- Have any of you heard this?
- headers and o2 sensor
- I wanna get a catback, but have a question...
- Bad PIAA Super Plasma GTX Bulbs?
- Need Advice…
- anybody with 19's dropped with S-techs?
- What to put on CV Boots????????
- airbag sensors - where are they?
- P1126 error troubleshooting
- Negative battery cable replacement question
- shock sensor
- dde owners, how cold for pink eye
- GAB mod
- my car pic
- anyone know how to change a pulley bearing
- Replaced IACV now idle is FUBAR
- 5.5gen IM question
- Lowered my car and now need a camber kit
- Strange Engine Noise
- can coolant evaporate? or is it leaking?
- Smoked side markers (non-DIY)?
- LTB 2 Install Advice/Help
- OBX headers and y-pipe question
- Just wanted to say thanks!
- No dash panel lights or parking lights..
- P0420 w/ noise
- could a big puddle cause p0138
- SSautochrome 3.5 Headers
- Mileage poll
- Steering Wheel Radio Control IN 2000se?
- Mice taking up residence.
- Steering Wheel Radio Remote
- removing door panels?
- Headers + high flow cat + B-pipe
- what do you guys thinks about this maxima
- Trailer hitch?
- Windshield washer nozzles that "fan" instead of "stream"
- Goodbye Everyone!! It's been fun!!
- Does anyone have modified side mirrors?
- Headlights & HIDs
- anyone here warranty their tokico illuminas?
- Any New Thoughts?????
- Brake "tightness"
- Is it possible to swap Frost Leather Interior for Black?
- RSB Install
- what are these problems?please help
- Upgrading suspension.......who has purchased Tokico Illuminas?
- Ayone know what it means when the following two MIL's come on at the same time?
- o2 sim
- How much for a tranny job?
- P0130 and P1148... Any relations?
- Getting the 6-speed moving smoothly
- Add HID high beams to headlights?
- To keep or not to keep
- 5.5 new header choice
- can we fit 2k1 coils in 2k maxima?
- Heated Steering Wheel - Off after 5 mins?
- Climate Control Temperature Adjustment
- Manual Transmission Fluid Level Check.
- Changing rear wheel bearings
- Down on power. What's going on?
- People with Coilovers, Especially JICs Step Inside
- Acceleration Problem
- poor gas milage , low idle no cel light on 3.5
- Radiator Hoses replacement
- Coils for $58 W/ Lifetime warranty
- PIC Request: Redline Leather boot + aftermarket shift knob
- Got rear-ended Saturday night/Sunday morning... (big pics)
- leather shift knob restoration
- PAC-X Switch for 2k1 who has installed ?
- Anybody running Warpspeed High-Flow CATs? (And Y-pipe)
- Can any1 post up Haynes manual pages or photos of 00-01 VIAS/Upper Intake Manifold ?
- Y-pipe Questions/Concerns
- Disabling Daytime Running Light Feature
- rear shock shot thru the mount.. any ideas?
- how to change the PCV valves on 5th gen?
- which one is better to go for...? help.
- MAF replacemant for 5.5 gen.
- Moderators - 5th gen forum suggestion...
- Which Dead Pedal?
- 2000 I30 parts the same as in a 5th gen?
- Problem with wheel bearings...
- Tranny shifts slow?
- I35 Cluster Swap into a 2002 Maxima
- Before I bribe the Nissan mecanic ...
- squeaky rear suspension, who has this problem?
- iintrument cluster compatibility question
- Aftermarket key fob
- 5.5 gen grill painted black
- 6000k or 8000k D2R
- Need headlight assembly
- Yes LED bulbs for our Gauges.
- AE Fog Light Replacement - How to's
- What To Do At 60k Miles?
- Can Nissan dealers do a history report on a used vehicle?
- Too lean?
- quick help (tire question)
- Installing RSB this weekend...have question...
- Opening up taillight housing
- Will my wheels get destroyed this winter if I don't go to steel wheels?
- MAglight
- need help please: regarding the spark plugs.
- My Max is no more.....
- NEED HELP from coil readers!!
- How-To Change Coils on a VQ30DE-K
- optima red top part number?
- First impressions (cleaned MAF and TB)
- What causes "ICY" to come on under the tach????
- Selling my 2k Max
- Another Stolen Headlight NJ area - But this one is interesting....
- need help with the right part number of coils.
- 3rd Party Extended warranty recommendation
- Is It Def. MAF???
- Need to know if 2003 350z 18" rims will fit on my 00 max. Will 8.5'' fit the rear?
- Touchup Paint on Sterling Silver 03 Max
- Falling In Love Again
- Cheap mod....
- 2003 Maxima Crankshaft & Camshaft Sensor Recall - I got hosed by the dealer
- MAF cleaning update...
- Boss Chen coilovers review
- does anyone know... how long those
- LED in Keyring always on?
- pinging and knocking sound went away
- MAF compatibility question
- Tokico Suspension
- go faster stupid thing..
- Small Crack Formed on Dash
- Power loss over 2500 rpm. Help!
- Painted dash
- Upgrading needed!
- Suggestions on custom exhaust components
- Any 5gen owner with only y-pipe and Cattman/HKS muffler?
- LED Gauges
- TB and Intake manifold
- raplacing maf
- Hlsd ?
- Replaced rotors now they grind?
- How do I take off my brake lines?
- Which Cat?
- Been a while... diagnosis possibilities, gurgling sound?
- Are these the right spark plugs I should go? Pic inside
- Exhaust Question
- Crappy shifting on 6 Speed - Is it me or the car?
- does anyone have samco silicone radiator hoses?
- Wheel Bearing Replacement
- any 5.5 gen'z remove their reverse gate?
- Just bought 2000 max and it has no balls help
- Borla exhaust
- shipping from dave b?..
- **p0172**
- front sway bar links
- Service Engine Light
- how to remove front bumper?
- help! Car does not want to go more than 1/2 throttle!
- Question concerning replacement of Coils
- New Car Knocking on Startup!
- Wierd knocking problem upon cold startup. Help!
- I have two questions...
- ECU Question
- TS ECU vs New Headers
- Calling all 6-speeds that have had the clutch replaced
- Attempt on Headlights
- what if my oil catch can doesn't have any oil in it?
- anyone bought these coilovers?
- Mpg
- Question: can the projector headlights take d2r/d2s bulbs?
- does anyone make or know where to get a 5th gen radiator cooling plate?
- how good are new oem brakes?
- I need 5th gen owners to check something about baby seats...
- Bought 6 new coils $63 each is this a good deal?
- VQ35 strikes again...
- nismo fuel pressure reg.
- Factory 17'' rim width???
- Your P0430!!!!
- Got TSB NTB03-022 Done today - NICE!
- Is it a good deal ?
- Favorite/Best Mod under $100
- clutch problems - plzzz help!!
- Where does 01 cd changer plug in?
- searching eBay for black SE tails
- Thinking of upgrading to a 5th gen and I've got some questions
- P1320 - Ignition Signal
- Websites
- Radio Fuse
- nissan maxima cd changer $60 -- fog lights $60
- Thermostat Issues...Please Help
- indoor/outdoor thermo & power seats q's
- Pic Request: Shifter linkage of a 6-speed
- Custom Gauge Pod for Five 60 mm Gauges
- Does the Transmission Control Module get programmed by the Solenoids?
- White, Black or Stock
- Painted stock 5.5 gen grill black
- who here has 6k hids on 03 housing?
- 6th Gen Engine Cover On 5.5
- battery relocation Q
- These any good??
- Great source for 13" rotors
- 2001 AE Engine Cover Question
- hardwired radar detector
- reservations about dropping my car
- New CALIPERS?
- Knocking and Pinging Noise
- Eyelids..where to buy?
- Anybody know anything about "Clutch Shutter"
- Spark problem
- who has nissan maxima halos from ebay?
- brake upgrade
- VLSD wearing out?
- HID questions...
- ebay Halo Crystal Headlights - NOT EBAY PROJECTOR HEADLIGHTS
- Gas MPG on a constant decline.. WTF?
- Recommended Code Reader
- Preferred AT Fluid?
- OEM clutch vs. Aftermarket
- Does anyone have the TSB for Tranny computer (TCM)
- Is it possible to convert 5.5Gen Headlights to 5th Gen?
- Pic request. 17" oem altima se rims on a 5th gen
- big brake upgrade.
- belt changed
- Gas Mileage
- RPM at 80MPH
- o2 sensor
- P0720 VSS output speed sensor malfunction?
- New Horn ...
- Going to invest in new spark plugs for an 03. Anything I should consider?
- Is this a good deal? (Used loaded 2k3 6pd w/ 53K)
- Driver side heated front seat question
- Is $160 too much for a Consult-II ECM update under the NTB03-022 TSB?
- New Springs in Front only? Advice?
- Would the dealership install 5.5 GEN Headlights in my 2001 GLE?
- ----- 2000 SE 'lost its Punch' when accelerating
- Specific SES Code Solution
- 6th gen IM?
- iPod Kits
- Climate control fan whistles after filter change.
- Shifter cable snapped, help please.
- 6th gen brake upgrade
- Wheel Bearing Issue?
- Weird Idle after TB cleaning
- LED Mirror shell (paradox) install help please
- has anyone bought this exhaust?
- ABS Light?
- NOISE coming front right front whell..help!
- Looking for clear corner/FRONT SIDE MARKER LIGHT
- please help me with this confusing P1320 code..
- Maxima.org........thank You For The Great Advice!!!!
- check engine
- Noise when fan is on
- pop tabs under bumper - how to get back in
- what does this cable do??
