- 2000 max now a six speed
- what is the diffrence between these wheel spacers.
- Wider tire that fits right on SE rims?
- What does an O2 simulator do?
- Simple PLug and Play HID FOGS?
- PIC REQUEST: 5.5 gens with Stillen body parts
- 5000K Picture request
- AXEL NUT SIZE? (CLICKY AXELS) 5.5 gen, 6spd
- NEED A REPLACEMENT CLOCK, don't ask...
- AE Shift Knob
- Side marker lights issue.
- slight thumping/thudding at low speeds when curving right
- Fog lights wont turn on. What to check for?
- HID diagram needed (I included my lights pic)
- Monroe Sensa-trac Shocks
- Lawsuit regarding IACV burning out ECU
- SUPERCHARGER KIT!!!!!!!! puppet master help ! hahaha
- KYB GR-2 or AGX? Please help.
- another exhaust question
- front seat questions...
- Engine Leaking Oil? VQ35
- 3.0L 5th gen max injectors
- anybody had this problem?
- 6spd trans mount pics
- just ordered these taillight tint covers
- exhaust sound
- CEL codes P0011 and P0021
- Am I getting ripped off?
- UDP...Is it really worth it?
- shifter swap
- Where can I buy clear corner markers?
- Trouble Code
- I think my ECU needs an update..what if it's already had it? 420/430
- Re-Installing Stock Bumpers
- some problems im coming across
- Found a VIP style 5th gen...
- Rear cup holder insert???
- Do you have to pay for a TSB fix?
- 2000 Maxima No power @ WOT, no codes
- What type of fuel do u use 02-03 maxima owners
- 5th Gen 5-spd Swap Parts
- 2000 Fuel woes
- Shiny Door Trim
- Changing PCV on a 2000 Maxima?
- Any interest in front door speaker spacers/adapters?
- Urgent held with rear brake calipers? Do I need to replace them!?!?
- Interesting problem:
- Differences between 02 and 03?
- spark plugs
- sounds like a squeak
- Is This Really Possible
- Air bag question
- Cleaning headlights
- Cylinder # and placement
- which connector to tap into
- Warspeed y-pipe??
- Battery connection problem
- lip spoilers
- Which is better?
- Torque Converter?
- which o2 sensor????
- Convert to Daytime running lights
- Can I replace non-heated mirror with a heated one?
- What are some of the little things that need maintenance/tune-ups?
- Jet Computer Chip Upgrade
- CD speakers, problems
- Need lots of info on the 00-01 VQ30
- Alright I did my homework on the vafc-II
- Hole In Firewall??
- headers
- Funny noise coming from front driver side during start-up
- any using metra 70-7551 nissan amp integration harness?
- Car flattens out at certain RPMs-no check engine!?
- Vibration around 2k rpm? bad motor mount?
- Best time to fill up??
- 02 Factory Alarm Question
- license plate lights
- How do you replace burned out gauge bulb??
- Need Remote starter installed
- Upgrade to a 5.5, what to look for.
- Po420 code??
- Do they make perimeter billet grilles for 2001???
- Hawk Pad users step in please...
- Need new tires
- Opening up 02-03 Taillights
- 1700-2000rpm rattle solved(on my car anyways)
- Transmission mount
- 2002 Power moonroof
- SMASH!! My Maxima got crashed :\
- 2002 in the shop. Tranny getting looked at!
- Warpspeed y pipe
- AE Tail light Q
- Its probably here somewhere....5spd Q's!!!
- Toyo Proxes 4 in 5th gen stock 17" size? Do my eyes deceive me?
- buying AE Tailights
- What kind of clutch to get?
- 5.0 gen flywheel question:
- climate control
- Knock Off PR Style CAI?
- Help Front Strut Tower Brace install
- anyone using NGk BKR6E-11
- do not buy speed racer y pipe
- DR MOD is on crack
- Starting in 2nd with automatic?
- VAFC-II wiring
- what kind of role does this thing play under the hood? Help
- Replacing clutch
- Weird sound from my Right Rear part of the car
- Sunroof Control Problems
- Question for electric component pros!
- Engine oil DipStick.
- D4R bulbs....will they work in our max??
- what is the best 6000K HID bulb out there??
- my LED int light
- best carbon fiber
- 2k HU VS. 2k1 HU
- Cusotm DIY Angel Eyes! (5.5 headlights)
- How much do you think it will cost to fix??
- LED Tails - Done with Pics
- Stick with 5th gen, or swap for 6th gen?
- HID woes - how do you replace the bulbs!?!
- check engine light on after intake install
- Programming Key Fob for 2K MAx
- Exhaust question
- My baby's been hit
- Spark Plug replacement - 3rd set at 149K
- Reverse Light Switch
- 2001 SE Audio Question - Stock Cd player with Amp+Sub
- Time for a D2 rebuild...
- 2k2 Transmission Problems
- Sub
- P0420 linked to MAF?
- Speedo Bulbs for 2002
- Pic Request- In dash screen
- How many miles on your stock MAF?
- SES light??
- Considering buying 5th gen
- Speakers
- Cold Start
- Has Anyone had to rebuid their tranny and......
- Tranny Question
- vis r34 bumper
- HELP! Question about nissan stealership.
- dash lighting out
- For those of you with the "Blower Motor Only Works on Level 4"
- Have you used AUTO-RX in your 5th gen's engine?
- Memory Seat Qst
- stillen has injen intakes forsale
- Leds that put the sun to shame
- does anyone have these fog lights?
- Tranny getting lazy...
- SE heated side view mirrors?
- Heated Seats - interesting Q!
- Spacers 15mm or 20mm?
- 2k2 headlights in a 2000
- Brake pads problem. Please help.
- speed racer performance y pipe
- noise on startup,....cant be good
- 6 speed
- Master Key Issue
- VCT Solenoid Replacement?
- Air intake (K&N) bad for a car?
- Scan Gauge II
- axis hiro
- Question regrading steering wheels audio controls
- Spark Plug Question
- Headlight ?
- Stock Maxima HID bulbs
- Whats the deal with frankencar?
- Car Alarm siren
- Any difference in 5 and 5.5 gen mufflers?
- Will we ever have HID projector headlights??
- Light Up Door Sills
- Maintenance Question
- Grinding noise when coming to a stop in front brakes
- Engine Code 0550- Power steering sensor
- Car died when first started and started up fine after..
- Brake time, (front pads and rotors) worth it to do rear pads too?
- need wiring diagram
- Car starter install/help
- Front Wheel Bearing replacement
- Exhaust Kits
- hardwire radar detector
- Angel eyes/halos/DDEs question
- Damn D2's and their damn clunking!!!
- Spring compatiblity
- Parking Lot Hit and Run
- The GAB, what a great little mod
- Lowered and Alignment Problem:
- What's wrong with my struts?
- Plastic Engine Underbody Covers
- Want to upgrade my HID's
- ebay CAI for 95-99 fit?
- Where to buy cheap cat. conv. ? parts question
- Fuel pump noise?
- Garage Door Opener Controls in Visor
- Blackstone Lab recommends Dino oil
- Reverse Lights wont come on
- 2k SE 135k stalls at idle???
- What kind of bumper to get...01-02 and are ebay parts junk?
- ES motor mounts Q.
- Ebay Yellow Halo Fogs
- remote start question
- k-sport springs for the 5th gen...
- Windshield Wiper Issue
- Hub bore on a 2k?
- Looking for some AfterMarket speakers
- How Do You Think These Wheels Would Look On A 5.5 Gen?
- 2k3 Max v. 2k7 G35S - long
- safc-II vs vafc-II
- 2003 6spd axles, how many splines?
- Urgent engine acts weird!!! please check
- Axxtion Short Throw Shifter? (anyone running it)
- Remove Grill 5.5 gen
- freak accident.... ECU dead
- 3rd Tranny in 3 1/2 years...!!!
- Power Steering and IACV operation
- custom CAI plans.. not goin so good
- crankcase vent hose question
- Anyone have the update disc for GPS Nav system?
- Need some clear corners advice
- chrome door sills
- Do I need a tune up??
- Question about Slight Hesitation when starting 2K1
- Clutch Pedal Travel Adjustment? (is there one?)
- Strut Question
- Engine Shakes. Engine light came on...Help 3.5
- I think I need a new transmission...
- Brake light and battery light On
- interchangeable vq35 motors?
- HELP!! Car Barely Moves!!!!
- Accident, Need Advice...
- will 2k stock springs fit on 2k2
- cold start....car almost stalls after putting in drive and hitting gas
- Mod Suggestion
- rear axle beam question
- "A/T Check" came on..... HELP!!!
- Need your Help guys!!!
- Roadside Emergency...
- apexi vafc II install instructions
- Heavy Engine vibration until 1500 RPM...
- White Smoke from Under Oil Cap in 3.5L Engine
- 01 maxima blower motor fix
- Leaking windshield
- ticking noise
- My poor Maxmia
- the Anatomy of a MAF...
- Will a non bose unit work in a bose car?
- Bad Bearing,Hub, Or Knuckle
- 5.5 Gen/Does engine exhaust come out of exhaust both tips.
