- AE Headlight Mod write-up needed
- Bolt almost rounded
- Strange 6th gear problem
- Sold my Maxima...
- Need help for unknown ground cable & Pic inside
- P0160
- fuel pump question...
- Synthetic in an oil burning 3.5?
- HELP!!!!Serious Transmission Issues
- replacing ac compressor
- Need help ASAP on clearing headlights!!!!
- grille opinions!!!!
- Clutch Problems
- Couple of questions for my online friends...
- Its good to have my Maxima back!
- considering buying 5th gen
- Quick help needed on an Anniversary Edition
- Need opinions on suspension parts.
- Exhaust question
- front main seal
- TCM location????
- P0160 O2 Sensor install question...already used search
- radio reception with window tint
- BlackbirdVQ hotshot exhaust videos?
- 03 muffler question
- Has anyone replaced 6MT under CPO warranty?
- Wheel Bearing just went... how long do I have?
- Confirm NGK Copper Plug Numbers?
- Help! My car died!
- Copper NGK Spark Plug #'s
- Driver door doesnt close straight
- do 350z breaks fit on the 5th gen?
- SES light - replace EVAP canister?
- Well Known/Documented problems with 5 gen 3.0 maxima
- Help car won't start in the morning
- Throttle Position Sensor?
- Really crappy gas mileage
- Bose SoundSystem SUCKS!!!!
- Car won't start HELP
- The ecu smoked when plugged in.
- 2001 Have a BCM? Dead battery/parasatic load??
- Thule Cargo Box ?
- Nothing but Cracking coming from speakers
- Need Help: ECU reset location
- scrapping in a turn
- my car vibrates really bad in high speed, why ?
- Your Maxima rating
- Extended Warranty
- will a 2000-2001 ecu work?
- A lot of free time... a little interior project.
- Shaved Grille Nissan Emblem
- Splash Cover
- where did you guys purchased the fidanza flywheel??
- Were 17"s an option or standard on a 2000 SE?
- *Confused!!* Coils or O2 Sensor & Air Flow Meter. NEED HELP!
- Time to get a 350Z?
- Is there a way to see if a wheel bearing was just replaced w/o taking off the tire?
- Vibration and knocking sound; need help with diagnosis
- guess whose back?
- Axle replacement
- Shift Pad Removal
- 2000 Maxima tranny question
- Stock navi swap???
- BRAND NEW Tokico HP's blew after 1 week!?!??
- Bad CV Joint?
- Megan vs. Frankencar (pic comparison)
- Need pictures, please look
- Confused about how to read tranny fluid level
- Finally installed the modds that were sitting in my room.
- Clutch Fluid Question
- A33?
- How many shims ?
- Anyone having SES probs with y-pipe?
- ABS light on then car suddenly has no power. What gives?
- 5th gen motor in a 4th gen????
- Help Please
- P0138/P0139
- Another project... TSX Projectors into 5.5 gen housings
- AIRBAG O_O
- Messed up Tranny... again!
- weird problem...
- All interior lights go out when Headlights are on
- ABS Light and Flashing SET (Cruise Control) Light
- bad throttle position sensor?
- recall help asap
- Steering wheel pulling to the right..
- Some Codes, Unstable Idle.
- Odd 3.5 Thermostat Failure
- Can't Identify Noise
- Questions on '01 GXE door panel removal
- 2K2 DTC P1122 & P1126 - anybody? Suggestions?
- Hood Scoop v2
- 5th Gen Check Air Bag Light Flashing
- Bank 2 not firing at idle when warm
- Stock Maxima 6-speed axles work with Sentra Spec-V 6-speed?
- Dont forget to check this
- Help me diagnose a P0171 code
- new maf troubleshooting
- Front end clunk when going over bumps/dips....gets worse :(
- MrGoodlube "screwed up"Back to doing my own oil changes myself.
- Coolant smell no leak.... Help
- How can I remove the plug from the coils?
- Opinion on replacing '01 factory speakers
- "Overkill" Big 3 Upgrade Pics/Semi-Writeup
- Blue_Batmoblie's overlay fanatics
- "TCS" and "SLIP" light won't go off ...please help!
- What ecu can i use?
- STI badge
- Lowering my 03 on 20's
- 350Z rear brakes.
- My 00 Max stop breathing after 3 seconds...
- Maxima SE TE
- last minute confirmation
- Throttle Hang
- 2002 dash light problem
- Buying a maxima.. how to test for oil leaks
- Question about alternator mount point for "Big Three"
- Flywheel removal: what size bolt?
- One last thread for my suspension problem...
- connector on rearview mirror
- 00 Maxima, can i change the temperature unit from Fahrenheit to Celsius?
- How-to remove fog lights on 01 max AE
- G35C Seats going in a 5.5 Gen soon
- stainless steel brake lines
- HotShot Headers Installed
- Ebay M3 Mirrors
- Ideas on how to unstick the right axle (replacing it)?
- Programming remote, Remote Frequency?
- gauge swap questions
- Weird ticking noise in engine
- 20" FX35 rims on 5.5 gen
- Rev'ing it up = Battery not like... What in the Hell??
- Cannot for the live of me find B1S1 O2 sensor!
- Hood Scoop
- She wont REV.
- Maxima and I35 doors interchangeable?
- cheaper ebay hids
- Alignment question
- Cross Country Trip
- Battery Change
- Just picked up another Max
- Frost Inside Car
- ABS and TCS
- 90% new 02-03 Maxima Grill
- whats cost to fix cv boot
- New Struts and Springs, What else should I do while I have them off?
- new recall?
- 02/03 grill that I found on ebay
- P0178 Fuel Composition Sensor Circuit Low Input.
- Got 2 codes...unhappy with my car.
- 2002 6-spd shifting question...
- Officially Joined the Clear Club
- Got a how to on CV/Axle replacement
- My car got hit last night...
- Poll: Still with original Automatic Transmission?
- Crank Seal
- New MAF and Reprogrammed, But A Month Later Its Back To How It Was....
- Where to buy IACV Valve?
- Test pipe fitment issues, it's too long... (thats what she said)
- Belts
- Missing $10 part is going to cost me...
- How to cover holes in trunk?
- Metal Maxima?
- Transmission spiking during shift from 2nd to 3rd, please God not a rebuild..........
- 6th generation exahust swap
- Hit granite curb at 25mph - what did I break?
- Lost All Keys
- auto tranny acting up, with a new VB. HELP!!!
- 01 RR ABS sensor help
- Bad Alternator...cause starter bendix to go out?
- wideband cattman headers.
- 02/03 grill possible to put on a 00 Maxima?
- Got SES light on (cant google it and broken link in stickies)
- caliper pins
- Radio or clock not powering on!help!
- Bad Dealer Diagnosis
- steering wheel interface
- Is anyone else totally disatisfied with their Maxi?
- Regular 87 or Premium??
- Problem with my max
- Power Steering Belt Help
- Throttle Pedal Sticking
- SEAT SWITCH
- 5th/4th gen parts compatability
- automatic window roll down on a 2001 maxima
- Repeat Threads/Topics that have been discussed. Suggestion.
- cattman header then CEL
- 3rd Brake light cover
- Matching Stock 5.5 Chrome
- Another Grille Thread
- Dual exhaust in 5.5 gen?
- 5.5 Gen eating my wallet...
- 4th Gen vs. 5th Gen - A thread of Specifics
- Where to buy idle control valve?
- Weird constant brake squeal?
- Did the 03 GLE had the sunroof as an option?
- Climate Control
- stinky carpet?
- Rear Suspension. Does this look normal?
- need help with rear hub bearing
- Is this 5th Gen worth it?
- spoiler installation
- Quick Trip Meter/Tachometer Q
- spark plugs in vq35
- ecu question
- My max sounds like a wookie between shifts!!!!
- No power after 4k rpm
- 01 Maxima SE
- interior lighting advice
- Ebay hid fog conv. any thoughts
- NWP Phenolic spacers
- trans. ?
- help with Apexi safcII instalation please!!!!
- Possible to Replace Analog Climate Control w/Digi Climate Control?
- Wheel bearing?...
- variations of the stillen rear?
- ring question on 3.5
- 5th gen MPG?
- 01 SE AE Hesitation
- $622 For Y pipe ?
- Strange Noise with Steering
- going to buy a 5th gen but pros and cons between 3.0 and 3.5
- 5th Gen Common Issues
- 3 quick questions regarding fog lights and paint
- ABS Light... Help???
- p1126 Thermostat?
- Steering wheel interface
- Seeking Tech Wisdom, Leave MAF Alone?
- Replacing MAF
- Steering Wheel Radio Controls Not Responding?
- vin check someone
- Stock Shift Knob w/ TWM STS
- P0128-thermostat
- Nismo Short Shifter
- 5.5 Model Info & Buying Advice
- Shift Knobs that work with the 5.5 boot
- Need some help with thule fit kit...
- Very nice low mile 5.5 in classifieds
- Rotora or Brembro Rotors, which do you think?
- Belt for underdrive pulley
- 2000 Emission Warranty Questions (Cat and Pre-Cat)
- Heated Seats
- powerslot cryo rotors are great.
- 02 sensor location
- Starting Problem?
- She over HEATED!
- start up outa wack!
- Alternator install - same Alt. for all years?
- Eyelids
- Front and Rear parking light trick
