PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 [116] 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. stillen vs ae kit
  2. Turning PowerSlots...
  3. "custom" intake
  4. 2k1 se gauges with rings in 2k gle
  5. SeaFoam How-To....?
  6. 02 fog lamp replacements
  7. TSUDO Exhaust
  8. Switching Headlamp Relays
  9. Re: Injen Intake Replacement Filter
  10. Hood pins
  11. bad ignition coils?
  12. FWD to AWD conversion
  13. Electronic Damper Control
  14. Y-Pipe emissions
  15. I35 gauges in maxima Help
  16. What fuel pressure regulator do you use?
  17. should i cut bumpstops with maxsped and blues?
  18. SeaFoam Testimonial
  19. Can you make an intake for a 5th gen
  20. what is that scoop part?
  21. made a board for the trunk
  22. When do you replace your drive belt?
  23. 6 coils Scoped. Results inside
  24. CA vs Fed spec emissions for 02+
  25. Cloth vs Leather, is maxima leather good leather?
  26. maxspeeds and tokico blues
  27. egr valve thoughts
  28. www.hi-tecdesigns.com possible GD? Check this out..
  29. pcv valve pics anyone?
  30. Nissan Dealer vs Dealer vs Private party...which would you buy from?
  31. Hesitation 1-2 shift
  32. Info on European Maxima...
  33. is this rice
  34. help...rubber to metal squeek when wheel turned left
  35. Does this sound good? *Brake Pad + Rotor*
  36. Suspension sounds?
  37. Front Sway Bar
  38. Opinions on Black headlight housings...
  39. Options for side skirts?
  40. what size is the wipers side driver n pass
  41. Front Bumper Conversion?
  42. Squeaking noises from front passenger wheel well...
  43. Air Intake temperature Sensor
  44. fogs will not turn on
  45. Issue with Heated Seats
  46. where 2 get maxspeeds
  47. seat heater dowsn't work need help
  48. Hyperground installed...
  49. Generic P0300 random miss fire?
  50. Finally got my Max today!
  51. Possibly warped intake manifold question
  52. whats needed to install 2k2/3 headlights on a 2k max?
  53. A little vid testament to the Maxima Superiority!!
  54. ok, just did seafoam...a little worried..
  55. 2000 SE Coils Help
  56. Intake valve timing control bank 2........
  57. Which battery to get???
  58. Auto Climate Control Bulbs burned out.
  59. Bose unit CD player fix?
  60. blower fan... HELP
  61. Why is it always me?
  62. Oil Leak, Help!!!
  63. Want to lower car
  64. Help please...Wider in Rear? (I mean WHEELS, not my girl)
  65. Intake Question
  66. How many people bought "Nissan Certified Used?"
  67. Brake Problems...dont know if car is safe to drive
  68. VB mod question..For those who have done it.
  69. Tein EDFC + FSTB fitment issues?
  70. first new post - custom
  71. EGR Port: Question...
  72. Effects of using cheap, regular octane gas for 60k miles
  73. Extended Warranty ??
  74. what are some common oil leaks on the de-k that i should look for..
  75. Anyone install aftermarket heated seats?
  76. Heated OXY
  77. easier way to check ignition coils
  78. 2002 Brakes Feel Low
  79. So whats the weirdest thing thats ever been stuck on your maxima?
  80. Paradox Systems Cefiro Coilover System
  81. K&N filter part number for PR CAI: anybody have a part number handy?
  82. where is the tranny grounding pt. on a 2k?
  83. JDM style headlights and 01 SE wheels painted benz silver
  84. Aftermarket struts and stock springs
  85. Considering 02/03 Maxima but I have Reliability concerns...thoughts on this???
  86. opinion on suspension
  87. Splash Guards
  88. 5th Gen. related PC software
  89. fog light bulbs
  90. headlights decision
  91. Got my new 02 today!
  92. someone make us this rear window spoiler..please
  93. Twin Turbos on a 2000 maxima
  94. Random question....battery tie downs...
  95. Accident, what options for front lip?
  96. Which theory would be right?-Coil related??
  97. basic rims question
  98. CE Grounding Kit Install..
  99. Missing Foglight 02 SE
  100. Brake woes...(Brake pads)...opinions? (Akebono Vs. Hawk)
  101. Nissan aftermarket warranty???
  102. Info f-sale 03 se maxima
  103. Accident: SideSwipe Bumper
  104. car dying on highway...dash lights on
  105. Quick help needed 2001 AE
  106. Comments on this ODB-II scanner? Good/Bad?
  107. Finally about to install coilovers....
  108. Anyone lowered just in the front?
  109. need pics of engine bay fuses, starter relay
  110. Ah... the great suspension question.
  111. Factory Anti theft alarm going off on its own
  112. Wheel Width 2000 SE 17"
  113. blown tokico illumina?
  114. My Poor baby in an accident
  115. Seafoam saved $$$$
  116. thinking of buying another Maxima questions
  117. new wheels on TSW Thruxton's...check em out
  118. battery light goes on with start-up
  119. Please help with Parking Lights/Blinker Bulbs
  120. Interior Lights & Remote Control DEAD - what the heck?? help!
  121. 2000 Max ECU cyclinder map?
  122. Install instructions for IPOD in 5.5gen
  123. Removing the BOSE Headunit.
  124. Sunroof not opening (2002)
  125. throttle cable slack
  126. 2003 max / help please.
  127. cv boots
  128. Custom Enterprise High Flow Cat
  129. has anyone tried turning up the torque bolt on the side of the intake manifold????
  130. considering some changes............... ?
  131. Yes, its an opinions thread...
  132. Does everyone with an intake have SES light ?
  133. Does everyone with an intake have SES light ?
  134. Weird voltage problem, meter says at idle I'm at 15volts
  135. no cel codes and still this problem
  136. Opinion on rear H&R 20mm spacers
  137. technosquare L-Spec
  138. HID question
  139. anybody red-out front turn signals?
  140. Cattman Exhaust System
  141. Neoprene Mounts for Exhaust System
  142. absolutly no pick up
  143. How to regrease rear axle bearings?
  144. Engine Mount/Motor Mount Noise
  145. The Best Cams
  146. tranny queries.....
  147. Shift Kit
  148. BLUE BATMOBILE overlay kits..
  149. New to the 5th gens
  150. newbie questions
  151. Clear Side Marker Installation
  152. ABS dynamics front lip owners step in..
  153. How to for ebay projector w/ TSX lense?
  154. Automotive Paint
  155. Noob Questions
  156. PO175 code came up, what is it?
  157. Question after exhaust install.
  158. opinions on aluminum flywheel on a 3.5
  159. opinions on clutches for 6 speed
  160. Brake nightmare
  161. abs wire snaped
  162. HELP!!! Possible Cracked Head?
  163. ECU reflash for MAF
  164. So 2 months later and still no car
  165. can't see giving dealer $450 to replace
  166. Is this good deal for 03 Se?
  167. engine bay wash
  168. going to the dealer...question
  169. Pros & Cons
  170. Another Newbie ?
  171. Let me see your interior pics!!!56k no way
  172. Need help Guys-possible blown fuse
  173. code help!!!! PO740
  174. Which set up is better? Also Weekend Painting Project Completed (5 Pix included)
  175. seat heater issue
  176. Tranny
  177. front strut bar question
  178. Need More Performance!
  179. Bottom Front motor mount leaking - replacement?
  180. How are the options packaged on the 5.5 Gen?
  181. auto es motor mounts
  182. 20's yes or no?
  183. Header video
  184. 6spd swap
  185. VIAS question...
  186. sound clip of GAB
  187. question about my stock wheels
  188. HID Wiring Diagram (For 2K1 to 2K2 Swap) Needed!
  189. First Maxima Test Drive
  190. Just purchased an 02 SE. New to the 5th Gen family
  191. 5.5 gen, more reliable than the 4th gen?
  192. want to Change Foglight setup
  193. Question for those with 5mm wheel spacers in the front
  194. Swapping in a 3.5L
  195. nyone with H techs...any axel or other issues?
  196. 00 paint code ?
  197. Need help, Navi is not retaining is location settings
  198. Anybody here on the .org?
  199. how to prevent bolts from snapping off!?
  200. Rear clunking
  201. WTB headlight housings Both R and L
  202. What year was your Max manufactured?
  203. HOW TO: Fix Amber to Red Conversion Paint Leakage
  204. g35 18" wheels for 02 maxima
  205. So where is the thermal flasher located?
  206. AMBER TO RED CHROME TAIL CONVERSION PROBLEM: Immediate Help Needed!!!!! (Pics**)
  207. Determining which TSBs/recalls I need to do?
  208. Can anyone tell me part #'s for these interior parts? (pic inside)
  209. 00 Front Grille Photoshop **PICS** opinions needed
  210. A question about stock '03 Maxima wheels.
  211. NEW 01 for me
  212. Cleaning throttle body with Sea foam...
  213. something is clicking in throttle body area
  214. Nissan Emblem ?
  215. Should I have my VTC Sprocket Replaced
  216. Throw out bearing noise?
  217. Where To Buy A New Donut Spare Tire?
  218. energy suspension bushings
  219. Blower Motor Noise
  220. what to use on cv boots to keep from drying out?
  221. Dtc 0171
  222. 2001 max V1 wiring question
  223. BLACK projector headlights
  224. Need your advice on A/M headlights
  225. do i need a fuse on this line
  226. p0455 and p1448: FIXED.
  227. DIY Transmission replacement (11 pictures; 2.95mb)
  228. Considering getting a 5.5gen 6spd
  229. first impressins on my 4th suspension set up...
  230. POS RainEx wiper blades (do not buy!)
  231. Help: Car will not crank and start
  232. question to the masters of 5th gens..
  233. New to the 5. Gen
  234. who around jersey can do an advanced timing for me?
  235. Goodridge stainless brakelines model 22133 fit 2002?
  236. OPINIONS needed....keep new grill or leave stock?
  237. rims and acceleration
  238. Thumping Noise in Driveline problem
  239. Tranny harness?
  240. Question about my new HID low beam/mini-H3 kit
  241. where can I buy a clear brake light for my spoiler?
  242. How to properly lift car?
  243. P1320 and P0420 - Anyone had this combo?
  244. PICS NEEDED: Your 5th gen painted ABS lip & experience...
  245. Remote Starter Kit
  246. got my 2k2/2k3 headlights :)
  247. exhaust question > 4 u exhaust whores
  248. MacPherson Strut
  249. Natl Autocare warranty f@$#ed me over
  250. Headlight Plug
