PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 [157] 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Major problem with my car....help...
  2. suspension questions
  3. 30K Service on 02 - Fuel Injector Clean Needed?
  4. how to install 02 sensors simulator?
  5. After changing the ignition coils
  6. Damn Rear Brakes!!
  7. Exedy Racing clutch- 1st impression
  8. Repair Manual For 5th Generation Max
  9. Transmission fluid
  10. Rear Fog light in 5th Generation Max
  11. Cold Starts - Sounds pretty hellish
  12. What are suspenion bushings for?
  13. Data dots recall
  14. Main Req light
  15. Where to find a 6 speed tranny to swap out my auto?
  16. suspecting foul play by dealership?
  17. need help,please-headers and o2 codes
  18. Tire problem or alignment?
  19. Brake-Torquing
  20. Shocks
  21. TSB Question
  22. 2k / 2k1 SE tailights - thought they were black?
  23. Muffler/Cat Flanges..Rusted away
  24. Front end accident w/pics. Where can I get a bumper?
  25. Post-Warranty Maximas and MAF sensor replacement.
  26. What is that d@mn squeaking coming from my front end?!
  27. DDE Lightning Plus
  28. how to install Fog light?
  29. Drivers seat
  30. how much did you pay to re-paint a front lip?
  31. Cracked fog light lens
  32. Berk Intake Fitment Concern
  33. Silverstar Fog Lights
  34. NEW O3 MaX SE 6spd Owner, any advice?
  35. cam question
  36. Help!!! Noise from Blower Motor
  37. 2000 Cali SPEC O2 sensors need how-to!!!
  38. Transponder Key programming
  39. Consequences of Redline?????
  40. anyone know how much this part costs?
  41. matching foglights
  42. Parking Brake Light on and torque converter locked out
  43. Projector Headlights
  44. installing all my suspension components myself?
  45. code thrown, anyone know this one???
  46. What is the best hp mod you can do?
  47. 2002 6-speed - Clutch at 36k ?
  48. My car's suspension systems is pissing me off.....
  49. 00 3.0 vs 02 3.5
  50. Remote starter.. again
  51. Bulb Replacements.....Help!
  52. Main pulley failure - questions
  53. halo projector headlight question
  54. Car hesitates while im accelerating
  55. 2003 Maxima SE front Brakes
  56. aftermarket suspension and ball joint woes...
  57. Stock bulbs finally blew need recommendations
  58. Car begins to shake at 60-70mph
  59. Fender smashed
  60. clearing out HIDs, need pointers.
  61. Need help finding a part number!!!! PLEASE HELP!!!
  62. Those with Ipods on there max
  63. Smoked Taillights
  64. battery ques
  65. Projector headligts for 01 Maxima AE
  66. 03 se hood vibration
  67. carbon canister and emisson problem
  68. Injen Vs. Berk Intake
  69. 2nd CV axle failiure in a month
  70. MonsterFlow HiFlow Air Filter..From Cattman Performance !
  71. Nasty smell coming from air vents
  72. Repair Manual for 2k3
  73. ecu upgrades?
  74. Gauge Cluster Problem
  75. Thumping noise from front end...
  76. Primed dash kit...which color to paint?
  77. need a new cat?
  78. Smoke side markers from CM??
  79. back to stock or not?
  80. Intake Problems
  81. help with spring/strut install
  82. Contest for 5th gen Spoiler...
  83. New Exhaust
  84. Electric motor mount question
  85. Problem with 20's??? HELP!
  86. Steering issues
  87. Anyone have the wrench for the HID "security bolts"
  88. We do own a FAMILY sedan... Right?...
  89. battery location minimum gauge?
  90. body kit advice
  91. Steering wheel covers
  92. 2000 Maxima Automatic - shifting issues
  93. extend steering wheel
  94. Hyper grounding?
  95. Help with wires
  96. High pitched noise while driving
  97. Ignition Coil install
  98. Budget or Cattman Y-pipe? Which one would you get?
  99. vtc - code 0021/0011 - sluggish max
  100. HID conversion
  101. question for the H-tech owners
  102. FAWKK!! In an accident & need some advice
  103. A lot of play in first and second gear
  104. How can I get the haze off of my headlights?
  105. Air conditioner / heat console
  106. PIAA fogs
  107. Gas Mileage
  108. How do I remove these
  109. Gauges
  110. Since I didn't get an answer from the FAQ thread. . .
  111. 2k2 hid housing
  112. sad day for me
  113. Suspension question
  114. Walbro Fuel Pump
  115. car audio forum not helping
  116. Installed new wheel bearing, still noisy
  117. Bulbs for clear sidemarkers...
  118. motor miss in my 00 maxima
  119. black door handles
  120. My car makes a funny noise when turning....
  121. Bad Coils?? / P0300 - Multiple Cylinder Misfire Detected
  122. Reverse lights, what size for 00 max?
  123. 19 x 8 Rims and Strut and Spring Question
  124. Wind noise coming from rear most likely driver side after 50mph
  125. Stillen Classic Lip...a good deal??
  126. Problem with Gated shifting A/T
  127. Help with yearly service maintenance?
  128. Does a 5th gen have a limited-slip?
  129. ALL INJEN CAI owners PLEASE step inside!
  130. Progress on my ghetto ride: 17" rims/tires
  131. FINALLY after 8 months got pics of my car up
  132. Lexus yellow fogs pictures are here
  133. Y-Pipe Installation and Emissions Testing
  134. The eyelids are here, pics inside. (Same that Left Coast Tuning used to sell)
  135. Nissan ECU codes
  136. Buzzing sound from the engine (hear it)
  137. driving my car then my car alarm goes off? wth?
  138. TWM Performance Short Shifter
  139. Poor maxine, slightly injured...
  140. turn signal bulbs
  141. Cruise Control no worky!!??
  142. Anyone have these Projectors?
  143. Are the Autozone batteries any good?
  144. black light
  145. Projector bulb color
  146. Need answers quick!
  147. will these rims wit on a stock 2001 GXE
  148. What happened to my car? help
  149. HIDs for the Projectors... Advice Needed
  150. Finally Driving...
  151. How to upload MAX pics
  152. PR CAI, How to keep it in place
  153. 2k2 bose HU in 2k1?
  154. Accel times for 00 5-spd
  155. Roaring sound from RF wheels
  156. Fuel Additive
  157. SPARK PLUG QUESTION>>>NGK HELP
  158. home depot grounding kit
  159. How long will it take in the shop?
  160. Newbie Looking for Help - Current Drain/Radio Probs
  161. strange idle behavior
  162. how long did it take you..
  163. anniversary edition pedals
  164. Noisy engine while rolling to a stop /low RPMs
  165. Max progress
  166. reseting the ECU on a 2K max
  167. Trunk Won't Close Properly
  168. for those who have CAI
  169. Fog light rewired (FKED UP)
  170. Climate Control Bulb Replacment?
  171. Pics of NY's Ghettoest ever maxima
  172. Real lexus looking yellow fog's with pictures.
  173. How to Drive in the fog
  174. WAI, Short Ram Intake Advice
  175. STS now available from TWM
  176. o2 sensors
  177. Headlight bulb replacement
  178. where to buy oem rim centercaps?
  179. Mass Air Flow-Update
  180. Help with memory seats
  181. Picked her up FINally
  182. Finally going to be lowered
  183. Finally taking her to the dealer
  184. 2002-2003 Ecu/maf
  185. Need new Break Pads Which one?
  186. SES Slip and TCS Off Lights all ON!!
  187. Ways to clean your air intake
  188. Got some Konig Tantrums 19x8 Rims/Tires
  189. Does anyone know where I can get one of these for my car?
  190. ARGH stupid bolts in our cars
  191. Whats the value of my exhaust
  192. sleeve for intake filters?
  193. Ignition Coils Vs. Spark Plugs
  194. G2 caliper paint
  195. interior dye
  196. Help
  197. Sylvania Silverstar H3
  198. HID replacement bulbs
  199. fender 2000 v 2002
  200. Berk Intake Tomorrow!
  201. Rattling Cigarette Lighter Outlet? Try this.
  202. for those of you who lowered your maxima.....
  203. will hs headers bolt right up?
  204. Everybody post pics of your grills
  205. E-Brake adjustment Q's
  206. Stillen Y-pipe
  207. Dealers telling me Bed time stories !!!
  208. Correct Amt of Engine Oil for 3.0 Litre 2001 Maxima
  209. 01 GLE Instructions for Maxima HID INSTALL Please Read (New Member)
  210. Brakes....here we go again..
  211. Did I pay too much?
  212. Exhaust noise
  213. 01 GLE Instructions for Maxima HID INSTALL Please Read (New Member)
  214. Huge dent in fender ahhh
  215. Bra options
  216. Steering wheel stereo control problems
  217. Color of my car?
  218. Stick Shift fun or hassle
  219. abs rear valance for an 02 max
  220. yellow foglights
  221. Power loss after 3500rpm???
  222. CEL Code P1453
  223. Want to put 02,03 Xenon headlights on a 01
  224. this way be a retarted question but i need opinions
  225. code P0171
  226. Sue my dealer? Motor mount + ECU related
  227. WTF? Is urethane front lip supposed to crack?
  228. Stock '01 vs '03 muffler
  229. Brake Question
  230. Stillen Grounding kit?
  231. Strange 'CLUNK' noise in front right wheel?
  232. advice on getting a used 2000 SE
  233. Bose stereo out of balance
  234. sound when i turn all the way my steering wheel
  235. 2k I30 LOUD knocking?
  236. Pics After Drop On Jic's!!!! *updated*
  237. I think we could all use 1 or 2 of these
  238. 2k2 Maxima with A Temperature Problem
  239. How to: 00 max AE headlight mod?
  240. New Maxima owner needs help!
  241. Tranny Problems seem to follow me...
  242. TWM Performance Maxima Shifter now available!
  243. Idea for interior dome lamp...
  244. ECM Replacement
  245. Aftermarket horns
  246. Gas milege for 2002 2003
  247. Does anyone else have trouble trying to check SES code
  248. 02 Simulator How to install- inside.
  249. jostling sound in my right front corner
  250. These rims on a black max..hot or na
