- removing 20ae body kit
- strut confusion....
- What's wrong with this engine bay?
- Need Help! I'm swaping a 03 Auto to a AE Auto
- bbmaf threads not working.. can you find these threads
- New eBay 5th gen FSTB for $20
- Which seats can fit on a 2k2 maxima?
- Oil filters that stops the clatter on start up.
- Brakes or Wheels The definition PITA
- What bulbs are you LED/Angel eyes members using?
- hopefully simple IAT ???
- Cattman Y-pipe discounts for 95-01 Maxima test fit in OC/CA
- ECU replacement Questions
- "Ultra Racing?" Anybody?
- Are the front and rear coil packs different?
- A few questions about the gab mod
- Tien EDFC
- Rough idle when warmed up + P0300
- spark plug non foulers..Make your engine leaner?
- 4th gen crank pulley on 5.5
- Who wants a FREE carfax report? setp in
- Replacing Ignition tumbler... help?
- exhaust leak
- Need Help - Resonator Replacement
- Good Website To Buy Motors & Transmission!!!
- OBX Headers installed BUT... help
- Possible future interior overhaul. Suggestions?
- help, light relay or bcm problem?
- HELP Hesitation and hesitated starts
- Fan Control Amplifier
- Cleaned Throttle Body... CEL is now on
- 5 Check Engine Codes, Help!
- putting an HKS exhaust axle back on stock pipes
- Tranny Mount????
- Not a fan of the chrome window trim... What are my options?
- 97 -99 se rims on a 5.5? will it fit?
- 02 parts on 01 Max
- sliders on calipers need to be replaced
- My trunk slams shut
- Are all MOOG parts upgrades?
- E-Brake problem (help)
- like a dumbass.. i broke a stud... no not me..lol
- Anyone tried seafoaming?
- Dual auto windows in 5th gen
- reduce your highway windnoise now!
- I did the impossible!!! Fixed heated seat...
- brake master cylinder
- Possible blower motor out?? Please Help
- Moog swaybar end-links: are they _too_ big?
- Rattling during acceleration. I've searched!
- differential bearing?
- Loud Squealing, but only in Reverse!?
- Attn: Stillen RASB
- Help! Strange Heated Seat Problem!
- check engine soon light is on
- 6SPEED SWAP VS SUPRASTICK: WHAT WOULD YOU DO???
- Rear door (driver side) is locked from inside and outside .. please help
- new ebay headlights..
- missing the actual front cigarette lighter assembly
- Power seats not working properly?
- help, two weird problems.
- This is so retarded
- Need to install Bushing (NY)
- What's the gear ratio/configuration of the 6-speeds?
- Wheels Specs Question???
- $200 Rebate on Pioneer Navigation [Holiday Rebate]
- HID Fogs
- Thumping sound over small bumps
- Some new paint work, what do you think?
- Have you seen this video?
- powdercoating wheels - what would look best?
- 3rd cv axle in 3 months?
- Center Caps for Winter Steelies
- Anybody ever replace their subframe bushings?
- update- new alarm and stereo setup up and coming
- Vibrations Vibrations
- black ON BLACK! Opinions needed for centers...y/n??
- Oil light on but dipstick reads full - please help
- 96 motor into 01
- Coilovers
- Engine problems at 3500RPM and more
- will this fit my maxima 2002 se?
- how do I change this clutch fluid hose?
- Would you put THIS on your 5th gen?
- What's everyone doing for CAT replacement
- Head Unit Bracket
- 5.5 Gen Front Bumper Issue
- Picture Request Please
- Which 16" wheels fit on Z32 TT brakes?
- Check out these wheels!!
- wiring hi/lo converter to non bose radio
- Two Major Issues
- hard knocking noise when going WOT
- I never thought I'd find this, but I found the world's ugliest 5.5 Gen Maxima........
- Ball Joints Question
- Ignition Misfire code.
- OH SH*T keys stuck in ignition...
- Any money for core?
- E/S Motor Mount Inserts
- Is this a good deal?
- Bigfatty signing out, thanks for the help .org!
- Does 6th gen Trunk Mat fit 5.5s?
- UTEC wiring confirmation
- 01 steering wheel on 00
- Its that crazy squeaking getting worse in the trunk...
- G35 Rims question
- Are Bose's subs interchangeable between '00-'03?
- Bose to aftermarket swap question
- Auto. Axle different from 6spd axle.
- Wierd Auto shifting
- want to see ES Bushing installed
- Which Front Sway Bar Bushings -- 22mm or 23mm?
- whose christmas tree is this?
- Auto Climate Control Button Indicator Light
- website to buy hids?
- Should I get the whole car painted?
- Does the Megan Cat-back still exist for the 5.5?
- help please.
- clunky sound
- Manual to Auto 5th gen climate control
- CV Axle replacement - Yes, I've searched
- 2002 maxima with P0226 code
- Pioneer releases FREE iPhone App [demo video]
- 12v Pwr Line from Eng. Bay to Cockpit????
- Radiator fan assembly removal
- Auto & MT ECU pigtails. Are they the same???
- Need some help diagnosing suspension problem
- driver side door hanging low
- Lowering Springs- Anyone using different springs on front and rear?
- Cut 6mt 5.5 shifter stick?
- New BMW ride but keeping my 2001 Maxima
- ABS Issues
- Steering column mistake
- cost for new rear bumper fascia + paint + labor?
- Laptop mount ?
- my DIY-one-man-non-asphyxiating seafoam device
- IS THERE ANY OTHER LIP KITS FOR 02-03? Gosh!
- How long will this Cattman Exhaust last?
- Seafoaming, spark plugs, valve covers/pcv, knock sensor, TB/IM cleaning...here we go!
- anyone running water wetter?
- Front and Back Bumper Removal
- Speed sensor wire
- Torque converter problems? Strange RPM problem...
- THEY STOLE MY MAXIMA!!!
- Electrical-light problems
- Going to buy a 02-03 Maxima/I35-have ?s
- 5.5 limited slip spare tire different
- Changed a belt and now the car makes a loud shriek when started?
- 3rd gear ?
- No AM/FM radio cable?
- Oh, so that's what that noise is.
- STAGGERED???
- Fastest 5.5 auto
- 02 vs 00 armrest
- looking for help with HID fog lights (long term use)
- EGR BS OBX Setup
- Need Help Quick - MAF sensor?
- New Alternator - New Noises
- moisture and water in taillight
- Engine Ticking Noise & Wants to stall
- Smog Test results
- HELP!! I have 6 check engine light codes
- A newbie with a ton of ?
- Transponder Key
- How do you install the gas pedal pad?
- All AEs step in with pics..
- How to ask for dealer reflash?
- opinions on a purchase please? (read first)
- Emissions Testing in North Carolina...Headlight issues
- Steering Wheel makes noise when turning...
- Tire size conversion
- quick question.. Belts & Hose
- P0420 code.....
- 02/03 Maxima 6spd VS. 05/06 Altima SE-R 6spd
- Friend wants to go to the track
- Question regarding Tein SS coilovers.
- Front wheels grinding (both)
- Fogs Backward Compatible?
- Testing A33 IACV, need member input
- maf adaptor question
- LED Gauge Conversion (109 LEDs!!!)
- 2 codes... p0031 and p0138 - help please
- Sticking accelerator peddle
- Help PLZ. FOG LIGHTS DO NOT WORK
- Dashhawk
- Rear Defroster not working??
- Fuel Delivery Question
- Code Reader
- Replacing Sunroof Assembly
- No Intake for 02-03 Maxima?
- Steering Issue
- Cowl drain?
- Pilot Bearing going out? already??
- goodridge SS brake lines
- Engine Noise
- Need Help finding 02 Bung Plug.
- supercharger
- i hear/feel my clutch pedal squeaking...?
- shifting issues - no reverse on a decline
- Installing ES Bushings under the Shifter Assembly
- Exhaust question
- Tranny Slip....and yes i already searched!
- Power Seat Problem
- Will 370z wheels fit a 2002 Max?
- Ground control coilver any good?
- illuminas winter settings.. what do you do
- Blower Motor Dead??
- shifter trim
- Sunroof Control Module in 2K
- Seeking Long Term Assessment on RTP Rotors
- Check engine soon codes! need help,installed berk intake days later light turns on
- Slow 1st to 2nd Shifts (Auto)
- License Plate lights won't light up
- Just installed ES 6spd bushings and STS - My thoughts...
- A belt in my car just popped, battery light came on but the car still drives...
- Overheated Brakes?
- Battery Relocation Installation with pics.
- High flow cat vs. test pipe - sound difference!!
- My ES project... Finally installed!...With pics!!!
- Wondering if I should sell before 2010
- Throttle body cleaning success story
- Megan OE-RS vs Cattman: Anyone tried BOTH?
- How bad is this and anyone else have this problem? Pics inside.
- Another OBX header Question..
- gas smell
- OEM 17" Rims Question
- Ebay exhaust on my 2002
- Broken shifter bracket... oh dam...
- who installed thier own o2 sim?
- Classic Stillen lip paint
- Transmission gets stuck at 2.5K
- car did something strange
- shifting issues 01 max
- Identify the Rusting 5.5 Gen Maxima Part (Fun for All Ages!)
- 6spd tranny fill plug missing?!?!
- clutch set ups?
- Strange symptoms (long)
- Light indicator on dash...
- Need help/Input-odd sounds and smells
- Replacement Alternator - Starter...
- Well, Original Altenator on i'ts way out!
- NEED HELP ASAP, Car will not let me go over 2.4k rpm
- A few minor Projects Completed....
- kyb strut differences?
- Fog Light Rocker Switch Suggestions
- cattman headers
- Are 97-99 radiators interchangeable with 00-01..????
- APEXi S-AFC vs. V-AFC vs. V-AFC II
- anyone use autolumination?
