- WOWOW this kit is SICK
- Rear Window Spoiler
- Dave B's number
- How to remove rear bumper for 01
- Help..headlights stolen..goin projector
- question on putting on springs
- How to install front door speakers?
- My New Max!!
- Two mods one day
- Clutch Pedal Vibration
- How the !@#$ do you remove the front bumper? HELP
- Short Max
- major problems last night
- question about brake install for front
- 4th gen intake on a 5th gen?
- Timing advance on 2k2/2k3 - pinging issues?
- Stillen RSB.....
- A'PEXi filter...what do I need to know?
- Need Help Grinding noise when I start.
- HUGE scratch.. Need suggestions on 02 Fender
- people w/dash kits...lets see some pics
- Which spring/strut setup?
- annoying security system
- Noise coming from Cat area
- project- air ride install, pics
- First 3 exterior mods?
- Can I turn the Navigation system OFF by default?
- Anyone used the Nissan paint touch-up?
- brake light out...can't fix it
- Shocks and struts
- GAB Mod Engine Safety
- About Reposts!
- Metallic rattle in driver door
- Questions about this shift knob....
- Driver side HID not working?
- Possible to switch analog air controls to digital?
- Do the GLEs have a softer ride?
- When I floor it
- HID Relay
- Aftermarket Ebay Glow Gauges 00 Max.
- In-cabin Microfilter group deal via Dave....
- 12v buffers? and bumper repaint
- Whats the best way to change the brakes without having a lift?
- Had some time last weekend, so....
- Just installed new brakes. Help.
- What is the best bulb for the reverse light
- Another G35 Wheel Question
- Difference between I35 and 5.5 gen
- Squeeking sound from my passenger side rear wheel..
- Cattman Y pipe, possibly big problem
- do i need new brakes? they are pretty messed up
- Brakes.......
- P0430 - is this what I think it is??
- Weird 1st gear acceleration
- A great site to check the lowest gas prices!!
- What should be the first 3 performance upgrades?
- Spark plug tube seals leaking oil?
- Eurodesigns Xenon Blue Bulbs
- HELP Fog lamp removal...sigh
- Mounting holes where NISSAN hamburger was after debadging?! HELP!
- How to take rear door apart???
- 26000MCD 5mm?
- Time to change the microfilter.....who's got them cheapest?
- X-tec HID Conversion Kit???
- Question for people with intakes
- Random Idea
- My Car Keeps Shuting Off ?
- wheel spacer and stock 2001 wheels
- Energy Suspension.....Where?
- how do you store your extra tires?
- Need all TSB and Recall Info for 2002 6 Spd
- aftermarket fog light question
- Can I post a link in here of something I'm selling on ebay?
- need help finding an orger..
- Can I clean the MAF??
- Hood question
- AT Tranny Fluid Change Problems, Done it?? COME ON IN! PLEASE!!!
- something weird (but i dont think serious) happened today
- where to buy VIS CF hood?
- 6 Spd clutch pedal squeeking
- sparky
- DDE's Not Working
- Looking for pics of an '01 SE Anniv. Edition
- Got my Ksport Coilovers today *56k warning*
- ABS light
- Quietest aftermarket exhaust?
- Need new motor mounts
- Queston about exhaust...
- Clicking sound when i press the gas
- Has anyone swapped a 4th gen auto tranny in a 2000-01 Maxima?
- exhaust help
- Please HELP! Problem with brakes!
- AT Tranny FLUSH HELP!!!!
- 6sp es bushings users
- pics please
- Sure hope so
- hid wiring kit
- do you guys think this anthracite color matches gray luster?
- Bosch Platinum
- Fing sun roof just stoped working, dealer wants $100 to look at!!! HELP!!!
- what sensor is this...
- Keep getting the PO420 (cat coverter SES Light)PLEASE HELP!!
- looking for pics of g35 spoiler
- Raditator Fan Chatter
- Home Depot Valence Grille - Comments?
- For those who have HPAutoworks first gen STS piece alone....
- STS installed
- Pics of my ride
- Anybody here have just y-pipe and exhaust as only performance mod?
- Posting Pics?
- Car stopped for 7 weeks, problem.
- Moving the STS back
- rear sway bar install
- LED Mirror...custom made, props to MaximaPolak
- are the ses codes listed in sticky for all 5th gen 3.0 + 3.5 ?
- Removed air box part
- Official Nissan Maxima photos?
- Sorry...I can't find it..
- 340 Miles per tank, good or bad????
- Quick question on 2k2 power seats hookup
- Tail lights messed up!!!
- Carbon Fiber Hood Lookout
- inner tie rod loose?
- Grill-tech inserts
- SPRING TIME IS HERE!!!!...my car is finally lowered!
- Stock Spoiler
- Road Trip
- AM Radio Gone!! Any suggestions?
- Slow leak??
- 17 Degree timing adv. Question
- rims
- No better way to clean your throttle body!!
- For those with HP Racing Evos or R5s
- Problem unpluging air bags or not?
- Door Panels
- Car won't start - sounds like machine gun
- Rear brake pad install help! Please!
- HELP!!!! car broke down
- got bored at work so i got creative 56k lookout
- shocks and springs
- As Promised...auto-x video
- why do mafs go bad?
- HotShot Headers - How long did it take yours to ship?!?!
- Is this a serious problem or normal
- Help!!!!!!!!
- Vb Mod
- Brakes suppose to be responsive??
- Maxima pulls to the left
- brightest non-HID lights
- clearing ses light
- STRUT QUESTION (please help)
- Loud Whine/buzz At Startup--
- Weird Clunking noise up front
- Engine Drive Belt Replacement
- Bulb application chart....
- Nobody Knows Whats Wrong?!?!
- Replacing fog light bulbs...DYI?
- Apexi or K&N???
- Help..My radio and clock just turned off
- WTF...LOUD knocking/rough idle at startup?!?!(LONG)
- Help on ODB II codes...I think im being lied too..
- salvage parts
- static shock anyone?
- Need help with blinker (after 2k3 headlight upgrade)
- Tranny leaking.
- Aftermarket Amps, Power Wire Install
- Need some help on what to do with water entering taillight assembly and into trunk.
- Cold air with stock airbox
- 2k0 rear bumper question
- Finally I can make a post... new here so here are som pics of my Maxima.
- Effective grounding points: List them!
- Link for Sidemarker re-wire to blinker
- 01 Wire Fogs So Stay On With High Beams And Turn Signals
- As an AUTO maxima...what are your mods and what do you run?
- Wheel Experts/offset
- Retrofit Question
- question about the sidemarker rewire
- Stillen VQ Pro
- Optima Yellow Top 34
- posted a couple of 5th gen auto-x vids
- The Best Intake For 2000 Maxima Ever!!
- Intake manifold problem
- DDE's, 8500k HIDS, Smoked Sidemarkers and Tails...*PICS*
- Crankcase
- just ordered my 02 maxima hids
- Anyone have a pic of stock 02-03 Engine Bay?
- really nice day..shot a few pics of the max
- Finally! New Pics of my 02 SE. 56K lookout :)
- s tech with 19's
- Evo 2 exhaust and injen intake
- Question about bose systme/tinting
- PowerTrain Warranty on 2003SE?
- Bday Coming up.. What to ask for..
- Need a little bit of help...CEL-0507:rpm high
- Work on a Sat
- Rear Door Interior Panel Replacement Help
- 5th gen with G35C 17's (not 18's)
- Manhole Ripped Car Apart!
- New Wheels Installed, What do you think?
- DDE turned on while HIDs turned on
- Just learned small things make me happy....
- rsb how-to?
- Is Franken around?
- Place Racing!!
- New and Proud member of the Stock VI club :)
- If car starts to "Shimmy" at 4000 RPMs...
- How To Remove Door Panels(Not in How To's)
- doing front brakes....any tips?
- Clutch making weird sound
- Did a little auto-x today....
- Clutch comments
- My Car got broken into.....
- BlemCo Tie Bar
- Calling anyone who is skilled with photoshop..
- Anyone got a VQ35 in their 00 or 01's?
- Minimum speed for 6th Gear cruising?
- Quick 5.5 Lip Question
- Rear Bumper - Scratched by Trunk Lid
- Injen cold air intake
- Pics of my whipp vs another Max
- g35c's on another max
- Sidemarkers Ripped out...New connectors?
- OEM Rotors won't come off - help!
- 2002 Stock Exhaust Question
- lookin at buying a 2003
- Stabilizer Links
- Maxima Commercials
- Current Car and Future Car **PICS**
- updated transmission control module.
- Ordering AE Parts
- door
- UDP belts where to find
- Struts and Springs
- Shifting problem
- How would this look?
- Need Help! Vehicle speed sensor location?
- How do I get the MAFS off the harness
- Need help: Steering Rack Friction Adjustment
- Do you wave?
- NOOB question- Difference in gauges and console cover
- Debadge?
- uneven drop-any advice?
- Basslink Vs Bazooka
- Weird Clicking Noise Front Drivers Side...Any Ideas?
- Anyone have info on SportCompactPro.com sponsorship?
- Sound Quality of PAC adapter?
- Question about springs & struts when dropping on 19s.
- Y pipe?
- VIS hood problems
- MEVI or some Aftermarket VI on a 5th gen??
