- Alternator and Starter Installation Blues...
- carfax request
- I'm outta here .... thanks for the info!
- Can i sell broken Hid?
- Anyone have replacement HID headlights?
- Online Microfiche/Parts Listing Availability?
- engine guard clips
- full rebuild or replace diff bearing only???
- Does your Bose sub rattle ALL the time, or only with certain notes?
- 2002 or 2003 buying help
- 2002 pulling P0138 (more O2 crap)
- 5th gen vs. 5.5 gen OE Mufflers
- 02 max is over heating, I need help.
- okay, i cant take this clunking anymore
- Question: 2000SE vs GLE/GXE exhaust ??
- Best way to remove rotors?
- Auto shifter "grinding noise"
- 2000 Muffler Recommendation
- Ram Air?
- Colors of Wires for O2 Sensor?
- HELP!! Car wont stay at normal idle (No, it's not the MAF)
- 5spd removal question
- Anyone Had Their Hood And Front Bumper Repainted? Questions
- Reliable coilovers…..
- Removing stuff from window
- TCS question.
- can alcohol rub....
- Can you replace the headlight wiring harness??? (m)
- Just bought a set of illuminas and tein stech what settings do i need
- How to remove rear lens condensation?
- 2k Auto Dimming
- help! insane amount of wheel hop!
- Picture of Side of DEK Motor
- 2k Max exhaust system? stainless steel?
- optima owners please step in
- Where can I get the pac-oem?
- Why does my temperture gauge bounce up and down?
- Vibrating side mirrors at higher speeds
- New Years Present-MIL light - p0140 - Warranty?
- power steering: GLE vs SE pump
- 6spd Fluid Capacity
- The Dreaded steering wheel shimmy
- Response to engine/ radiator shroud
- ••ü•• Customer End Of Year Showcase & Thank You
- headlight aiming
- maxima plans for the year 2006?
- would this cause engine light to come on?
- need options to replace p.o.s stock 02 fogs
- Looking at OEM 18's for 01' Max.
- Happy New Year!!!!!!!!!!!!!
- silver maximas - what color for calipers?
- 2002 clutch pedal adjustment
- Engine/radiator top shroud...someone make one
- differences??????
- Are 2k-2k1 headlights DOT or E-code type?
- whats the difference?
- Sold the Maxima - VQ Burning Oil - H&R/Superleggara available
- Fog light bulb replacement? HELP!!!
- code please help asap
- Redlinemax.com - H3 Halo Super yellow Fogs
- Scheduled Maintenance Questions
- brembo blanks
- Rubber strip on top of headlight!
- I put the Demon in Daytime Demon Eyes :grinno:
- Help: My ABS light is on; 2000 Nissan Maxima SE
- Suspension quiestions..
- Nissan Maxima Service Manual
- Key Question
- quick exhaust question
- blue fog light capsules
- me and my 03 are back
- Must i change plugs with new ignition coils?
- Metal Maxima Method For Window Switches
- Need help with Ignition coils....
- LOL, wouldn't it be great if prices were this low!?
- Help?? Got 2 questions
- o2 simulator question
- Anygood Price on illuminas for 2000-2001 maxima
- I30 & Max Rear Decks
- Reverse Glow Gauges Power Question.
- HOLY CRAP! Internal Engine Failure!
- which rims for black 2002
- Synthetic ATF Flush or Refill?
- Weird Noises when driving
- Auction Prices???
- swaping stock se manual ac control to auto?
- ISO rotating motor......
- Steering wheel controls for mpg, temp, etc rewire with aftermarket HU?
- Front and rear lip on ebay??
- 300zx brakes or 6th gen Brakes
- Hot to Check MAF--Write up
- firing order on a 2000
- is agx 95-99 compatible with 2000-2001 maxima
- "ICY" on the temperature?
- Anyone tested how much suspension mods really help?
- Need Detailed Writeup on HID Foglight Install
- 2K spark plugs question
- Has anyone purchased a set of illuminas from Ebay?
- Future Maxima Owner!
- tools to remove wheel bearing nut, what do u use?
- If you got 8” wide rims – come in
- Taillight question, please help - did search and found nothing
- Performance Depot HID Lights on Ebay
- timing chain rattle
- Extended Warranty
- Is it necessary to change spark plugs with new coil packs ?
- Article about cutting springs
- Huge problems with the Stealership I need some advice
- Been out of the Maxima loop for a while, quick question.
- wheel bearing
- intake install
- Which intake for '03 Maxima
- Body kit question
- Updated my Maxima
- intake install
- Water in tail light housing
- HID's & Turn Signals on 2k
- ECU reset and advanced timing
- New Sirius S-50 Install
- Need Wheel HELP! BBS LM
- Engine problems and transmission problems ohh my! Please help
- 2000 SE Cluster
- plz HELP!!
- iPod in '01 MAX
- Opinions needed please
- 22" Rims on a 5.5 Gen?
- Is it Possible to put 6th G steering Wheel into 5.5 Gen
- HELP! **scared**
- Strut replacement - Did a search
- The definitive Navigation CD THREAD!!
- will 300ZX 30mm TT iron big brakes fit our stock 17" maxima wheels?
- Problem with power steering..
- Auto Tranny Problems with 59,500 miles on the car PLEASE help
- Wheel question :)
- Import Intelligence...
- 2k3 max
- Lighting Options for a 2000 max
- trim level question
- D2's vs. Illuminas + S-Techs
- WTB: anniversary sills in grey and anniversary pedal for auto
- Options for rear valence and skirts
- Highway Shutdown
- 5th gen tranny question
- Maximas with the H&R drop. Post pics here.
- INcabin Micro air filter
- exterior body 00' maxima
- Where to buy Redline MT-90?
- Other possible auto trannies in a 5.5 gen
- wheres all the ladies???
- My gas mileage sucks!
- A32 5spd in a 5th gen??
- tranny clunk
- cold air intake
- timing
- New MAF & Dealer says no ECU Reprogram needed
- Rim question
- Stillen Rotors Installed...question
- Car won't stay idle/ or sometimes won't start
- Automatic Climate Control Swap Possible?
- energy suspension bushings
- Buzz sound on Cold Starts
- Question regarding tranny pan gasket.......
- maf specs
- Do Warpspeed SFCs Work?
- I35 vs. 02 se
- need a 2k2-2k3 grille will pay
- stock HId to 6000k
- Wiring Up LED in Foot Well To Turn on When Doors are Open
- dealer retarded my timing
- Nismo Pads 6 Month Review
- Wheres the antenna wire?
- 02 GLE Lost Drive
- 5.5 gen. bose + ipod
- window UP via key fob?
- DIM SES Light
- Tanabe test car needed SoCal
- drivers door window control rattle
- Woodview molded dash kit ?
- 2k3 Black Maxima SE/TE sighting on Speed Channel
- Rpm Needle Holds Steady At 1800 -2000
- Question about factory warrenty
- Swapping Bose 8" Sub for other?!
- sub issue with new radion
- just want yall to know...
- Malibu lens cover vs. no cover at all when clearing turn signals
- Which pads are best for a non-racer?
- Started the process of looking for a shop to fabricate SFCs
- Blower motor noise
- ebay aftermarket Headlights
- those who painted their front lips themselves..
- Rattling problem found underneath. PICS.
- RE: F1 fenders
- need help with engine stalling problem
- Does anyone have pics of stage 1, 2 and 3 Warpspeed SFCs installed?
- Grille Tech owners, please step in!
- High Mileage Oil Worth It?????
- Best Color Dash Molding for Beige/Tan Interior??
- fuse?!
- detailed instructions on stillen body kit install???
- SWEET I just bought the very last Progress RSB
- D2 coilover before and after install
- some problem....
- 02-03 Haynes manual...Does it exist???
- coolant leak from iacv, will this fix work?
- Aftermarket exhaust - Hangers (Nismo, Walker, etc)
- Speedometer recalibration
- Smoking at startup. Anybody else???
- question about SE gauges
- HLSD failure symptoms??
- Muffler?!?!
- Got Rid of those damn squeaks!
- When braking alot of steering wheel shaking
- New Fog Rewire feature: Accidently discovered
- SES code of P1320
- P0420 code pulled - Three Way Catalyst
- Got my ecu reprogrammed today......
- is my master/slave cylinder going bad?
- Redlinemax.com- Bodykit Video
- should i get a vb mod stage II, or get am 5 spd manual conversion?
- Wheel Vibrating
- So my ECU is toasted (?)
- My maxima got its Christmas gift Early LOOK
- catalytic converters and Sirius
- Power windows struggling
- Unable to post....
- Happy 30th to the Home Depot Mod King
- no wounder we blow our mafs, here is some investigation...
- LED bulbs in taillights
- indigo door sills help?
- Possible to have a y-pipe and not know it...
- HeadLights Gone
- Dimmed door light
- window tint ticket in pa!!!!
- Exhaust Diagnosis Request...with Pics
- OBD2 Codes
- Which Exhaust
- Where can I get a new drivers seat??
- Can you cancel orders from tirerack.com?
- new upper and lower grill idea
- air/fuel gauge install
- Headlight Aiming Sticky ...
- which 02 sendor wire for air/fuel gauge
- Where Can I get the Otto Racing FSTB?
- From Ticked off to well....worse...
- can someone please post the TSB for the 2k2 2-3 auto trans slip?
- anyone know OBD II - laptop scope quality?
- Cutting cat make different tone?
- Rear top window air deflector NEED HELP.
- GXE Kit and double din HUs
- Which O2 sensor is it.
