- electric cutout install
- Cold Start; Gas smell;Low mpg;Analyzer
- EU install cranks won't start...HELP!!!
- New Max for Christmas
- power window problem
- P0505 need advice
- $2,000 rims?
- Foglights wiring Problem (help asap)
- I dont get what could be going on with my throttle response ...
- Back In the MAXIMA game...SON
- On a cold day will your regular(non-AC) air blow cold?
- Audio fuse under hood is blown...Replaced it and it blows again. HELP
- Won't start after clutch job
- Went to install new front speakers, surprise
- Doubt with 300ZX calipers
- water leaking onto front passenger side floor after rains
- white wheels?
- Maxima Help
- Is this Limp mode???
- question
- advise please.... something is wrong! help
- 60+ MPH "wobble", I've done the obvious ...
- 4th gen ECU in 5th gen
- Where to get an axle for 6 speed?
- who manufactures cattman mufflers
- Car has a numb feel and likes to wander, control arms?
- 15 Minute 5.5gen Belt Change....
- Another fit, form, and function of 00-03 Ebay Projector style Headlights
- 3rd 5th gen in a row!!
- Car wobble
- Winter rim size
- Running foglights with Auto headlight sensor?
- Cattman exhaust system production?
- Might have transmission issue
- Bad electronic motor mount?
- OBDII Code on 2001 AE P0153
- Need some input on obx headers/warpspeed y pipe
- Looking for a 2002 Maxima Original Window Sticker
- Negative Battery Cable Specs
- Maxima and GS spur of the moment photo shoot
- Tired of CEL and no power. Help!
- Can someone look at pics of my new BOSAL precat....
- Unknown vibration question
- Looking to come back to the Maxima family
- stock flywheel on boosted 03
- Fan/Blower noise on 2002 GLE
- only drop front???
- Need help with p0057
- Yet another issue
- ABS and Battery light flashing?
- Brembo Brakes on my 5th Gen
- Stripped threads
- ecu wont send signal for evap..
- Puzzled after HID install.
- Side marker problem???
- Do these all weather mats look oem?
- All Racked Out For The Winter
- Picked up an 04 3.5SE.
- getting ready for a valve cover change.
- OE Muffler Internal Pictures
- Wooow, Dave Burnett gone from Southpint Nissan
- 5th gen need help- map light
- ecu REPROGRAM
- P0464 solution?
- Headlight Socket Wiring - Help Identifying?
- CRIKEY! Oil in the UIM - help?
- Starting Issues.. Battery or Short?
- Electrical Issues - Step Inside!
- Cold Weather Start - Engine Rattling or Knocking sounds with Blinking check engine li
- HELP!!! CAR WONT START
- Blower Motor resister Help!!!
- Springs/Suspension question 2002 Max (Auto)
- what size exhaust pipe to use? here is the answer
- Creaking and Groaning
- Replacing Coolant Reservoir Tank
- 4th gen engine in 2000 max
- Internet? In MY Maxima?
- Dual Pipe Catback VS. Stock Y-Pipe Modification... Question(s)
- Blue-ish hazed lens won't clear up after restoration, HELP
- adding remote start to my vehicle
- Car revs in neutral, but not in gear
- Cheap repair method for P0455 P1448 codes 2002 Maxima
- paint pen for chips... yes or no??
- Who here has OEM-style (NOT eBay halos) aftermarket headlights?
- maxed out first gear by accident ... car limps now
- As soon as I turn key everything goes dead. Any idea why?
- BBMAF Apexi Neo Settings
- HID Problem
- Coilover help.
- Acceleration Videos
- Heated seat switch blinking? searched and checked FSM
- Rear beam noise. need help to find bushings.
- Part name ? or solution - Bank 2 sensor 2 stuck
- Ticking sound.
- Keep, sell, or part out? 03 GLE
- Won't Stay Running - Help with Order of Repair
- RAYCO STS FAIL
- Stock Bose stereo mod?
- Spray Can Paint Job
- Coilovers
- Window washer light coming off/on randomly means bad alternator?
- working on radio, now blinkers don't work
- Is my alternator on it's way out?
- How much is my Maxima worth?
- p0031 o2 sensor heater circuit low voltage.
- What the heck does this part do? And where does it reattach to?
- Is my clutch master cylinder bad?
- Antifreeze Residue all over engine bay?
- Loud whistle on 03'
- steering wheel problem
- IACV/Elec Mt Mounts/ ECC
- BOTH low beams don't work
- Unable to diagnose steering problem
- 2000-2001 Maxima Color
- Suspension = new car
- Abs, Tcs, slip light on only when wet?
- 2000 front bumper
- educate me on heated seat buttons (01)
- Heater troubleshooting
- Auto climate control lights on and off
- Automatic climate control not blowing warm below 80*
- Transmission jerk?
- ECU Harness stuck HELP!!
- My LRMAF Writeup
- Weathertech floor mats
- BBK or drilled and slotted?
- Welp...it was bound to happen. blown rad :(
- Poly Mounts + Torque Link = Beneficial?
- P0430 caused by exhaust leak
- Side marker blinker and parking light bulbs
- oem or aftermarket
- Mix 'n Match Ballast/Bulb
- Water leaking into the trunk?
- Strut and wheel hub not coming together
- Help! can't change serpentine belt
- Whats it worth 5.5
- Aftermarket Seat Belts?
- New to me 02 GLE...Have a question
- Replace engine now or later?
- Need A/T solenoid packs? PLEASE READ
- Bad diff bearing..5 Speed Trans experts Please step in
- insurance question help
- 2000 vs. 2001 OEM Air-Box & Snorkel ???
- Help: Need To Remove UIM For Gasket
- Valve Body Mod
- No More 300zx Conversion Brackets????
- Thermostat for 350z fit 5.5gen Maxima?
- input shaft bearing
- Drive belts?
- p1614 code
- Car wobble
- The right Torque? + Gear oil
- Road Hazard Warranty
- Gutted Pre-cats Dyno run
- Greg(Luvlexus101) Quad Projector Retro Setup (Extremely picture heavy)
- Strange clunking sound when shifting gears
- Side Marker Directional Mod - Write Up (With Pics)
- Steering Column Lower Dust Cover
- Aftermarket Air Filters... post here!!
- TPS.?..TIMING?...
- Wiring for HVAC blower motor
- Swap in a VQ35 from an 06 Max?
- 350z clutch swap issues
- Had P0430, then it went away
- Found source of parasitic battery drain, unsure how to fix issue
- Weird Tick (video)
- max feels weak,, need that power back.. Help
- Overheating - Temperature Spike
- VQ30DEK Bad day... motors blown -_-
- Sts Mod Question
- outside mirror cover off, how?
- Farewell to the Max
- Outside Temp Gauge
- 2001 AT valve body bolt just spins
- trailer wiring diagram?
- Swapping trunk lids
- EVAP job??? expensive!
- Price with labor for replacing window motors
- Removing fluted lens
- Real quick Q? about my tails...
- water on drivers side floor? need tips
- Slight lost in power/ car sometime randomly dies
- saw this car today had to share
- 5.5 gen Tein SS owners
- Infiniti Steering Wheel into 5.5Gen
- Need new exhaust for 20th Anniversary Edition
- Sensor location at front bumper
- Belt, Pulley, Alternator issue
- grinding f*******ck me...
- ball joint, axle or something else???
- Sputtering Under Wot
- Need to find a Single Din Dask kit
- Front end protection.
- un plugged my dr.for fun.... just.to see
- weird shaking on my max....
- ABS light ON
- Pic Request of Center Dash Removed
- Rust Assist? Name that part!
- confused with lighting!!
- OEM part number question
- Spark plugs..which one do YOU guys recommend
- 2001 AE rear lip kit installation
- need help for some parts!
- Crankshaft Position Sensor Help?
- Need Advice, swap engine or sell 2000 SE
- Who has a radar detector?
- Scored Some Projector Lenses.
- Doing VC Gaskets... What else?
- Which way does my dip stick go in- is it upside down?
- .....TunerMaxima's Sell it or Keep it Thread......
- 03 maf sensor needed asap
- Just took in a 2007 G35S~Manual
- Headers noise levels
- Finally got my Racks on-Springs and lip installed!
- Cant pass emissions, help !
- NWP Engineering "Economy" Thermal Intake Spacer Kit - New material! Lower prices!
- factory aux on factory radio??
- 85w 90 gear oil
- Thinking of a 2000 / 2001
- Rust On Titanium Edition Rim :(
- MAF and O2 sensor
- muffler and resonator for custom 3" exhaust
- Call now: Cattman 00-01 Cali Spec Y-pipe and header/Y-pipe combo...Order it now!!!!
- 02-06 3.5vq thermal spacers - 3pc kit Install
- Car won't start... smoke
- Key FOB programming
- Thule rack and Fit kit help?!
- Burning smell from engine
- Sell or fix
- Front end noise when accelerating
- drop resistor mod...... yes... i know....
- Drop Resistor Problem?
- In my country MAXIMA is rare so please help me with idle problems and IACV.
- Weird Grinding/Scrubbing noise only when car is cold...
- OS Temp Read out...
- P0505>> Definitive Inspection/Diagnosis Thread
- Seach Down, Need PN for Power steering Switch for Courtesy Nissan
- e brake wont release
- Help!!!!! No Heat
- Parking Lights
- Does anyone know what this unused connector is for?
- NEED HELP, TRYING TO BUY 5.5 GEN!!!
- Difference in LSD 5th gen and 5.5
- How to rebuild K-sport coilovers
- 02-08 3.5vq thermal spacers - 3pc kit
- Nitto Zeo Gens? Need some input
- who is running hankooks
- rubbing/squeaky noise when turning
- Replacing Upper Oil Pan Gasket questions...
- Car wont start, need help on ideas
