PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. p0505,p0140, p0160 Can they all be related?
  2. Car feels like it want to cut off.
  3. Strange Engine noise- what is it? Video Included
  4. 2003 good deal
  5. 2003 noise coming from under hood
  6. 5th gen with a leak but I can't find it
  7. Is a ballast needed for 35W fogs?
  8. What oil + air filter are you running?
  9. Torque value for PCV valve?
  10. Where is the leak coming from?
  11. Where is the leak coming from?
  12. Another Maxima with a Misfiring Problem
  13. Quick exhaust question
  14. Newbie!!!! Looking for input on headlights and bumper upgrades
  15. crank no start no power to fuel pump
  16. Maybe a hard part to find but where can I get it at?
  17. 2000 Nissan maxima SE parting out
  18. Clutch Install Question... Urgent I'm Stuck
  19. Bad IACV...please be gentle
  20. Fog Lights Burned ?
  21. Car died on me on the way to school, help!
  22. 03' maxima se headlight issues
  23. Rattling Noise From Engine Area
  24. Random Starting Issues
  25. Not your normal header thread?
  26. light buzz noise in engine bay
  27. Bought cam sensor shaft from Napa doesn't work
  28. LED turn signals questions
  29. Finally Headers are in.
  30. Complete Transmission Failure after routine service
  31. Idle air contol Valve
  32. Car gauge Pro
  33. Transmission parts.
  34. Trying to program a replacement remote
  35. Steering Wheel Controls Don't Work
  36. Swapping ebay headlight lense
  37. 01 Maxima Headlights with Halo Rings
  38. 02 Wont Start, lights flashing
  39. Replacing Wheel Studs on a 2001 maxima
  40. ? about speed sensor.
  41. Bad 02 Sensor.
  42. 03 Engine part name?
  43. Gauges Died
  44. Odd headlight behavior
  45. cd cd changer in 2k doesn't work
  46. Water on passenger floor after rain. Pics here. Trying to find leak.
  47. Intake/Test Pipe Opinions +More
  48. Buying a Car - Advice?
  49. ACT Street Clutch PP with exedy disk?
  50. Brand New radiator leaking!!!!
  51. IACV issue (P0505 code)
  52. My 5th Gen with Crown Vic Mesh Wheels
  53. suggestions for a loud agressive muffler for a 2000 maxima se
  54. Maxima Rear Passenger Hub
  55. Catback exaust, and struts
  56. clunking noise
  57. So annoyed, radio/hvac stack screws were so tight we couldn't remove them.
  58. Heat not working properly
  59. Hard starting, quits at hwy speed
  60. Anyone running Matic-D?
  61. Seat belt replacement for 2000 gle
  62. 02 sunroof help!
  63. What do you use under your car while working?
  64. Radiator Support: Need part selection advice
  65. URGENT! Need a quick pic or help stuck in the middle of Spark plug job
  66. Manual transmisson fluid
  67. Difficulty with manual shifting
  68. Nexus 7 in 5th gen max (video included)
  69. 2k Sunroof won't open / Lighting Issue
  70. Main Fuse??? Next to battery
  71. Headlights turn off when accelerating
  72. 2002 Maxima KN Air Intake
  73. squelch under load
  74. P0139/p0400
  75. Weird miss fires, hard starts AND NOW NO RED LINE!!!
  76. SE without a moonroof??
  77. Maxima won't start, cam/crank sensor?
  78. 2000 Maxima Air condition/Heater Won't Turn On?
  79. open the trunk with the key fob blows fuse
  80. 200k miles - Failures to watch out for
  81. 2001 Nissan Maxima MAC intake throwing codes.
  82. Hard shift from 1st to 2nd auto tranny
  83. Need replacement key and remote fob for 2002
  84. Question about Sidemarkers
  85. New o2 Sensors 4months ago same codes..
  86. TPS only Reading 90% @ WOT
  87. Any Help Appreciated (Newbie)
  88. 18x9.5", RPF1's Fitment question.
  89. 2000 Maxima Issues
  90. Headlight Protective Film
  91. Fuel Filter Location (Australian 2001 Maxiam A33)?
  92. Please help! Crank, chokes then die??
  93. Creaking ES trailing arm busings
  94. opening size for stereo
  95. Test pipe CEL
  96. Suede headliner
  97. Manual shift console on auto?
  98. Double din
  99. Need help with rims and spacers
  100. MAP sensor & o2 sensor problems after replaced
  101. Auto leather shift boot
  102. Calling all Pearl White 5th Gens!!
  103. OBX Headers & CAT Back System
  104. buying new wheels
  105. washer fluid heater?
  106. Valvoline maxlife motor oil
  107. OBX Version 2 Headers O2 Sensor Relocation
  108. 5spd Swap?
  109. 4.0 v6 xterra swap?
  110. Potential Buyer's look here: Let's reach a consensus
  111. car Gauge Pro app wont work 00
  112. Today: pre purchase inspection!
  113. 2001 Starter writeup
  114. Rough Idle and No Codes
  115. maxima going rouge
  116. Changing trans fluid
  117. Trading 98 Max 5spd for 02 Max 6spd, Any advice welcome
  118. Codes!! P0139&P0400
  119. 2001 AE rusted b pipe, need suggestions
  120. Help finding Correct FCC ID for Key Fob.
  121. New struts with old springs?
  122. Color temperature of headlight?
  123. New guy with a hot 2000 maxima
  124. Will this Key FOB program to my 00?
  125. Will this key FOB program to my 00?
  126. ...How to remove gear shift (chrome handle)
  127. Head light removal?
  128. Fog Light?
  129. Car buying troubles
  130. What tools are needed to install the bank 1 upstream sensor?
  131. Advice on how to install Air Duct hose to throttle body
  132. Missing Only On Startup
  133. Infiniti I35 shift knob
  134. idle screw
  135. Magical Non-Wearing brakes....
  136. Can you tell me what part this is? Part number?
  137. Radio Install Question
  138. 01 Maxima Hard Shifting
  139. New Thule Product: Aeroblade
  140. Oil Leak
  141. bass knob install location?
  142. Flash or not?
  143. LED cluster conversion '01 SE
  144. Ideas? New here
  145. 2000 Infiniti I30 Transmission Issues. (Video)
  146. Transmission Mount
  147. Need some easy help
  148. ? about rear windows..
  149. hid headlight not working need a temporary fix
  150. 2001 AC compressor bypass
  151. Will 2003-2005 g35 sedan seats fit in a 5th gen maxima or i30???
  152. any bluetooth recommendations or non bose radios
  153. Cannot figure out vacuum ports of upper intake manifold
  154. O2 Simulator to the Rescue
  155. Grounding kit question
  156. Performance chip
  157. Overheating Issue
  158. Lowering sping help asap
  159. A/C and Boss stereo lights not working
  160. Replacement headlight
  161. VR38TT internals
  162. low beam wont work (tried everything)
  163. A little dusting of snow *pics*
  164. Intake variable timing sprocket problem?
  165. 4AT to 5AT
  166. color ideas
  167. What should I expect to pay for cv shafts?
  168. cant.get.rytes 4" intake and tune reaction
  169. super custom Retro projector build, 5.5 style!
  170. Help from suspension experts
  171. Any way to disable / turn of Service Engine Soon light?
  172. 2000 Infinity I30 noisy power steering
  173. Proper belt tension 3.5 ?
  174. CEL on code P0011
  175. Cattman Headers production Run December 2013
  176. Wheel Opinion Size?
  177. Intake manifold gasket replacment.
  178. OEM Block Heater Q
  179. Code P1320 Ignition Signal Primary
  180. 00 Problems starting.
  181. 02 Maxima Auto Help
  182. ...Sway Bars
  183. Computer fuse blown ?
  184. disassembled my gauge cluster and touched the fuel gauge needle...
  185. 02 Sensors again
  186. Silver vinyl wrap on interior
  187. 2001 Maxima with 180K Miles
  188. Camshaft position sensor
  189. Mystery plug need help!
  190. P0505 - damaged ecu caused by shorted out rear motor mount (pic)
  191. Alternator issue..... Please help
  192. 2003 Maxima Trouble Codes.po174,po113 x2,po1800 Help Please
  193. Broken/Misplaced Links ??
  194. Parasitic battery drain... Audio fuse
  195. 4th Gen A/T Starter Work on 5th gen M/T?
  196. Has anyone experience this ?- coolant & oil mixing due to bad water pump
  197. Windows have a mind of their own?
  198. Need Stabilizer Bar Links, Which to Order?
  199. Gauge Cluster Bulbs/ Bases
  200. clutch feels funny
  201. Electronic motor mounts
  202. Question about vacuum line !?
  203. Rusted Radiator Crossmember
  204. Alternator question!
  205. Clunking suspension
  206. Do the top bolts on rear shocks back off?
  207. P1320
  208. Can I get a Power Steering Hose from an Altima?
  209. Anybody ever clean IACV 2000?
  210. Replacing front door courtesy light
  211. 4th gen addco rsb on 5th gen
  212. question
  213. 2001 projector retrofit questions
  214. NEW Cluster
  215. Had to buy it, price was right!
  216. She's pissing anti freeze [2001]
  217. starting problems
  218. Can't Find an Oil Leak
  219. ECU pinout question
  220. Idle Problems
  221. buying coilovers
  222. Where can I find used manual transmission for 2000 maxima SE
  223. 03 Maxima Check Engine Light
  224. Does this sound like a bad IACV?
  225. Throttle swap..from a Pathfinder
  226. should i try to put the G35 UIM& LIM or stick to SSIM?
  227. vq35 engine casting leftovers?
  228. Maxima getting hot the eventually overheating.
  229. Quick valve cover gasket question.
  230. How to open driver door stuck locked
  231. Key Fob not working
  232. Pass side headlights went out
  233. ugly front end
  234. ugly front end
  235. 2002 Nissan Maxima Rear Camber
  236. wheel bearing problems
  237. Suspension problems
  238. ABS Issue
  239. Clutch Replacement: Dealer says / Need input
  240. 5th Gen Non-Bose Base Head Unit AUX Input Mod...?
  241. Cattman headers
  242. Code p0400
  243. I'm Looking For All 4 Grey/Gray Window Bezels
  244. Maxima Headlight lid
  245. High pressure power steering line
  246. Headers!
  247. Ebay Front Catalytic Converter Question
  248. 5.5 Gen Tail Light Project
  249. Might be trading in my 2000 SE soon and want some opinions.
  250. Do not use AutoEcu!
