- Aftermarket Hood fitment
- Carbon fiber trunk alignment.
- Nissan Radio swap??
- 5th gen lugnut thread pattern question
- Testing 03 Auto @ Houston Raceway Park
- Quick ? regarding 00-01 taillights...
- oxygen sensors?
- Car keeps shutting off randomly..HELP.
- 2002 tranny codes any help would be great
- Maybe a hole in exhaust?
- 00 se bose help! no sound after pothole!
- Need a Hamburger :( Anyone?
- 02 maxima high idle...
- with Illuminas & ss lines, steering pulls, clunky noises
- time for a spring refresh...
- Distinguish a 22680-AM600 MAF from a 22680-6N201
- Sorry to do this but where can I get replacement clear corners?
- Just got my tranny rebuilt
- Bad accretion at high RPM Problem HELP!!!
- is tis exhaust setup good?
- 17" 03 TE Rims on my 01 GLE is Rubbing?
- Stillen intake
- OBX Headers and NWP Spacers....
- What?? More leaks??
- WTF is this noise? Video
- R.I.P. 2001 GLE :(
- Pre Cat ???
- Manual tranny for 2000 maxima
- Do you have a squeaky/rattling front end? Read this.
- Headlight Restoration Kit?
- So how would I go about to fix this
- ABS Noise and Light
- JWT intake and HKS Sport rear section question
- Poor acceleration ONLY after warming up (2003 Maxima)
- Long Term Ownership Assesment
- 2 alarms..
- Keyless Entry / Interior light issue.
- o2's gone, need help locating
- Muffler/B-Pipe Flange
- Power Door locks stopped working
- Dropped off the car today (Header and Spacer Install)
- Grounding kit problem
- Weird Knocking Sound
- *Need Advice* Sick of Coilover --- WANT A SMOOTH RIDE AGAIN!!
- Strut boots and mounts with new suspension...
- Cold Start Grinding Noise
- are there any relay's for te cruise control if so where?
- Weird sound on passenger side suspension
- Rear Brakes
- Anniversary Edition passenger CV Axle
- Check engine light on = gas cap loose or massive leak HELP car smells like gas
- Muffler Removal help!
- hole in the exhause or .........
- Wiring VAFC on 5.5gen
- 13" Wilwood BBK, need 5 to commit
- 4th gen brakes= fifth gen?
- 00 Max shuts off while car is in park.
- tokico illuminas vs Teins coilovers
- how to get new alarm remote to work with car
- To reprogram, or not to Reprogram? O2 P0138 Question
- DTC 31 (P0100) issues...
- AE engine cover
- Replaced control lights and now blows hot air
- 100,000 Club
- P0506 .. need help please.. on a 02 SE auto maxima
- euro tails
- Noise during start up
- Engine pinging is getting worse!! Why?
- Car shuts off while driving? tps??
- navi headunit Help
- P0327 low input knock sensor
- Do I need a new TCM?
- Car now feeling slugish
- Where is the best place to buy these tailights?
- Project Max finished
- new maxima issues
- Info on changing rear ABS/Wheel Sensor on 01 please
- Different front/back Tire size?
- Catalytic converter question
- Auto tranny swap question.
- I Rear ended someone.
- Barely squeaked by on my yearly emission test
- Oil leak from valve cover
- Opinions Needed
- Can't seem to find stage 2 clutch for 5.5 gen
- '00 Tranny swap - stock exhaust: What's gonna break in the swap?
- cel P0174
- How would I find out who has my old car?
- Lets See Those 00-03 Maxima Pics w/Carbon Fiber Hoods
- Power Windows
- HELP - failed emissions
- Spare Tire and Accessories
- High Beam Issue
- The last time Navi ashtray mod. (Clear pictures)
- Need Inner Tie Rod Tool - Richmond VA
- How wide can we go? (tires)
- Will a 2000 Y-pipe fit a 2002 Maxima?
- Help finding Navi Headunit
- Need ES Inserts Fast! - Where from??
- Foglights....
- P0430 code aka CAT needs to be replaced
- To those with a tune...look what the MN tuners said..
- How to get started with the code searches?
- I guess I have to drive more than 55 miles after an ECU reset to pass emissions
- Something that made me smile
- OE Speedometer calibration question
- Tranny replacement quote (NY)
- Aftermarket Bump Stops ((H-tech/Tokico HP))
- Squeaking sound when shifting in cold day
- o2 sensor question
- Got new set of wheels
- 01 transmission flaring (vids)
- P2138 code
- skipping....someone help
- Is there any truth to this?
- I want a OEM Navi
- Front Suspension Noise *Creak*
- Tranny repair shop
- Funny Liquid sound... Help
- Everything you ever wanted to know about spark plugs, and maybe more...
- Strange creaking noise from the front
- Est. how many tenths with a TS ECU reflash
- p0403 from ecu swap
- has anyone swapped out their dash/climate control lights to LED's?
- Idle'ing issues and CEL light after changin valve cover
- Good looking DIN radio install kit??
- 2002 SE missing bad - help
- Can I get a honk?
- A few control lights out, ideas on how to fix
- P0300 misfire code. All the usual suspects check out OK...
- What's considered "highly modded" for a 5th/5.5 gen?
- Still bad mpg...im out of ideas
- Could these spark plugs be bad???
- You know gas prices are too high when...
- Does anyone have/know where I can get sidemarker clips?
- erased code never came back...nothing wrong?
- Replacing Lower Oil Pan on 5.5 gen.....Anyone?
- Brake squealing/hissing halfway to work :(
- P0171 from bad gass, is it possible?
- If I upgrade to '02 side skirts can I keep the rear Mudguards '01?
- Epic tie bar fail......
- Vaccum Leak???
- to those with s techs springs
- Trunk light out
- Strange mechanical beeping noise when turning off car
- Eibachs + Tokicos = Loud Noises at Full Lock
- broke front left A-Pillar. what is part number? where to buy?
- power steering pressure hose leak
- I'm Back!!!
- No start...towed
- Stillen header question
- 2000 electronic motor mounts
- WTB fog lights 2k2
- End link question?
- 2000 SE - 160K Impressions
- bad motor mount = hard getting into gear?
- Is my radio going out????
- i need help
- 03 rocker panels, 4 mud guards, & front badge= 900?!!
- BIG Install comming soon!! Need some help with finding the right things!
- Coils and Plugs not the problem....??
- VQ35 falls on its face.
- REPLACED BRAKE PADS!!! HELP!!!!
- WTB 2000-01 Front bumber
- Raybestos pads/rotors
- strut mount question.. i know its been beat to death
- anyone know where to get an 03 titanium edition ghost chrome wheel?
- Will the 2001 mudguard fit on an '03??
- gap between headlights/bumper 2002
- Automatic Engine Mounts
- At 123k miles on an '02 Max, is it a good idea to...
- Need Fuse Help
- Two part question re: p0138/139 and Federal Emissions or Cali
- Please help..Need help indetifiying a part
- Which rims should I choose?
- Squeak, Squeak (Another Suspension Noise)
- '00 Two new dings on fresh painted (tri-coat pearl white) hood!!!! Crap-ola!!
- Solder, crimp or caps?
- 5.5gen auto leather boot
- Need Help: EGI Harness?????????????????
- Custom Magnaflow 3" Exhaust INSTALLED With Pics and Video
- oil drain plug washer?
- Sigh.. Chain Tensioner bad?
- RPM Switch for VI Activation?
- power seat stuck..............
- Upgrading Suspension - Which Mounts?
- ABS Sensor for 2001 Maxima SE rear left
- 01 Auto Climate Control not blowing cold air
- Possible Clutch issue?
- 6th Gen Front Brakes?
- Ceramic Coating & Cattman Headers
- How do you clean an injen CAI filter?
- Anti-freeze on floor board, and hesitation when cold
- headlight flickers
- Fog light/Fuses
- problem with Locks and Keyless
- Knowing the Model Year is only a starting point
- transmission slip?
- Custom 3" Exhaust
- Front/Rear bumper removal
- Transmission connectors mounting plates
- I NEED HELP!!!!
- 03 Maxima front suspension noise
- Steering wheel controls
- CF Hood - which one do you guys like?
- Lowering Car
- Pressing bearings
- OBDII/DLC Connector Terminal L? (For ABS check)
- question on aftermarket springs.. ?
- 2002 GLE and 1999 SE: wheels interchangeable?
- How-To: Maybe a solution to CD skipping
- What is the black plastic box under the trunk? driver side?
- what my hs y pipe looks like after 3 years in ny..
- HKS rear section
- Mixing synthetic 5w-30and 10-30 ?
- My car hesitates at full throttle!!
- Underdrive pulleys
- 6000k?
- Couple of Problems today
- what MP3 adaptors will work with the stereo in my 2K3 Max?
- Dim Angel Eyes?
- LOUD NOISE COMING FROM REAR DOOR WHEN I UNLOCK
- How to pull ABS codes?
- Hood Vibration 2001 Max
- Location of all O2 sensors?
- Replacing LOW SIDE A/C hose
- Replacing radiator, what do you use to plug the transmission cooler lines?
- 03 GLE Price Question
- Reliability...
- LED's from V-LEDS....
- Spray Tint
- New ecu, fried in seconds....
- IACV gasket part number?
- HID Ballast Mounting
- Valve cover install
- Ball Joints
- Transmission?
- 04 sunroof visor work on a 02
- Black lips and side skirts
- y pipe and headers from 3.5
- I'm looking for an old Friend white AE 2001 max
- 02-03 Testpipe Installed
- Need to replace passenger rear door actuator
- Stillen Classic Lip vs MaxxTuning Lip
- p1147 02 + stealership
- trouble with remote program
- Questions..
- Rear Main Seal?
- 1990 Flywheel on a 2001 SE?
- CENTER CAPS FOR G35 Rims
