- JayPee I'm coming for you.
- Keyless Remote problems - sporadically working
- clutch/tranny problems, help please.
- call me Crazy Drove a 2011 and like my 02 better
- New Spoiler Help
- Noise coming from front left wheel
- Guys that did the 6sd swap on a 5.5 gen?
- acceleration run.
- Power Cut Off
- EXHAUST DRAFT PICK
- NEED FOG LIGHTS
- Anyone use an oil drain valve?
- Standard Motor Products - Oxygen Sensor??? Good or Bad???
- Where to get OBX headers
- Eibach & Coilover Install Photos
- MAF sensors for 00 maximas?
- Do autozone sensors work on the car...yes or no ?
- WHAT kinf of rotors you guys are useing for WILWOOD SL calipers??
- Make SURE you get what you want for Christmas, Hanukkah, etc. @ Cattman Performance
- I may have to sell my Max :(
- Cattman December Discount Sale in Group Deal
- Freeze Plug Replacement
- Does this sound like a seized pulley?
- Snapped control arm, Torn CV boot, Axle popped out of the Tranny
- CLARIFICATION ON THE MEANING OF HESITATING,BOGGING AND MISSING.
- WHAT R THE SYMPTOMS OF A BAD INTAKE AIR TEMP SENSOR
- Have you re-greased your starter?
- Just installed my 3000K HID fogs.
- 6th gen brake upgrade
- help
- hey guys im back -__- i missed maximasss n i need help
- new ksports!
- 5th Gen overheating
- What is this called&where do i buy these small bulbs of the A/C control
- Cattman
- mods question
- Helicoil for stripped threads in Fidanza Flywheel?
- Flywheel Removal, heating red loctite
- Dropping/Repairing 5.5 Oil Pan
- 5gen and 5.5gen manual parts compatibility?
- I need a MAF with sensor, And I found one on EBAY, Any good?
- who the hell are all of you???
- front wheel spacer ?
- Applying high torque to those damn torx bolts
- How to test bad ignition coil???
- Maxima horror picture (feat. Rust) **caution, not for the weak hearted**
- Project LS13
- Brake Problem!
- Heated seat question
- bc coilovers? step on in please...
- NEED HELP.. Tranny problem surfaced- DON'T want to get stranded!
- 350z injector ?
- random issues with the maxima...need help
- SES P1706 - Park / Neutral Position Switch
- hmmmming noise!!!! plz hhelp
- how to test a tps properly please help
- battery
- Front wheel bearing question
- Rear Main Seal and Aluminum Oil Pan removal
- It's COLD outside!!! rear brakes issue
- Coolant system damage
- Clutch pedal has no pressure, it sinks to the ground.
- ***PLEASE HELP*** BRAKES STUCK
- 6spd swap question
- Can mileage trigger an SES light?
- i know another hesitating maf problem... work with me on this one
- i found a vac line disconnected.....
- HELP WITH AC PROBLOM
- Want to Upgrade! WHATS BETTER?
- Trying to fix wobbly steering
- Install outer rod ends and drive to dealer for alignment?
- rockauto closeouts
- Strange sound and car choking at 2500+ RPM
- From a 3rd gen to a 5.5 gen
- Heat not working at Idle.
- FCP Import/ FCP Groton 1st Annual Year End Inventory Clearance Sale
- Can't decide on fog light hids
- Any ideas why my head light/tail light out light on the dash is coming on?
- Transmission removal and center member
- Ghetto fab JDM bumper mod - Accident (pics)
- hard starting, hesitation/bogging only when cold..... wtf
- What do bad trailing arm bushings feel like?
- UGH Tensioner Bolt snapped!
- Quick Question
- is there a kit for the projector retrofit?
- F***'ing women
- NEw Fidanza flywheel, rust on friction surface
- Crossover coolant tube leaking
- abs/tcs cause caliper to go bad??
- Rust in wheel wells - worth fixing? cost?
- Need to step on accelerator to start + P1320 = Crankshaft pos sensor?
- Bracket Welds on Stillen RSTB -- Good enough?
- Diagnosis Plug
- 5th gen in shocking videos of streetfire
- couple questions i need answerd...moog...ssim.....
- Nasty smell at high speed?
- How many throttle body gaskets?
- Maxima not starting. Lame..
- sticking rpm when cold please help!!!
- Spark plug removal?
- 5.5gen: Best OEM replacement bulbs, 4300k?
- turn signal issue
- Where can the MAF thermisistor be had?
- 2000 Maxima Bose amp seems to be going off/on randomly, any ideas?
- New thread, same misfire problem, new question.Recording device to tell where mis is?
- how wide can we go?
- How to prep my car for the cold?
- Looking to Buy OEM Clutch / FlyWheel
- 00-01 maxima/infinti rear seats
- P0031 P0037 P0051 P0057
- New key question
- Disable the "self-lock" option
- Removing factory BOSE sterero. HELP?!
- 2003 Max. Intermittent missfire at idle. No SES light or code. Looked, did not see.
- Obx header install
- Should I buy a new car or get my max fixed??
- Takeda SRI
- 88$ eBay Coilovers
- O2 Sensors-Direct fit-Color coded?
- something different for a change
- Anyone here install a light under the hood?
- 2001 Maxima SE....When I start the car....
- Cheap tire websites?
- Tein SS Coilovers Picture Request
- 2002 Maxima SE totaled. Question about value
- Warped Rotors.
- Fog Lights. Help
- Question about idler pulley removal
- p0430 cause MAF to die?
- OBX headers & y pipe with Megan ORS catback?
- Win a Sony Playstation 3 (PS3) or Gran Turismo 5
- Sound clip, bad engine noise... please help
- Those with UDP's with bolts that hold the timing ring...
- Oil Problems
- Automatic Trans Motor Mount Replacement Options
- Cold Air through Steering Column??
- Emergency brake line stuck?
- Getting lots of CELs... need help
- Headlight separation question
- M1 Syn ATF no longer ok for DEX III/Mercon?
- Changing transmission
- scored tickets to the seahawks vs carolina
- Steering rack leaking at the seal (big nut) 2003 max. Alternative to replacing rack?
- CamShaft sensor replacement - P011
- 2002 Maxima SE auto trans
- halfshaft replacement
- How many people..
- What is my car worth?
- They Got me Again
- Seat belt discussion- More Analytical
- Underdrive pulley belt size...
- Transponder Chip Transplant: Possible or Not?
- FlyWheel Question
- Decision on procedure for 2003 Auto Transmission service procedure, more analytical.
- How to remove rear bumper ?
- hi beam question
- Viper 5901 installation?
- weird clutch issues??plzzz help
- NEED HELP 911 911
- bad ABS control module leading to speed sensor malfunction?
- Did I spin a bearing?
- MOOG inner tie rods 2002/2003
- Stuttering When Cold ...
- NEED A QUICK ANSWER PLEASEE!!
- Tires with rays 19's
- Buying o2 sensor and just want to verify part number..
- Invincible Bose System
- Going to be a good holiday. Close on my house on the ~25th
- My Car is now a turd!!!!!!!!!!!
- P0138 Code-Sensor replacement-ECM reprogram?
- Quick Winter Question
- SAFC setup WTF cant get certain screens
- Timing Advance Issue
- 6spd maximas : Do you use 2nd gear ?
- 4th gen tranny in a 5th gen?
- 5.5 gen 6 speed to auto swap parts list
- mis fire are idle and under load random
- Rod knock or piston slap when starting car in cold weather?
- Bushing questions
- Sincity Max is for sale
- Rear Deck Rattle?
- Muffler hanger broke
- Where is the joint connector for the fogs
- ES motor mounts
- What Body Kit?
- Performance gain ideas on N/A
- Lotta Questions! Please Show Me The Way.
- Another, hopefully more analytical, transmission flush thread. Method, extra magnets?
- Grill burger removal?
- 2001 5 month recap
- 6spd swap question about parts
- safc install and initial setup (NmexMax, Moncef and Tech gurus)
- Where to buy lettering/emblem?
- How many miles before replacing the timing chain?
- I'm changing my cat converter, what to get and from where??
- A more analytical MPG thread please.
- Battery fails to quick
- 2000 Maxima Vs 2000 Bmw
- Did any 2003's come stock without trunk emblems?
- Maxxxtunning front lip for sale
- Axle Help.
- Megan Strut Bar?
- Passenger side front window switch broken
- OBX headers replacement gaskets
- Routed Passport Radar Mute Button to Shifter
- NEW TIRE QUESTION!
- Transmission removal without transmission jack?
- scissor doors
- Pushing out of 6th gear
- mpg range?
- OBD-II USB for 5.5 gen?
- Full suspension/steering overhaul
- Question on stock flywheel
- Help! New Engine will Not Start
- spark plug gap... what do you run
- Iphone Dyno and OBDII scanner
- Rattle/Vibration while sitting still
- Sick of the Bose!
- Engine Stalling, IAV Learning, and what is this thing on my engine?
- SAVE 20% off already low prices @ AUTOPARTS123.COM
- Advice for project plz >>
- Struts
- ECU self reset or OBDII Scanner reset
- opinions and thoughts on and intake setup
- Exedy OEM vs Stage 1 (also, flywheel?)
- VIN Check
- Painting grille on 2000 max...
- painting inside headlights question!
- 395 HP 5th Gen Maxima
- 2K2 AT Shift Console in 2000 MT?
- peeling clear coat
- Learned something new about my Max
- If anyone is looking for chrome gauge rings for the 5th Gen
- Poll, do you use spacers?
- Can we talk about 6MT clutches?
- Finally Upgrading ! :]
- BBMAF or LRMAF and tuning question?
- Umnitza angel eye help.
- Gutted pre cats?
- Dealer failed to solve this , Please help me
- air filter options
- Angel Eyes 2000 maxima?
- Front Wheel Bearings What Brand?
- bad ball joint?? plzz help
- Srry for doing this custom maxima...
- What are the best looking fog light bulbs out there?
- Good to be here
- Front PreCat is Gone
- 7th gen vq in a 5.5?
