- CENTER CAPS FOR G35 Rims
- Cold Start stalls...
- creaking noise from?
- Timing Chain Dealership Experience
- It was the wheel bearing and hub
- Car wants to stall when starting.
- Max Factor "rides" magazine?
- STS for 2000-2001
- spring rubbers to stiffen your spring rate
- Where in our keys is it safe to drill a hole?
- Brake Upgrade Recommendations - 2002 5.5 Gen
- So i entered my first auto-x
- Did my susp. this weekend....but
- Chinese rotor question (repost)
- Is this causing the noise Im hearing in the transmission? Help
- Brake Pad ?
- Quick question about axle removal
- Sunroof Tilt Seal
- Clear Head/Tail Light Covers
- One headlight won't turn on, lamp and fuse are fine
- Installed my COSMO CAI, today
- Replacing Radiator Fan, noticed this?
- How long does an oil filter last?
- Megan OE RS for Canadians!
- ES Shifter bushings
- Suspension Shopping List?
- New TCM To Fix Hard Shifting?
- Real weak FM signal.
- Poll: What tuning devices is everyone out there using?
- First CEL? What to do.
- windshield trim question
- Titanium Edition interior trim
- Where is the 2K2 Front Bumper Swap Instructions??
- How do you take off front and back side markers?
- replaced ABS speed sensor now Cruise control don't work
- Who has re-packed their bearings and is it DIY worthy?
- What other years did the auto LSD tranny come in?
- Cattman 3" catback
- wtb/.. center wheel cap
- Where are the 2K1 to 2K2 Bumper Replacement Instructions?
- headlight depot HID's vs OEM
- 00 Max Failed emissions (CO)
- 4th gen progress RSB?
- Brembo Brakes
- Nismo black ball shift knob, will it fit?
- BAD COIL
- Rear speaker stoped working, any ideas?
- BATTERY DIED NOW LOCKS & REAR DEFROST.............
- Rear brake job... help
- Bosch Generic or OEM O2 Sensor?
- Clutch Bleeding question
- Intermittent code 1320 experienced
- bottom radiator support bracket
- Can u/have u changed frt sway bar?
- Annoying catalytic converter.
- Codes P0440 & P0420
- ONLY GRINDING INTO 3RD. NEED YOUR OPINION PLEASE!!
- weird noise from front left...
- Cattman Headers, Fastcat, Catback Full Exhaust Only
- 5th Gens "Dropped" Thread
- Wheel clearance question!
- wanna go lower!!
- maybe a maf prob?
- Blemco, Z32 Calliper Upgrade BBK
- Adding TCS, a few Q's
- My LED mod for tail lights
- Where should I buy good headlights?
- Tire Shopping
- Rear Bumper Grommet?
- NISMO 380RS Gas Pedal
- Lost...questions on VQ35 6 Speed Swap on a 2000 5th gen
- wheel spacers
- grill-tech
- vfiber kombat nose
- tint the inner taillight
- tranny issue...i think
- Driving Without Axle-Back (Muffler)
- Odd knock or pop on the passenger side
- performance ignition set?
- Bose and wiring harness?
- Headlight Bulb?
- running lean and rich at the same time?
- 5.5 Gen Navi?
- Reverse, pop, then sounds like the tire is flat but....
- Rumbling sound from heater
- Bad strut /strut mount at only 56k miles???
- Using Toyota oil filter for Maxima?
- Just resurfaced the brakes
- Auto Tranny issues
- led size?
- Bose Radio not working after disconnecting battery? Not a fuse problem
- removing the c/v axles help
- Im out an HID fog light,.. buy another 3000k or buy(2) 5000k to match the headlights
- HID'S
- show me ya grill!!!!!
- 3Bspec foglight install question
- cleaning intake manifolds
- Ultimate Tune-Up
- maxima bose sub/ g35 question
- Odd Starting Issue (MT)
- How the F*** did i screw up installing clear side marker lights lol
- this sound sucks... help
- Ever seen an in-cabin filter with 200,000 miles on it?
- idle problems in gear (thump/kick/chunk) 03 AT
- Starting Problem
- 03 MAXIMA VSS WIRE LOCATION
- 2k2-2k3 retrofit turn signal wiring
- Whats more worth it?
- Noisy Console Shift Interlock on 2K3 Automatic
- New Maxima, new problems!
- Q45 calipers over stock 5.5gen rotors
- Ball joint install
- Location of Paint code on our cars??
- Hotshot headers installed
- 2002 Maxima 17inch SE rims on '02 Altima
- speedo reading off
- Complicated window switch problem, Experts help please!
- 5.5 gen fog lamp replacement
- Locking Differential?
- Door Clips
- Shopping around for clutches
- walling trunk
- Gas tank fill-up ?
- looking for led conversion pics!
- All Maximas 4DSC's?
- Dose anyone have this key?
- 00-01 getting a 3.5l?
- subframe bushings?
- New Owner, odd issue
- squeaky sound on turning need help
- Removing tint from tails
- Wheel bearing problem?
- New roof spoiler
- 5.5 gen camber ?
- Clear Door Lenses??
- anyone running faskbrakes 12.6" 4 piston caliper kit?
- Rear clear makers
- Brake Pedal Pressure Issue
- 5th Gen Aftermarket Headunit and Other ICE Pictures
- 5th Gen Bodykits, Lighting, Exterior Modifications Pictures
- NEW STICKIES in Progress - Need Your Help
- The 5th Gen Piggyback/Tuning Thread
- Thump sound coming from rear of 00 max
- turning and makes a metal on metal noise
- 5th Gen How-To/DIY
- 5th Gen Modifications
- Rpms high on parkway?
- Ticking/tapping noise
- best intake for the 5.5
- ahhh I miss my maxima
- Front and Rear side markers
- Wiring 5.5 headlights
- Swapped Motor Problems?????
- satisfied gransport 6 pads
- WTF is this stuff on my oil dipstick?
- P0139 and P1147...
- 00MaxSE project2 headunit installed (pics)
- Coming to a hard decesion...
- 02 to 03 Trade? Opinions?
- Miles required after SES Codes Cleared
- Turn signals issue
- Front marker wiring got stripped off during a fender bender ... what parts do I need?
- What do you think of warpspeed's ypipe good or bad?
- So new headlights.. Just not fitting
- P0302
- this may be the audio wiring diagram?
- help! vavle cover replacement while putting on NWP spacers?
- what are the two sensors that are fan switch
- Spacers and Vias installation/deletion today!
- kinda dumb question about my 00?
- maxima mirrors
- Aftermarket replacement parts?
- Are the Bosch O2 Sensors for 5th and 5.5 gen same?
- Looking for 01 Max Ignition Coil Connectors
- pulsing dash lights
- catalytic converter question
- Utec
- ECM connector help me
- Hard shifts and CEL lights
- Replaced Spark Plugs... Idle Issues
- So, um... Will you take a 3rd Genner?
- 5th gen bulbs?
- Please Help...problem with corner lights, brake lights and dash board illumination
- Clutch issues, keeps slipping
- Bose issues...
- GAB - minus the ghetto
- squeak at 1000 rpms...
- LED tails
- Power Window One Touch Up Problem
- Shifter cut and weld
- Just got Pummled .....:(
- Regarding spring/strut area on an 03
- Cost for a clutch change?
- Rear Rotors wont come off
- SES Mystery
- Coolant leaks. What's wrong here? *pics*
- MAF
- I think my engine is falling out
- On/Off Throttle Feel/Jerk
- P0100 and P0505, car dying at idle...need advice
- Power stering fluid flush?
- Is there anyway
- Muffler Question..
- avital 4400 remote start
- Coolant Leak from the metal Housing
- AXLE PROBLEM HELP!!!!!
- Another strange electrical problem thread...
- Andysautosport.com
- How to find vacuum leaks...
- Check Service Engine LIght Questions?
- Tips/Tricks for Replacing Clutch Master Cylinder on 2001
- Anybody have or seen these installed?
- Anyone had problems with Dorman Control Arms?
- RSTB for the win
- weird P0420
- Timing advance 1st impressions
- soon selling eibach springs
- Download Factory Service Manual?
- stillen rear strut tower brace
- Tein SS Wrenches-Need to Borrow ASAP!!!!
- 5.5 gen headlight disassembly
- $tillen classic lip 02-03
- 2 VIN's on one car? What the f....
- Obnoxious shake - advice?
- Auto Maxima 5.5 Gen - 2nd Gear Power Loss
- ECU SELLERS?
- ECU reset question
- tax return time ( gift for the max)
- yes yes... the popping sound while turning again
- Wheel Bearing and Hub Assembly
- Norkoastal's Part out Sale!!!
- Careful Replacing Rear Side Marker Lights
- 02-03 motor mount how-to??
- HALO headlights with HID conversion
- weird tranny leak problem
- Where can I find those Bright White Lexus License Plate Lights for Maxi?
- 6 sp. 5.5 Gen Maxima
- Installed intake, now it hesitates.
- 02-03 headlamps
- Megan OE-RS exhaust owners
- Braking Advice
- HELP!!! car wont start!
- Knock sensor
- Annoying rear clunk
- 6 Speed Transmission Harness
- Willwood kit Clearance
- Car Drives Like Crap - Please Help.
- 5.5 gen housing
- Instrument lights out, how to replace?
- Please help - dashboard illumination is gone...
