- Help with wheel hub removal
- Question about Snow Tires
- heated seat switch wires
- SES light ...what to do
- magnaflows are finally on *pics*
- Silverstars arent all they are cracked up to be
- How particular is Nissan on honoring the warranty
- Rear Fog Light (installed)
- Gauge pod options for 5th gen.
- Please HELP! Warm stall = 'Air Flow Meter'
- Searched - Disable DRL?
- Can anyone help me out?
- Digital Temp Control not working like it suppose to...any ideas?
- Fuel gauge not working when cold?
- 02/03 Bose to replace an 01 Bose
- question:Planning to upgrade with HID's
- Let off gas, revs stay up a second?
- Swapped out my windshield nozzles!
- Does anyone know how to disassemble 02/03 Altezza tail lights
- 350z rims on 02 Beige MAX???
- Air filter choices
- Is there an easy way to swap a 5spd MT for a 6spd Tranny?
- Redlinemax.com
- Driver Door Sag
- Correct Optima battery for the 5.5th Gen
- Tranny problem
- Question about one touch up/down windows
- Front defroster question
- Manual Trans Drain
- 02...black mesh grille?
- Led Doom Light?
- Made a copy of my key for my car
- 2001 AE alarm problem
- Clear Chrome Tails issue (anyone else with this problem?)
- Help, 2k2 ECU removal
- Who here with an 02/03 6mt has NOT had a 3rd gear crunch?
- bumping sound
- Bose Hu (cd Stuck)
- How to take front speakers out?
- OEM Air FIlter Replacement
- When to change brakes?
- oil consumption
- which rims are better looking for the 02-03 maxima???
- How many 5th Gen Maximas in the 200,000+ miles club?
- Body Rust
- How to replace a taillight??...
- Clutch squeak and interior lights issue
- 5.5, stearing wheel controls supose to light up?
- Question: Cold Morning car cuts off
- Inpection blues
- Qyestion about the Fuel Injection Cleaning.
- Spark plugs
- Speedometer trouble...Need Help
- MAF Going out Slowly.
- LED Tails: The video
- Help me get the dealers back!
- 2002 Maxima Map light bulbs help and mysterious passenger ghost window
- starter for 2000
- 2001 se hard to start after fuel pump replaced
- Need help
- Tilleys99 can you clean out your inbox
- 2k GLE problem
- What's wrong with my new alternator?
- Nature Strikes!
- Starter Finally Quit on me?
- Any winter driving suggestions?
- wtf, are 5th gen STOCK springs impossible to put on??
- AT Going out..... Help needed!!!
- New 5th gen owner
- New Brake Problems
- 01 Maxima with 105k - need a checklist before buying
- Should I buy 6000k Bixenon kits?
- Quick question about Autolumination 7443 LED's
- Auto Park Option
- Ok... 5.5 Grille Painters... Step Inside...
- Advancing base timing :D
- Where to purchase a transmission?
- Replace Broken Wheel Stud DIY??
- injen cai cone filter
- any harm done?
- Question
- Headlight painters.... Flat black or Glossy?
- maf reprogramming?
- Where can i get a mass air flow sensor
- purchasing OEM replacement parts
- Spark Plugs
- Clear Corners question
- New Y Pipe Install
- 5th gen to a 6th gen, worth it?
- New Maxima owner, ? about noise.
- Does anyone know what this means?
- Max ground kit
- 5.5 gen stock whp?
- Feed back: Code reader
- I35 side skirts
- translucent led red lights for the clear/chrome tails
- 5th Gen LSD Options
- 5.5 Gen Auto to 6-Speed swap
- catback exhaust options ?? 2002-2003
- MAF cleaning
- O2 Sensor
- Changing Air Bags!!!
- Bad ECM
- Changed MAF - What is Idle Learn?
- code P0171
- Brighter Dash Cluster
- Problem with front right wheel?
- Ever dealt with DAVEB on 5th gen parts? step inside...
- sunroof problem
- A33 Maxima 20th VQ30DE 2001 Oil Filter 9E000 65F00 Dealer warnings, please help
- Which brand is better and will last long?
- idle problem after bored out throttle body install
- How to remove the governor from your Maxima
- Is my clutch about to go on my 02?
- Weird Window Problem
- exhaust questions
- Need Help!!!!
- 2000 maxima is slow?!
- My CAR is Having a hard time starting
- Trip from Phoenix to Chicago.
- power cable routing :(
- Need Strut boots
- Did FrankenCar go out of business?
- y-pipe rubbing on cross member
- Is my exhaust on its way out?
- 2 questions..DRL's and rubbing
- 5.5 oil and filter
- Neighbor's Maxima had a "computer board" burn out. Dealer wants $1500!!
- questions about 300zx bbk
- Back to the Max- Some ?'s
- Weird dome light problem: turns on when bulb is pushed up
- Rear Struts
- So who makes the Best CF hood? (CF hood guys)
- searched first, no luck - Need help with installing sub on base (not bose) system...
- $1083 For Airbag Update!!!!!
- battery fuse ?
- Heated Seat stopped working? Heres why...
- Need help with Bose 2001....
- light blinking fast
- MAF Bolt Size
- Help...Car feels slugish and slow !!
- 300ZX projector retrofit?
- Question About Pealing AE Shift Knobs
- For You with INTERIOR NEONS!!!!!!!
- greddy evo II fitment (from 02 to 03)
- Got these 2 codes poped up (please help)
- Noobie guide to getting that G35 sound for FREE
- Best Option for Upgrading ECU on 03 Max
- camber question
- 00 ecu pinout
- 2006 Turkey Day(or stay the f**k away from in-laws)
- oil pan ?gasket? leak
- Need Your Help With MAF Issue. please!!!
- what is this hose to intake?
- infiniti sound
- WTF umnitza!!!!!
- Has anyone install Koni Sport w/ stock springs?
- Black 5.5 gen headlight housing
- Power Steering Leak… what should I do?
- PO650 Code
- RIght headlamp WON'T TURN OFF!!
- remote starters?
- Car dies after being started...starts up okay later
- Speed odometer help!!!!
- help with stereo
- Please help...My headlight doesn't work
- DDE Light Intensity Help
- OEM Strut part #'s?
- greate...
- 2K3 Bumper On 2K1
- what can cause the engine to stall?
- Will 02-03 GR2s work on 00-01??
- Install New Radiator On '02 SE?
- 2000 ignition coils (again)
- Spark Plugs choice..
- Quick EZ-Pass questions
- Engine Code question PO507 high idle
- fujitsubo exhaust
- Tokico HP
- Door misaligned
- Help, headlights+foglights not working.
- So, I need a tranny
- decided to finally replace my belts
- My car shifting hard...(Auto)
- testing the waters : fog light protectors
- Heated seat problem
- Early 2000 SE's with 16" OEM wheels?
- M3 trunk lip spoiler
- Is this the brake booster line?
- Right headlight wont work!
- Does anyone know how to wire the fog lights with alarm?
- Dash Brake Light on when cold out
- how to change side lights
- Was not shifting into 2nd gear, high rpm - 2k auto
- Anyone have one of these ...
- srs airbag resistor
- Accurate Price To Replace Axle Boots & Bearings...
- 07 infiniti g 3.5l pushin 306hp?
- HELP!! Acceleration gone!!
- Leaking Oil Cooler
- Gas overflow
- $560 for 2 O2 Sensor's?
- Nothing but Issues....Help!
- Thinking about doing a 3.5 swap...
- L/100km
- Electrical System failiure
- Advance Auto Cheap Rotors
- TSX projector retrofit in 02-03 headlights **PICS**
- problem with loose wheel
- Ebay tail lights
- P0725 Speed Sensor Malfunction
- how to check if i really need to replace my battery?
- Question about Swap?
- Final exhaust video. stock everything, CATTMAN GEN 1 only. calling puppetmaster
- header question...
- Maf
- please SOMEONE help me with my Headlights
- Tokico Blues too soft?
- My quest for a proper handling and braking, loooong
- Need Help! Can't figure out Problem
- New Rotors ...
- Oil Leak 5.5 gen
- Steering wheel tight
- :grinno:
- picture request
- Starters...
- 5th gen fog lights
- Decode Model number, Transaxle number, Trim/Color Codes!
- Chewing sound while starting car...
- front arm rest on 2k2 problem
- LTB creaking during turns
- Clutch Stop
- Installed EBC Rotors...weird noise.
- Watkins STS - New Info from Steve Watkins
- Weird P0011 Intake Valve TCS Occurrence
- Umnitza Angel Eyes Dim for several minutes?
- How to get check engine light to turn off?
- slipping clutch
- ABS Light
- Plug Replacement and 335 Code (2003)
- 2002 gauge Cluster in a 2001 Maxima??
- easy, fast mods?
- Where is the air filter???
- Grinding Noise
- new brakes?
- rear beam
- Oxgen Sensor Issues...
- Question about Clutch Pedal "length"
- What is that smell?
- How to test if your ECU is bad?
