- squeaky rear springs, stock setup
- New shocks and warranty
- Black Housing Fog Light
- Rattling after shut off ...
- In need of sunroof help.... desperately
- Question About The yellow fog lights...
- exhaust thread
- exhaust thread
- I need a new AE front lip!
- bumper dent repair
- Just Turned 100k this weekend!
- Component to left of rear valve cover
- Axle nuts keep coming loose
- Fast way for L.E.D.'s
- mud flaps
- High Pitch Sucking from intake under 2500 RPM's
- Lost a bolt somewhere in the engine bay
- Transmission fluid change ... part #'s correct???
- Triple Gauge Pod...
- Pic Request!
- Just Gont Done Painting My CALIPERS...please see
- Redline Leather setup pics?
- any fitment problems with 17" 350z wheels
- Quick newb question.
- Stupid Vent trim piece, trying to install radio
- need help asap..please
- Clicking noise while driving
- PCV valve ...
- HELP! O2 Simulator question
- Transmission
- MetalCat Installation Problem
- key fob power window mod???
- Brakes squeak while reversing. Why?
- anyone have a pic of an oem 2k2/2k3 HID ballast?
- Am I gonna be missing something?
- How do you change the climate control/window control lights?
- Air filters ...
- HID bulb type
- Is there such thing as NISMO STS for 5.5 gen?
- Manifold absolute pressure sensor fault??
- 3rd gear feels...crunchy, uneasy (cant find the right word)
- Exhaust problems yet?
- Anyone have a Kenwwod DDX-7017, 6019 or 8017 in their 5th Gen???
- Bose bypass with aftermarket deck/ adapter needed or not?
- 6 in dash cd changer for 2000?
- Yellow fog light?
- mechanic can't figure out prob/can you help?
- Are vq30 & vq35 5th gen catbacks interchangable?
- Rotor weights for 5th and 6th gens.
- what are the absolute best PERFORMANCE mods?
- OEM GXE 5th Gen Radio Dash Kit
- Fuel pump problem?
- Resetting ECU - 2k3 Max
- Bose woofer not working
- clutch going out?
- 3.5 6 speeders - gettin' mo special and special!
- Swapped The ECU Questions?????????
- Another Reason Not To Use JiffyLube
- Sudden Bose stereo loudness...
- Got another Maxima and have a question.
- Resonators
- Fan stuck
- Anybody have diagram to tell you which is cylinder 4 on 5gen?
- Reset ABS light
- 02 headlight question
- 5.5 Gen Changed Plugs and Now Transmission not downshifting on time?
- 245/50/17?? too big? input please.
- Before I buy
- What battery do u guys recommend?
- Temporary loss of OD
- Tranny starting to skip: what do you guys recommend?
- Engine Dampener?
- 5th gen to 5.5th gen parts swap
- Thumping noise when driving...bad wheel bearing?
- Did you get yours yet?
- Extra Part??
- air conditioning not as cold?
- Rubber bumper damaged - advice needed
- Battery issues ...
- Are our cars made in the US?
- help picking new rotors
- quick question regarding brake bleeding
- no throttle response?
- who has bike roof rack? if thats what u call it..
- rattling noise..timing chain?
- Wierd Squeatity Squeak
- Pic Request: 5th gen dropped on H&Rs
- All new Rotors/Pads & Spacers *Pics
- Right side high beam not working
- Wrapping Doors is Suede
- Right High Beam not working :-(
- Indiglo Gauges, Where to buy 'um.
- Engine just shut off at idle!
- Help, valve cover gasket leak!?
- Question regarding Cattman Ypipe
- y-pipe with stock muffler..... pointless?
- Emergency brake light always on, where is the switch?
- Power steering flush?
- Replaced PW motor, now have problem with auto up, goes to top and backs down 3 inches
- need help with this issue........
- My GAB quick impressions
- Door pillar removal
- resetting pass side auto up window
- SE Guages
- ES Bushings, Whats the effect?
- Anyone have a Dynomax Super Turbo muffler? Sound clip?
- How to check ECU?????
- can i see a pic of the pvc valve on a dek
- Where Do You 5.5 Geners Buy Your Drives Side Wiper?
- Are the 6th gen rotors worth it?
- Hel: A/C stopped working need input
- What would you choose???
- greddy evo 2 users come in
- Pic request: cargo net attachment
- Just Bought Brake Pads And Rotors, Brake Pads Not Fitting!!!!!!
- 02' warpspeed y-pipe pics????
- Where Is The Write Up For Installing Rear Brake Pads+rotors?
- Need MAF plz help
- how to install S-AFC II unit onto 2000 Maxima?
- moving throttle body to get to 3rd screw on VIAS?
- need help with search of maxima..........
- CV boot torn and spewing grease all over
- Where can I get spare parts for an ADDCO RSB
- installing black carpet
- installing home made black carpet
- Lamin-X... What do you think?
- revised timing chain tensioner
- PICTURE REQUEST: Tinted Taillights w/ lights ON
- tiny nissan sticker
- windshield wiper switch doesnt work, but pullback stalk does? help
- modifying and getting engine light
- Power Window Motor replacement instructions?
- Headlight upgrade install ?
- Picture of rear suspension: Anything wrong?
- Is it a bad ecu, bad wiring harness or could it be the starter etc.???????????
- My clear corners dont fit...pics inside..help needed
- 16s on a 5.5gen?
- 16s on a 5.5gen?
- Air in brake lines!!!
- 5th Gen 5Sp versus 5.5 Gen Auto
- Fresh start low idle, no power, jumpy performance
- LSTB From Matt
- Can I test a Crankshaft sensor On a 00 5spd
- Infiniti 19's?
- need help!!!!!
- Service Engine Question
- Anyone with a black front lip
- The Best Mods
- Compression Test for VQ30DEK motor? Standart Pressure?
- Redline MT-90: was smooth, now notchy as hell
- Could I Just Replace My Rotor And Brake Pads?
- Will progress springs/camber kit void my warranty?
- Help with headlights??
- Smoked Bumper Lights
- shocks KYB gr2 vs tokico blues
- Noises after RSB install?
- need suspension specifics
- Rear Deck Holes for Air Ventilation ???
- Strange Issue
- Driver Window
- Z32 calipers + R32 rotors = very spongy/lots of travel feeling?
- Motor Mounts
- The dreaded P0420 code...anyone else experience it?
- Anyone want something photoshopped?
- Looking to buy a 5th Gen Maxima and worried
- clear 3rd brake light?
- Injen Short Ram Intake
- Drive BELTS @ Dealer Good PRICE?
- Valve body, $900 to fix, are they ripping me off?
- altima se-r wheels!!
- what can delete the rev limiter?
- power seat stopped working
- question about headlight bulbs.
- Another check engine light question
- SE 23mm FSB vs. GXE/GLE 22mm FSB
- Can clutch hydraulic system cause clutch to slip?
- 5th gen grill options
- Idiots at shop can't properly adjust clutch after cylinder change
- PCV BlowBy -- Oil Type
- Need opinions, Brake light and Battery light on?
- 2000 to 2k2 headlights
- Does anyone have any experience with warranty coverage for KYB struts?
- Chrome Window Trim Replacement?
- Rev Limiter
- How Much For A Paint Job?
- rear window spoiler
- My seat wont move back-- and I'm 6'6!
- 2002 wrx spoiler
- LED Taillights, Metal Maxima Style...PART I: Design. NEED YOUR CRITIQUE!
- condensation in headlight
- NEEDED CLEAR COVER OF BOTH HEADLIGHTS 02 Max
- My 02 6sp is burning a LOT of oil
- Oxygen Sensor needed!
- 01 Body Kit advice
- clutch / throw out bearing question
- need some advice on this test
- red overlay for the SE tail lights
- El Crappo Gas mileage VQ30
- Another Successful AE Mod
- need help please...
- let it idle, or turn off the car, for better gas mileage?
- Automatic Climate Control question
- Hey guys, Cooling question ?
- Solar Gard HPTint - Colors???
- LTB bang = nut strippage :(
- datadots headlights
- Add me to the list, Headlights Jacked, Allentown/Philly area
- insatlling ae side skirts on a non-ae
- need suspension work...what to get?
- 2001 Transmission Control Module in a 2000....
- 1750 rpm rattle???
- Windshield replacement
- Taking car to the dealer..Question
- What intake should I get?????????
- trim tape (pic request)
- Another Victim: Headlights Stolen
- Brake HEEEEEEEEELLLLLLLPPPP..
- Pics please
- thoughts on this....jus curious..
- Let's play "spot the new mod!"
- LED Array for sidemarkers...do I go legal or illegal?
- weird sound right when driving the car after it's started
- can 15" wheels be used on 5.0 gens?
- Any good repair manuals for the 3.5L? Other questions as well..
- Write-ups and review threads
- A few new minor mods *PICS*
- Spoiler
- Airtex Ignition Coils
- Radio Reception Issues
- HELP - programming new remote...
- Time to replace CV joint ?
- Anyone wants to trade 03 stock rims for 04 stock rims?
- Home depot grill mod. You want to see my what!!
- hi-flow catalytic converter
- OEM Electrical System Upgrade II of II: BIG THREE, Grounding Kit Big Brother (HOW-TO)
- 300ZX TT Brakes on...thoughts, comments, and pics
- '01 Maxima GXE rear suspension problem?
- Do i need to gap NGK Copper spark plugs?
- Best Intake
- Clear to black 00-01 tails?
- thoughts on these coilovers????
- 2000 Max "Service Engine" Question
- The Prospect of a Starter goin bad
- Beware Of The Nowhere Land Gas Stations
- P0720 Output Speed Sensor Malfunction happen 2 u?
- Abs
- OEM Electrical System Upgrade I of II: OEM Ground Wire Upgrade (HOW-TO)
- Jacking point
- Headlights - eBay NOT Projectors
