PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. VSS on 2000 maxima 5 Speed Help!
  2. Another Engine Light Came on 01' Max PreCat Bank 1
  3. What size is the Stock exhaust on an AE
  4. New Member with Hesitation question
  5. Pre cat gutted
  6. Broken trans mount bolt
  7. HELP!! VALUE OF 2001 MAXIMA w/ ENGINE BLOWN
  8. Help
  9. Nissan Maxima 2000 starting issue Catalytic converter, Cylinder misfire no. 3
  10. Fuel pressure test
  11. Drivers side A/C evap leak
  12. 03 maxima security light should it come on for a few seconds when you turn the key?
  13. Car stalls when in drive
  14. Need to Vent- Bummer Led Experience
  15. HID problem - ballast or igniter?
  16. Clunk from rear end at low speed, smooth pavement?
  17. 2003 stalled out on highway..scary!
  18. My 02 Maxima Project
  19. Replacing Drivers Seat 2001 SE
  20. 2000 Maxima GLE won't crank
  21. Looking to return to a 5th gen
  22. Oil light on...mechanic says to replace timing chain
  23. An array of questions!
  24. Wanting to Mod up my 02
  25. 03 Nissan Maxima GLE car alarm problem
  26. 4 DTC 2002 Nissan Maxima
  27. P1456 and P 1147
  28. Darn my luck - need axle nut opinion
  29. Timing LIGHT help 2000 SE
  30. Speed Sensor Replacement
  31. How to clock and 02/03 flywheel?
  32. Misfire/Hesitation Issue Difficult to Confirm Cause
  33. Key barrel light change
  34. Quiet flow SS drone, what next?
  35. How do i adjust the clutch
  36. Drivers side fog light is being stubborn
  37. coolant leak
  38. New sub amp cuts out when braking?
  39. Oil Filter and oil Maxima 2002
  40. Replacing the rear valve cover gasket
  41. Steering and suspension
  42. 03 Maxima stalls after a few minutes and won't run
  43. 3rd brake light out
  44. Weird sound coming from Engine/something else
  45. New fog light bulb size.. Help!
  46. 02 6spd tranny noise ???
  47. Car hard starting please help
  48. Transmission cooler line, big issue
  49. Looking for ignition hot wire source
  50. Axle Disengaging Please Help!
  51. Reccommend Engine wash? Or nah?
  52. Anyone have this trans problem?
  53. 2000 max acting up.
  54. Help!!!! TSC Off, Slip Light on!
  55. Aftermarket steering wheel
  56. Idle Control Valve -- clean vs. replace
  57. Headers installed
  58. 2000 5 speed exhaust missing need help
  59. 2002 Max GLE
  60. 2000 Maxima hard to start, stutters and stalls when started
  61. 2002 rear calipers not functioning...
  62. High Flow Cat or Test Pipe??
  63. 2000 Maxima shut off while driving....
  64. Tested New Alternator not charging
  65. Catalytic Converter
  66. subwoofer cutoff fix
  67. Newbie HIDs color temp ?
  68. Mini Maximas
  69. Muffler advice required
  70. Throttle Body Swap
  71. NEW Line of 3" Cat-back Exhausts for 00-03 Maxima & 00-04 i30/35!
  72. What is this part?
  73. Starting Issue (Getting Worse)
  74. what parts ?
  75. valve body probs?
  76. Stock bose sub cut off problem
  77. Bose Stereo System acting up
  78. 2000 Maxima SE has a 91 oct requirement?
  79. Best Brand for Control Arm?
  80. Anyone Else Have this strange issue?- Sunroof
  81. VAFC2 Installation Problem
  82. Ac compressor or altenator
  83. headers for 5th or 6th gen still produced / available?
  84. My new Volk's GTV
  85. 01 Max E-brake loose
  86. New used purchase-1 key, 1 remote
  87. difference (?): OEM vs aftermarket gas cap
  88. Lowered Car, Better Gas Mileage?
  89. High Pitched Whine/Squeal During Acceleration
  90. Brake and suspension upgrade
  91. Are AutoZone fans OEM Quality?
  92. Heat shield on front precat
  93. What is the switch by the headlight?
  94. Pressure Sensor
  95. Mediocre gas milage
  96. Seat Covers
  97. shopping help?
  98. Megan catback
  99. Check engine code p0505
  100. Car cranks, but no start - immobilizer?
  101. Top Speed issues..?
  102. Brake lights won't go off
  103. idle problems when hot
  104. homelink wont program
  105. searched but no help clutch pedal falling to floor
  106. Please help with passenger seat!
  107. Remote for keys broken randomly
  108. Have no idea what this part is called or where to find it
  109. Cargo Net Hook
  110. 2002 Nissan Maxima not working
  111. Intake
  112. Auto tranny swap question
  113. Ignition Key issue starting up Max
  114. Stop/Tail warning light fix when adding spoiler
  115. Ac compressor
  116. Collant dripping from IACV
  117. IAC valve replacement
  118. No air from vents??
  119. 2000 GLE Power Loss
  120. no power
  121. no power
  122. what years flywheel will fit
  123. Diagnostic help: blower motor, etc.
  124. Electronic Whining sound coming from up front? 2001 AT
  125. Suspension lowering and squeaking sound from the rear
  126. I30 clock install issue:(
  127. cylinder 1 misfire
  128. Calling on an electrician.
  129. Cattman exhaust headers
  130. Scrapping Noise when turning
  131. Looking to mod my 5th gen neeeeed help!
  132. Burning smell & possible leak? (pic)
  133. 2000 Maxima won't start.
  134. Exchanging tail light on 02 Max
  135. Weird suspension issue
  136. Whining noise/muffler repair
  137. p0171 - 2001 maxima
  138. 5th gen engine sound: video
  139. 03 Nissan Maxima Black 6-speed
  140. Front end thump
  141. Back with my 3rd Maxima--yet a question
  142. 2002 Maxima Starter?
  143. are my engine mounts electronic?
  144. Cheap eBay 2" Drop Springdaddy 75$ lowering springs
  145. 2003 maxima 6mt no start
  146. Knock Sensor Bad Without Throwing Codes?
  147. Turn only the fog light on?
  148. Are these reliable cars?
  149. 01 Maxima AC not very cold
  150. Back in the Maxima community
  151. Code p1564 help
  152. Nexus 7 Install with Steering Wheel Control (Replaces Headunit Completely)
  153. ANY A/C Questions ?
  154. 2001 A/C Issue
  155. Spark Plugs?
  156. Is this the real deal?? Ebay Hitachi IACV
  157. 2000 Maxima Driver Rear Brakes
  158. clock, security light, and trip odometer resetting
  159. Rusty weekend
  160. Mirror Creaking Groaning When Folded
  161. power steering leak
  162. Plasti Dip My Max
  163. Plasti Dip Colors
  164. 2001 Maxima brake noise/and other weird noise
  165. 2001 Maxima brake noise/and other weird noise
  166. Cam chain replacement
  167. Strange B pipe gasket isssue
  168. Cone intake
  169. 5th Gen Maxima Restrictor?
  170. car overheating...water pump is how much?
  171. 2001 Nissan Maxima -Transmission- Revs Rise, Speed does not
  172. 02 maxima SE misfiring problems
  173. Found a shady 5.5gen, look inside
  174. Help me with my pulley
  175. 2.5 MT Swap?
  176. PCV valve grommet part number?
  177. 2001 Max project (not worklog)
  178. Maxima won't idle
  179. Anyone using ELM wifi OBDII
  180. Whatever I do, I can't get my clutch working again
  181. 2002 Maxima A/C system not cooling
  182. intermittant starting issue
  183. speedometer issues 01
  184. 5th gen with copper plugs?
  185. Can't pass emissions on a 2002 trouble codes need help!!
  186. Front right fog lamp is off
  187. Vibrant Exhausts? HELP!
  188. 03 running rich, even at idle
  189. p1122 & p2135
  190. Quick OEM oil filter question
  191. Gauge lights brighter in certain areas
  192. Nissan Data Scan II
  193. P305 - Cylinder 5 Misfire
  194. Exhaust problem
  195. Code P0507, New TB and IACV!
  196. Mushy brakes after long freeway grade
  197. p0505 questions
  198. Factory Stereo Replacement with PAC ROEM NIS-2 on 2000 Infiniti I30
  199. Fog light led swap?
  200. budget gsxr ITB vq35de?
  201. Tranny Fluid Question.
  202. catalytic converter
  203. Is there anybody can point out the DRL module on the pics?
  204. need a mt cluster for my 2002 maxima
  205. Question about P0430 code
  206. Quick Exhaust Related Question 2000 Canadian Maxima in NY
  207. 6gen brake upgrade
  208. Need a few bolt sizes (Cali PreCat) if possible
  209. Trans cooler hose size.
  210. 2001 Fog Lights Yellow bulbs
  211. Crank pulley wobble persists after replacing it
  212. 2002 Maxima wont start after brief overheat
  213. 2002 Maxima SE, 3.5L for SALE!!
  214. is this exxedy clutch kit good
  215. how do I top off manual transmission fluid
  216. Happy Father' Day
  217. Modification Advice Please!
  218. please help me, electrical/starting issue..
  219. anybody tried nokya hid bulbs
  220. Issue after new spark plugs (vid)
  221. Car not firing
  222. help with problem since led install please help!
  223. AC/Alternator belt keeps slipping
  224. 2002 3.5 AT Issue
  225. When do you shift
  226. New alternator creating 13.4V at idle
  227. Should i fix it or ditch it, dead engine 210K miles
  228. Replacing IACV... Have to replace ECM?
  229. 6th gen seats ?
  230. Check Engine Light after Refueling
  231. KYB Excel G / GR-2 Rough Ride?
  232. Greddy emanage Blue wiring vq35de (350z 2004)
  233. how do I remove steering gear
  234. P0442
  235. 02 maxima letting out alot of oil from behind front valve
  236. timken bearing
  237. Where is cattman?
  238. New plugs, car not running
  239. Install Heater Servo Motor for the A/C?
  240. large snap sound!!
  241. abs light spliced wire
  242. Car keeps dying
  243. Engine Light On (High Voltage)
  244. SS 5.5 gen 6spd clutch line
  245. Just a few questions if anyone could help out
  246. Muffler Help!!! Im New.
  247. VLEDS V3 Triton Installed (pics)
  248. exesive right front tire wear
  249. Emissions issues
  250. Possible sticky e-brake
