PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 [109] 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Rear wheel gap
  2. Whining sound, plz diagnose.
  3. knock or ping around 2500 rpm
  4. time to replace o2's?
  5. side view mirror glass removal
  6. ABS Sensor...
  7. sunroof problem
  8. Does Nissan have an odometer correction tool?
  9. Radio, and ACC removal
  10. Radio, and ACC removal
  11. Tein SS Coilover kit
  12. air temp. sensor
  13. H&R Springs/ Tokico Illumina
  14. Switched out gauge cluster, now mileage reads wrong mileage WTF?
  15. rear tires wearing out faster than front...wtf??
  16. Trunk Wiring harness connector placement
  17. How to adjust 6 speed clutch??
  18. I stopped being stupid and found a black/black 6 speed>>
  19. Clutch Pedal squeak????
  20. 01 grille question
  21. Painted '00 Headlights Pics
  22. Illuminas up front, Blues in back
  23. Redlinemax 5th gen bumper installed inside (no 56k):
  24. looking for the org's input on "vent hose for brakes"
  25. Has anyone used this before ?
  26. can anybody tell me how to rewire the fogs lights with pics?
  27. what can i do with these?
  28. Y-Pipe Question?
  29. BRAKE Light
  30. temperlite
  31. High Flow Cat and Test Pipe Q's
  32. coilovers...
  33. OEM or aftermarket caliper and what is the core fee for parts?
  34. 2003 6 speed max exhaust replacement needed what should i do?
  35. Looking For Some Headlight Bulbs.......need Help.
  36. Car's suspension feels loose.
  37. Stupid Center Console
  38. Mirror Tint vs. Black Tint
  39. 2k3 calipers on 2k1 ???
  40. When Changing Your Oil, Do You Need A New Oil Filter?
  41. My Gas Tank Cover Has A Nice Size Dent In It!!!!!
  42. How to remove rear deck (for subwoofer)?
  43. How much for a spoiler?
  44. Now its time to say goodbye!
  45. ? oil drain plug size/thinking of replacing with
  46. are header's and y pipe important?
  47. K&N vs. Apexi
  48. My 01 Maxima Se Is Having Rattling Noises.
  49. Pathfinder TB in a 5.0gen?
  50. Bad valve cover gasket??
  51. Quick! How do you remove the 2k plenum!?
  52. 2000 Torque Specs for Wheel Nuts
  53. Swap '01 to '03 Steering Wheel Audio Controls & Airbag into '00 Possible?
  54. My $15 mod :)
  55. how to check engine oil level?
  56. Progress RSB installed (opinion and a few questions)
  57. How to: AMB button.
  58. ne1 running different exhaust tips on a stock muffler?
  59. New oil catch can...less ghetto
  60. Fog light fuses
  61. 2000 Maxima Tune Up
  62. Wheel adjustment on Maxima 5th Gen or I35
  63. Cant get my rotor off!
  64. quick question for those who have used G2 paint
  65. Weight Distribution
  66. 4rth gen 5 speed
  67. interior replacement bulbs
  68. ES 6spd Shifter bushings
  69. Brake issue, not biting?
  70. Can 00/01 headlights be swapped into an 02?
  71. Yellow Injen Intake
  72. Air Conditioning Question - Need Your Help
  73. Hawk Pads
  74. Maxima Bike Rack Help
  75. Know how to roll down the back windows down all the way?
  76. FS: 02 03 headlights OEM HID!!!
  77. brake lights wont work??
  78. Anyone have a 5.5 gen M.T. flywheel
  79. ES Control Arm bushings Ride quality
  80. A tool I must own one day. Anyone tried it?
  81. 300zx turbo rear calipers on 5 gen Maxima?
  82. AC button does not light up
  83. Working on the stereo..
  84. Wheelskin for frost interior?
  85. My VIAS is broken, what should I do?
  86. Alright dont jump down my throat on this one but I'm lookin for these caliper covers
  87. its been a while
  88. very direct suspension question "oversteer" (be gentle)
  89. Stealership Ripoff?
  90. Got some toys in the mail today
  91. Hestitation during acceleration
  92. 5.5 GXE's
  93. washable In-cabin filter
  94. What a change, ES coil spring insulator on D2...
  95. 3.5 grounding kit is it worth it????? Please provide details on how to?
  96. 4 gen cai on a 5 gen?
  97. Where do i attach the grounding wires?
  98. Question about Ball Joints?
  99. can cheap gas mess-up your engine?
  100. ANOTHER y-pipe question
  101. squeeking when the clutch is used, HELP
  102. ordered the redline bumper
  103. Need Help with installing my intake!
  104. Lack of low end power question
  105. 2003 Maxima speakers
  106. Governed
  107. How Do I Advance My Timing?
  108. Gas Door Question
  109. '02 Max - SES/MIL blinks 7 times then stays lit
  110. screw to adjust 00-01 TB?
  111. 921 bulbs in park lights
  112. confused about LEDS
  113. Little help with fogs please
  114. Intake question...
  115. KYB Dustboots and bumpstops
  116. BlehmCo Grounding Kit
  117. Found a sweet Maxima, but..... I need your help!>>>
  118. Unsuall wear on tires and nose on front passanger side
  119. Do I Really Need Strut Bearings
  120. quick question about hot shot headers
  121. question 'bout rear strut bar..
  122. Need help with a How-To.
  123. Need some info on installing the 6th gen rotors/calipers
  124. Rough start/idle MAF symptom?
  125. Stillen Grounding kit
  126. Transmission question
  127. hid fogs........
  128. Car accident with a drunk driver
  129. rattle from passenger front wheel only when I make a sharp left turn???
  130. It's not the starter..What else could be causing start problems
  131. miss fire still has me puzz...
  132. best place to buy cf hood oem?
  133. Molded Dash Kit - Installed (Pics)
  134. Just got done re-wiring me fogs.
  135. LED upgrade for climate control and stock headunit
  136. replacing control arm??
  137. Cai
  138. Need Help - Coolant TB Bypass
  139. Car wouldn't rev past 2.5k rpm HELP
  140. Replacing Lost Low End power with CAI Install
  141. HID bulb question..
  142. HELP-annoying brake scraping
  143. Best MPG is achieved at what speed in 2002/2003 Maximas?
  144. Piston stuck?
  145. Need help locating 02 sensors.
  146. drove through high water, can anything get messed up?
  147. side airbags question
  148. Anyone with an 01 have a fidanza flywheel?
  149. I think my trannys bad :(
  150. Help Please!!
  151. Squeak Squeak noise during straight line driving? irish44, drklop?
  152. Power window not working
  153. Tokico Suspension Kit
  154. removing rear left side lamp?
  155. 2K2/2k3 HID Help
  156. carpeted trunk floor?
  157. spacers cause vibration??
  158. 2002 Ball Joint replacement. Dealer says whole control arm must be replaced!
  159. KYB strut mounts
  160. Cleared headlights on a blue 5.5 gen?
  161. MOTHA FUBBAR (large anti 56k)
  162. What exhaust set ups sound good on this car?
  163. Stupid birds...
  164. PLEASE HELP!! Big problem with strut
  165. KYB-GR2 Struts w/ Vogtland Springs (56k enter at own risk.)
  166. suspension sticky got updated
  167. '02-03 Subframe Connectors
  168. Aftermarket Clutch for a 6 speed maxima
  169. Thinking about adding some ghetto pre tension to my springs
  170. 5th gen aftermarket steering wheel adapter
  171. Need help replacing exhaust manifold stud
  172. retroed ebay lights ....jacked!!!
  173. Slotted rotors and stock pads
  174. Changed OUT Redline MT90 from my 6spd
  175. evap cuase big mpg change?
  176. Which o2 simulator do I need?
  177. *Vibration* but not from unbalanced tires
  178. I have $500 to spend
  179. To All My Maxima 2001 Se Owners Out There!!!
  180. Silicon sealant for tail lights... A question
  181. Need help from the org finding parts this shape
  182. suspension almost done, but what else?
  183. Vibration
  184. Extended Warranties... newbie question
  185. 2K Max Bad Coils DIY replacement
  186. Losing Overdrive on long highway drive
  187. Muffler difference?
  188. KYB GR-2 struts 00-01 vs 02-03
  189. LED Tailights?!?!?
  190. Polyurethane Bushings on 2003 Max
  191. Clicking and vibrating - front left '02
  192. My Little Project With Pics
  193. Torque Converter Question
  194. A/C behavior
  195. D2Rs in fogs?
  196. oil cooler?
  197. damn headlights.
  198. I must be tripping
  199. clicking sound from left rear of car
  200. Window Tints
  201. Suspension Upgrade-Satisfaction
  202. 03 Rear Bumper replacement
  203. Buying a 5.5 this weekend... need help from you guys
  204. needs new lower tie rod..right price?
  205. Progress RSB Installation
  206. wow your right, this made a bigger difference
  207. need help w/ aunt's maxima
  208. 2000 Calispec question
  209. lights out?!?
  210. Over-charged AC
  211. 2k2 automatic hesitation issue in second gear
  212. weird noise when starting car
  213. intake and rims ?
  214. MASSIVE brake problem...
  215. Passenger Window switch LED replacement
  216. Hotshot headers and polyurethante motor mounts, step in.
  217. Is there a how-to .....?
  218. How hard are the ES bushing to install
  219. Windshield Noise?
  220. Random missfire
  221. they stole my lights!!!
  222. Car not starting, need a little help.
  223. Stillen rear sway bar.
  224. my cars been shot! call the ambulance
  225. Where can i get a base paint spray
  226. HELP - Rear side marker trim piece removal
  227. Alright just a post to make sure I'm not missing anything
  228. 6spd shift knob options!?!
  229. 2003 bose 6 disc head unit
  230. A/C problem?
  231. A/C Problems
  232. Polo/others with ES Front LCA bushings, step in...
  233. BLUE BATMOBILE side marker overlays (**PICS**)
  234. need to locate evap canister & vent control valve
  235. HELP - Changing Brake Pads, QUESTION
  236. Tightening handbrake handle - feels very loose
  237. Run of the mill mods
  238. I was tripping when I saw this
  239. need opinions
  240. Trunk Emblems
  241. how far to compress caliper pistons
  242. drivers side rear window wont go down
  243. bbk problems 300zx/cobra
  244. Extra storage
  245. Best Brake Pads?
  246. Doing a complete tune-up, what should i change?
  247. Engine Code P0420 - Catalyst Effeciency Below Threshold Bank 1
  248. Cattman Exhaust ?????
  249. MTEC fogs
  250. P0420 & P0430 codes... how to fix them?
