- I'm tired of the CEL, now I'll take it to a Nissan dealer
- headers install?
- what kind of pads fit these wilwood calipers?
- help with custom headlight zenon conversion..
- New cold air intake
- Carbon Fiber and Stillen
- Sensor Name
- Alright, a list of what needs fixing...
- Diagnostic code reader shows "NO LINK"
- Alignment question after drop
- lowered maxima. alignment?
- Need some help please
- AE Auto Tranny Pedals for a 5.5 gen Auto
- Why is my maxima so slow!
- OBx v2 headers-testpipe-magnaflow res-megan muffler
- 2000 max accelerates by itself.
- P1320 Lives! NOOOOO
- Strange Electrical Problem...
- plz help! '00 I30/Max won't start. No codes. no prior problems.
- My 6spd swap and suspension/perfomance upgrade finally started:D
- 3.5 Compression Test = Issues, please step in
- Looking at 5.5 gens
- Lack of power caused by oil leak?
- exhaust clip
- Outside Mirrors
- Clearance Issue, help?
- Mystery Rattle - not the precats
- Both fans stay on
- Wheel hub bore
- Squeak/Squeal/Tick from Drivers Front.
- P0152 caused by timing advance?
- Has Burning of Oil issue resolved on newer VQ engines?
- To Scoop...or not to Scoop ?
- Help Please
- PO720
- Trans Issue
- Random ABS Light...What to Check?
- Transmission or Flywheel slipping?
- half throttle first - second HARD shift
- How many of you have ditched this brace?
- .ORG, I need you ASAP. 03- P1610 NATS Malfunction
- Stopped accelerating all of a sudden
- p1130 someone offer advice...pic inside(not pretty)
- Weird Reverse Noise
- Weird acceleration pickup problem
- extended redline with stock injecters? ur not getting all the powerr!
- How to keep the Pop-Charger from falling off?
- Price opinions?
- Bose upgrade ?'s
- Replacing Blower Motor 2002 Maxima
- Method for debadging 02/03 trunk burger?
- BOSE and Climate Control
- Wow ... this is different ...
- QUESTION: HEADER INSTALLATION powdercoat/warp
- Weird Rattle
- Strange issue with my rear window.
- LED Signals... In process
- How many hours to replace 4 struts/springs?
- Hard Starting and Crankshaft Sensor: A new lesson learned
- Factory remote auto window drop
- Bc coilovers--A journey
- Amazon motor mounts
- Engine makes helicopter like sound in Drive
- HOW TO: Install rear spoiler on 2k GLE
- coilover conversion kit?
- LED Sidemarkers>> TunerMax style
- Chapel Hill NC, 876miles
- Are our o2 sensors wideband or narrow?
- Need Some Wheel Bearing/Ball Joint Advice
- Clutch won't spring back
- My Max made me bald!
- Video(gutted pre cats) Cattman 3"
- Belts
- About had it up to here wit Calipers
- Front Strut Mount: MOOG
- Huge problems
- Reducing heat soak in summer time - DEI cool tape
- Need a new Rear bumper cover
- 350z header questions.....turbo build in the future.
- Can't get rid of shimmy
- What are the rubber seals under the hood called?
- start/dies, unplugged this hose, fixed problem....help
- Loud Whining, Anyone?
- Need Engine advice
- Nwp spacer feedback
- Opinions needed please: spring/strut
- Gutting your pre cats
- Tein ss coilovers-- A few questions
- Drive belts...
- BOP ideal ....for more hp
- 2002 Navigation CD-ROM Broke : (
- XXR 526 JUST CAME IN!!!! 18X10.5 ALL AROUND
- Should I use a Monsterflow filter?
- Suspension upgrade fail!
- One Brake Light Not Working
- throttle body spacer
- Altering brake pedal for heel-and-toe
- precat rattle?
- Are all 5th gen lower control arms the same?
- Next "BIG" 5th gen Grounding Upgrade:
- purchasing tein ss coil overs
- Both Low Beams Stopped Working
- Not sure if its time for a new Trans?
- Sooooo......Any of ya'll go to Import Alliance?
- Help after nwp spacer install
- Maxima Hit, Maxima Hit...Pics Also
- Leak Down Test Results and Questions
- neverending coolant leak battle!
- Is there a safe+effective way to make clutch engaging point a bit higher on 2k2 6spd?
- Shifter Button Won't Depress (Not the brake switch!)
- Aftermarket stereo help
- Urgent: 5.5 won't start, security light on solid.
- Starting Problem: How to determine which sensor
- Soft clunk over small bump: Front Strut Top Hat Nut loose?
- Bumper and trunk question
- will a cat back from a 99 max fit on an 02?
- Side Marker Upgrade under $10 :)
- NWP spacers install help
- Removing ECU
- 2 o2 sensors to one...
- Diagnosis and solution of P0420, please step in - video inside
- How to remove factory stereo
- Help with exhaust manifold leak (ebay headers )
- How long does it take to reset check engine codes?
- Maintenance thats been put off for a longgg time
- Anyone do their own paint and body work?
- I need 2000 maxima ignition coil wiring harness???
- mileage screen busted
- How stiff should new struts be out of the box?
- Weird electrical problem with sunroof?
- 150k + miles, need to replace suspension any suggestions?
- Exhaust sound ?. No-not what you think.!
- Battery Recommendation
- Ran over a car battery, WTF!!??
- QUESTION: PO430 CODE = OBX HEADERS
- Good source for used 5-speed tranny?
- A bunch of problems need alot of help please
- Brm 3'', 2.50 and 2.25 now available
- 100,000 plug replacement time
- Ignition Coil Replacement for the 2nd time!!!
- How to turn flywheel to see if they are missing teeth
- 200 i30 Rear Catalytic Converter 93230 questions !
- 2000 GXE HVAC - lost all fan speeds except high... solutions?
- Tokico Illuminas
- Making sure I get all the parts I can
- Code Scanner.
- FINALLY, I have six matching spark plugs.
- Is it possible to pass NY state inspection Emissions with EVAP system NOT READY?
- HELP! Car won't backup/drive forward after CV Axle Replacement
- power locks and sunroof
- Ebay 00-03 Tail Lights
- Exhaust question
- wheel bearing durability
- SRI Aggrevation!!
- Renewing the steering feeling
- Overheating problem! stumpped
- HELP!!! Opening 02-03 fog lights
- IACV? dies after start, unplugged hose and it works
- Race gas:do or don't
- Oil in intake manifold
- Armor All on your mags?
- rear brake help needed?
- positive cable for battery
- I need Long stud lug nuts???? anyone???
- Cold Air Intake
- P0172, P0720 (CEL)
- Quick Question: How do you differentiate between a pre-cat's rattle and a heat-shield
- Engine swap advice needed
- Looking at a 5.5 gen 6spd: Need some help
- 2k maxima shifting behavior seems odd
- Preignition is gone!
- Cheap Nav Double DIN HU vs. Reputable
- Tire Problems
- Hotshot Headers! Help
- AC compressor help
- ? on small mods and expected gains.
- P0057+P1456 is gone but now P0420+P0456
- Reasonable Price
- 2001 AE tires
- 3.0 motor mount question.
- 03 maxima cluster question
- 02 - Low Oil Pressure @ Idle
- Another chance for gauge ring GD
- Climate Control Color/ Hazard LED?
- Noise from engine, thaughts?
- Turnsignal Issue
- A little update
- So this is a question I have as I am looking at getting an A33a. regarding suspension
- Which Oil to Use?
- Help my maxima wont start
- Need Help 02 Max Overheating
- Rough starting
- Clutch Burned out need epinions
- How to remove painted cap off a side view mirror
- Anyone running Eibachs on OEM struts?
- Noise when turining crank
- twin turbo 5th gen ?
- Clunking when Turning
- Can I install tint without a window working?
- Ebay Headers?
- LED Brake light install - Possible ?
- starting problems
- Energy Suspension Bushings
- People with 5.5 gen 6 speed please your opinion ...
- Conversion
- 02-03 Auto tranny wont shift past 2nd gear
- If anyone is interested the Aluminum Gauge ring GD ends July 4th 2011
- manual tranny won't shift into first gear
- 5.5 head lights part #
- In need of a FSM for 03
- Dealers giving me different part numbers!!
- loose butterfly valve screw
- Special Delivery from Megan Racing
- Motor swap and headers
- How many different colors
- Cutting bump stop KYB Gr2 + Eibach spring
- speedo not working properly
- 245/40-18? Look good?
- P1456 Small leak - smoke test?
- MAP numbers vs MAF numbers
- cheap hid kits
- My car has a black eye....
- Gonna be back at it again...
- Annoying Squeal When Turning
- Bad luck continues: Symptoms of a bad master cylinder?
- Front end vibration hunt
- Rear Motor Mount
- DEK Knock Sensor Question
- Throttle body gasket pn#
- Custom Y-pipe size?
- can p1100 be caused by the camshaft sensors?
- control arm bushings
- DEK's, whats the highest MPG you've gotten?
- Well its My turn (Engine Problem)
- Failing Coil Packs?
- Have any of you driven a 6th gen? How different is the clutch+engine?
- OEM Sway Bar thickness
- Cluster bulb holder issue
- 2002 Maxima Retrofitting
- I just have a quick question about a window motor on my maima
- Pics of the new drop
- Stock Intake Hose - '01 Maxima?
- 02-03 bose harness picture
- Rattling Driving me Crazyyyyyyyyyyyyyyyyy
- HVAC Replacement White LED - Part #'s - Pictures
- VQ35 OE Y-Pipe Removal PITA Factor
- Bank 2 Sensor 2 Part number for Bosch
- Crank/No Start - 2001 Maxima
- LED tail signal install - fail so far.
- Wireless OBD2 and Torque app for Android?
