- Clunking Noise in Undercarriage
- fuel door release?
- Dash Lights.. possibly alternator??
- E-brake is useless
- A few issues, please help!
- NEED HELP PLEASE!
- Help! Front and rear flashers causing havoc!
- Steering wheel pull/lock on reverse
- New Front Axles, Torn boots. What to do?
- Unique ABS SLIP TCS lights problem driving me nuts
- 2000 Fog Lights on a 2003?
- How to change engine mount and transmission mount?
- Going to take my 03 to the dragstrip
- In search of...
- Cold start (outside temp) and Gauge cluster problem. (Searched and no solution)
- Full custom Exhaust
- Ecu rebuild
- True CAI Saturday Project
- I need some Spoon feeding here...
- Best OEM muffler replacement?
- how to tell an oilburner
- iac block off plate
- Stalling, rough idle, RPM cap = MAF sensor?
- searching....
- CXJ vs NWP
- Car won't start need help PLEASE!!!
- Pulsating scrape with left turns....???
- Sputtering then dying problem. Help?!?
- tire size ntk asap!
- Some performance suggestions?
- Unknown rear suspension clunk
- CAI that works
- Tps and vias canister?
- Crank no start help!!!
- Who Makes Blue Springs for the 5th Gen?
- Rough Riding Maxima
- 5.5 Gen is running rich
- i♥mya33 decal design
- 17 or 18"
- No Power
- 2001 gle maintenance to get better gas mileage
- Exhaust help!
- 02 sensor question
- Clicking Noise with Jerky Throttle
- GAB with K&n filter or SRI
- Side Skirts Ghetto Problem (PICS)
- '02 Fuel Filter. Got pics? Got Part # ?
- My AC/Heating Works ONLY in "OFF" & 1-3 Positions...HELP!
- 6TH gen header installed
- Scantool For 2002 i35 In Brooklyn,ny area
- Transmission swap?
- rear lip
- 18" Wheels But No Drop
- Odometer Screen Replacment 2002
- Need HELP
- wheel bearing??? help!
- what the...
- Wideband not working?
- Cipher & ABS Question...'03 Max
- Ebay Cat-Back for B-Pipe?
- White smoke back of engine after water pump replacement PLEASE HELP!
- Car in fail safe mode
- 4 AT Guys, Worn Out Clutch Bands or VB?
- NEED HELP!
- Alternator? Battery? Or Something Else?
- newbie with questions
- Quick Question for the knowledgeable
- 00-01 Stillen kit on 03
- Cattman 3" catbacks in production - Call to get in on this batch!
- 01 Maxima rubbing noise..
- Amazing MPG......
- 2000 maxima vibration
- Towing with a 2000 Maxima
- What do I need to do to keep this from becoming cancer and killing my quarter panel?
- What kind of slicks or Drag radials do you use?
- Transmission Help
- VIAS silenoid
- $140 ? Are you kidding me?
- engine problems
- 5th gen noob with question
- Southpoint Nissan's crazy prices
- information Request, 2003 6mt Window Sticker....
- Who did the IAVC Bypass???
- Need pre catalytic converter selling advice...
- Bluetooth Hands Free + USA Spec
- BAD rattle coming from engine
- engine noises
- 2003 Maxima will not pass smog
- Thinking of buying an '02 MAX with 127k
- Seat motors
- door replacement
- Thumping under acceleration
- Stalls at Idle, Long Story
- pulley belt size
- will a 2004-07 CAI work on a 2002?
- Pulled this plug out of cylinder #2
- p0011 help needed
- maxima speedometer
- what is the nissan paint color of this car?
- ABS question.
- 2000 Manual Transmission fluid
- 5.5 Gen Keyless Remote advice
- bds1304's maxima body work thread
- what are some of the cool things you've discovered about your 5th gen?
- White Smoke, Whining and No CEL. Someone help please?
- can you help with tire fitting please ?
- 2001 MAF on 2002 question
- Lowering the Max-Your Spring/Strut choice
- angel lights
- my 2000 maxima wont start
- Exhaust work labor question
- VQ 40 Thermal Intake Spacers
- 02 infiniti i35 few questions
- need help
- really low car vibrates when accleration any help guys?
- Radiator capacity??
- 00-03 Body Kit in Ct
- Instrument Cluster Swap Problems
- Noob Questionl: How to disable parking light when arming/dis-arming alarm using
- Color paint?
- Idle problem with burnt gas smell, need help!
- p0430 and p0420
- 5th/6th Gen Lower Oil Pan Difference?
- Starter....
- Zax Nitrous TPS activation
- Coolant bypass on a 2000
- Am I losing it?
- Ebay 5.5 gen Front Bumper Cover
- Question
- 06 maxima bank 1 cat converter location?
- FS: (MD) D2 Coilovers $360shipped
- grinding noise while turning
- Oil pan seal going?
- Irregular Acceleration
- MAF or VIAS...at a loss...please
- New shifter for 2000 SE
- HOW TO REMOVE REAR BUMPER COVER
- need auto trans for my 03 or has anyone ever rebuilt one any tips
- To Low?
- Extractor fitment
- Aluminum front bumper splash shields
- 2001 exhaust fit a 2002?
- Auto climate control sqeak/creak
- Garage door opener
- Who does timing advance in Dallas
- Genie Silentmax 1200
- Question/Pics - who does STA509A chip repair?
- Im new. But have an important question.
- Lug Nut Issue
- Anyone ever TINT the clear "ricer" 5.5 tails?
- hesitation / jerk on accel
- Transmission fluid leaking (manual)
- Change LED color on A/C controls??
- Mixing tranny fluid?
- help with 00' Maxima Shift
- Roof Rack Question
- help with 2000 maxima GLE, acceleration
- Advancing Question
- 2002 Maxima electrical problem NEED HELP ASAP!!!
- sound when key turned to On or Start
- OEM 5MT Clutch Kit parts list. Need some help
- People with obx headers
- Maxima hit... How much to fix this?
- Acceleration issues and stalling ? HELP ??
- My 6speed tranny acting up
- Wheel Swap question
- P0011. Just great..... I need help
- Shifter Cable Trouble
- Factory Bose Stereo Issue
- How long will a VQ35 oil burner last?
- Gap in hid foglight beam
- Selling my black beauty 02 6 speed
- WILWOOD SUPERLIGHT
- ~Post Pics of your Local Street Signs~
- Damn Cat Codes - Question
- 6th gen BBK Upgrade spongy brake pedal
- Rockauto wholesaler closeout parts
- O2 sensor / computer reprogram
- At a loss...
- Rim Suggestions???
- Oil Leaks (two) on my 3.0..need insight
- MaxGig out
- aftermarket keyless entry with remote start questions
- passenger window auto up problem
- 00 GLE Won't start.
- Ghost SES Code
- Governor
- Valve Ticking Cylinder#1 Exhaust Lifter Gap 0.026"
- How to diagnose engine failure due to precat
- THIS BODY KIT WITH MAACO PAINT JOB????
- Steering Noise/Issue
- Fresh paint
- All the Learning Procedures - who has them?
- 6th gen transponder key on 5.5 gen?
- Driver's seat stopped moving front/back
- remove headlight 02
- Wont Start
- Im new to the maxima scene
- Crazy issue, tranny/engine
- Need 02 Maxima Airbox and what else?
- Mounting an amp board to back of fold down seat?
- 2000 bose aux input?
- New Wheel Bearing New Noise
- problem after nwp spacers install
- Help...car starts and shuts down
- Need an opinion... Grill or No Grill...
- Clip for a bumper ?
- 4AT guys enter
- Where does this hose go?
- Tire question
- Do thgrottle bodies go bad? Nissan trying to tell me it is. 01 Maxima
- Maxima Steering Mod.
- Utec??
- Low power/MPG 2k max SE
- Looking for Splash Guards for 2001 Maxima 20th Anniversary Edition Splash Guards
- Non OEM Wheel Lug Color Question
- Need savvy shopper help: Where to find OEM gray dot ignition coils?
- Valve Lifter/Clearance Problem
- Anyone run Aftermarket Headers and Y pipe with a Stock cat back?
- When did maxima's stop selling so quickly
- Maxima 2002 make engine noise?
- 2000 maxima misfire issue (5th gen)
- Weird whine coming from front end...help !
- cam gears
- PLEASE! do not buy this 20th anniv out from under me. Looking for advice
- Another cooling issue....
- Replacing VC & UIM gaskets...Questions
- 02 6Spd Gone
- Burning oil?
- Please help with oil burning issue!
- Gear Jerk..
- 4SP question
- Minimal Clutch Pressure. Pedal sinks 3/4 to the floor.
- Clutch peddle is soft , not the way I like it to be !
- Has anyone here ever tried the Prosport Halo Series Gauges?
- Undetected Noise From Front Right Wheel
- Exhaust Bolt Size?
- Swaybar End Link Question...
- Engine won't rev past 2500 rpms... MAF sensor?
- Armrest Broke - Part Question
- Corner lights acting strange
- Inner tie rod steering rack dust boot
- Auto trans downshifting hard when coming to a stop.
- Best Exhaust Setup
- What Octane Fuel do YOU use? Might want to double check.
- Surface area of trunklid for 3m Vinyl-ing
- usa spec ipod
- AE passenger axel replacement trouble!!!
- Fog light glass stained?
- Whine when turning (video inside)
