- Please help - dashboard illumination is gone...
- windshield nozzle not working
- Replacing Front Rotors 2002 Maxima
- Turbo or Supercharger???
- TRANNY not flaring on full tank?
- THEFT -Headlights and bumper
- part identification?
- Ebay Retrofit
- P0150 & P0403
- got her Aligned.
- What muffler will be just louder than factory
- New windshield
- 00 Headlight removal tutorial?
- stage 1 ltb?
- water sound when i accerate
- Cattman Headers installed...
- Has anyone tried the ebay bumpers?
- FAILED EMISSIONS
- Passenger Airbag Torx Size
- Stalling Problem
- Questions about GAB
- Sloshing noise coming from the car
- Failed Fuel Door Actuator?
- Dimming interior lights after new Battery?
- Headlights turn off when blinker is on?
- squeaky clutch 02
- Rim Clearance
- h4 kit install
- Muffler/exhaust piping repair question
- Another one bites the dust...
- Installing Cattman Headers, what else might I do?
- Magnetic Drain plug for manual trans?
- 2002 SE in Seattle area
- Lexus Capsules How to..
- nismo shift knob
- Cosmo CAI??
- Curious to know what the inside of Cattman's muffler looks like
- metal vibrating sound when the heater is on. what is is?
- Need Help..
- strut mounts and boots
- Spark plug tube seal removal
- Weird Stalling Problem
- Whistle Noise from Throttle body area
- P0303 code. Can I drive with this code?
- 6th gen brakes on a 5.5 HOW TO?
- whats wrong with my window
- Bad battery now whining/whirring noise?
- Tein SS Coilovers...Inputs!!!
- Question about a swap out>?? Leather Seats
- Strage electrical problem
- How do these plugs look?
- burned out Xenon '02 SE headlight
- Blower motor chirping
- finally able to post up, got a few ?s
- Need help removing brake light switch
- SYSTEM TOO LEAN BANKS 1 AND 2
- Rear Sun Guard
- Driver side door stuck shut
- Issues with SECU and windows
- Bad Coil Diagnosis
- Magnaflow muffler question.
- how hard is it to do this ??
- Priming engine when changing oil--Dummy oil didn't shutoff
- Weird annoying suspension noise
- PLEASE HELP:Fidanza flywheel fitment issue gen 5.5
- 6000K D2Rs with bluish tint
- 5.5 bose hu fit in a 01 ae?
- Help with my custom exhaust setup
- Dealer can't get into the ECM??
- Average Life of Tokico Illuminas
- WTF!! New set of tires = Less mileage
- 5th gen emblem
- Grille Options...
- Leather is in !!
- vq30 to a vq35
- Pre-cats/Exhaust manifold interchangeablility
- code p0172
- SPORT mod
- Showing signs of warn clutch
- Was rear ended last week, need insurance settlement advice?
- Hid issue
- Heads up on the 5th gen - front end noise and clunking and a shakey steering
- If Cattman made a Ypipe with 3" collector... (5.5gen)
- 2002 Max & 2001 Bose HU
- Barely-visible SES light?
- Who bought my max (Wisconsin owner)
- Any tips on wiring power folding mirrors?
- Boo For Accidents :-(
- Driver side mirror
- Brake job.. Ceramic on Max?
- Projector Headlights
- 00' EGR removal
- 105k
- Starting problems
- Anyone here know how to wire 5.5 HIDs to 5th Gens?
- Drivers Window?
- RPM's
- Opinion for Brake Job
- Hit a curb
- odd bose question
- Windshield
- Replaced Heater Blower Motor now airbag light flashes
- 02 GLE ECU Diagram
- Ok, who now has the best deal on Illuminas?
- Auto dimming mirror wiring harness
- Cold Weather car not starting.. help plz...
- Driver side mirror won't heat
- Clutch Issue.
- squeeling brakes
- fog light rewiring help
- Weird high pitched noise with heater on full
- small leak from main seal maybe?
- stillen RSB
- Anyone have trouble removing their fog lights??
- Turn Signal- legal or not?
- bad muffler
- What is this connector??
- Readjusting the seat..
- parking lights...advice/help
- Automatic Adjustmenting Seats
- Possible New DIY Brake Fluid Flush?
- Radio antenna 00 se
- Will 02/03 seats fit in a 2000?
- Intermittent knocking / vibration
- How to tell if the slow 2-3 shifts are from tranny? or valve body
- Emergency brake play (slop)
- HID Fogs installed! (well one of them)
- P0340 - Camshaft Position Sensor (Phase) Circuit (Bank 1)
- Cattman Exhaust FITTMENT ISSUES ANYONE?
- Odd intermittent noise from right vent
- ABS Light
- Usefull TSB Links service bulletin
- Need help with factory headunit swap
- P1147...how to fix?
- New Wheels now car pulls to the right??
- Reliability of stock shocks/struts?
- Anyone had their MAF replaced under warranty even though the car is OOW?
- how many belts
- 5.5 Gen Tokico Illumina's Settings
- Installed my exhaust
- Rear spoiler brake light
- Bad struts. aftermarket route cheaper?
- Help me fix my oil leaks and other small things :)
- Intake and exhaust question..
- Cali Spec ECU - Fed Spec Engine?
- P0420 With Aftermarket Y-Pipe
- Q/A will a 4th gen 97 vq30de fit & work in a 5th gen I30 2000-2003
- Who stocks gen 5.5 aftermarket flywheels?
- HID high beams? (5.5gen)
- 2nd gear grind
- Strange burning smell?
- Should i do it or not ??
- Tranny Troubles......
- MY RIMS JUST GOT STOLEN
- Radiator Cracked Today!
- HID bulb replacement
- Where can I find a window Regulator and Driver side motor for an 03 SE?
- Dimming dash lights
- clutch spacer required?
- Hit Curb on 2001 I30
- Tokico front strut mounts??
- AIRBAG LIGHT CRASH ZONE FAILURE!!HELPPPP PLZ
- what should the RPM should be when the car
- Stiffer steering?
- ok new issue o/d light & high rpms
- Removed towing hitch and now one hanger down.
- Interior color codes??
- Alternator replacement nightmare
- Does anyone have those M3 mirror style ?
- Retrofit
- 00 Max questions...
- Heated Seats Not Working
- need help with sidemarkers
- All my lights went out!!
- 5.5 Gen Headlight Covers
- Umnitza Orion V2 Angel Eyes
- Replacement for thermistor on 02+ MAFs
- Performance Mods (tax return)
- What clutch setup & how many miles do you have?
- Fidanza Flywheel w/ Stock Clutch
- hid help
- y pipe cattman or obx
- need help mpg problem
- Do our 5th gen autos really shift around 5950 rpm?
- idle issues below 25 deg F
- Bose Woofer Cut Off Problem for 2001 Maxima
- angel eyes and cleared blinker light
- Rear squeeky suspension
- Squeaky shifter in a 2002 6 speed
- Rear end clunk/Knock/Thud noise???
- 3 changes made my car so much more enjoyable
- how many quarts of oil for 5.5gen engine?
- I will now own a 5th gen!
- Fog light Hids installed**Pics**
- 350z Injectors for 5.5gen
- Suggest replacement alternator
- I35 low on oil/burning oil?
- Tranny Swap
- Loud squealing sound on start & sometimes downshift
- What the difference in the 350Z 3.5?
- Wing or trunk Spoiler installation and cost
- HELP PLEASE with rough clutch engagement
- ae heater button left of dash
- New Wheels I Just bought.. check em out!!
- $800+ Bass Controller?
- Need a tip on bleeding my brakes; the thing will not bleed!
- Wiring harness for trailer hitch
- seat heater problems
- Sunroof installation and cost
- Timing advancement on high mileage maxima
- Finally Getting Some Goods Installed
- Annoying rattling sound at 1800-1900rpm's.
- 2002 California Max.. rear O2 sensor wire color and compatibility?
- Car burning massive amounts of oil?
- i got a lowering situation
- Alternator Problem
- Weird Issue with HEAT
- Help diagnosing an ABS problem.
- Help please, car won't start. Weird.
- car was shaking last night
- Heater Core repair day 1
- Sunroof sits a little high in front
- anybody know about this front lip
- 55W HID'S OR 35W HIDS? BIG DIFFERENCE?
- anyone buy rtp slot/drilled rotors from automax?
- transmission swap question
- intake question
- Window Visors???
- Opinion: Turing Radius of 02 Maxima Issues: Steering noise (cracking, rubbing)
- HELP PLEASE!!
- Airbag light flashing but no codes are coming up
- Quaife ATB differentials for 00/01 5MT Maximas
- Fitting 2002 cali-spec B-pipe (Cattman) on 2000 Fed-Spec
- Rear sidemarker wont come off
- too much coolant going into the reservoir
- changing sway bar links
- Power steering pump
- Question after seeing my dyno plot
- NKG Platinum- G Power?
- Power driver seat problem
- Do i modify the bump stops when installing H&R springs on 03 Maxima?
- Replacing radiator - do i flush the Auto Transmission fluid too?
- power door locks not working
- CODES CODES CODES!! SMH!!
- AE OEM brake calliper color?
- Transmission questions
- How low can you go
- head lights??
- Changed o2 sensor mpg plumeted?
- How to remove the HU in a 2k3 with Navi?
