- sift kit install, help
- Infinity Valve cover
- Help me with my radiator..
- 6th gen BBK query
- HID goes out- What to do?
- Is there any advantage to getting cross drilled and slotted rotors?
- stillen muffler on a 5th gen
- where can i buy H&R springs for only the front?
- Sputtering
- Bouncy Idle between 1500-2000 RPM
- Rotors and Pads question????
- p0138/p0325 questions? 125,000 miles
- Tinting question
- Best place to buy rotors and pads for my 2003 Maxipad?
- R.I.P. My 03
- Tokico ABS line issue
- Windows Switch for GLE
- Lug nut torque...
- Brakes: Do it yourself or pay to have them done?
- Car sounds like crap! Help!
- mcguard tuner lugs not fitting? wat the...
- Best place to buy an alternator???
- 2000 nissan maxima GLE exhaust
- pilot bushing on an 02 auto max engine
- Anyone with tint over 20%?
- just your opinion...
- Best Upgrade for under $500
- 02 I35 tranny slippage update..feedback needed..
- Anyone Know where I can find this Part?
- Chrome Nissan Emblem on 2k Steering Wheel?
- ABS, SLIP, and TCS OFF light are all on
- vq35 swap into a 2k maxima
- Rear Beam install + ES Trailing Arm Bushings mini review and pics
- ABS light- should i get this checked out?
- Found engine starting issue
- HELP NO CRUISE CONTROL
- Snorkel
- !!crash course in vafc2 tuning!!
- Backed into =/
- What is the % of tint in maxima factory glass
- P0300 code, Please help
- Washer Fluid Issue
- battery post & fuse?? delete
- Replacing 4 strut boots, tie rod boot and fuel pump...
- Vibration starting out in first and 2nd
- 6th gen bbk brake line question
- another exhaust option
- WATER FROM UNDER THE DASH
- what your insurance cost.
- 02 maxima se rotor or pad noise
- H&R Wheel Spacer help?
- My experience with Amsoil GL-4 75w-90 gear oil
- 2002 Maxima SE MAF question
- 2003 off to a rough start
- I've been a member a while, need advice on this 2k2
- can someone help me out?
- Help locating clutch interlock relay
- Vacuum Bleeder Question
- Replace Headlights
- O2 Sensor Extending
- both 5gens hard start this morn !?!?
- We Know of Yellow Fogs -- But What About Amber?
- hack job amp install
- Clear spoiler light?
- Weapon R Intake
- 5.5 Dyno day @ mainstream
- clicking noise when i turn right what is it?????
- Safc help
- how do i tell if my seats have ADP?
- Where is fog light fuse in fuse box?
- 01 Maxima Vs. 05 Acura TL will i win????
- Engine and transmission weight
- Using SeaFoam
- Calling all 4AT > 6MT 5.5-gen swaps
- EVAP - "Large Leak" - What to replace?
- 2001 Maxima Y-pipe Cali/Fed spec question
- was this cheap
- Maxima saved my life!
- Replaced o2 Sensor - still have code/SEL?
- foglight bulbs 03 max se
- were to findd intake...also question on front lip
- Microgreen MG201?
- o2 sensor spacer
- Need help P0507
- i need some help please!
- dustboots.. autozone.. advanced
- Making some much needed changes (G35 wheel restoration included)
- Need Help ASAP: Car doesnt start
- Which stock intake pieces will I need for pop charger or Stillen?
- 3.5 swaped 20th AE???????????????
- Transmission Problems
- DROP RESISTOR MOD? 5.5GEN..
- AT Trans. Parts
- Having problems wiring aftermarket headlights with halos
- Help: General info on windhsield wiper motors
- Show me your Flaps
- Clutch/trans issue
- ES or OEM Engine Mount?
- Megan test pipe too long
- Replacing front and rear mounts -- labor, is this right?
- JIC fla-1s front dampers blown again..
- New bearing--still have wheel play
- brightest bulbs for 03 maxima headlights + foglights
- Cattman B-pipe resonator took a dump on me
- More 5.5 power loss, running out of things to check
- OEM Shocks Struts and HTEIN Springs ride is Garbage?
- Steering Issues
- plastic foglights for 03 maxima?
- Steering Wheel Mods, if you have done them...(no matter how small)
- NEW MOD!!! "Beehive Mod" 5th GEN ORIGINAL!
- vias delete question
- AC Issue!
- Cracked mirror
- CV Joint/Boots?
- HELP Keep losing Overdrive
- Ebay exhaust
- No dyno fail but seems to be acceleration fail
- Should i be worried about these numbers - cylinder compression test....
- Headlight Removal..With Data Dots.HELP.
- FOUND!>!>!>!>!>! NISMO SE-R MAXIMA.....
- BG coilovers made by BC??? any info
- Are these the TE rims?
- gutted cat?
- Billet Grille on a 2003 GLE?
- Wrong exhaust?
- 5.5 Gen dyno FAIL!
- and another one....... issue that is.....
- Sitting on the side of the road.
- VIN Check
- VIN Check
- exhaust input
- Just plugs..
- Warm start issue
- slight popping sound when turning
- Starting problems when hot
- How to reset the garage door opener?
- anti spark plug foulers to remove ses light
- New Fuel Filter
- 18in wheels with +45 offset fitment on a 03 max?
- Is this a rare car?
- Wheel Question
- Interior LED Conversion (PICS)
- Tie Rods, Bearings, Control Arms & Sway Bar Links..Isn't it all about the Bushings?
- 200,000 mile service ideas
- Installed Exedy stage 1 & Fidanza
- Stumble During Cold Acceleration
- UTEC Plug and Play harness for the 5.5 !!!!
- exhaust done the cheap way
- Birds under my hood?
- What are YOUR recomendations for LED bulbs for clear corners and interior?
- Maxima with Swagga
- worst luck with wheels/tires/life
- exhaust rattle!!!!!
- Maxspeed front, H-tech rear
- Torsion Beam Bushing Leaking
- Settling Springs / Progress
- Embroidered Trunk Carpet
- anyone rebuilt their 4 piston AP Racing calipers?
- High Idle:
- Opinions on my repair.
- Free STS - Improved version. Perfect parts list.
- New suspension.....new noise
- Grille
- Crazy squeal
- outside ambiant temperature display
- Water Sound when giving gas... Need Help
- 2K-2K3 Maxima Courtesy PDF Database
- Rear Spoiler Removal? How To
- URGENT HELP NEEDED: RSB Install how do you get around the brake lines? PLZ!
- Trying to find speed sensor, HELP!
- ramdom video!!!!
- Quick Q on brakes
- Blower motor
- Steering Wheel Control Lights?
- house hold paint on my car
- H&R Wheel Spacer Problems
- 2003 maxima w/ 09 19in wheels?
- HOOD SWITCH
- Pick my poison...
- idle low tranny funny exhaust rattles .. HELP
- suspension tread
- Manual Trans Fluid
- Where do i go to rent a transmission jack?
- My accident back in the beginning of March...
- Parts Diagram Request for 5th & 5.5 Gen Headlights
- Anyone SUCESSFULLY removed the running light lens on 5.5gen Headlights?
- TURBOCHARGER on my CAR ?!?!
- Blacking out chrome window trim
- Rough Idle...Motor mount??
- Check this maxima out...wow 5th gen
- 4th gen front turn signal harness same as 5th gen??
- Ordered HLSD Diff, Need immediate advice
- Looking for stock headlight harnesses
- Gear Box feels Rough-Advise?
- How Can i tell which Alloy Rim type do i have?
- annoying hood shake. any thoughts?
- Wheel Bearing/Hub Assembly? Or something else?
- Just bought a New clutch master cylinder, and slave cylinder
- Changing out my shocks
- audio help
- Sound Proofing
- 2000 SE Mirrors...Will they fit?
- Any Feedback on OEM Shocks & Struts with H-Tech Tein Springs
- Prolumen HID Kit
- timing chain tensioner
- Tranny swap question
- Need help on 6MT clutch repair SLC UT
- Timing advance important question ?!?!
- Help with Umnitza HID fog install
- need help
- question on 5.5 belt replacement
- Important Question about struts/springs !?!? NEED ADVICE!
- Short Ram Intake or Cold Air Intake ?!? Maxima 03
- 9003 Lightbulb question
- Problem ??? Axle? cv Joints? something else?
- Restoring a 2003 Maxima SE
- tranny question
- Anyone have paint matching problems?
- Anyone try these out?
- exhaust question
- Steering Wheel controls added??
- Steering Whaal controls added??
- What are good exotic mods for a maxima 5.5 gen ?!?!
- Pre-wired for Navi?
- SoFlo Accident 4-7-09
- New CD player...no audio...
- Any writeups on replacing 5.5 gen clutch?
- Starting issue
- What bulbs to buy?
- "SE" font to replace emblem
- Strut and Spring advice
- walbro fuel pump installation questions
- Took out The Resonator. Oh yessssss!!
- 350z Clutch
- 01 vs 03 = 01 getting owned?
- Need suspension advise
- Repair Fog Light / Remove glass
- new motor,clutch,headers and more...
- RSB installed thoughts & question
- Help with ABS, SLIP, TCS lights.
- Headlights?
- Header and Y pipe? 4th and 5.5 the same?
- Trade my ES engine mounts for your OEM ones
- Hit some deers, poor baby
- suspension help
- Weird problem
- Replaced Fuel Filter, Car Won't Start!
- WWANT TO CHANGE FROM AUTO TO 6SPD
- JDM oil cooler leak
