- BBMAF or LRMAF and tuning question?
- Umnitza angel eye help.
- Gutted pre cats?
- Dealer failed to solve this , Please help me
- air filter options
- Angel Eyes 2000 maxima?
- Front Wheel Bearings What Brand?
- bad ball joint?? plzz help
- Srry for doing this custom maxima...
- What are the best looking fog light bulbs out there?
- Good to be here
- Front PreCat is Gone
- 7th gen vq in a 5.5?
- Ugliest thing in the engine compartment
- oil overfilled by kwicklube now check engine light on
- Insulating Fuel Lines
- 2000-03 Maxima GLE parts
- Lights turn on only with key turned to "on"
- HELP FIXING WATER-NECK PLZ
- My .02 suggestions on Alternator replacement
- 5th Gen: Behind the "Grille"
- SSIM
- anyone have ksport springs?
- Fix front bumper gap?
- Sentra 6spd transmission
- Exhaust rattle? I know its been beat to death
- Start up Issue
- Exhaust Options
- 02 sensor pinout
- How do I remove my fuel injectors and fuel rails?
- at check light flashed like 17 times
- Water Pump
- Men Lie Women Lie..Maxima's Don't
- Umnitza Orion v2 Wiring Install Help
- good strut kit for decent price?
- Alignment alright?
- I'm having some top end chatter...
- How to add turnsignals to miror
- P0505 SES...Replaced IAC Valve and still have it
- Catalytic Converter Help
- What is my Maxima worth?
- wheel wobble wtf
- Trading in the 00..... signing off
- ADMAN back from the grave...
- Hello, getting a 5.5 max
- 2000SE ABS Sensors
- Annoying rattle just under 2,000rpm...
- Screwy heater
- 6spd axle
- MIL Status After ECU Reset (How long before OK)
- On a 2001 SE auto stuck in first gear, what are the chances the trans is gone?
- Engine stand - Bolts to transmission area
- can the oem AE kit be painted?
- hidextra review
- Rough suspension? Time for new bushings
- Most agressive size/offset on S-techs
- POS!! 5 speed trannys!
- oem 5.5 navi swap out help
- grounding kits, are they worth the money?
- 3000k fog users...
- Ugh... Maintenance... looking for some opinions
- She's Toast!
- Possible Auto Heat/AC Control Unit Issue:
- tranny question
- I need your help
- any1 try the 350z lightweight pulleys?
- AC/Heat not working on low
- whos this?
- LED Tail light bulbs
- 2002 SE - P1147 and P139code...and cant fix !
- Change of Gauges Project
- Additional Suggestions on 200,000 mile maintenance
- Nitto Tire on Facebook, LIKE to win tires
- How is the Max's MPG calculated?
- Vq35 sitting for 8 years
- After eliminating the P0420 code, I now get P0134
- Maxima lost it's spot in the garage
- Replacing a Post-car o2 sensor with a 4 wire unit!
- Which sensor to change ?
- Mechanic
- Clutch master cylinder
- Where is the crank position sensor?
- My little diy on making my reverse HID bulbs
- someone i know is selling a 2003 TE 6 speed with 23k miles ... should i buy?
- How to get some low end power?
- Front Hub Questions,
- Bumper Cover difference
- tire reccomendations
- PAS/DRV LOCK/UNLOCK, DRV Side Window Switch Problems,Need Help!!
- digital mph stuck in the rpm section of the cluster
- 350Z clutch and pressure plate with 2003 Maxima
- Radiator is weeping just a bit...
- When adding or changing oil, have you ever noticed...
- SSIM (pics), AFR.. whole smorgashboard
- Tein SS Coilovers (where to buy, what to buy, etc.)
- Guage Cluster Removal
- Replace driver side axle on 6MT
- MT Newbie; 5th, 6th and R won't go into gear. Halp!
- Where to get Thermistor (IAT sensor)
- Talk to me about low and midrange power...
- Button on the cup holder lid is broken. Lid stays open. OEM part / fix available?
- Will these foglights work as OEM replacements?
- annoying sqeaking
- Getting analytical about the VQ35DE (2003 Maxima) oil burning problem please...
- Help with re-attaching the "Econ" button
- Would you rock 5mm spacers with no extended studs?
- How rare is this 02 Max SE?
- Back-up(reverse) lights don't work , code P1706
- Front end steering noise.
- air suspension
- connecters under seats?
- Altima 3.5 in a 5.5
- On a whim, had local dealership run my VIN
- Anyone use Urethane exhaust hangers
- Engine oil pan rusted...
- Increase steering response?
- GT-R Steering Wheel Swap?
- Cabin Filter Question
- Odd noise coming from engine...WTF?
- Anti Rattle Springs/Pins
- sonar headlights jm auto racing
- Who has the 1-second rattle in their VQ?
- Cold Outside, Rough Engine
- Power declining by the day?! Weirdest problem I've ever had!
- Stupidity codes
- ES motor mount pics/specs?
- Hi-flow cat worth it?
- Ever use one of these?
- Remote won't open trunk
- Side mirror quick question
- Left side of gauge cluster dim
- Looking for new 2002 MAF
- Ob2 not reading..? fuze>?
- Will these work
- Yay! rear door stuck shut
- 02 Sensor code?? Confused
- How to tap reverse light switch?
- Replace Ground Cable?
- Help! Mt AC clutch/pulley went out need a new one!
- trunk board
- Changing Auto motor mts OEM to ES..... WTF???
- Maxima OEM wheels/polished?
- urgent advice from you guys
- Another ebay supercharger thread
- Weird problems.....
- code reset?
- Upper Oil Pan or RMS?
- 5.5 HID
- Engine noise.
- How much power increase when doing full exhaust?
- ABS issue
- Rough idle with A/C on
- 01 Friggin motor mounts
- Tape error message with cassette adapter - Bose TAPE ERR. Any workaround?
- Help plz!
- I dont mean to beat a dead horese, but.....
- Change color of Odometer?
- Dad removed the rear ABS sensor for later repair?
- Reported attack site?
- Suspension feels soft?
- speedometer going apesh*t (not working)!!!
- Changing MT gear lube
- Man, when it rains, it pours.....
- 6MT Axles these days?
- Part Swap Idea?
- Axle issues after replacement
- stripped o2 sensor
- Thoughts on installing or custom fabricating a a Neutral Switch on manual
- 4th or 5th gen?
- DNA coilovers?
- P0138 & P0139 Quick question!
- Procedure to replace 2K Max pre-cats.
- IVT Control Solenoid (P0021) - Testable?
- Rattle
- exhaust system clanging underneath - any ways to secure other than hangers?
- rear abs sensors - are they the same on each side?
- A couple of 5th Gen questions
- Steering Wheel Hard
- Stillen RSB brackets - anyway to make or buy them?
- Redline Goods door inserts interest thread
- help motor swap
- 100k miles
- need some advice
- How hard is it to steal a Maxima?
- Has anyone tryed rtv silicone on intake
- Map LED bulb #?
- sidemarker harness help
- ksports coil overs
- What do you do about your rusty/corroded fuel filler opening?
- FINALLY!! Custom Itouch in ashtray and Garmin in vent cluster pics+video
- Noise when releasing clutch
- 5th gen L.E.D mirror covers
- Squeaking from rear end
- 5.5gen impressions after 10 days
- '02/'03 17" GLE wheels vs 17" SE wheels - difference in offset, width, weight?
- Hitachi Reman Alternator from Parts Geek ... any good?
- Looks Like Im Joining The MD/DC/VA Crew
- Mass airflow sensor
- ebay projector/retrofit
- Brake Pad Installation Woes
- This Pioneer good price?
- Anyone install ADD Gauges? (01 Max)
- Intake supercharger?
- Navigation ver 5.1 vs. ver 5.4
- battery or starter?
- racing seats?
- Shopping for a new alternator
- Is there a CAI or WAI that...
- Air intake mistake
- 295 hp & 272 torque..no FI ..i call BS
- Removing my EVAP System in it's entirety...
- AFR in regards to CAI and ECU
- Trying to Keep Max in the Family...
- Are they HID in fogs??
- 02 6 speed - seems smoother when cold.
- ANyone upgrade their horn?
- Problems after VB install.
- Retrofitting
- I was stuck in Richmond for two days and my car is still there.
- 2002 air leaks/hiss through rear doors
- flex pipe help
- To CARB or Not to CARB (P0420)
- front strut mounts!
- A real 0-100mph Thread.
- Now I've got the INFAMOUS P0505 Code:
- Hydraulic clutch question...
- WRONG MPG?!
- How should I go about removing a stripped bolt with no space for vice grips?
- Windshield washer nozzles~
- Estimated Half shaft replacement cost
- finally installed jwt flywheel now starter issue
- Voghtland Sport Suspension Kit
- new [[PICS]]
- Lost 4mpg after cleaning TB
- How to know if I need a new Knock Sensor??!
- Most Recent Project: Grill
- MAF Question
- Chirping sound coming from engine ...
- Grill Customization Options
- Marble sounding clutch
- aftermarket headlights bulb socket problem
- Bumper cover replacement difficulty?
- Radiator Hoses
- Weird problem.... what could it be??
- Gas backing up out of tank....
- Leaking oil after hitting curb.
- Hamburger on engine cover
- Tire Review RIKEN ZR 18 inch
- Anyone have tis strut problem?
