- Xenon vs Halogen Headlight Housing Difference
- Weird question about moisture in the trunk
- Shift Lock Control Unit Replacement
- Taking taillight assembly out
- Suspension thoughts
- Projector Headlights for Xenon equipped Maxima
- Will a bad ECM fry a new IAC Valve?
- Transmission Motor Mount Question
- Removing Rear Spoiler
- 5th gen Cattman 3" Catbacks available - Soon!
- P1320...I know, Ive searched....
- Monroe Quick Strut on an SE
- Maxima will start but die
- P0300 due to low compression?
- Gauge Faces available on ebay 02 maxima
- 2001 maxima AE muffler(HELP)
- 02 max 6MT, doesnt have electric motor mounts?
- 2003 maxima engine and tranny mounts
- woo for i35 grille.
- Received my new wheels! But they won't fit???
- Replacing broken motor mounts
- Will a 4th gen control arm fit a 5th gen?
- Ultra Racing Room Bar Install
- HARSH ride after tein ss install
- Tein Lowering Springs with KYB Struts
- clutch issue??
- Search Function Not happening for me?
- Gasket fest 2013?
- i35 grille emblem
- Brake light and charge warning lights came on
- aftermarket radio won't turn on
- 6th Gen Rear SS Lines Work On 5.5?
- 2001 AE Floor Mats
- Which Double Din will work?
- Got some new wheels
- Throttle Body grounding points picture.
- Loud Bank 2 Eastern Catalytic Converter
- Looking for 5.5 gen momo ebrake handle install guide
- nissan maxima engine swap
- RPM gauge stopped working followed by smoke coming from the dashboard.
- Part for bumper to fender clip, fastener
- no air no a/c no heat doesn't blow air
- 2002 nissan maxima
- 2001 Maxima passenger side axle difficult to remove
- Person that Retros HID for i30?
- Rear O2 Sensor OBD Codes - Horrid Mileage
- Fog Lights Upgrade?
- Misfire - lack of power shaky smell gas vibrate what could it be?
- Help Brake issue!
- A thread about gas
- Hood insulation
- car seat cover
- rear main seal
- Incredibly weak headlights, all other electrics are fine
- Replacing i30 Ebay HID bulbs
- Air Cabin filter clip missing?
- Bahnhof Clutch + Fidanza Installed!
- To Ypipe or not.......(sound)
- Top 10 gen5.5 topics I like reading about
- Few questions regarding 3.5" LRMAF tuning, VAFC2, 3" exhaust
- 2000 Maxima Rear Struts
- Oil in combustion chamber/spark plug
- Misfire help
- Top 10 things new Maxima Owners should do
- Wet Passenger side floor?
- trunk valet switch lock
- What do you think this is worth
- disconnect electric motor mounts?
- What next?
- 5 gen to 5.5 headlight conversion
- H3 hid (help)
- Anybody in Mass gut precats?
- Question on octane booster
- Anybody know this car? (White 02 6 speed Stillen kit, Lowered)
- engine swaps
- Water leak on nissan maxima 2000 se
- Need help Wiring Seats
- What code
- What code is this
- What code is this
- Child Safety Lock Please Help!!!!
- Maxima Love.
- Tail Lights Not Working
- Everything works BUT the stereo
- U 1000 code - faulty communication circuit
- Fuel Filter
- Anyone have a picture of their 5.5 headlamp assembly clip?
- 2002 maxima vafc
- Oil consumption and PCV valve?
- ABS Error code 61
- Another Cat question...have mercy..
- What to use to seal this?
- O2 sensor Identification
- P0420 - need info on Eastern pre-cat install
- Just curious, those who have done 5MT to 6MT swap
- First trip in my max, 400 miles yesterday, driving impressions
- gas quality??
- Suspension Issue
- Quick question and iI don't have a lot of time
- Battery Issues, No Charge, Troubleshooting
- New to the site/ecu question
- Refusal to start, Secruity?!
- Opinions needed...speedometer upgrade....
- After installing radio
- Has anybody ever installed side mirrors?
- flywheel question
- Im new need help
- RMS and half moon gasket
- MAF and Transmission Issue
- Unknown part and need to know to replace/ random clanking noise
- Timing advance....
- installing a bose radio
- P0505! New questions for the dreaded infamous code...
- Coilovers
- 2003 headlights on 2001 maxima?
- Tail lights
- tail light problem please help
- Anyone painted 5.5gen valve covers?
- 03 Maxima Power Issues!! Please help died on side of road.
- Have I ordered the wrong part again? (Koyo Radiator)
- Transmission is swapped but...
- 5th gen suspension help
- Wipers frozen, stalled
- Right !@#$@& Drive Shaft
- A/C Compressor
- Piston rings question
- Kensun HID kit review
- Drive train shaking under load...need help diagnosing
- Car died after WOT
- Weird idle help...
- Air Bag Fitment Problems
- 6 speed transmission removal question
- how to wire LED Strips 2001 maxima 20 se anniversay
- 2000 Tail Pipe Cover
- 5.5 gen 6spd shift knob thread.
- 5th Gen Prototype MS-CF5 or MS-FG5 Suction Kit
- Painting OBX Headers
- No Start if Below Freezing
- Quick Charcoal Canister Vent Valve Q
- Anyone have a part # for heat seat relay or fuse?
- Need some help Please.
- Any suggestions on what to replace for a clutch pedal groan
- 6 Speed Swap - Car Doesn't Stay Running
- intermittent idle issue.
- It Takes 5 Mins to Unlock my 2000 SE
- Passenger power seat problem/question about plug! Need advice
- maxima in mercedes commercial
- HELP! 2003 Maxima cranks but won't start after spark plug change
- Question about brakes
- power windows roll up SLOWWWW....
- Gl-4
- Anyone know the bolt sizes for the flywheel and pressure plate for 2001?
- 2000 SE odd transmission problems.
- Info on brake kit
- Help car wont run!
- Anyone know general price of leather reupholster on 01 i30?
- Rattle/drop noise from front suspension..HELP
- P1800, p0420, video
- Is reprogramming a Junkyard ECM possible when you have a possibly broken IMMU (Immobi
- passenger rear wheel dragging?
- Carbon fiber vinyl wrapping door moldings?
- OBX Headers with Cattman Catback?
- Ebay Catback Review
- DLC connection issues
- Finally silenced my rear axle squeak!!
- Bulb HID / Ballast question
- 20 inch rims
- BBK question
- Valve Covers
- 2002 maxima se horsepower mods?
- Vibration under acceleration only
- 2000 Maxima Wont Start
- Will test pipe make exhaust louder?
- What do you think? (Exhaust related)
- Going to begin to weed out the Sticky's
- Oh just great.......P0430
- Short shifter kit for a 5.5 gen
- 5.5 gen upper oil pan replacement.
- P0175, anybody fixed this issue?
- Transgo Shift Kit: a must do or not?
- 2k2 w/6spd - clutch "howling" when engaging
- Ignition cylinder stuck -__-
- Headlight Wiring Harness etc.
- Cleaning up oil on electrical connector
- Frankencar Intake - Failed Visual Inspection
- buying another 5.5 gen, but has rust under hood.
- Upgrading Muffler/Exhaust ... Need help
- Craigslist Drop Springs/Shocks...help identify
- 01 max AE ringing sound from front pass wheel
- 2001 3.0 motor mounts and valve cover gaskets
- Rusted/Welded Radiator Support.
- 5th Gen Manual Trans Leak,&& Type of Gearoil.
- Noobie Thread: How Do I Replace An Idle Air Control Valve On 01 Maxima?
- 2001 Infiniti I30 climate control fan
- 2000 I30 Brakes
- CF hood + trunk on a black max
- P0505 idle control valve
- 00 Maxima SE, factory springs...
- best bang for the buck mods and maintenance
- whats the oem brand for ignition coils?????
- 2003 Maxima Base Model - Buying Quesiton
- fuel door
- 2002 Maxima shakes hard
- Vacuum line help.
- After new Throttle Body - love my Max again
- Would Struts Usually Be Considered A Maintenance Item At 75K Miles?
- HELP!! 2003 Ignition Coil multple replacements
- Doing/did a few of the mods many people are asking about.....
- Lights flickering can it be a bad ground??
- 2002 HID Lighting Issue (Strange)
- Vacuum Leak Sound under IM?
- Worn shocks/strut symptoms
- Periodic belt squealing
- rear main seal.
- Strong gas smell in exhaust
- Vehicle surging while in gear
- Parking Brake only goes half way up
- wheel hop after new tires?
- Time To Replace Rear Shocks
- This is a Nightmare for Maximas =(
- Oil leak but not sure from where
- 00 Se Overheating
- 03 maxima se transmission not shifting to over drive
- Battery drain
- Needing Advice on Oil Leak/Burn Issue
- 277,000 miles on Infiniti i35
- 6 speed transmission trouble please help
- Rusted Radiator Support
- Bad lug nut or stud
- P0110, P0500, Rough Idle
- Will Bad Ignition Coils, Faulty 02 Sensors, A/F Sensor, or Bank One Cat fry the ECM?
- Multi Cylinder Misfire--Not the common problems
- some newbie questions
- 2002 Black GLE with G35 rays?
- YES anothah VIAS question?!?!?!?
- 111 octane gasoline..
- Another injector Question
- Help!! 6MT tranny Leak
- fire
- Oil cooler leaking???
- 2000 Maxima starting problems
- Here we go again....03 6spd Question
- HELP ! - Sound Deadening ? AFTER Dynamat - Input please
- Let my 79 year old mom drive my car, now my flywheel has hotspots!
- Gutted front pre-cat, installed nonfouler, now code P0158
- 02 6MT, clutch starts grabbing almost as soon as its moved away from the floor.
- GI: GB Tdmimports coilovers...biggest more durable out for us...
- Do our cars only require a front end alignment?
- Question about braking system
- Lowering 02 Maxima
