- exhaust clanking noise
- fender bender :(
- lug pattern
- I need some help.
- carbon fiber dash kit
- Error code 0420 and racing pipe?
- Power Steering Filter ...
- Rep your town.....
- Weird Intermittent Sunroof Issue
- Drivers side window - does not open
- programming keyfob
- Gear Shift Question
- Automatic headlights
- Like my new wheels? (Photochop)
- ignition coil. How to replace
- Grit or Film on inside headlight....what to do??
- Any clue on tightining the steering wheel....
- Brake Experts. Please Step Inside.
- best pads with oEM Rotors
- question on energy suspension bushings
- Reprogram my Nissan Key - anyone know how?
- Tranny slip!! HELP!
- rattling sound?
- manual-manual swap-easy?
- Putting A Sunroof In Your Max.....question
- OEM H.I.D. Bulb has Officially Burned Out!
- Frozen Caliper (replace one or both)
- ES Sway Bar Links
- Steering wheel controls 5.5 Gen
- Whirling noise from the EEM electronic engine mount
- The Great Brake Pad And Rotors Thread.
- 5.5 gen rim offset?
- cross drilled+slotted Rotors
- Taillight tint covers
- I know im going to get flamed, but......
- 03 SE Question
- 130K Service
- Power Valve (butterfly valve) one screw is missing on 3.5L ...
- key fob buttons worn down with age?
- I need help with ES bushings
- Made the switch from Eibach to H&R...
- Is it possible to replace the plastic housing on my 02's headlights?
- Lack of power.....
- Any vids/pics of turbo 5thgens.(3.5)
- infiniti g35 coupe rims
- Dielectric Grease ...
- Exhaust Help
- Afcii True Or False
- Dash-Clock, Instrament Lights, Hazard lights w/ remote lock, Fuse Help.
- VIAS cup orientation
- A $794.8 service at 39k?
- What else could cuase shake?
- Drive Belt tension gauge
- Best Clutch?
- is it illegal to not have the f&r side markers light up?
- Ebay Tokico struts
- My Trannsmission is shot... NO it's your CATALYTIC CONVERTER???
- New Eyelids, tell me what u think
- Can a bad O2 sensor cause knocking/pinging?
- TCM question
- HLSD installation
- Sound Clip of EBAY Catback Here!!!
- Weapon R Intake
- Battery and Brake lights stay on
- What will a bad tranny do?
- radio issues
- Installed SAFC II and dynoed it
- ELC system 2 fault P1448...what is this?
- need help with fog & headlight bulbs...please advice
- progressive or stillen....
- What are the chances of a belt tensioner going bad?
- ?? from 4th gener for 3.5 owners
- Front End Noise
- Ratings 1-10 Tokico illumina struts
- can an OBDII scanner pick up codes that dont throw CEL?
- Knock Sensor Install Write up?
- abs speed sensor part number
- What Is The Best Spark Plug 2 Use on my max?????
- locking wheel to left, I hear a "crunch" noise...wtf?
- WTB, 2002 Maxima bra
- Gxe Radio/dash Trim/ring?
- Question about Maf
- whats up with my battery? leak?
- Suspension advice
- 100k Maintenance
- anzo projector headlights..
- getting a 2 second squeal on startup?
- Dime-Sized rust spot...
- H3 Reverse Mod?
- Vq35det boreoutkit
- for those who have 2003 headlights on their 2000 maxima
- Synthetic Brake Fluid ...
- Pic request
- Help, might be getting 03 350z rims on my 00 maxima. Need help and opinions!
- Testing Your VIAS
- Place Racing 5.0 Gen CAI
- how to post pics
- difficulty in replacing O2 sensors??
- Yes I searched....tire question 235/50R17 vs 225/50R17
- How to clean crankcase using seafoam?
- Good ole' brake fluid
- Governor on 5.5 gen auto
- Tranny Problems
- Nedd exhaust help
- how could i fix my headlights?
- Custom exhaust plan
- Climate control fan missing speeds
- New Headlights & Grille
- Anyone know about Tranny's & Torque Converters in a 5th gen?????
- Maxspeed springs??
- Rear windows in 5.5 gen...
- ATTN: 6m/t owners...My dilemma...
- 00 and 01 full gasket set different????
- Best Rotor and Pad combo
- Is It Necessary To Clean the AC Condenser? please READ!
- How do you read the VIN #
- Perform TSBs for free?
- Looking to re-wrap steering wheel.
- Ebay catback
- Driver Side Window does not come to a close
- reg gas cause of knock in engine
- Trunk scratch TSB: rust
- New version Faktion STS for 5th gens. Anyone??
- Help !!!
- New Mods for next week, Comments
- Chrome 18" G35 Wheels?
- it is unfortunate that KYB refuses to make the AGX for A33's..
- Spring Compressors needed to install H&R rears?
- 6K HIDS & 6K FOGS...comments welcome
- Power steering fluid leak??
- auto tranny hesistation?
- i35 cluster in the 5th gen 3.0 step in...
- Getting rid of EGR after headers install
- tranny fluid supply line ...
- UPDATE after accident
- o2 simulator
- HIDs in fogs
- Weird rev issue
- Modified Injen intake, and now I think it is the MAF
- replacing headlight bulbs
- Slow with AC on...
- Battery issues
- tranny cooler
- are you suppossed to check ATF when hot or cold?
- Rsx Vs Max Talk
- engine ckeck soon
- Its Official...
- Accident Pic....ahh poor Max.
- WTF!!! Fuel door issue!
- I need a new exhuast....
- Arghhh!!! I hate Eibach springs!
- Got cel for igntion coil, installed new plugs problem solved!
- Need help with Fog lamp - 2000 se
- can someone help me make since of this fuel issue?
- ABS Sensor Replacement
- Stock HID looks purple on one side....??
- My sunroof is semi-broken.
- Spark Plugs?????
- Anyone running a safc on a N/A?
- ABS light is on...how come?
- Side Marker removal ?'s
- Would this Pathfinder Mp3 unit fit in my car ?
- Will pulley setup fit from a 350z or g35?
- Car won't after changing spark plugs
- PIC request of steering wheels
- oil light?
- Hose that connects to Trans (02 MTX)
- Im sorry but....
- Intercooler to a 5th gen Maxima
- Automatic Transmission Flush
- Tranny Bearing Problems
- is this possible??????
- Used 5.5 Gens
- Anyone Have A Picture Of G35 Sedan Wheels On A 5.5 Gen?
- NOOBS: Injen,Berk,Frankencar,Popcharger,GAB are NOT "true CAIs"
- Problem With Manual Climate Control
- are red stuff brake pads any good?
- Now I'm A Offical Newbe!
- Exhaust is loose...
- Check CV axle
- Ksport help please
- In refernece to the GAB... what do u think about this?
- Shift knob screws??
- Where to get clear lenses for turn signals?
- Service Engine Soon Light
- do headers really make a diffrence in accleration
- Need Pictures of 350Z Deal Pedal
- Cattman/Progress RSP Question
- tail light covers....what's your opinion
- Any luck w/ aftermarket starters?
- ?? for Helios HID fog people...please step in..
- Have an FSM? Look something up for me, please...
- Coolant Temp Gauge (which Sensor)
- Location of oxygen sensor
- Cheapest place to get OEM brakes
- Trouble wiring 2k2 HID's 2000
- Need some help please (rattle)
- vq30de-k manifold question.
- Cool lil pic....
- anyone had this problem?
- Broken Valve Cover Bolt
- replacemnet for aniversay edition lip
- jetchips
- Please see and tell me which one to go for....
- Ignition and flickering base display electrical problems
- Gapping a sparkplug
- What can I do with ALLDATA?
- What do you all think??
- climate controll
- Auto Tranny Guys - did you replace your gasket when dropping pan?
- Can we save gas by having 3.0L
- Need Help
- SPOTTED: 5th gen with NH plate MAXXIMA
- Automatic Transmission slips on last gear
- replaced something under Warranty? step in
- which one is better...
- SES Light: Code P0138
- Vias Fix
- Cattman basic suspension package.
- Clutch pedal adjustment?
- How do I test if there is a draw on my battery when the car is off?
- VIAS Ratttle at 5600 RPM's...
- Idea for the rear door speakers. Plug your ears!
- who makes speaker adapters ASAP????
- Fuse problem...Help!
- Are 4th gen & 5th gen catalytic convertors interchangable?
- Wow! a 5 cyl. maxima!
- Expected 1/4 mile time?
- Is this maxima owner a member of the forum
- aftermarket y-pipe with stock catback
- got the car tuned yesterday
- Need Advice Before JIC Install
- K&N or AMSOIL air filter
- hesitating at first startup
- Wanted pics
- Please take a look and tell me what is it???
- 2000 spark plug gap ...
- Help me with a muffler choice
- intake setups....(pics please!!)
- wheel spacers ?
- Gas Mileage
- ES Bushings
- can't find
- Have automatic, wish it were 6spd...
- Wheel bearing...
- 2001 se
- how much is my car worth??
- HID Fog light problem...
- stut mount bearing replacement advice needed
- Gold CADIUM Plating on Rotors
