PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. 2000 SE Ignition coil pack...what other years can I use?
  2. driving on gravel.
  3. Ignition timing question...
  4. Closed/locked thread
  5. VQ30DE-K throttle cable mounting brackets?
  6. Secondary timing chains
  7. Knuckle question 2000 SE
  8. Speed sensor issue?
  9. Overheating 01, 6 cylinder
  10. Question about Underdrive Pulleys
  11. Will The OEM GPS from a 02'-03' work in a 01' GLE w/Bose
  12. Full Service Manual Genuine Link
  13. SE auto overdrive power loss?
  14. End link removal issue
  15. New alternator, now a/c compressor won't fit?
  16. how to rebuild a manual transmission
  17. Radiater support
  18. Low rpm power loss,
  19. 03 Max Stock Bose System - Suddenly No sound
  20. Ghetto airbox question
  21. Real gas mileage vs MPG indicated
  22. i 35 swappable parts
  23. rpms slightly fluctuates at idle?
  24. maxima dash/interior lights pulsate
  25. 2000 Max replace coil packs or just spark plug boots
  26. No DLC Connection or MIL on Inst Panel.
  27. Changed IACV, still driving with toasted ECM
  28. Unofficial Poll: Max kPA readings for N/A max
  29. Careless act on an oil change
  30. Another o2 sensor thread
  31. swirl control valve control solenoid valve PART NUMBER
  32. broke spindle pressing wheel bearing out...
  33. Pandora Eats Pavement (Maverick4189)
  34. Air Intake Hose Problem - Urgent!
  35. 2001 Maxima: Alternator or Battery?
  36. shifter lights
  37. shocks and struts
  38. Hard time diagnosing a misfire
  39. loud pig squeal noise on start, metal shavings
  40. 2000 turning off every few minutes.
  41. Charging mystery...after valve cover/spark plug job...
  42. Maxima Reverse with brakes noise
  43. Cold air intake
  44. Where to get wheel bearings pressed in Atlanta area
  45. Is my 2003 Nissan Maxima engine ruined?
  46. Link to HID Fog conversion TUT?
  47. Alarm keeps on going off
  48. Video: normal noise or ticking
  49. Passenger Side Power window Not Working
  50. 5th Gen Auto X
  51. 2k1 Armrest fit a 2k2 ?
  52. anyone have a FULLY stripped 5.5 gen?
  53. Plenum cover sequence and torque specs
  54. 2002 Nissan Maxima Build questions
  55. ABS sensor
  56. OEM Ignition Coil Brand for 03 SE
  57. P0102/P1102 engine codes
  58. Headlight Problem
  59. AC issue
  60. Power steering pump making noise...
  61. Code scanner to reset p0430
  62. 02 6 speed surging slow acceleration
  63. found an 02 se max, 88,000
  64. Help with testing MAFS & calibrating and testing TPS
  65. [2001] Transmission Issues
  66. Suspension Noise
  67. Starting without pushing the clutch
  68. Security light, no start
  69. My boot is stuck :|
  70. P0171 - 02 Sensor - Intake Leak ?
  71. po158 and po139 po138
  72. removing front axle
  73. TS Ecu troubles
  74. 01 Maxipad ECU/Immobilizer
  75. How to install a clutch
  76. 5.5 Gen fed or cali spec
  77. Service Engine Light Question - 2001 Maxima SE
  78. I30 Cluster Illumination Help
  79. what this thing?
  80. 00-03 maxima projector hid upgrade
  81. 2002 maxima dash lights.
  82. battery drain from window fuselink
  83. Oil Leak
  84. Quick question Regarding Wheel bearing
  85. Grille for 03 I35
  86. 2010 rims for 2000 GLE
  87. Increased noise in reverse on 2000 se
  88. Guess where this part goes...
  89. to those of you with USA Spec
  90. Car runs ROUGH when cold...
  91. 01 Maxima won't start
  92. So i was goign through sticky list of parts...
  93. Weird loosen rattle sound in the front end?
  94. Is there a common place for A/C leaks?
  95. 2k2 6mt Passenger Axle
  96. Car won't start....should have taken autoshop...
  97. 2K Ball joint & Lower tie rod Q
  98. 02 sensor?
  99. Bumper lips or no?
  100. looking for a rear motor mount for a 00 max manual tranny
  101. ? about manual transmission
  102. Driver side window
  103. 3.5 pinging, pulled plugs. Pics
  104. A/C only goes down to 65F?!
  105. Carltonator: 18"long/ 6" round Magnaflow
  106. New 2001 GLE owner, lots of questions
  107. Rear Caliper
  108. Vacuum leak and p0430
  109. Addco RSB fitment 97-2001
  110. Who has and Where can I get a performance Chip
  111. Not my taste
  112. injector/maf
  113. Strong gas smell at startup
  114. Instructions to replace rear struts and springs
  115. Maf sensor
  116. P0340 Code
  117. Rear Calipers
  118. another blown coil
  119. Best loud exhaust sound ever! LOL!
  120. Should I do it...again..?
  121. 246,000 miles on stock clutch.
  122. Stock EXHAUST QUESTION
  123. DS Front Axle Question
  124. HID fog problem
  125. Did 2k2 to 2k1 Maf swap...ECU Update Needed?
  126. Looking to buy a maxima again. What would you offer for this? Couple questions also
  127. Bose Radio Dead 02 Yawn again.
  128. slow start or just me ?
  129. 87, 89, 91, what's best?
  130. 5W30, 5W20, what's best?
  131. knocking noise from rear end (video attached)
  132. a ? for the manual tranny guys
  133. 2000 Maxima P1335 code
  134. Headlights Flicker When Turning Turn Signal On/Off
  135. Who has a better Radiator Cooling Fan TYC or Dorman
  136. 03' GLE heated steering wheel in a 01' GLE
  137. A 03' Speedo
  138. Spark Plugs covered in oil
  139. Replacing front and rear struts/shock
  140. hmm what could it be
  141. trouble starting
  142. High pressure building in transmission
  143. 2000 Maxima GLE Idle issues
  144. NWP 75 mm throttle body installed, first thoughts
  145. Help! weird transmission problem!
  146. Setting OBDII catalyst efficiency before EVAP to pass inspection?
  147. Car suddenly went totally dead. No electrical power.
  148. Clunk while turning SOLVED!
  149. replaced driver's door now automatic unlock does not work.
  150. Purchased 2000 Maxima GXE on 7/25..Need info regarding parts and service please..thx
  151. I think I fried ECU. pls help.
  152. Camshaft Postion Sensor
  153. The new project ;)
  154. Mevotech outer tie rod end and ball joint
  155. Bose sub amp fix 2002-2003 5.5 gen
  156. New Megan EZ street coilovers review?
  157. Set Higher Idle for Track?
  158. Can't reach bottom thermostat bolt?
  159. Caliper problem or what?
  160. Help...Issue with running lights...
  161. Weird Noise After State Inspection? (Video)
  162. 2000 maxima Manual Transmission Removal
  163. 03 maxima ratlle
  164. Wobbling Crankshaft pulley...help!! thx
  165. New to forum.. Just purchased a maxima
  166. I think its my Front Wheel Bearing
  167. Code P0345 03 Maxima SE
  168. Replacing the Head gasket
  169. tail lights bulbs?
  170. Turbo and vafc ii
  171. Could this cause a P0300?
  172. Couple ?'s from the new import guy
  173. 01 Maxima ECM, Scammer Alert On eBay
  174. 2000 Clutch Cylinder issues
  175. mods???
  176. Dash/console lights
  177. 03' maxima AC wont stay on PLEASE HELP
  178. Maintenance at 168k?
  179. New to imports and need guidance
  180. Check engine light FLASHING, car sputtering
  181. i have a p1130 and p1165 code on my ae
  182. 2003 maxima 3.5 does not fire to plugs.
  183. Ticking noise fix?
  184. Ssim
  185. Po217 help
  186. Part number for metal CD player bracket
  187. drivetrain conversion
  188. 5.5 Brake Issue, stumped.
  189. I feel like an idiot
  190. 6th gen to 5.5 gen motor swap. Upper oil pan swap. Which oil plate baffle to keep?!?
  191. maxima blues
  192. Need Help On Alignment
  193. My SRS exhaust clip after 1 month of having it on.
  194. Replaced alternator
  195. 200SE stalling
  196. Thoughts on this exhaust for the vq30
  197. Bypassing the IACV, P0505
  198. Dome light DE3175 LED issue
  199. Need help buying a 5th gen!
  200. Catalyst Monitoring Incomplete
  201. Help me determine what the problem is ....
  202. Front Catalytic Converter bolt/nut torque specs
  203. The dreaded P1320 Code
  204. Brake Master Cylinder Ran Dry
  205. cabin air filter
  206. When is it time to throw in the towel?
  207. Bad Wheel Bearing question.
  208. 2000gle transmission problem
  209. Would you?
  210. O2 sensor/wiring problem
  211. A/C not cooling like it should. What's up with that?
  212. Lets play: Is it totaled?
  213. Time for a new motor
  214. $20 intake for my 2002
  215. quick strut advice
  216. What upgrade/repair would you suggest first?
  217. 2000 Maxima Gauges stop working in heat...
  218. 5.5 Gen Maxima Not Fitment For Illumina Struts?
  219. MAF Sensor / 2000 SE - problems, action, results
  220. Alternator ???
  221. 2 questions on Auto to 5 speed swap.
  222. 2002 Maxima Transmission Code?
  223. cranks but doesnt start! help pls!
  224. Strange Stalling Problem - Car cranks and runs, dead throttle.
  225. Globe box not opening
  226. Front sway bar upgrade?
  227. squirrely suspension.
  228. Average MGP on cluster, wrong?
  229. my sunroof wont open
  230. 2002 no start.....ECU problem?
  231. Shift knob, auto trans
  232. Spring busted and went into my tire! (Pics)
  233. 2000 GLE transmission problems
  234. Hesitation When Downshifting
  235. APR Exhaust for Maxima?
  236. Best online part vendors for 5.5 Maximas?
  237. Siezed Nut and Bolt
  238. To help with dash rattles and squeaks...
  239. Help: 2003 maxima Idle relearn procedure
  240. 03 6speed hlsd axle question.
  241. 2001 Maxima GLE // P0430 code
  242. Performance and gas mileage enhancements.
  243. 2000 Max overheat/tranny slip
  244. How do you know if your car is running efficiently?
  245. 2002 gle maxima fans not working! Help!
  246. Battery Cover Question
  247. Quick 02 Sensor/Gut Precat question
  248. Suspension Upgrade Labor cost
  249. Aftermarket hand brake handle
  250. Anybody?
