- Aftermarket Oil Pans
- Is it time for a Trans fluid Change??
- Alternator croaked with no warning?
- Long crank (start), losing fuel pressure
- 5.0 Headlights, 5.5 Trunk Emblem, Bose Head Unit, Smoked Rear Sides etc.
- 03 engine dies after wot no cel
- A/C Fan only works on high (#4)
- Vibration. Engine mount or clutch?
- sunroof driving me nuts!
- P1167 Code
- High Beams not working in 2001 Nissan Maxima
- 2001 starting problem.. help!!!!
- 2003 i35 newly acquired - my experience
- Power steering pump seal?
- 5.5gen hotshot headers+custom cattman y pipe...
- 01 se oil light.
- Read codes without scan tool
- Found Yellow Fogs for 02-03 Maxima, they good quality
- 2001 Nissan Maxima GLE catalytic converter needs replacing should I buy this vehicle
- 2003 3.5 engine coolant temps, ALT bolt size
- do they just not exist anymore?? subframe mods
- CEL Code P0420 HELP
- transmission issue
- Seals/Gaskets
- Headlight theft still a problem on the 02-03 Maxima?
- iac messed up ecu 20th ae
- Rear Main Seal Leak
- Double Din with Nav Install Help
- Tsudo Exhaust - Opinions
- 5th Gen Wooshing Noise
- Newbie Lighting/Projector Question ...
- Steering Wheel compatibility 00/02-03
- 01 Max 5-speed
- Weapon R Air Intakes
- Knock sensor
- Hit a curb, Driver front wheel has positive camber.
- 2002 Nissan Maxima SeaFoam
- Fans Running Full Blast When Warm?
- Negative Battery Terminal Help
- 03 Maxima SE Transmission noise??
- Maxima.ORG decals and other stuff
- Electrical problem. Nothing turns on. Please help!
- Need help
- Energy suspension or OEM mounts
- changing ac controls and navigation system
- exhaust 2001 20th anniversary
- Alternator Question
- Bluetooth and Cd changer Adapters
- IVT Assembly: OEM or Aftermarket
- Fix Rattling - Upgrading Sound System
- check engine light
- Precat 5.5th gen
- Does this sound like a vacuum leak to you guys?
- Core charge
- Headlamps Question
- Looking at 2003 Maxima - power problem?
- Few problems with m 2002 Maxima SE
- Single or Double tips?
- Immobilizer Issue
- Need Help with my Instrumental Cluster Lights!
- P0300 cold start missfire clears up
- Is this a deal?
- oil pressure question
- Were does this plugs in to? Help?
- random/multiple misfire
- Fog lights
- When the Maxima was "best selling v6"
- No replacement tire thread?
- Where can I get a jack and lug nut wrench?
- What are the best Heads that will bolt up to the 2003 FWD VQ35DE in the 5.5gen MAX?
- 2003 Nissan maxima head gasket
- mustang gt 500 gets smoked
- 2010 Mustang v6 wants to race my 5.5 gen
- Should I get headers/catback on my 01 max with 155k? If so, what's the best options?
- 5th gen commercial
- Projector Retrofit
- radio buttons are loose!
- tein ss vs street advance
- murano engine compatibility
- P0430
- Cattman headers
- Just bought 2001 20th Anniversary Edition, anything to worry about?
- Headlight wiring
- metal-on-metal noise in the brakes
- Help..before i send it to the crusher
- Headlight Bumper Gap
- Slip and abs light is lit permenantly...
- please help having a lot of problems
- Exhaust is TOO LOUD!!!!!
- I need someone to tune my computer!
- Please help, coolant issues
- race prepping
- maxima went bye bye
- Fuel tank filler neck
- Bye until ~2015
- How to tell if/which coil is bad?
- Doing a P0505 ECM repair yourself? This may help!
- New owner of an 02 Nissan maxima se 6 speed
- Allignment / front end / suspension problems & Acceeration CLUNK. What is the problem
- Catback
- 2003 Maxima A/C problem
- left front power widow
- How thick is the intake vacuum hose
- Need new headlamp!!!
- Can all these codes be associated?
- Exhaust tips
- a/c problem help plz??????????
- my car keeps dying even after jump..
- Swirl Control Valve Selenoid Valve 2000 Maxima
- P0650
- Head unit/speakers
- Another Headlight Thread
- Transgo
- O2 thread chaser experience?
- Can't find my year!
- p0305?
- Wide Wheels Advice Please!!!
- Oil Consumption repair/fix
- oxygen sensor
- car pulls to the side under acceleration
- Exhaust System
- need help, no start after replacing sensors
- 03 Maxima 3.5L won't start
- 2000 fed spec o2 simulator help
- suspension help
- Need help with my head unit wiring
- Need help with demon eyes/Halos
- Gutting precats
- Sway bar advice needed in isle bushings...
- Coolant drain plugs, easy to get to?-02 max
- Vanity plate ideas
- motor mount replacement help!!!
- engine swap.
- more power?
- Maxima needs a new water pump, radiator, and cat. Estimate is $3k
- Airbag Recall
- Where can I relocate my battery negative cable ground?
- Look what I found on ebay today?
- Where is the instrument gauge fuse located?
- FEELER: Intake Mid-Pipes-Please read
- Socket holder for 01 ebay angel eyes headlight
- PS Axle removal assitance
- 245/45/18 on g35 wheels
- My poor baby
- Gutted Precat with pictures and vehicle mileage.
- Valvetrain noise
- Question for those of you who have rebuilt your auto...
- Exhaust Question
- misfires but without check engine light
- Spoiler brake light on dash!
- 2003 low/intermittent performance high milage
- Oil consumption gotten worse? -02 Max
- Wobbly idler pulley. Should I replace it? Video
- Speedo problem
- Air intake problems codes,rough idle Pls HELP
- What is this pic? Transmission Drain Plug?
- yet another high idle (2001)
- Clips for side skirts
- Air Intake
- 2nd or 3rd
- Map lights change to LEDs help
- Selling my max soon
- clutch/flywheel DIY
- stock air box midpipe question
- Power loss and bad shifting
- Crankshaft pulley
- Weatherstripping around Trunk
- Maxima WILL not start HELP
- HO2S1-B1: Best method for replacement?
- OBX 3.5 Owner Thread
- emergency brake handle in leather????
- Rust Problem
- Need Help Replacing my Bulb in my Cluster; 03 Maxima
- What is the best intake I can get for my 5.5 gen?
- 2000 max signal/hazards randomly stop working
- 2nd to 3rd gear slip (over rev)
- p0420
- motor mounts /stuck clutch
- Lug nut for G35 rims
- switching from manual A/C to auto A/C controls
- Possible A/C Pulley
- Spoiler brake lights
- O2 sensor heater resistor help
- Swapping in a 5 speed HLSD trans
- Dashboard brake light on
- engine wont rev past 2500
- new rear caliper
- 2003 auto shifter issue or something else
- Car thump
- Im A Noob When It Comes To Audiow
- ES motor mounts
- Power seat question
- Injen Air Intake
- Rotors and Brake Pads 2000 I30
- Is this sound normal?
- 2002 Maxima Randomly Dies
- Where to find OEM grill for Anniversary edition?
- What are the valid OBD Readiness Monitors?
- Car rattling
- Help sealing tail lights
- Accelerating problems
- Last minute checks
- Sunroof, Visor vanuty lights and map lights non-op
- Reason to fix that leaking Power Steering Hose
- When right time to get car Align
- Name That Part
- Transmission question?
- RIP Grey Luster Maxima
- LAST CHANCE EVER!! Saggy Spare Tire Cover Fix for your Maxima!!
- Wheel bearing Question
- Urgent: Need suspension help
- Key Not Turning Ignition
- 2000 Maxima GLE Intermittent Engine Cut Out and Restart
- Need help bringing 01 Max back to life!
- 03 Nissan Maxima GLE VQ35DE.....Please Help!
- Springs
- People with Sterling Mist Maxima, I need tips/advice
- o2 sensor simulator on 2000 maxima
- Rough ac at idle
- For those who installed baby seats in their 5th gens
- Brake pedal
- Just bought 350z clutch. Clutch options?
- Help with Acceleration Problem
- Groaning rotational noise under load, 01 Automatic
- Ride height difference
- Hello I'm new here to Nissan forums 2003 Nissan maxima windows will not work ??
- Best OBDII App and Bluetooth Scan Tool
- Why are the left headlights always worse looking than the right?
- This needed after NWP plate?
- Pending Codes P0300 and P0507
- engine swap cost opinion
- Installed catback, exhaust smells like coolant
- 2000 Maxima, AC not working
- 2000 maxama
- Transmission slipping (goes into neutral while driving)
- 46550-2y900
- Can 2000-2001 Maximas use pathfinder IACV
- 2002 Maxima rear sway bar questions
- Clutch adjustment
- 02 Camshaft Positioning Sensor
- Debris Sticking to the Front Radiator Fins
- Codes p0420 $ p0300
- TPMS/Tire Valve Alternative
- Is it bearing hub, or tie rod end ?
- HELP Alternator ????
- I need a turbocharged kit
- Transmission swap question?
- Squeaky belt? bad idler pulley?
- 2000 Maxima Headlight bulb cover
- Anzo USA tail lights legal or illegal?
