PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Master window switch compatibility - 5 and 5.5 gen
  2. window regulator and motor
  3. Speedo inaccurate
  4. Axle question before drop her more
  5. Original equipment parts
  6. Time to sell 2003 SE?
  7. Gen 6 Big Brake Kit from ROCK
  8. Engine noise after long distance drive
  9. Rough idle when turning on ac
  10. car randomly stalls
  11. Which cv axle fits my car?
  12. knocking
  13. Overheating??? Weird?
  14. Ultra racing chassis parts
  15. Driver side interior rattle connected to steering column?
  16. Kinetix intake manifold
  17. Bose radio replacement
  18. Motor mount Solenoid/sensor connection
  19. My '01 Wheelskins steering wheel cover install...
  20. Maxima just dies on freeway...please help!
  21. Hot transmission, and wobble under acceleration
  22. Fixing a Saggy bumper w/ Pics
  23. Used ECM install
  24. 02 maxima parts for an 03
  25. Camshaft Positioning and Timing & Low Oil
  26. brembo 350 brakes
  27. Brake issues... booster or master cylinder or..?
  28. 01 Maxima Dies
  29. Please help
  30. Driver Side Axle Woes...
  31. Engine aie noise
  32. LARGER Throttle BODY!!!!! Pathfinder
  33. NEED HELP!!!! Not getting VOLTAGE
  34. Rear brake pads interchangeable between 5/5.5 gen?
  35. Replacement Rear Calipers Different From OEM?
  36. 1st Gear Sticky
  37. Pricks....
  38. rockauto.com discount code
  39. Shocked at What I found Today
  40. P0550 and P0021
  41. Transmission Code 9?
  42. Best place for replacement parts
  43. Maxima destroys porsche
  44. Auto to manual trans swap
  45. 335 is
  46. Please recommend OBD2 scanner
  47. To newbies - don't shift at 3000 - 3500 rpm
  48. Do 2003 Nissan 350z rims fit on 2003 Maxima?
  49. A/c
  50. Electrical problem? All vehicle light keep flickering/oscillating
  51. 03 maxima se alignment specs
  52. Solid SES light day after filling up
  53. Question about exhaust
  54. Plasti diped Maxima
  55. Need more help :(
  56. 03 Motor mounts bushings
  57. 2002 Occasionally wont turn over
  58. Upgrade clutch
  59. Need help bad!
  60. 5.5 Running Rich
  61. Wind/road noise in our cars
  62. Anyone else struggle with the timing gear bolts?
  63. Window won't roll up
  64. slow start issue
  65. is "LSD" traction on control?
  66. 01 Maxima Se - Surges at 2500 rpm
  67. Inline transmission fluid filter possible in '01 Maxima?
  68. Just want to be crystal clear on what to order for a new exhaust setup.
  69. Driver Side Radiator Fan Contantly On
  70. Should I drive a car that's misfiring?`
  71. Need a mechanic reference
  72. Slave cylinder compatibility
  73. Aackshun gets a 26" resonator
  74. 02 Max with blinking engine light and codes p0420 & p0455
  75. Speakers
  76. Motorized passenger seat in 01 GLE getting stuck...
  77. 01 Maxima front Lip from 04-05' STi
  78. 3.5L oil consumption.
  79. "Multiple MisFire?" ---is Jesus Busy ?
  80. Transmission acting funny when hot
  81. p0154 - - Sensor Location(s) ? ? ?
  82. Knocking Sound - Difficult to Find
  83. Addressing the "Code 25"
  84. Serntra Spec=v struts
  85. '03 Maxima replacing headlight assembly, now car won't turn
  86. 02 sensor correct one
  87. Hid's
  88. Wheel search for 5th gen
  89. power steering pump hose.
  90. 350z 18" Anniversary Wheels: What Spacer For Rear?
  91. 2001 Nissan maxima
  92. 01 maxima 20th aniversity for 700 need bank 2 cat
  93. cattman headers where to get it from?
  94. Need tuning/electric help
  95. Car Temp: gage showing wrong reading showing hot.
  96. 00 nissan maxima for sale 2 issues
  97. rough idle and defective 02 sensor
  98. Clutch Pedal Position Scale
  99. water leak
  100. 00 nissan maxima or 02 nissan maxima
  101. Need help with my braking system
  102. Radio and Instrument Clster
  103. new blower motor resistor??!!
  104. Inspection Camera Images of Cyl 2, 4, and 6 on an 02 Oil Burner
  105. My local "you pull" junkyard has 5 Maximas (+ 20 Altimas). What should I look for?
  106. Paint Match Replacement Body Parts
  107. Reservoir Drain
  108. The drilled aluminum pedals are too slippery when wet
  109. Happy Father's Day!
  110. Codes and more codes
  111. DRL/High Beam LED
  112. Question: Outside Termometer Temps ?
  113. Car Audio Build Log for an 02 Maxi
  114. Engine swap advice please, I used the search bar
  115. 6 speed maxima won't go in gear
  116. Door Hinge and Electrical Connection ?
  117. Engine hangs at/or around 4000rpm
  118. 2000 Max with Overheating issue **HELP**
  119. 2000 maxima OEM ignition coils.
  120. Crank all day and no start....
  121. New guy
  122. new to the thread looking at 02 maxima 230k?
  123. 2001 maxima going into fail-safe mode
  124. Gutting Precats , do you keep any screen etc?
  125. 02 Nissan Maxima Struts
  126. Trans seal leak 5th gen maxima
  127. Proper way to install/seat injectors?
  128. Looking for a 6spd swap.
  129. Maybe a solution for rough idle, bad acceleration
  130. IT LIVES! me on the other hand...barely
  131. Just changed the radiator and seriously confused now.
  132. 4th gen coilovers on a 5th gen ?
  133. Nyc exhaust shop
  134. Knock Sensor/Harness nightmare
  135. Headers Question
  136. Rebuilt pressure PS hose make noise??
  137. Brakes go to floor at over 90 mph or high rpm
  138. Heater core replacement
  139. Looking for Lazy???
  140. Timing Belt on 03 Max
  141. 01 Anniversary Edition 200k needs repairs....Qouted 7k...need alternatives
  142. 2nd estimate now adjustor wants to meet???
  143. Bad HG .. or worse?
  144. Bought a 5th gen, got problems now. Please help!
  145. Sad news...
  146. My GAB Mod
  147. Vibrating Steering Wheel: Can I change the Tie Rod myself?
  148. Selling 2002, what's it worth?
  149. How many 5th gens are 6 speeds?
  150. dates of rear brake pads
  151. Oil cooler ro reduce Oil burn?
  152. 03 6 speed BHG/ or lucky enough for thermostat...
  153. 2002 w/ spoiler bike rack
  154. 01 maxima AC not blowing cold
  155. non-bose stereo no sound
  156. 2000 Maxima Door Lock
  157. 19" 350Z wheels
  158. axle won't go into hub
  159. cranckshaft from vq30de
  160. Where should I start with my car to get more power?
  161. Vogtland springs what struts
  162. How to get out better time on 0-100 km/h
  163. Buying Tires ? ? ?
  164. Cooling system upgrade
  165. radiator fan
  166. Looking to buy an OEM horn
  167. Axle question!
  168. Can someone tell me what the lateral link does?
  169. Another P0505 problem
  170. Screetching sound w/ video
  171. Couple questions
  172. 02 Max....IAT sensor relocation?
  173. just wanted to know
  174. intermittent battery/parking brake light question
  175. no power
  176. Is dealer relearn needed? P0505 still after ecm,tps,iac swap
  177. P0403 after ecu swap
  178. P0300 with white smoke solved & compression/oil burning question
  179. Mystery buzz/horn noise - 00 GLE
  180. Pulling my hair out
  181. Oil Leak Query - Oil Cooler O-Ring Vs. Oil Pan Gasket Leak
  182. Need new ECU 03
  183. AC & Heater Temp Sensor?
  184. Redline Shift Boots! *Canadian Members*
  185. Clutch
  186. Timing Chain maintenance?
  187. Can't find tensioner assembly parts, please help
  188. Codes P1444 and P0453
  189. My Beautiful Max Totalled
  190. 2000 I30t P0720 wont clear!
  191. 2000 3.0 Maxima Transmission Replacement
  192. charging issues
  193. 2003 maxima shuts off while driving
  194. Draining Sound Concern
  195. Overfilling ATF
  196. Oil pressure testing?
  197. Navigation cd
  198. can supercharger kits be bought anymore?
  199. 2001 Maxima revving driving on it own?
  200. Idle
  201. Question on O2 Sensors
  202. ABS brake bleeding question.
  203. Brake Battery Light on - Just replaced my Alternator
  204. 2000 Maxima Kick under hard acceleration.
  205. Wierd looking Oxygen sensor
  206. Maxima 2002 SE in trouble
  207. power steering pump leak.
  208. Simple transmission question
  209. clock spring
  210. A/c
  211. 02 Fuel Injectors
  212. Weird OBX outlet size for cat inlet
  213. Ac compressor clutch not engaging
  214. Bad experience with Koyorad
  215. Engine Code P1800 and P0340
  216. freon
  217. Interchanging parts
  218. Franken Car stalled, now runs fine?
  219. magnaflow Y-pipe difference
  220. 2003 Maxima dies then sudden acceleration.... Please Read!!
  221. Idle Surging
  222. different r134a
  223. Mystery front end vibration
  224. Bought a beater for my 14 yr old to learn on
  225. Both headlights stopped working.
  226. 2000 infiniti i30 obx headers
  227. Painting questions kv3
  228. P0303 Error code. Cylinder 3? Not Spark plug or coil. Where to look next please?
  229. Part # for Bank 1 camshaft position sensor?
  230. Jumpy / Bucking acceleration in 1st gear
  231. a/c not blowing cold!!!
  232. Rapid flasher
  233. Steering wheel wants to recenter rapidly
  234. Shaking, shaking everywhere...
  235. New to forum. Have some questions.
  236. safc ii in/out setting
  237. Anybody ever tried any of these?
  238. 2000 maxima scraping noise
  239. P0420 Code
  240. Help
  241. Please Help with this bucking, misfiring
  242. Some trouble codes, need help ordering correct parts.
  243. E.S. subframe bushings
  244. Wheel Fitment
  245. Exhaust rotting away, Choices?
  246. 2003 5.5 gen o2 sensors?
  247. Upper control arms & O2 sensor
  248. Upper control arms & O2 sensor
  249. Dead 2002 6 speed
  250. shift kit
