- Does an ECU updates include multiple fixes?
- Tsb ?
- LED tail bulb- now no cruise?
- new car?
- Car is hard to start when park on a tilted driveway
- Clean fuel injectors ...
- Otto FSTB - Can't Find... Will 95-99 Work?
- 99-01 Cali Spec. SS Y Pipe "Special"
- Where can I buy an otto bar for a 5.5 gen
- Is 3.0 pre-cat interchangeable with 3.5?
- Blown shock?
- rear sway bar
- URGENT: '03 reprogrammed, now installing Berk Intake; will I lose the reprogram?
- Differences between 350Z/G35 and 5.5 Gen ECU?
- 02 Maxima recalls
- Studdering/Hesitation Problems
- Street Scene Front Lip
- creaking seat
- tranny flush
- 2002 Maxima Stock Struts
- liscense plate bracket
- Opinions on HKS rear section for teh 5th gen.
- How much would be the trade-in value?
- Wheel Noise
- Disconnecting Battery
- Pulled my MAF to clean it.. SUPRISE
- Foglight lamps?
- Should I stock up on Apexi Filters?
- thought on SS conversion lines
- comparing 00/01 sts's
- humming sound from right rear
- Found a Code (P1320) need your help please
- K&N fit for a '00
- Extended Wheel studs??
- Engine Noise: Knock? Rocker?
- stalls; clogged precat in y-pipe? fed or cali spec?
- Welcome me to the family
- Drops.
- "Service Engine Soon" light question..need advice.
- can a 02-03 nissan maxima headlight fit i35.
- New HU
- Selling my Max guys... come check it out
- Rear Sway Bar Break-in?
- Increased hesitation/cranking during starts?
- ventilation button led's burned out...
- 5 gen headlights
- front stabilizer links
- Strip paint
- Aftermarket Keys Won't Program
- where do u get your oil filters?
- Hey guys
- Hard 1-2 shift on 03 4AT transmission
- Bad gas mileage on 03 maxima
- Can this really happen? What the heck ...
- Thinking of getting an 2003 SE 6speed.What should I look for?
- Express Paint
- Should I add the SE spoiler?
- Seat Covers?
- MAXIMA hamburger on the trunk
- Switch to Leather Interior
- What the Hell
- frankencar K&N filter
- Again with the knocking....
- Engine/ maybe even tranny probs?
- Why so low?
- Did the 2K1 MAF mod for my 2K2, now I've got O2 error codes
- Corporate Lease
- To all owners of HID fog lights....
- taking dash apart
- Cant Unscrew Bose Headunit. Need A lot of Help Soon.
- weird alarm issue
- shift light...
- To All Led Know It Alls
- Question on Front Grille Fitment.
- Question about 3rd brake light??
- 2k2 vias
- couple of questions I need answered
- SunRoof Rattles?
- Gah! I knew this day would eventually come...56K warning
- ecu
- Is it possible to add the memory seat option
- No Start!!
- Anyway to make seats heat up faster?
- Ae Door Sill Part Number?????
- How Do U Remove This F'ing Pinstripe!! I Hate It!!
- Got some extra cash -- Which Mod?
- Would appreciate all your HELP ...
- help!!!! car stalled
- signal bulb question
- Heater Core Flush, Please I Need Help
- Dashkit intrest
- 00-01 owners w/ stillen classic front lip
- OK what is causing this jittery drive?
- Fixing the Dumb Seat Motor
- can a maxima front bumper fit a i35.
- SES light on then off
- Battery dash light - when should it come on?
- Is There a Way 2 Test DIY O2 Sim?
- my heaters dont work :(
- Front/Rear Strut Bars
- Keep blowing a fuse.Need help!
- Car seems tired
- 4 years of ownership, still in love with her.
- intake mani. question
- I heart you forum contributers
- Part # Question(s)
- New Tokico struts
- Why/Where is my exhaust falling off? 2003 Max
- Pics of 00-01 w/ AE Engine Cover
- Pros/Cons 4th Gen v. 5.5 Gen
- car accident but whose fault?
- 5.0 and 5.5gen guages interchangable?
- Gearbox Done(missing gears)
- Wrong plugs CAN cause CEL...
- New Mod. Maxima to Minima
- P0302 (guess what everyone)
- Feels a little sluggish
- old woman in a maxima
- 5.5 335 questions on crank sensor
- Ebay Angel Eye burnt out - 1 on each side?
- Just sold my '97 max... trying to enjoy the '03..
- Clear sides: Multiple manufacturers/quality, or same mfr w/ different distributors?
- Car is not willing to start
- P1320 and P0301
- FOG light replacement HOW TO?
- 6MT - Is switch from synthetic back to dino bad news?
- Where Can I find an IACV?
- Differences between Frankencar and Berk Intakes (Apexi version)?
- Upper grill options for 02-03
- 5th Gen on Autoblog!
- 2000 max hard to start
- 2000 Maxima Accident, their insurance is covering a front bumper swap.. please help
- Which OBD2 Scanner to Buy
- car "hangs" in 3rd gear...normal? MAF issue maybe?
- driver's seat will not move
- What should I do?
- will a modified valve body from a 4th gen tranny fit a 5th gen tranny?
- will these yellow fogs fit my 03?
- Shifter bezel pops loose going into Reverse!
- blue or yellow film
- Sorry, one last time w/ my sunroof
- what are the symptoms of a bad tranny solenoid?
- After I get my new MAF...
- question about the diffrent grade of oil use.
- Motor and Transmission mounts
- 5.5 Gen Seats fit in 5.0 Gen?
- odometer wire??
- Question: How can a bleed brakes with mighty bleeder
- Black grill 2k2-2k3
- Performace clutch
- Is it safe to use 02sim for a P0159 ?
- low toned exhaust
- Removed brake line bolt on rear caliper. Need to bleed?
- Stillen FSTB
- My 2001 died on the highway...now won't stay running
- 20 Amp Draw while the car is off?? Please help!
- Stupid mistake. Busted lug bolt. Need quick advice.
- Idle speed ...
- Front Lip Pics!!!!!
- Help with brake problem
- Resistor Removal
- Car stalling in neutral, any ideas
- Intake problem?
- Question about 5th Gen and 5.5 Gen tail lights
- Chrome rings on gle gauges
- What could it damage???
- Quick Help with 20th edition!!!!!
- Transmission Fluid Question
- Suspension knock/noise diagnosis help please
- Need Rear Spindle Nut Torque Spec!
- Have coilovers? I need you to measure a part of your stock suspension off the car
- Car Just Died =(
- Poor Performance at low RPMs
- Clear/Smoked sidemarkers... Step on in!
- WTF... CEL back on after O2 Sim Install
- ebay bumper
- speed sensor wire
- 5th gen forums suck
- Question for those with Hotshot headers and Frankencar cat-back
- jic exhaust, anyone got one?
- 2002 advice needed please.
- Automatic-Downshifting and Overdrive OFF Question
- Where can I get yellow fog lights?
- Question about relay colors
- cattman headers
- obd2 SES light codes p1165 and p1131... Help!
- anyone retrofit 2k headlights for HID
- questions on coil packs tried search didnt get answers i needed
- Adding shock sensor to factory alarm
- "plug & play" 2k1 HID lights...
- angel eyes / demon eyes
- DEPO! Good or Bad or Same as all else
- Owned the car for a month and half and look what I have done already...
- Considering a Y-pipe
- Possibly going 4th gen. --> 5.5th gen. What to expect?
- Suede Interior, pics inside
- Which would be a better option?
- Eibach Spring Owners
- has anyone tried to fit the middle part of the 04 and up maxima grille on the 03?
- O2 senseor
- Are these issues related??
- Changing Power Steering Fluid ...
- HID bulb blown after less than 1 year...
- Where can i find the chrome or aluminum grille OEM replacemnt.
- Anyone have problems with Yellow Top in a 5th Gen?
- rigged up a CAI...is this safe?
- 5.5 gen auto seat position
- P0300 and other codes... need opinion
- rough idle?
- Reservoir tank ...
- Removing Headlights --- NOT HID --- on a 2k1
- another lighting thread
- My tranny is shot...where to get new one with price?
- Need some help with clock panel on 5th gen.
- motor mounts
- Hard Start Problem
- SRS Airbag Light Flashing on 2001 Please Help
- Have anyone heard tittail?
- Gas mileage on 03 6m/t is not good...tune up needed?
- Need new battery? OEM or aftermarket?
- Yellow Foglights?
- Exhaust tip
- Which 1 of this will stand out if replaced with OEM?
- What don't my headlamps and foglights match even though they're both 6000k?
- I need you opinion about these taillights
- serious 5-speed transmission slippage
- how do u get more horsepower?
- Leaking???
- Radio LED
- quick question... about headers...
- Anyone heard of Kaixen? + Another Question
- can this be done?
- question about 03 SE shocks and springs
- Why my oil catch can does not work??
- weird noise @ 1900rpm
- Gas needle stuck again
- Installing gauge pod...
- No heat until its set to 85 deg.
- JiffyLube Undercover Video
- Stock Front suspension makes knocking sounds.... why?
- SES Code P0057 O2 sensor. Help!
- Does the 5.5 gen have any other options for a rear lip besides Stillen?
- squeeky belt on my 02 maxi
- EVAP canister purge volume control valve?
- My Maxima made the news
- My 2002 6sp Max gets into a fender bender!!!
- Getting to rear spark plugs, need help immediately
- Belts
- Intake manifold Torque spec.......
- Need help Picking a new front bumper...
