- Retractable winshield sunshade
- vent visor tint dark or light??
- clear plastic type film on stock 02 SE Rims?
- old school emblems
- Tranny/Valve Body...I need advice
- WTB-5.5 Gen 6 Speed Motor Mounts
- Problem with Stock Alarm!!!???
- Well i guess where moving to 18's!!!!
- Pulls right when Accelerating, Left when braking
- Couple questions for experts and oil consumption victims
- Need rim opinions..
- To 18" SE-R users : What size tires ?
- 2000 with High Mileage
- Windows Mysteriously Open
- 100 or 110 amp alternator?
- Front end crash!
- 3.0L Oil in intake manifold?? HELP!?
- 3.0 intake on 3.5
- uneven drop wtf??
- 5.5gen e-bay fogs
- CRUNCH! ... No 3rd gear...
- Pulls hard to the right when accelerating partial throttle
- Painted my center console
- Clear Spoiler Lense!
- Ok i been buzy but finally got all of it done :)
- BC racing coilovers for maxima 00-03 new
- Changing intake manifold upper gasket on 5th gen
- possible to un-smoke my head lights?
- will 4thgen suspension and exhaust fit 5thgen?
- Painted Fogs?
- clicking noise after suspension swap
- Coil/ECU problem
- not engine swap, engine replace
- Wow these numbers are a bit surprising
- removing stereo with nav
- Ignition Coil Harness Connector Part Number
- !!!Found our 3-4K hesitation!!!
- Canuck Motorsports Springs - CMS - anyone on them? any pics?
- Park/Neutral position switch trouble code - P1706
- power steering fluid
- should i let my maxima go??
- Greddy vs. Megan Catback
- Steering Wheel Lock
- Soooo...someone explain this to me..
- msr 045 rims?
- anyone here bypass bose amp manually? what pins on harness to use?
- Does anybody have ebay LED tail lights on their max?
- 00 Max, rough start issues
- R-Tec 3" MAF aluminum adapter - Cheap alternative for custom intakes (pictures)...
- Intake cut ac line
- 5.5 gen BOSE AUX input
- Headers and Y-pipe from Custommaxima.com
- 2001 se trailing arm bushings
- Confirmation of a bad steering rack?
- Sound or performance?
- g35C rims on a 5th gen
- SE to GLE Tire Size
- Starts like timing is off
- Rpms to speed
- What kind of bulbs does the 02 Max use on FOGLIGHTS?
- Windows Up w/ Remote?
- Good Deal????? or nah???
- WEIRD EBAY MAXIMA FRONT BUMPER LOL
- Modifying 4th gen struts to fit 5th gen? Anyone do it?
- Better response after tightening the pedal? WTF?!
- Click sound when I brake
- Repair Radiator worth it?
- Slight vibration in steering wheel
- looking to join a club in ny
- 2000 Maxima Headlight Mod
- spring isolator
- Knock Sensor Issue
- NEED SOME HELP WITH LIP
- Finally installed my Ralco RZ lightened pulley! (Pictures)
- Cheap/easy 75MM ID aluminum maf adapter
- yellow fog
- Bush Link Pin Nut
- Ecu Question
- swapping gauge clusters
- Alignment Necessary after strut replacement?
- HID not working
- what could be causing this??
- Hope to put an end to oil consumption
- 2000 automatic differential question
- FLEX PIPE BUY
- HELP-- SES (I Read all the old posts and instructions)
- alternator fitment question
- Coilovers just not participating...
- Please help. car Entry problem!!
- Fog Light Bulb Replace w/pics
- custom CNC'd camber/caster plates
- Throttle cable
- Replaced Cabin filter
- Need website to buy manual mounts
- Front door speaker mounting depth
- 00 I30=4th Gen Y pipe? HELP!!!
- Outer CV boots are torn on both wheels, need advice...
- Hid Kit Install
- Is the spoiler removable?
- Cracked Radiator+Sprayed Coolant=?
- color code for icelandic pearl?
- 02 Max 6 Spd Shifter Options?
- What are the Maxima basics ?
- OK....so have any 5TH GEN (not 6th) hardwired their IPOD to the factory BOSE?
- G35 spoiler - To be or not to be?
- question about wheels...
- Photoshoot with the coilovers
- Installed turbo timer and can't find VSS signal...
- Bad News.
- Reason to not race a 5th gen on an oval track...
- The day has finally come ....
- wow not sure if its repost, but i think i saw this car somewhere in this forum...
- light options 03 max
- Good way to check coilover life?
- hid fogs
- 2000 Max - replaced starter, car still wouldn't start
- y-pipe questions
- Just Got a 5th Gen
- G-tech Performance Meter
- IAT/MAF connector:
- MAF sensor replacement!
- Auto AC control problem
- 2000 nissan maxima speed sensor location?
- So... this happened
- Crack in my OBX Headers
- hesitation in 3rd gr. dont flame
- Timing advance question
- 19 x 10" in the rear - Will they fit?
- NWP Spacers installed on 2001
- whats causing this oil leak? (pics)
- Gah!! Ignition coils are the work of the devil >:\
- i searched but nothing
- Replacing Cluster, odometer roll back?
- AUTOMATIC 2000 Maxima with MANUAL mounts?
- Changed water pump, fans on full speed
- HKS Sport Axle Back Users Come Here!
- Email from hidextra.com
- i want a nice sound
- engine rattle?
- cattman header y-pipe install?
- Cause of Vacuum leak?
- weird noise
- alternators?? wat year fits wats maxima
- Question: Climate control positive/negative
- high performance fan...
- NWP spacers
- Interior pillar removal
- Oh wow my rear fenders have gotten BAD. Need bodywork.
- AC, starter, alternator fail, 3 times in 6 months
- Timing Advance: ECU Reset
- ABS Sensor
- Hit a pothole: car shakes and pulls right
- Windows and POwer Lock Not Working!!!
- auto tranny leaking? pics inside..
- How to identify transmission model #?
- i was wondering Mass air flow question
- i need some quick direction
- Quick coilover question..
- help with diagnosis
- Clear coat peeling
- tranny filter issue
- experience of a lifetime
- 00-01 > 02-03 Ghetto Headlight Conversion?
- Running rough when cold, fine at temp, no SES
- headers?
- Vibration/Thumping (???) at low idle
- Confusing Experience with Service Shop
- Steering wheel Jerk
- To Let everyone know Bit sizes to removing airbag
- intake leak ?
- NEED PICS: 350z track rims
- tightening the Throttle cable
- Best way to spend ~$350-400?
- anyone ever ship rims or tires
- power loss?
- Leaking Rear Suspension Beam Bearing?
- On the De-K what hose is this and where does it connect?
- Please help, is it my clutch!?
- throttle body
- Tranny Stop Leak???
- 5.5 front engine mount
- P1168 after 02 sim install (dual sim)
- OBX headers without tune?
- new stage 1 clutch.
- WTB: 2002-2003 kinetix intake manifold or NWP Spacers and Block Plate
- 19x9.5 all around yaya
- Hid fogs are are giving me the WTF runaround
- NWP block plate + GAB sound/video clip
- will i rub if i slam the max?
- 3.5 VQ35DE!!
- I cant find the rattling in my car can you?
- 02 Foglights: Is there any bulbs matching the stock headlights?
- Found This, Anyone Need A Spoiler?
- Exhaust Question about Catback
- Front passenger side door "sticks"
- anyone heard of/ used these coilovers before?
- wiring question...need help please
- Stock Suspension Question
- front bumper cover install
- What size Torx, to take out an airbag ??
- Saggy Door Fix
- For those with EVAP codes...
- Check my video out n leave a comment
- SES LIGHT WON't EFFING GO AWAY!
- HELP!!! just drove into a deep puddle!
- Knock sensor location on a 5.5 gen???
- 5.5 Seats in to a 5th gen
- Engine Noise (audio included)
- Horn upgrade DIY
- I need some help with a suspension issue
- what had happened was...
- Write up on motor swap??
- Would you try this on your VQ engine?
- I am putting this on my car...
- ABS lights trace it to the ABS motor so what now?? help plz
- Y pipe or custom full exhaust from local shop?
- just replaced maf
- Exhaust is on!!!
- tie rod help
- n3985's review of carnal_c30's subframe collars
- Help!!! rear suspenion noise
- second o2 sim, Still not working with pics, Help ASAP!
- Tar on rims
- Should I sell my Max? Realistically speaking...
- Camshaft Sensor Removal
- Uh Oh. Broken Motor Mount or Axle?
- cleaning intake manifold, replacing head gasket and tranny issue
- 5.5th gen grille for 5th gen?
- Anyone Ever Tried to do This??
- no spark or fuel pressure
- $30 FSTB From Ebay - Any Good?
- Changed motor mount = no more vibration
- Exhaust problem can rev!!
- Quick Fidanza Flywheel Question
- 1990 FSM
- ebay headlight lense swap
- well another problem again...ugh
- Braking Power
- Black Housing??
- Anyone have pics of a sterling mist 5.5 with black headlights?
- Polishing stock exhaust tips (2002 SE)
- Car will not start while in Park
- G35 Wheels on 5.5
- Does it Fit? (Need help / advice)
- Fog re-wire w/ tails
- Clunk ClUnK ClUnk-Top hat?
- VQ35DE Vins
- GLE to Heated SE steering wheel
- G35 sport sedan springs.
