- Maxima.org Stickers
- HELP alternator replacement
- wheel size
- "Reprogramming ECM"
- my hand is to fat cannot reach
- 2000 GLE at 60,000 what can I expect?
- shaved
- Question on Stillen + ABS Dynamics front lip 00-03
- new illuminas/springs...have 3 install questions
- How Can I Get My Trip Control To Work Again?
- hey 5th genners!!!
- blah blah blah another question
- HotShot Headers
- Blinker bugging out
- Jack points,,,etc
- what could that be?
- Solinoid Valve Assy.
- Need help with Spring Rate for Ground Control springs.
- What other suspension parts are needed?
- Greddy exhaust
- maf nightmares need help
- Freshalloy meet?
- Gunmetal with silver lip OEM 17's pics
- Wheel spec I need Help (Advise from experience)
- Bad Cv Joint ????
- Questions about Nav Disc
- Walbro 255lph fuel pump
- Looking at a 2002 6 spd, with 35k miles, $15k
- Bulbs behind 02-03 Gauge cluster
- 2000 a/c noise....??
- Overheating!
- Anybody run the Halo fogs from ebay?
- 2k se gauge w/o tcs in 2k gle w tcs; workable?
- hints/questions on changing manual tranny oil
- Something to plug license plate holes with
- Got my car back from the shop *pics*
- replacing coils and MAF
- Bose just ate my CD...
- Spark Plug color... running lean?
- deciding on front spacers
- Wheel bearings..how much play is ok?
- Has anyone fiberglassed the Stillen AE valences into the OEM bumpers?
- Code pulled - P1706 how to fix?
- Which spark plugs to use with timing adv?
- Sat. Radio Install pics
- 02-03 maxima headlight retrofit **pics**
- Got my MAXIMA Fixed ***(PICS)***
- e-break questions
- Help A/C Fan or bearing makes a loud noise
- Vias Help Needed Immediately
- 00'SE Grill Opinion
- vias screw removal
- What 17" Tires for 2000 SE 5 Spd?
- 19s which offset and width??
- give me your vin and I can check it on carfax
- What are the difference in trims for 5th gen
- for thos looking into brakes
- Any thoughts on Burgundy colored 2002-2003 Maxima
- How to check continuity of MAF
- Illumina hardware
- Windshield wiper "click"
- need part number for 2000 fed manual ecu
- Trimming 3/8 off front hub?
- Injen intake air filter?
- Performance problems.
- Those going to performance nissan meet
- Brake making weird noise
- Need help getting educated in spring/strut combos
- odd question about rear bench
- where to get driver's leather seat?
- Race!!!
- 05 Altima SE-R exhaust, can it go on 02-03 Max?
- well had something break today
- Pay to fix or go new??
- OBD II scanners who has one?
- 1-2 Gear Slip After Tranny Flush
- 3rd gear grind
- 18" 04 SE rims on a 00-03
- High pitched noise when rear seats are removed
- Strange sounds (like lots of little rocks hitting car) after car starts
- 300zx bbk...w/ 2 piece rotors?
- 15 or 20mm spacers in rear
- Hlsd?
- where can i get O2 sensor?
- Where can I buy KYB Bumpstops?
- Exhaust Suggestion (Cattman)
- LED tails......pics are up!!!
- Videos on the .Org
- help with tranny pan bolts, please
- DDE Cold Climate Ballasts
- Im going to be a 5th gener soon
- Tein EDFC w/ FTSB
- opinion on springs
- Bulb Fitting
- BACK UP CAMERA was it easy to install?
- Where the hell is the ecu
- Where to go to put in a DIFFERENTIAL??
- tune up
- Steering Wheel Stereo/Audio Controls
- steering wheel controls
- Fidanza Question??
- Something hit my headlight, now its loose and aims low
- Cattman Gen II Headers Installation Experience and Related Thoughts
- Where can i get a good deal on stillen sides..
- Pictures of retrofit 02/03 hids anyone???
- O2 Sensors went out!
- 5th Gen 18" Murano SE Wheels Gallery *PICS*
- uh-oh o/d light flashing
- problems: need advice..
- 5.5 gen intake mod?
- Installed my AE modded Headlights Tonight (pics included)
- why does my car run like crap when warm???
- 5.5 gen problem
- Wow resale value on 02’s has dropped dramatically.
- My clock stopped working
- Remove stock 02 side skirts for Stillen's?
- P0420 Code - Still a Bit Confused
- ES Shifter Bushings & Watkins STS
- Illuminating clock on 5th gen
- just my thinking?
- Oem Leather Installation
- Broken Sunglass Holder Latch Fix
- WTF - This is crazy
- need exhaust
- cALIPER BOLT HELP!!!!!!!!
- 5TH gen tail lights
- MY AE MOD - pictures
- 5.5gen Foglight Cracking Dilemma?!?!
- New Tranny...AGAIN!
- moon roof
- 5th Gen Bose Fix How-to
- What two-tone color combos for Katzkin seats
- How do you get the VIAS box off?
- Intake poll
- How to AIM headlights on '01
- Removing power rod from Intake manifold
- Mobil 1 or Royal Purple?
- Steering wheel off/not centered
- Xenon headlight question
- Polarg Yellow Foglight Bulbs INSTALLED
- pcv valve question
- Anyone with Sterling Mist and white wheels?
- intake installation questions
- dde owners: Am I missing something?
- Got Angel Eyes/DDEs ? Post Pics Here
- How much for side skirts off a 5.5 gen
- Anyone with timing advance notice ...
- Stillen RSB
- limp mode.... darn
- noises for a newb
- Roll cages?
- Performance!!!!!!!!
- Would you guys want this???
- Broke reflector, need help
- couple of issues with Max after 90K service
- Noise from right side when turning.
- Attn Puppetmaster Vid of my exhaust
- Noise from belt
- Maximumtuning stage 2 VB didn't fix transmission problems
- After market spring life??? I have H-Techs.
- found a potato in tailpipe....any possible damage?
- Buying soon, help me decide...
- Got a DTC, fixed problem, but STILL have a CEL. Will a CEL clear itself?
- i30/35 side skirts on a 00 max?
- Gas door replacement
- Before & after pics of my H&R drop
- Any Benifits With Some Y-Pipes over Others
- First part
- brake issues
- SPACERS FOR 245's please help!!!!!!!!!
- problem after tranny fluid switch
- Stillen rear sway bar write up.
- Random Technology High Flow Cats..Yay or Nay?
- Any chance of getting rid of scratches on roof from Wind deflector...
- Installed eyelids....peeling after 30 minutes with headlights on..
- Just installed lower valence billet grille (PIC)
- The trifecta...
- Anyone have a TSB for P0430 SES?
- Oxygen Sensor replacement?
- Brake Pads
- Probably buying this '00 SE - Would you haggle on these items?
- Paradox System's New Rear Window Spoilers?
- Need Ideas for NEW retro project
- Rear Sway Bar
- **HID KITS***owners step inside..
- Traction Control Question
- 5th gen Hesitation
- Trunk won't stay shut/closed
- '00 SE totaled Buying another. Few questions?
- Guys Please provide you opinion! RIMS AND TIRES!
- Xtec Foglight Issue - Help Please
- hi temp paint for dde's?
- Pinging?
- Can you fix fuel cutoff TSB by resetting ECU.. i think i did
- Best h4 bulb?
- Speaker sizes in 5th gen
- front bumper covers
- How important is trans fluid type?
- Darn PINK EYE AGAIN!!!
- 5.5 gen paint question. Need quick response.
- Thumping in engine at idle
- Congrats to Fezzik! NICO Ride of the Month
- Toyo Proxes 4 - A question to owners
- air intake question
- # of lumens for common K ratings?
- Tein SS coilovers has anyone tried those?
- 5th gen snorkel and airbox
- Climate Control Lights Out
- Quick Drops in Gas Needle
- Which O2 sensor is it?
- Anyone paint match their front grill? Pics please!
- Clear brake light
- new poll what is your top speed reached in first
- gd on coilpacks
- Tips on installing a lower-valence grille?
- Engine experts: Low power Maxima 2000 auto
- Should I keep my tint or redo it?
- Cup holder insert part #
- 60,000 mile maintenance
- what to buy
- 15mm or 20mm wheel spacers for the rears?
- safc II question
- tell me what you think redlinemax bumper
- ScanTool.net products in a Maxima?
- Need New Bumper Cover Fast..plz Help
- two quick vids of my exhaust
- Look what I got :)
- Let's get one of these SFCs....:yeahright:
- ECU Reset question
- 3.5 oil consumption possible solution:
- Where to get Indiglo gauges for our 02/03 Maxima's
- 2k-2k1 maxima 5spd..swap car doesnt run?
- Exhaust Parts
- 6 speed shifter knob..who has one???
- Free JL Audio Contest
- Awful Fuel Economy - What else can I try?
- First Tranny Leak, now Clutch worn out.
- Stolen Headlights and Body Work
- were to get the double din kit for navi unit??????
- 6000k D2r bulbs...input please
- Can somebody help me ... need to install a o2 sensor
- Hotshot Header Install Q's
- photoshop gurus...step in please
- DOme light wire???
- I saw a 5th gen with Stillen LEDs today.
- Gauges just flipped out...
- What's the difference between 2K1 and 2K2 SE wheels?
- What can be damagine to our paint?
- questions about 5th gen
- ATTN: people with clear corners...
