PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. 5th gen transmission advice
  2. P0110 Intake Air Temp Sensor?
  3. Parking brake question with pictures
  4. Knock after grounding kit install?
  5. Coils?
  6. How to replace Transmission Control Solenoids 5th Gen
  7. What tool should i use?
  8. 5TH GEN HIDs????
  9. 5TH GEN LED Lights??? Nah Stock plz
  10. Back brakes
  11. Part # for reverse light switch? Help!
  12. Prioritizing Repairs
  13. Dash lights up,won't turn on
  14. Hoen H3 replacement (Nokya)
  15. Life of a clutch
  16. Pioneer FH-X720BT Bluetooth CD Player
  17. Scuffed Rims-Are they fixable?
  18. Engine Swap
  19. Replacing your 5th Gen
  20. Crankshaft pulley replacement - has anybody done this job themself?
  21. How much is too much?
  22. Another thread about a flashing Airbag light (Codes Posted)
  23. Headers or nah??????
  24. ECM Bad or good?
  25. Altima transmission compatibility
  26. Rear 02 sensor stripped
  27. rough idle, bucks at low RPM when cold
  28. Rear struts
  29. 2000 Maxima In need of serious HELP
  30. I'm having trouble with my nissan maxima idle air control motor
  31. 5th gen engine probs
  32. Recent 2000 Max upgrades
  33. Recommended Headlight Replacement
  34. 02 Maxima Battery Charging
  35. How to Install an Alarm/ Remote Start/ Keyless Entry
  36. Car starts up and then dies
  37. axle-back or catback?
  38. cross threaded bolts while replacing lower control arm
  39. Radiator support part??
  40. What kind of exshuast is good ?
  41. I finally put on my new muffler, pics inside.
  42. whats normal compression on a vq35? buying a used engine
  43. 2001 transmission question
  44. E brake issue
  45. Battery/Alternator problem
  46. tuebo
  47. 2001 Maxima Passegenger side HID light won't work
  48. Air box sleeve
  49. RockAuto Lower Control Arm for $53???
  50. The Valve Body's curse haunts my car :(
  51. Did I damage my transmission?
  52. FX100 clutch + fidanza flywheel
  53. Trying to decide between 00- maxima 3.0 or 02-03 3.5 engine, which is more reliable?
  54. radiator or heater hose leaking?
  55. Code p1491
  56. Broke down on my way to work!
  57. Transmission starts in second
  58. Negative Terminal Starts to Spark please help
  59. HKS rear section muffler?
  60. I used MerconV ATF, what did you use?
  61. VQ30de rear main
  62. Jack stand points?
  63. A/C experts step inside, I got a challenge 4U
  64. Need help-only one speaker plays
  65. vq30dek engine cover
  66. maxima struggles when cold or uphill, code 1130
  67. Stillen Rear Valence Muffler Clearance
  68. What The Heck, complete power loss
  69. Just bought a wrecked 2003 6spd, need some advise
  70. Problems starting up
  71. Weird clacking on start-up
  72. What tire size should I be using with these wheels?
  73. Rear Caliper Died - Only a year and bit old
  74. Hard starting in cold weather
  75. loose hose, wondering where it connect to? (Pic included)
  76. MAX ATF for 02 Maxima?
  77. p0134
  78. Happy new year! My alternator! :D
  79. Instrument Cluster Light Dimmer Part Number?
  80. Looking for headers
  81. Mass Air Flow Sensor & Y2K . . . ?
  82. Mass Air Flow Sensor----Cheap ?
  83. What wheel colors do you guys run?
  84. Plastic push rivets for splash guards
  85. From 6th to N and randomly dies.
  86. Save your VIAS...
  87. Brakes madness
  88. Saw the rustiest gen 5 ever!
  89. Passenger Side Mid-Woofer not working
  90. P1800 code help
  91. A/C Saga....my experiences in Wonder-Land?
  92. Engine overheating fluctuates
  93. 2000 Maxima idle
  94. Wheel fitment...again
  95. what a Merry Christmas p0430
  96. Tein Street Advance Coilovers
  97. Cruise Control Problems
  98. 2001 Nissan Maxima engine won't turn over without giving it gas, produces black smoke
  99. "What your Inside A/C Temp?"
  100. Trembling car
  101. 5th gen grounding kit install
  102. Weird Headlight Issue
  103. Odd rattle from suspension
  104. Delayed Transmission Shift
  105. New Compressor took a Dive.....(F~#k)
  106. 02 maxima gle with Bose
  107. Best Cold Air Intake?
  108. Quick Struts - - - Monroe ???
  109. 5.5 gen 6speed HLSD?
  110. Struts Frozen.......(wat da)?
  111. Transmission went kaput!!
  112. Engine shaking. checked most of stuff.
  113. Built-in Self Diagnosis ?
  114. Evaporator...where to Buy?
  115. 02 maxima best headers to buy
  116. Best roof rack?
  117. Windows phone obd app
  118. Coolant leak
  119. uncomfortable seat
  120. 2001 Maxima ECM Replacement
  121. Alternator 12mm post nut
  122. Cold weather makes car leak coolant
  123. 2000 maxima intake question
  124. cold start
  125. Cranks, but no start
  126. Thinking about buying headers!
  127. What's your Gas Mileage ?
  128. Fuel Injector Replacement Worth It?
  129. Clanking then no start
  130. Bluetooth for 2003 maxima Bose stereo
  131. loss of power in higher rpm's
  132. Cattman,The Man,The Legand. Back???
  133. Home Link Distance
  134. Quick misfire
  135. Aftermarket steering wheel!!!!!!!!
  136. Lowering Springs!!!!!!!!
  137. BURR!!!! best Cold air intake for 5th gen
  138. audio help
  139. help! new rotors/pads
  140. Should I change the oil now or wait?
  141. Idle issue
  142. control arm bushing question
  143. 2012 GTR wheels on 2002 Maxima
  144. Maxima 5th generation (specs)
  145. Back light stays on when car turns off
  146. 2001 maxima 20th anniversary for sale
  147. Performance Chip mod??
  148. Worth getting the fuel system serviced @ dealer?
  149. Car sits uneven after lowering
  150. Rear Brakes Grinding Noise
  151. Car wont accelerate
  152. Programming Key Fob
  153. Aftermarket Side view mirrors?
  154. 5th Gen Roof Racks
  155. 01 Maxima having trouble starting, please help!
  156. Struts and rotors
  157. terrible gas milage
  158. 2001 max AE problem
  159. 2002 engine noise when starting/stopping vehicle also at about 2k rpms
  160. New Front Bumper Cover
  161. New wipers - Recommendations?
  162. Airbag Sensor
  163. steering kit deals
  164. Replace DMF with clutch? + 350z clutch q's
  165. Possible Leaking Head Gasket
  166. Steering problem
  167. 2001 Maxima rear sway bar
  168. Bose tape deck error
  169. Beck/arnley thermostat-strange behavior
  170. Problem....with Starting ?
  171. MAF problem ? please help
  172. Exhaust manifold
  173. TCU swap and trans electircial probs?
  174. Temp problem
  175. Dimming Instrument panel/ Headlights
  176. Resurface my rotors?
  177. 13" rotor help
  178. Post your 0-60 videos
  179. HARD TO DIAGNOSE STARTING PROB SOME HELp please!
  180. Help -- Smelling burnt oil through hvac when stopped
  181. 00-01 & 02-03 bumper interchangeable
  182. Why does this car always pull up next to me and stare at me?
  183. Faulty IACV?
  184. Re-thinking replacing bose head unit
  185. BBK... options
  186. Airbox delete
  187. could i install a y pipe and delete my precats
  188. 2001 front struts
  189. Replace cracked front crossbars.
  190. Heater not working
  191. Koni Sport Shocks
  192. Valve cover gaskets
  193. OEM Alarm Issue
  194. I need help immediately
  195. 2000 nissan maxima
  196. Picture fail
  197. Blower broke the gearbox.....again.
  198. Center Console/trim removal
  199. Nice
  200. Right Side Speakers NOT WORKING? HELP!
  201. HLSD Oil Type, Weight and Additive
  202. Front wheel bearing w/o the usual symptoms
  203. 2002 Nissan Maxima P0022 Need Help!
  204. got me a fresh 25k badboy :D suggestions for maintenance replacement parts?
  205. Remote Starter Bypass Module
  206. Car still misfiring. A LOT tried so far
  207. what headers should I get vq30dek
  208. Vq30dek intake
  209. HELP! Cat converter won't separate from manifold
  210. What is this hose? (5.5gen)
  211. Damn exhaust bolt seized to all hell
  212. Why is my MPG so poor?
  213. Yellow paint/film in high beam 5.5 gen headlight?
  214. Desparate Need For Car; All Around Issues
  215. 2000 Maxima Engine Into a 2001
  216. Can someone point me to a good tutorial for resealing a timing cover?
  217. 2000-2001 taillights fit 2002-2003
  218. knock sensor
  219. Humming noise coming from fuel system after engine shut down
  220. Starter pack lol performance parts
  221. need advice on wheel hub/bearing. Are these any good?
  222. NEWBIE HELP where to buy parts for 5th Gen
  223. 00 Maxima coolant bubling out reservoir
  224. Aftermarket halo headlights
  225. how to return idle set screw to correct position?
  226. 2002 Max, 6 Speed, Slight Misfire Under Load
  227. help
  228. Engine Mount Help
  229. Oil on top of 5th plug
  230. Where is the EGR Valve located on 2000 Nissan Maxima?
  231. What do you guys think?
  232. battery terminal recall?
  233. obd2 0305 code HELP !!!!
  234. Replaced the trailing arm bushings and still have the chickens.
  235. Idle re-learn ANYtime TB is disconnected?
  236. I'm being tempted by a... Honda S2000
  237. Possible Blue Tooth Upgrade for Bose HU
  238. NWP Upgrades
  239. Body Work
  240. Heated seats blowing fuses
  241. Oil Pan using RTV vs Gasket?
  242. Correct 5th Gen AC Bypass Belt
  243. Access, test and replace instruement cluster dimmer switch
  244. My muffler is rattling back there...
  245. 2002 GLE 4-Speed Automatic problems
  246. Vq35 hks f-con
  247. Potential 5th Gen Maxima Buyer
  248. Seat heater pad replacement
  249. tirewear with g35 coupe 18 inch wheels on 5th gen????
  250. I Think I Need To Buy This, and rethink my whole game plan!3.0/DEK/hybrid guys please
