PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 [136] 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. staggered rim setup
  2. how often do i need a tune up?
  3. Clicking Clutch.....
  4. ABS and Slip problem.
  5. Murano rims on 2k3 - take a look *PICS*
  6. Fast Cat and Cattman catback Installed
  7. Can I upgrade the Alternator on my 5th gen!
  8. 480 Miles On Tank Of Gas
  9. ok guys wich do i dyno headers or timing advance
  10. Anyone trade their 03 Titanium@Niello Infiniti...
  11. Zero Rust, POR-15, Rust Bullet Products
  12. new 5.5gen vent visors?????????
  13. Just stopping by
  14. Headers and Y-Pipe Questions
  15. i need window help! please
  16. Car feels slower with A/C on.
  17. CF style tail lights on Sterling silver 5th gen?
  18. ECU and Reverse Wire
  19. rear ABS sensors from 00 work on 02-03 just fine
  20. Sorry for the Projector Repost but...
  21. Need your help....
  22. Tokiko Blues and Tokiko Alluminas.
  23. Anyone ever fix their coils?
  24. Stock exhaust reliability
  25. Almost 100 Deg no AC PLEASE HELP
  26. Totalled the max early Monday morning.
  27. Painted nissan hamberger...
  28. replacement wheel studs
  29. Timing Advance
  30. Intake Manifold Question
  31. Help me decide on what to get for my next mod!
  32. strut torque specs
  33. Time delay switch-off control on 2k1 GXE?
  34. Hid Stock Lamps
  35. Fog Lamp question
  36. UPDATE- 2k3 losing OIL
  37. maxima/i30 body
  38. Straight/Race pipe owners step in
  39. newbie gas q
  40. Help with EVAP
  41. smooth idle rough acceleration
  42. Wheres the Fuel Filter on a 5th GEN?
  43. iPOD adapter appears to have RCA in jacks
  44. pinging pos!
  45. removing cross member under ypipe/cat?
  46. Nissan Caliper Stickers *pics*
  47. Catalytic Converter
  48. Just bought 02 max se
  49. need tech help, rear spring install
  50. Strut Tower Bars & Strength
  51. quick coilovers question
  52. Greghome 5.5 Sparkplug Change
  53. How to adjust ambient temperature reading?
  54. Cross Drilled rotor failure
  55. Need Help - (Loosing Clutch Fluid)
  56. Maxima 2000 Automatic and Kenwood Navigation Unit Speed Sensor Wire and Reverse Light
  57. Timing Advance In Schaumburg IL
  58. Broken Key in 5.5 Gen Driver side
  59. 5.5 gen v.s. 04 350Z Rims
  60. which tranny to get?(opinions needed)
  61. problem with my 01 SE HELP
  62. Replacement Headliner??
  63. Replacing stock catalytic converter and question about ECU codes
  64. Crank Shaft Position Sensor problem in a 5.5 gen
  65. 19s on a 2k, what suspension is best?
  66. PowerTech 1012
  67. turnin radis question
  68. question bout intake
  69. Lightweight wheel effects on wheelhop
  70. ABS problems???
  71. Aftermarket (or Walmart) fog lights for 5.5 Gen?
  72. Wtf I Found A Spacer Below My Pedal!
  73. Survey: 1 thing u like most, dislike most about max
  74. Installed Eibachs/Illuminas HUGE difference
  75. The Great Picture Thread.....
  76. misfiring help! e55amg2, blackbird?
  77. Opinions on Shocks/Struts
  78. Weird idle.....................
  79. Vertical Sun roof
  80. All 5th gen members, Mandatory Read!!
  81. Sunroof
  82. Finally i chose what rims i want !
  83. Pics of rear window spoiler?
  84. Rattle under the hood, after acceletation...
  85. question about dte/trip guages
  86. radio question
  87. test drove a max today...howd they do this??
  88. fluid dripping by tranny and axle......
  89. Spent so much on gas :(
  90. tire size change and speedo calibration
  91. general questions...
  92. Question about HID
  93. 1 Sourceautowarranty - Extended Warranty
  94. Intermittent wipers on a 2000
  95. fog light rewirin
  96. Taming a 6-Spd Need Advice
  97. Crank, No Start Condition. Help Please
  98. Help! Service engine light is on again.
  99. OK, I'm Confused...
  100. symptoms of slipping tranny?
  101. 2000-2001 Maxima OEM 17" Wheels/Rims on ebay
  102. A quick wash and wax... what do you guys think?
  103. pics of my 02 max se
  104. maxspeeds on
  105. Why are wheel spacers so expensive?
  106. Tint on 2000 max - back window?
  107. Custom Exhaust bending
  108. bottoming out/harsh ride with Progress/Tokico HP's
  109. 13 inch cobra's on a 5th gen!
  110. Curious About Frankencar Performance Service Hours
  111. please help. how to remove driver side door panel?
  112. Help...Please!!!
  113. Reprogram ECU now or later
  114. car lights for inside
  115. What are some real good brake pads?
  116. Do X-Drilled rotors have certain direction they need to turn around?
  117. Grill-Tech Grille
  118. Need an How to for installing 2k4 rotor/caliper.
  119. Need brake rotor knowledge
  120. The condition of your Cattman Products?
  121. where to find haynes manuel for 02 max???
  122. Way to program key????????
  123. out on my maxspeeds got one question
  124. Blue LED gauge mode question!!!1
  125. Tokico Illumina front only with Maxspeeds
  126. Vibration Vibration Vibration
  127. Custom two-tone interior project! ***TEASER PICS***
  128. Need Opinion supercharger or 5.5 gen
  129. 2k maxima with ticking noise
  130. 2k2 foglight rewire????????????????
  131. Leather Ripping?
  132. Front suspension noise fixed
  133. new clutch issues
  134. window up/down button
  135. Ran over curved metal tube on highway
  136. Rubber Dust Boots for front suspension
  137. anyone know how to change pvc valve
  138. Outside Temp. Display
  139. What should i offer
  140. Ugly hole....any ideas how to cover?
  141. Center Caps....Black or Silver??
  142. Need a carfax report
  143. performance between flywheels
  144. Cattman muffler on, wooohoooo.
  145. looking for abs dynamics rear lip for 5th gen..who sells them?
  146. Rear brake pad?
  147. P0153 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 2)
  148. Are Monroe Sensa-Track Struts OK for a daily driver?
  149. 3 Things
  150. Got my VIS CF hood today
  151. CAI UDP Dyno Results
  152. Painting the motor cover......???
  153. Can I buy Langka at auto stores?
  154. Eibach/Illumina-cut bumpstops?
  155. Advance Timing
  156. Eibach Pro-kit and Factory Struts
  157. My 5.5gen GXE and friend's Prelude at OU (8 Pictures)
  158. Which a better combo?
  159. new springs :)
  160. g2 paint suggestions, how long to wait?
  161. question on oil change
  162. Basic brake parts...
  163. Yakima Roof Rack measurements
  164. Bushings replacement important after 80k??
  165. Intake problems
  166. my MPG says 15.0 MPG????
  167. 5.5 gen lips(both of them) Please post pics
  168. Curbed!!!!!
  169. How to remove the front passenger seat?
  170. CF engine cover
  171. Cleared HID's Install PIcs
  172. I Hate Fifth Gens!!!
  173. CHEAP NOS for you guys....
  174. difficult 2nd gear..
  175. P/N for OEM style switches?
  176. Even Suspension Stance...Cut springs?
  177. carbon fiber trunk with or without a spoiler?
  178. Autozone Brake Parts
  179. Frankencar B-pipe installed....my impressions
  180. Aftermarket HIDS?
  181. installing Illuminas and new springs
  182. $43 piece of plastic!
  183. quicker first gear in 3 gen than 5 gen?
  184. rattles
  185. technosquare makes an ecu for 2001 but 2000?
  186. aiming projectors
  187. I want an ECU
  188. My Ride
  189. Help!!! 5th To Reverse Lockout G-o-n-e!!
  190. projector led change
  191. Update On Frozen Rotor Gd
  192. My first dyno
  193. Wheel OFFSETS?
  194. FrankenCar intake impressions after taking it off.
  195. Hood making noise
  196. What Springs??
  197. I got a FREE Y-pipe!!
  198. AAMCO's Power Purge Transmission Flush
  199. 300zx tt brake pic needed..
  200. HELP: Keeping Window in Track after TINT
  201. Changed my front struts and STILL the same bang noise
  202. 4th gen max looking for a fifth gen
  203. Looking for suspension mod..advice needed
  204. CAI - What to do w/ overflow connector?
  205. 3.5k-4kr pm power drop
  206. FSTB - Noticeable improvement?
  207. Rear brakes (Hawk HPS or OEM)
  208. Springs breaking in?
  209. Smoked '00-'01 SE inside tail lens to Euro '02-'03 SE inside tail lens?
  210. will spindle/hub from 2K fit my 97 SE
  211. H4 conversion recommendations?
  212. rear brake change question
  213. Anyone Did a Gound Wire mod And Felt as if the Car Lacks Pep.
  214. VIAS mod
  215. New pics of my whipp
  216. problem with strut/spring install
  217. Any Pics of Super Plasma GT-X's on 5.5gens??
  218. 18 mille miglia evo 5's on maxspeeds plz post pics
  219. Need help with loose wire underneath car!
  220. Wheel Weight!!!
  221. wtf 94 octane and pinging
  222. Don't you love it when...
  223. Seen headers for the 6th Max on Ebay...
  224. Maxima Pros
  225. SES light code P0420...wat should I do?
  226. Berk Intake Problem
  227. Removing LED spoiler light...HELP!!!
  228. Best place to get Cattman Y & cat-back?
  229. grounding kit
  230. 00 Max with 02 rocker spoiler/Splash Guard
  231. help needed really fast
  232. group deal frozen rotors
  233. Rear driver side brakes rubbing
  234. Service Engine soon light & ECU test mode selector
  235. Stolen Headlights Question 02-03's
  236. Nissan Customer Service Blows
  237. D2 install problems. Please help!
  238. Ticking sound coming from A/C blower motor
  239. a shiny present waiting for me today....
  240. Sirius Antenna - where to position?
  241. problem with LED
  242. OMG is ALL I HAVE TO SAY!!!!!!!!!!!!!!
  243. Question about the Bose system
  244. Soundtrack from HlH0501 Turbo Compilation III
  245. Problem with "TRIP" button on steering wheel...
  246. O2 sensor
  247. Cat Converter
  248. Awful, Broke Rear Parking brake Bolt!
  249. 350z Dead pedal install
  250. Pulled over by the boys for Clear Side Markers in CT...
