59. Got Hit Last Night....
  60. Air conditioner making clicking/clunking noises?
  61. B pillar tape
  62. HP Gain Estimate?
  63. need help with a cat-back
  64. Problem with chrome rings on 2k1 SE
  65. Calling all suspension guru's
  66. Hight Mount 3rd Brakelight Question
  67. Buying a 2002-2003 Maxima sugesstions?
  68. Heater Problem 2000
  69. carbonfiber engine cover
  70. stock HIDs
  71. HELP with dents
  72. Problems getting NAV CD to work
  73. Help, Fan Rattling behind dash when AC is on.
  74. Bad strut......HELP
  75. wierd knock at low rpms
  76. Thinking of buying a 01 max...HELP PLEASE
  77. 2001 ae tranny
  78. crazy 18th birthday..........
  79. Am I missing something?
  80. Lookin for Stillen Front Fascia.
  81. does anyone know where the IACV located on 2k1 max.
  82. Front right end rattling noise any ideas?
  83. Had the ECU reprogrammed this morning for the TSB 2500-3000 RPM stutter...
  84. remove stock stereo
  85. 2002 Maxima Stalled, Tach Dead, Hard to Start - P0335 Code
  86. SO, i just found out my car has frame damage. (never knew)
  87. Security System Problem Help!
  88. opening hood from outside??
  89. a few questions...
  90. Need help for tranny
  91. hood pin switch
  92. rear quarter panel repair
  93. Daytime Running Lights Install
  94. throttle body coolant bypass
  95. Custom Enterprises WTF!!!! Upset!!
  96. cleaning the manifold
  97. SES light just went off....
  98. My Max IS NOTTTTTTTT Good Shape
  99. Code P0160 O2 Sensor - Just want to make sure I order the right one
  100. Pinging noise when accelarating
  101. New MAF. Should I replace my Stillen Intake?
  102. Tune-Up
  103. Stillen Classic Front Lip 00/01 vs 02/03 question
  104. ABS sensor install
  105. cleared out my blinker which bulb to use for amber light
  106. Tune Up
  107. 03 Compass Mirror installed on 02
  108. 01 Maxima.. How to remove windsheilf washer nozzles??
  109. transmission went bad with only 90k?
  110. Carb cleaner and fule inj cleaner
  111. bad cat smell when "DRIVING" my car a little hard, normal?
  112. My car doesn't burn oil, how rare is that???
  113. bit the bullet - all new coils - have question
  114. never experienced anything like this!
  115. Loose Steering
  116. Remote Start
  117. angel eyes -ebay leds and ebay ccfls updateing
  118. Just got Fast blinking LED turn signals. do you like them?
  119. Decided to use 5W20 synthetic oil
  120. How to roll the rear fender?
  121. Changing Guages questions on a 2000
  122. Body Kit Question
  123. Max wont start (long)
  124. speed limiter?
  125. 02' grille
  126. CODES Please Help!!! P0420 & P0440
  127. Need Help ASAP with IAC Module
  128. Anyone with autozone blue/white PCV valve?
  129. Control arm question
  130. maxima acting up, vets please enter
  131. replacing PCV valves makes any diffrence?
  132. Silverstar Ultra
  133. How to reinstall sideview mirror?
  134. 02 gauge cluster lights
  135. What to do when the SIM won't help (P0430)
  136. Dash / running lights out, fuse keeps blowing
  137. right passenger wheel?
  138. what resistor for SRS airbag fool?
  139. Please Help.. 2001 Maxima is possesed!!
  140. Sounds like my wheel is going to fall off!
  141. those with silverstar fogs (5.5 gen)
  142. help aiming headlights
  143. hose just for looks?
  144. Custom CAI
  145. does Infiniti I30 wheel bearing/hub fit 5th gens?
  146. Beyond the BIG 3
  147. Help Installing Helios HID kit
  148. Looking at a car, what should I be aware of?
  149. My Car after a accident and repairs...
  150. angel eye options for AE only
  151. Owned by Depo Fog light?
  152. I need help
  153. HID in the fogs
  154. Accelerator??
  155. Camber Kit
  156. How come I can't search?
  157. any small mod ideas guys?
  158. Selling MISC parts.
  159. How to remove headlights with data dots?
  160. Does anyone have DaveB's phone number?
  161. Clunking when turning or going over bumps??
  162. Question about paint
  163. VAFC-II or AFC Neo
  164. question about 02 headlight install
  165. Making 00', 01' SE TAILS
  166. Brake Problems again
  167. Diffrence between aftermarket rotors?
  168. 03 maxima acting wierd
  169. Rear Turn signal issue
  170. To those lowered w/ 235/45/17 on stock wheels...
  171. What if my HID die...
  172. 5/5.5 seats
  173. aftermarket e-brake handle choices
  174. 2k2 headlights with ebay angel eye mod
  175. The time has come...
  176. need help with Blemco ground wires...........
  177. AC Blower Motor?
  178. Final Exhaust Decision
  179. For those who've baked their head lights... enter
  180. Car won't start. Still have power and I have replaced the starter but still no dice
  181. Short throw kit
  182. Paint Fall or Spring ?
  183. 02-03 Automatic Shift Knob
  184. Just changed brakes - Rear brakes dragging
  185. 4th gen intake midpipe on a vq30dek 5th gen?
  186. Does any body know?
  187. Changing miles on ODO?
  188. So who loves thier max BUT still wants a diff vehical?
  189. Sticky brake caliper? Plus a funny suspension noise...
  190. Engine removal???
  191. 2002 HID Headlights
  192. Suspension setup for the newbie...
  193. 5-speed detents?
  194. Need help with oxygen sensor issue
  195. Question about Illuminas
  196. Feeling Invincible in My Gen 5.5 6-speed
  197. ABS Dynamics Front lip?
  198. Very Strange Problem When Braking
  199. Difficult Nav Swap?
  200. Removing headlights in 2001 AE
  201. P0464 - CEL How do i fix?!!?
  202. Need Help!
  203. Power Steering Hum?
  204. Razo pedals (has anyone used them)
  205. Does anyone have this link??
  206. Need Opinions: '01 AE Maxima or '02 Max SE?
  207. CEL P0420 out of 8/80 warranty... o2, ECM flash or cat?
  208. Wheel 'Humming'...?
  209. Those with Umnitza HID fogs...step in
  210. very quiet ticking while the air is on
  211. Car stutters when engine is cold...MAF issue?
  212. Problem with manual tranny
  213. frozen brake lines?
  214. Groaning Clutch 02 6 spd
  215. Any advice on Stock Brakes?
  216. P0430 - What can I do?
  217. Who sells the trunk floor thingy
  218. Exhaust smoke only out of ONE TIP.
  219. tranny slipping????? need input please
  220. Side View mirror repair: adhesive??
  221. Rear Suspension -- Ping/Ting/Clang
  222. Gentleman, your opinion is needed....
  223. Need help. Do i get these aftermarket fogs
  224. Just saying goodbye to the .org family
  225. Transmission poll
  226. Bye-bye max, hello baby
  227. brakes and battery connected?
  228. exposed rubber pipe behind rear driver-side wheel
  229. Double din gxe dash kit
  230. Interior Swap --- Cloth to Leather --- Can it be done?
  231. Changing inner tie rod ends
  232. Valve Body Mod
  233. Need Help, Cold Start Issues
  234. retrofitted projectors into oem 2k/2k1 housings? anyone done it here?
  235. auto trans makes a hard CLUNK into D after initial startup
  236. 2k Auto Tranny almost dead
  237. Looking for some feedback on the ES bushings
  238. rattling noise
  239. Help with wheel hub removal
  240. Question about Snow Tires
  241. heated seat switch wires
  242. SES light ...what to do
  243. magnaflows are finally on *pics*
  244. Silverstars arent all they are cracked up to be
  245. How particular is Nissan on honoring the warranty
  246. Rear Fog Light (installed)
  247. Gauge pod options for 5th gen.
  248. Please HELP! Warm stall = 'Air Flow Meter'
  249. Searched - Disable DRL?
  250. Can anyone help me out?
