- best looking tint on a sterling gray max?
- Alternator problems, need some help!
- Any pictures of titainium tint on a silver max?
- Anyone installed remote starter?
- I made MOTM... Woot, also more info on 13" BBK
- Does anyone make aftermarket exhaust manifold catalytic converter?
- Eibach Vs. Tein S Tech..
- Remote Starter: Do our 5.5gen factory alarms support 'Auxiliary Output' ?
- SES light went on, now gone?
- Whitest, Brightest Hibeam Replacements?
- stalling
- Let us END THIS (HIDs) Step inside and vote!
- Online retailer for OEM Exhaust
- thieves, dumb and dumber
- How to fix Leather Seat Creases
- Thumping rear brake after pads/rotors replacement, What should I do?
- This Time the Extended Warranty was Worth the $$$
- Anyone had HIDs stolen that don't live in NJ or NY?
- My car barely starts..help
- The Definitive Strut Bar Thread
- How much brake fluid for flush?
- ECU Screw reset procedure!
- Ebay HID kit
- Some one please help me! I'M LOSING IT!!!
- Finally Got My New MAFS and Installed it!
- Ignition Coil Law Suit!!!!
- Lets get this straight, can u put 00-01 headlights in a 02-03?
- Shocks/Struts 90K help
- Berk Midpipe
- weird braking noise
- Air bags
- Maxima messup?
- Cheaper Halo/demon Eyes - Ebay
- Question about the front catalytic converter.
- Early 5th gen paint class action lawsuit
- Sunroof problems on a 2K
- tb restrictor question
- Replacing 02-03 HID options
- My 2003 Max won't start. Help !!!
- max ranking?
- HID theft results in class action lawsuit vs Nissan, add your name
- Fair $ for 2k2 GLE?
- quick stupid question
- Best sway bars?
- JMS grille installed *pics*
- Are there any benefits of RE-Timming
- PAC SWIX Infrared eye placement ?
- Tires slip when I accelerate from a complete stop
- Keep Your HIDs From Being Stolen
- Aftermarket Audio
- can we get our car TUNED ?
- rev limiter
- 2000 5-spd acceleration
- VQ35 Hyperground
- 2K3 Throttle body cleaning caused SES light!!!
- Climate Control Temp Display C to F Change
- Loose Hub?
- Help
- Tinting dot matrix
- do those viper alarm systems decrease the chances of getting the HID's stolen?
- 1/4 mile question
- Headers...Emissions
- Tranny fluid to be changed
- Fog rewire
- 5spd tranny fluid change...
- people w/cattman exhaust
- Hit by the headlight bandit
- Wheel Locks
- 2000 Cali spec with test pipes step in
- Got my 2001 5spd ECU, what should I have Nissan update/reprogram with consult II?
- Post Cattman Mods Results
- 2000-2003 Maxima CLEAR Taillights
- TB cleaned, TB/IM restrictor removed, updated MAF, and sea foam
- *Anyone have pics of the GREDDY exhaust on their car???...*
- NGK Sources.
- power windows problem
- Need help.... what struts to get??
- 2000 max se 3 button on driver side sun visor.
- Adjustable camber plate
- how do i know which car this ecu came off of?
- Nissan Security Plus Entended Warranty
- Installing a factory rear spoiler
- ignition keys for Maxima 2001 - expensive!!
- LED lights
- What is this light?
- i blew out the check engine light... help ?
- Transmission Service Deal Question
- Got some new pics
- Noise coming from front right suspension, HELP!
- Exhaust Setup Question Y + B + Stock Muffler?
- OBDS post reset driving cycle
- 2002 Max ECU code breakdown!?!
- Fog Lights Suuuckkk!!
- Help! California Spec car?, need O2 sensor
- Help! Code P0444--EVAP Canister Purge Vol. After Header Install
- Foglight open and rain?
- WOW - It came in a week!
- SE 20th Auto
- Benifits of running Rich/Lean
- Clear Bra Recommendations
- Nissan Headlight Theft Deterence Kit
- CEL, SLIP and TCS OFF ??
- well need an idea
- help: need pics of 2k2 Climate Control Wiring Diagram
- Front Bumper Removal Help
- PIAA H3 fog lights: Xtreme White OR Super Plasma?
- Surprise in 3 days
- Blown HID question
- Got my items for custom grille.
- 2001 w/ 2002/03 hid lights
- Air\Fuel gauge install
- Help Please Asap D2 Install
- Having trouble with the power on my car, Please help
- 02-03 Map light into an 01 SE
- I got sponsered! kinda i think
- Comestic Mod Ideas for Majestic Blue
- Do i need to change a/t fluid filter or just change fluid?
- license plate thread
- Anyone have STATIC problem when you touch the car?
- windshield wipers...
- Cattman or Stillen?
- Worth it buying a salvage?
- 5th Gen Tranny Help
- Removing rear sidemarkers?
- Ground Wire for Horns
- Clutch Stop Mod
- Stillen rear vallance & Greddy Evo fitment Questions.
- Which struts with stock springs..
- Parking Light Color and Clearance Lights
- Where is the PVC Valve located?
- 00 SE which projector headlights...
- write up on fixing VIAS
- o2 simulator
- Any problems with the 2001's?
- What to do?
- adjustable fuel pressure regulator
- How much $ would this bring?
- "Throttle Valve Closed Position Learning"
- What's the connection?
- harness for 00-01 SE tails
- HELP with code P0450 - evap
- Clutch problems ?? advice ??
- 1st time buyer Please help me out
- MAP sensor and EVAP pres sensor problems
- Anyone Know how much HID bulbs are?
- 2002 Max?'s
- Any pics of smoked tails on a sterling mist?...
- 5.5 Gen shifter knob on a Skyline GT-R???
- MobileTek or Levelten ??
- Haziness in HID lights
- Strut Bushings........
- 2003 with stillen classic step in
- projector upgrade
- headlight
- What did your dead MAF look like?
- Strange Sound
- ebay clutch?
- How to replace drive belts on 2001?
- How do you lube your doors?
- Charcoal and Grey Lustre Colored Cars
- Chances of Auto Tranny going bad???
- clutch won't depress
- Maxima Blueprints
- A little help needed...
- 02 SE auto tranny shift delay
- DIY wheel bearings
- Those of you with the factory trunk mounted 6 pack CD changer.....
- Frankencar Ques
- Loss of HP Possibly Due to Lack of Back Pressure
- Yes !!!
- Rough Shift- A/T
- OEM Navi Install Project Begins....PICS
- is it worth the money???
- Top Speed
- Engine Surges while slowing down?!?!
- Trunk Emergency Escape - please help
- How low can I lower with a 245/45/18 rim and tire combo
- Are the Nissan Z Horns Plug and Play like the Hella?
- update on the cf trunk project
- need service manual
- What the heck is this?
- 03 auto max has NO... NONE tope end power !
- POS projector help
- Replica '02-'03 HID headlights...where to get them?
- 01 red taillights for sale
- Ran in w/ 6th gen
- am i obsessed with my engine bay?
- Pics of my Custom XM Radio install.
- Mechanics ever left a present?
- Think this would fit and work for us ???
- Which Mod is better...??
- Quality on D2's compared to JIC
- install on parts
- Programming remote
- roof rack (snowboard, mountain bike)
- Looking@ Powerslots for an 02
- Nissan or Brembo (or other) rotors?
- Washed the engine bay, now it's louder
- Fuel Pressure Question
- Quiet rattling in driver's window area..
- weird sound
- Smoked Tail Lights
- CDRW mp3
- placement of 02 sensor
- 02 Maxima SE - 2 problems.....
- Recommendation for New Shocks
- how much $$ to install springs
- High flow cat from custom enterprises any good?
- The Frayed Ends of Sanity
- Question about warranty
- Can 2k or 2k1 headllights be opened?
- finally got first performance mod
- eye lids
- P0171 - Fuel Injection System Too Lean
- 2003 SE Auto locking ????
- Front Motor Mount
- post PICS about parking lights!!!
- Whats up with my car?
- Technosquare Ecu Is DOne
- iPod direct connection
- Bi-Xenons on 2k, 2k1 Headlights?
- Car problems, mounts, idle, HELP
- new struts
- Problemo
- ****03' 350z full brake kit swap into 03' Maxima***
- Cattman Catback for 01 and 03
- 2002 Maxima CD Problems
- Replacement rotors
- 02 Question......
- O2 Sensor?'s
- Help!!! Second battery dead...
- Feedback from ppl with tein H + illuminas.
- 5.5 HIDs in a 5gen - portability?
- bulbs? Replacement various wattage?
- Air Flow sensor
- Brake Pedal Sticking
- Ebay DDE kit , also h4 HID kit
- Custom sunroof on my max. possible?
- Headlight question
- Dealer says pinging is normal...
- Checking MAF Sensor
- Hard Wireing Radar Detector
- RPM's Fluctuating At Idle, Whats Wrong?
- Faster you go, louder the volume?
- Adding moonroof to 5th gen...
- Anyone else driving a beat up Maxima?
- Condensation in Headlight
- need some advice!!!
- solution to the Car wont start issue
- Instrument Cluster - Bulb type?
