PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Coilover install
  2. Miles to expect
  3. Timing advance
  4. 03 headlights fit straight into 01
  5. Door and boot cylinder lock
  6. replaced air filter with intake, now its bumpy
  7. Calipers 02 opinion
  8. NEW HELP!!! Please
  9. What car should I go with?
  10. 01 muffler delete
  11. 2k1 Engine in 2k Max EGR question/help
  12. 2000 maxima flywheel question
  13. H&R Springs Setup Advice
  14. Intermittent rattle in reverse.
  15. Squeaky sound
  16. Gear oil (help)
  17. Ride feels little bouncy
  18. P0400 found, please suggest
  19. 2003 Maxima only 58,000 kms - is it worth it?
  20. Wtf... replaced fuel pump..
  21. Flooded 00 maxima
  22. Light issues
  23. Whistling sound front right
  24. 5th gen Infiniti i30 cluster swap
  25. 5th gen Big Brake Kit upgrade Finished
  26. P0300 Code Random Misfire Detected
  27. To buy or not to buy - 2001 AE No Crank - Advice needed
  28. Different Codes----Different day ?
  29. Advice on what to ask for my 2000 Infiniti?
  30. Junkyard or Dealer?? New OEM Steering wheel.....
  31. will 3rd generation seats bolt into 5.5 generation???
  32. Check engine light on
  33. 5th gen BBK (Big Brake Kit) upgrade
  34. POWA COATING!!!!5TH Gen BBK(BIG Brake Kit)
  35. Speakers wont work?!
  36. The 4AT....
  37. engine swap instructions
  38. Brutal Winter
  39. Smoked headlights...
  40. Please Help diagnose this...p1574, c1109 ?
  41. 02 Sensor - Bank 2, Sensor 1: Can I do it myself?
  42. if I hit bumps I go into limp mode
  43. Do you warm up your car ?
  44. Replaced Engine
  45. Coil #5 REPLACEMENT HELP!!!!!
  46. Need help ASAP. Car jerks, jumps and hesitates
  47. Can someone ID this wire harness?
  48. 2000 Maxima EGR Solenoid
  49. Looking for feedback from Rattle Can painters about long term paint results
  50. AEM filter #
  51. 01 I30 with serious issues, Good deal or run?
  52. Anyone do a 5 speed swap to an 01 max electric question
  53. Having starting issues...
  54. Vents! No cool air, just HOT, what's the problem?
  55. 2003 misfire after replacing heater core
  56. Air filter
  57. considering BRM exhaust
  58. 2000 Maxima Engine swap Help
  59. Ecu
  60. Parking Brake Sticking
  61. how crap are these?
  62. dimming interior lights
  63. 2003 Maxima bogging @ 4000-5000rpm
  64. Custom intake questions
  65. quick question
  66. isn't throwing a code!!! whyyyy
  67. Need help valve body question
  68. want advice on double din install
  69. Car totalled by insurance
  70. question regarding 02 ecu
  71. My car shut off
  72. Modify a Nismo intake for 6th gen Max's to work in a 5.5?
  73. Need help passing Emissions!
  74. Wheel is trashed anyone else?
  75. Modded 02 MAx
  76. Bouncy Ride
  77. Car wont start
  78. P1167 code
  79. Exhaust flow....
  80. Need HELP finding INPUT SHAFT BEARING
  81. Aftermarket resonator opinion
  82. Oil leak Cant tell if its tranny or motor oil
  83. Will a 7th gen rearview mirror fit?
  84. Which COIL to replace??
  85. throws into limp with no codes
  86. 02 Auto Climate Damper Positions
  87. 2001 Maxima Fog Lights cover gone...
  88. flywheels (jwt,competition,fidanza)
  89. Rear Strut Tower Bar?
  90. Maxima has been sitting for 2 years.
  91. Battery dies when parked 2 days
  92. Will a bad mass air sensor prevent car from starting?
  93. Sticking Accelerator
  94. Just alternator issue?
  95. Please help! Charging/wiring issue?
  96. Turbo w/ HD2 Transgo Auto
  97. P1612 advice needed
  98. 2000 Maxima Belt Question
  99. tiny cracks in camshaft sensor
  100. P0000 code
  101. 3.5 Manifold on 3.0 question
  102. Remote starter help
  103. hella Horns
  104. Squealing belt only at startup
  105. New struts seem odd
  106. parts question- cv axle
  107. 2002 Maxima Shock Sensor ?????
  108. Window module wiring 2003 maxima
  109. How can I test crank shaft connection
  110. Possibly a very dumb question, but...
  111. Check engine light on
  112. strange ticking sound
  113. 2002 Maxima: Passenger Headlight Bulb Out
  114. 2015 5th/5.5 Gen Picture Thread
  115. What needs to be done?
  116. cold natured
  117. New Shoes soon
  118. 87.5% Throttle
  119. Auto passenger window
  120. Climate control
  121. OEM or advance auto crankshaft sensor
  122. 6 speed will not engage clutch
  123. Clutch Pedal Assembly
  124. Power Steering Hose Leak 497172Y900
  125. Sincethe 3.5 has more hp does it burn more gas?
  126. Daylight bulbs
  127. High miles
  128. Need Some Help - Crank Pulley
  129. Caliber rattle
  130. Blower issue not resolved...
  131. Oil change
  132. Valve cover leak - will switching oil help?
  133. Car wash killed MAF help!!!
  134. Odd steering wheel question....
  135. 2003 maxima
  136. 2003 Maxima Coolant Leak
  137. Question!!!! For All!!!!
  138. G35 rims
  139. Possible TCS error
  140. cleaning headlight switch contacts
  141. Manual transmission fluid.
  142. 2001 Maxima brake light switch pin connection
  143. When to replace the water pump?
  144. 02 maxima- fuel pump notpumping fuel after replacement
  145. 5th gen maxima with honda 96 lip
  146. P0300 Help, checks done...
  147. 6th gen 2005 big brake kit upgrade
  148. 03 maxima 6 spd differential problem?
  149. BELT SQUEALLLLL - It's so embarrasing
  150. 03 Maxima Please Help
  151. Only p1320 code help!!
  152. FuelTech management systems
  153. Headlight/Brights Beam pattern issue OEM HID
  154. 2003 Maxima on security lockout?
  155. 2002 Nissan Maxima SE axle question
  156. My Story
  157. Anyone got lowering springs on their 5th Gen?
  158. ALL aluminum radiator?
  159. big problems with gen 5 wont start
  160. Maxima exhaust opinon
  161. G35 rims
  162. Enhancing the performance of my 03 Max and adressing its issues.
  163. building a faster max
  164. Honest opinion of value
  165. Anybody catch the Nissan super bowl commercial?
  166. Tokico Blue Part numbers for 5.5 gen?
  167. Max Snowday drifting aftermath
  168. 6th gen brake upgrade.
  169. What are some good exhaust systems?
  170. 2000 Maxima SE - Tune-up/repairs suggestions? advice?
  171. Performance Suggestions..... Nothing TOO BIG
  172. ABS sensor?
  173. Any one else still not get the Takata airbag recall done?
  174. Gutting Cats
  175. Exhaust advice, opinions, and/or help
  176. Molex plug for 2000 Infiniti I30 power window
  177. codes
  178. Dealership or Can this be store bought???
  179. Exhaust!!!!# go vroom
  180. U want codes??? I don't want them
  181. DAMN Engine code P0705
  182. Cd changer install
  183. LED Exterior bulbs
  184. I got a question for the 03 maxima...
  185. Blower Motor ??, dosent seem exactly the issue
  186. Please help 02 maxima overheating before even turning car on after sitting over night
  187. Cold start dies after 2 tries and started
  188. Suspension or steering Experts: With Video (knocking)
  189. Does this look like a radiator leak?
  190. Projector Set-up decision
  191. 2003 SE auto will not shift into 4th gear
  192. p0221
  193. Tranmisson noise
  194. 2002 maxima SE potential owner
  195. 03 auto transmission issue
  196. P1456 vanishes when freezing
  197. I want to put nos in my car but idk the things ii need help please
  198. Where can I find this part of a 2000 Nissan Maxima GLE
  199. Headlight Relay (2k2)
  200. Stuck in first gear auto.
  201. Oil consumption-What have you guys done to...
  202. 2003 6 spd idle issue.
  203. Help!!
  204. car hard to keep running
  205. When to Fix timing chain Issue
  206. High idle at start up and Drive?
  207. 2k vs 2k2 bose
  208. Car hesitates at weird times
  209. Maxima on Jalopnik again
  210. Change bulbs in the heater/ac and the shifter
  211. 02 maxima windows dont work/automatic headlights and rear defrost neither...
  212. Clicking from new rear brakes. Stops when brake pedal is engaged.
  213. Fidanza flywheel+exedy stage 1 clutch kit
  214. Rack and pinion
  215. knock?
  216. struts and coils NEEDED
  217. Odd starting issue when car is warm
  218. Alternator, Axle seal Leak, Hub Assembly Advice
  219. please help a lady out alternator trouble
  220. Power Issue
  221. hlsd vs vlsd
  222. lost keys
  223. Strange sound
  224. 2003 maxima electric issue pls help!
  225. 5th Gen Issues to Look For
  226. Fix or sell wrecked maxima
  227. 2000 maxima se a/t speed sensor
  228. 2000 3.0 Valve Cover Gaskets
  229. Sensor location?
  230. 2002 had issue shifting in and out of Reverse?
  231. JDM 350 (Fairlady) Z steering wheel thoughts? (..airbag.. >_<)
  232. I Own A 2000 Nissan Maxima SE
  233. Pothole really hurt my car, damn winter season!
  234. cv axle seal issue..
  235. Need some help with p1335 and p1336 crank positioning sensor codes
  236. Anybody ever use stp fuel system cleaner ?
  237. HVAC question fresh air vent
  238. if a VQ35de has been sitting for at least ~5+ years, my next step?
  239. 5th gen transmission advice
  240. P0110 Intake Air Temp Sensor?
  241. Parking brake question with pictures
  242. Knock after grounding kit install?
  243. Coils?
  244. How to replace Transmission Control Solenoids 5th Gen
  245. What tool should i use?
  246. 5TH GEN HIDs????
  247. 5TH GEN LED Lights??? Nah Stock plz
  248. Back brakes
  249. Part # for reverse light switch? Help!
  250. Prioritizing Repairs
