PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Help removing my headlights...
  2. Spark Plug
  3. P0160 & NJ Inspection
  4. Need some posible solutions, Car turns off.
  5. 5.5 gen rear brakes
  6. Any Valentine 1 stealth setups?
  7. Fog Light Change How To
  8. h3 mimi fog bulb replacements
  9. ebay chin spoiler ?
  10. It's been a while
  11. Illumina Question?
  12. Been thinking about changing my fuel filter...
  13. Think Twice before replacing your MAF
  14. Want to quiet your intake and improve the low end?
  15. Energy Suspension Motor Mount Install (with pics)
  16. hks sport exhaust
  17. Boss Chen's are in!!! **Pics**
  18. Fuel filter replacement
  19. HELP! Car won't start! Just get a clicking sound when I turn the key
  20. Carbon fiber hood shocks?
  21. Hot Air comming through firewall ???
  22. Need Opinions
  23. Y-pipe bolts...
  24. Can anyone quickly
  25. Two wires in trunk keyhole?
  26. Fog light lenses
  27. 20" wheels on an 01 AE Max lowered
  28. Body Kit Install
  29. Car Beeps
  30. 5th Gen Purchase
  31. cattman headers
  32. If you have installed Boss Chen coilovers, please help...
  33. Broken rear motor mount
  34. Problems with brakes
  35. Y-pipe installation question
  36. Got OEM CF Hood, now further options?
  37. sunroof stopped working.
  38. Dayco belts with UDP
  39. front precat SES
  40. 6 speed swap done in 4 days!!!!
  41. Replace Bose SUB?
  42. Installed HID fogs...Have a few Q's
  43. Write-up for Berk install? (i've searched_
  44. Air Leak only during warm weather..
  45. Air Hissing from Engine Bay
  46. lost my doot
  47. new version coil has no dot?
  48. Strut Mount Replacement
  49. Another Max accident
  50. Wood Removed - Molded Dash installed pics
  51. fog lamps lens
  52. bad whistle sound when braking any idea? please help.
  53. are these the correct bulbs for an HID retrofit from 6k to 4300k
  54. Tein S-Tech and H-Techs for super cheap
  55. does the G35 Maf work???
  56. My Max knows when Inspection is due..Can weather throw a cam/crank code?
  57. ebay speed chip
  58. Longer Wheel Studs?
  59. How many of you went back to stock airbox after WAI?
  60. Strut Bar question.
  61. Sun roof problem
  62. slight squeal noise upon acceleration and deceleration
  63. rattling noise under front of car
  64. 00-01 Exhaust Tip Removal
  65. 3.0 Removal
  66. 2000 black stock headlights on ebay
  67. 02 Maxima SE Bose system acting weird
  68. Aiming headlights + HID upgrade on my 2k1
  69. Cattman Ypipe on a 5.5gen 6mt...worth it?
  70. Supplemental air bag light is flashing
  71. Wheelhop Dilemma
  72. Error F3 CD player
  73. Sandblasted Side Skirts, ball park $ to get fixed?
  74. P0430 Code!
  75. Dealer possibly replacing my o2 sensor under emissions warrenty.
  76. turning the battery sideways
  77. Everytime I press brakes, interior light on dash comes on
  78. JWT Pop Charger Heat Shield
  79. LED's blowing fuses.
  80. Just Graduated to 5th Gen....
  81. hot shot headers , megan test pipe, ebay catback..pics +video
  82. Help with sponsor stickers
  83. Brakes
  84. clutch fluid?
  85. Quick Question about the Brake Rotor
  86. Low idle
  87. is this even possible? autoenginuity Q
  88. Foglight Bulb Replacement Help
  89. Cobb access port
  90. Any known issues with the Nav/Climate control on an 02?
  91. Warranty Question
  92. No Keyless entry and interior lights???
  93. replacing the O2 sensor - where is the wire harness?
  94. Frozen Gas Gauge??
  95. Premium Fuel??
  96. Help with a code please (interpreting it...) I think it's P0455?
  97. Car not sitting even after suspension instal
  98. 6spd drivers axle
  99. Squeaky wipers
  100. need clarification on the check engine light procedure (2k3 max)
  101. Ceramic Coating... worth the money?
  102. LED tails.
  103. Steering Wheel Vibration when going 60MPH+
  104. Good, not best exhaust...
  105. rear bumper removal
  106. Maintenance Ideas
  107. i got 300z brakes
  108. Best place to buy aftermarket OR OEM parts
  109. H.I.D fog lights question.
  110. Should i Seafoam it? 2k3/150K
  111. SES light on and two o2 codes...
  112. stock oem bose sub isnt working.. em i missing anywires
  113. ok newb question time: where is the starter?
  114. 2000 SE, Rough Idle
  115. Got P0140 code need help on current procedure
  116. Alignment Question
  117. moderate bucking in low gears and slight buck in higher gears?
  118. fuel filter on a 2k3 maxima se?
  119. Need some help from the org (sunroof, kinda long)
  120. Driver door sags
  121. Triple Gauge Pod
  122. Motor Mount ?????'s Please help
  123. No rev above 3500
  124. P0455 and P1448 MAX Gods what do I do??
  125. Battery charge light and E-brake light
  126. Fuel Filler Door
  127. Grinding noise from front wheels/brakes area
  128. Cabin Air Filter Queastion.
  129. help with misfire when start up...(P1320 was set, but car runs fine after a minute..)
  130. Jerky/Sticky Clutch
  131. Wheel spacers
  132. i keep bouncing with these springs
  133. Shifting problem after accident. HELP NEEDED PLEASE!!!
  134. Help with oil leak
  135. Best amplified car tv antenna
  136. axle install problems
  137. Illumina Question
  138. Need New MAF
  139. a few questions.
  140. i want to do a 5 speed swap......
  141. Scraping Noise While Turning On 2000 Max?
  142. 5th Gen Grounding kit
  143. Strut Mount Replacment How to
  144. Clunking noise when braking
  145. reprogramming sunroof
  146. 00 auto to 01 AE auto.
  147. Eibach Pro Kit
  148. Thinking of replacing spark plugs...
  149. White Rims
  150. Buzzing noise when releasing accelerator...Oil filter or TB
  151. Just wanted to share yet another compilation.
  152. Another great product for the $
  153. New owner - 2000 SE (56k stay home)
  154. Replacing inner tie rods - need advice
  155. need some advice....
  156. Programming the Keyless entry
  157. flywheel reinforcement plate on aftermarket flywheels
  158. O2 Sensor Heater circuit resistor
  159. How is the stock brake pedal pressure suppose to feel? Compared to other cars?
  160. suspension help
  161. Hit and Run
  162. Nismo (Altima) F&R Stabilizer Bars for 5th Gen Max/I35
  163. Wheel almost fell off.......
  164. 2003 Projector Headlights
  165. P0138... But I have an o2 Simulator!
  166. 4th gen RSB on 5.5 gen?
  167. CV Boot/Axle issue
  168. how much should it be?
  169. Flipping ticked off
  170. 5.5 gen grill?
  171. Bumping/Grinding Noise
  172. MAF dead?
  173. New brake pads
  174. tien coilovers
  175. D2 problems fixed and adjustments explained for 5th genners
  176. In the middle of suspension install....
  177. SES Lights, now high/fluctuating idle...what can it be???
  178. I would like to thank BERK Intake for letting me moisten my pants...
  179. will be dyno tuning in the morning but need help with settings
  180. Wtb
  181. HID Interest?
  182. 2002 Max se Steering issue Help!!!
  183. Buying New Front Bumper
  184. idling, how much fuel does it really burn?
  185. Grille's???
  186. 20th Anniversary SE gauge cluster swap???
  187. Bendix rotors for replacement?
  188. Can someone help me ID this dash Light?
  189. steering wheel sawp.
  190. SEL Gone...Can I Pass Emissions
  191. Factory Alarm setting itself off!!!
  192. ABS issues on an '02 SE
  193. 00-01 Painted Mud Flaps Vs 02-03
  194. Fixes for 2 blehmco products (LTB and BBK)
  195. Cefiro conversion
  196. ........... MAF, O2, Coil ... The $$ is alreay sucking away....
  197. New Brakes question. Help a noob
  198. have a question about vb mod?
  199. Interior buzzing at certain RPM
  200. need help w/ passenger window
  201. Aftermarket Headlights
  202. PA State Inspections & Codes P0455, P1448
  203. compressor not turning on
  204. big fuse that comes off battery
  205. Pending trouble codes?
  206. Had a minor accident today... Lookin for estimates on price
  207. Help Identifying Problem
  208. are 4th gen and 5.5th gen valvebody's interchangeable?
  209. Other FOB Hidden secrets?
  210. car shakes when I brake
  211. Thoughts on Technosquare and throttle response
  212. Issue? Rear spring on strut perch install position. Look...
  213. Weird Tire Wear!! Little Help.
  214. Da Foggies, Da Foggies need replacing
  215. Traded my 02 Max 4 a 07 Altima but already...
  216. Lexus yellow capsules and HID fogs?
  217. Looking for some help/advice ...
  218. Springs that are good for travel
  219. z33 intake swap and now brakes are messed up
  220. does anyone make an aluminum radiator
  221. I'm Baaaack....Bought a 2000 SE today
  222. Suggestions needed for Shroud Project
  223. 99-03 same muffler???
  224. Hood Support Struts
  225. Locked keys in car...need advice
  226. Custom 2.5" Catback with 12" Glasspack
  227. Inside brake rotors thinner?
  228. One Tough Axle Nut
  229. Turning off and on the valve body mod?
  230. Rattling noise
  231. 02+ HID Painting & Clearing Journal: PIC HEAVY!
  232. 2003 SE Stock Headunit
  233. how do i get the face of
  234. Anyone have the next gear I.M. gasket?
  235. sunroof visor
  236. Were 2000 or 2001 5 speed Grey Lustres built with Black leather interiors?
  237. What should Nissan HAVE done to make it for you?
  238. Anyone successfully replace O2 sensor S2B2?
  239. A Quick Response Please - Mid repairs
  240. Bad Alternator?
  241. Side marker
  242. Torsen limited-slip differential
  243. HELP!!!!!- Car won't start......need advice!
  244. HID Replica vs. OEM
  245. Busted a Brake Line whilt traveling...
  246. Quick ECM question
  247. 2000 SE BASS BLown ??? Need replace amp, HELP!
  248. CV Joints Clicking Only when REALLY COLD
  249. Does your blower motor sound like a weedeater? Cheaper fix inside..
  250. Installing Fog Light on GXE Nissan Maxima
