- New Shocks/Stance adjustment
- 2000 Maxima Weird Noise
- Lost 4th gear/huge puddle of gear oil
- Pulley Kit -
- OEM stereo power/volume knob fix ?
- tcs and slip light on
- VIDEO FIXED! ABS Pulsing in Reverse? Help Please!
- Swapping Steering Wheels
- thinking of tradeing in my maxi for an i35
- Help, My 02 Maxima Won't Start
- Annoying sound
- Noob with TCC OFF, SLIP...no ABS light
- 00-01 and 02-03 front doors Whats the difference?
- Stock Pipe size
- Air leak sound inside car
- Bought new control arms, what else do I need?
- Code P0021
- Please I need a straight answer
- Am I Missing Parts? (+ATF and Plug Questions)
- think i found my vibration problen... ES question as well
- 02 Front bumper
- '03 G35 Sport Sedan 17" Rims on She Max
- P340 on and off ater refill
- New to the Nissan world
- What do you think would be a good start price to sell my I30t?
- Code P0340 plus more
- LCA hits passenger side rotor on hard left turn
- brakes then TCM light
- sensor problem i need desperate help with
- Maunal LSD swap
- Overheating
- Gas Mileage
- Water in front door
- Who wants to be my friend?
- New Wheels
- 2009-2011 Nissan Murano ALternator on the 5th gen! Pics included!!!
- Squeaky noise coming from front end....5 year search is over!
- Alternator & Charging System, A Story
- A Little (detail/repair) Help From My Friends
- Would it be a good buy
- Secondary Intake throttle Plate CAUTION
- Pinging issue oil pressure related
- The worst acceleration and performance ever
- Brake light on after caliper change & bleed
- code PO720 ???
- Alternator/ Battery/ Other.. Help
- Transmission questions
- 2000 SE Dies when I press the gas/idles hard.
- Gains from Cattman Piping
- Does the coolant in the throttle body also affect the 5.5gen?
- 03 extension harness?
- Bad luck with this 02 SE...
- looking to change motor mounts.. questions
- Will NOT go in to 1st or 2nd
- Difference between 5th gen ang 5.5?
- G35 type s auto?
- buying maxima
- Yet another hard starting thread - with a twist and an unlikely solution
- VAFC2 with LRMAF/BBMAF
- Oil in Spark Plug Tubes
- Looking for 00-03 under/around 50k miles
- Fram #
- P1706 PNP Switch, ECM terminal #44 only 4.8 V
- SSIM paint or polish?
- Is it possible to need to replace MAF sensor twice?
- 1320 code after welding
- 01 Maxima hesitating under load
- spark plugs
- Full throttle hesitation?
- brake pads
- Possible transmission problem?
- Heated seats question?
- O/D button type
- How many have installed this kit? SKRE4F04B
- cracking sound when turning in cold weather
- Overdrive Problem: Yup, another tranny thread.
- Tranny Problem
- How long did your stock clutch last?
- 2000 SE Will Barely Start Up - Please Assist
- 3.5 Swap
- Maxima Won't Crank, No Start Thread
- Fuel Filter replacement ISSUE! Need some advice!
- Do safety recalls expire? - Camshaft position sensore bank 1 error P0340
- '00 Rough Idle
- Speed Sensor
- 2002 maxima auto convert to 6 speed
- My maxima is too quiet!!!!
- Engine cranks slow at startup
- Gutting ore cats o2 sim??
- VQ35DE in 01 SE
- 5th gen intake find
- RSB= rear end slop?
- If you're wondering how much a low mileage maxima goes for
- What mods does my 5.5gen have left?
- Catback Exhaust choices on a 2000 SE
- Bleeding engine mount
- 2000 Maxima SES Light
- 2002 maxima oil pressure gauge wiring installation
- Extending cable
- An easier way to insert PCV valve grommet
- Spark plug gap
- How much more is a 5.5 worth more then a 5th gen ?
- Need help with VQ35 swap
- Found a loose rubber hose?
- Paradox-Systems Illuminated Door Sills... help?
- Odd Lighting issue
- Extremely Low Voltage at idle..
- Thermostat swap today.
- No water draining from the A/C?
- Nismo Maxima!! Lets see pics!!!
- o2/Cat/MAF or coils??
- 01 MAF sensor ?
- would 6th gen springs fit on a 5.5 gen?
- Help figure out this engine noise!!!
- Replacement cd player 02-03
- high pitched noise when accelerating
- Engine compatibility help 04 into a 02 Maxima
- Modified Intake - Where to Install Air Temp Sensor?
- Grinding sound under light turning?
- 03 maxima 120,000 miles help
- Dreaded P0430 code... need help deciding what to do next
- Stalling
- Really really rough start then lots of blacksmoke
- Where the PCV located?
- Bleed Power Steering
- 00 Max issues (P0505)
- Just inherited 2001 SE 20th Aniversary Ed
- 2003 Maxima GLE/ New owner
- vibration/ shudder..engine mounts??
- 2001 nissan maxima oil leak problem
- Horrible gas mileage...squealing brakes post rotor/brake job..help !
- Starter Won't Shut Off
- car is not starting
- 2000 Maxima Doesn't try to start
- Gas line covers?
- 2001 17 inch wheel vs 2001 20th wheel
- Issue with 350z dual piston brake upgrade
- 350z fuel rail on a 2002 maxima
- 2003 maxima wanting a tail light swap
- Advise on these 18" wheels
- 2012 Maxima Rims
- Retro fit for 02-03 max
- Picture thread
- misfiring help
- Kidneys for life car show
- 400,000 miles achieved!
- Belt Squeal Question
- 2001 20th anniversary headlights
- Poor design of PCV valve & seal, now fall into crankcase, help!
- Cleared Blinker and angel eyes
- Time to play, The price is right!
- bouncing rpm needle
- 5th gen trannys
- 2003 maxima keep shutting off after 55-60mph
- Coilovers vs new struts and lowering springs
- Time for New Wheels - Good Deal?
- Greddy Evo 2 or Axle Back HKS?
- HELP 02 maxima overheating changed EVERYTHING
- Pay for a shop to get the motor put together? Or engine swap?
- Opinions...
- Engine oil dissapearing from 03 Max
- SAFII and Maf Issues
- New to Maxima Forum lookin to improve performace
- new here having trouble stating my 5th gen maxima gle
- 2002 SE Problems When Engine is Cold
- Seat Belt question?
- What is the Kirkland battery size for my car?
- Need guidance,tired of lacking power on 2k I30
- Free Copy MTS to iPhone 5,iPad 3,Kindle Fire HD,Galaxy Note 10.1 in Mac App Store
- I finally finished custom jobs
- hid help
- 20 inch rims
- how to bypass the ac compressor with a shorter belt on the 2000 maxima
- Ebay Find F430 Side mirrors
- Brake Light On
- Car never starts after rain.
- Which auto transmission in my 2000 Maxima SE looking for a shift kit
- 01 maxima headers?
- No POWER?
- 2002 mafs replacement
- Stillen front lip
- Double Din radio for a 03 Maxima
- New radio what will fit??
- cool nissan maxima mod suggestions
- how can I tell if I have a 20th anniv edition?
- Transmission decision
- VIN Decoder
- Timing Advance
- New to the 5th gen maxima.. Anything i should know?
- Replace cabin air filter & check blower motor
- Maxima Fog Lights and Door lights
- Which fuel pump?
- Nissan center cap on G35 fronts wont fit
- 5th gen rear brake calipers are garbage....
- Power Steering Fluid
- AAM Competition ECU Re-flash for 2002-2003
- Fuel Gauge reader is a problem...
- Tomei rev up cams
- Another identify this noise thread
- upgrade maf 5th gen
- WTB 6 Good working coils for 00 max
- Going to have the heads rebuilt someday in the near future
- Radio Display
- Idle air relearn mil during rev
- I am here to fix the Bose Sub problem once and for all.
- 2002 fuel filter replacement
- Is it the alternator? Flashing Brake and Battery Light
- car doesnt accelerate
- 2000SE knocking sound when hitting bumps
- Any interest in Raceland Coilovers?
- What color to paint my car?
- bad lucky
- Swap Steering Wheel
- Front End Clunking Noise: Before Buying Any Parts Read This First
- '02+ Max/I35 vs. '00 Max/I30 wiper/headlight controls
- Performance Possibilities? Looking at 00-01 3.0
- Retrofitting 2001 Steering Wheel on 2000?
- How do i remove rear winshield panel
- Second Car Ideas
- Weird Start up.
- Tinting small window in rear door
- 2002 maxima se 6 speed blown transmission
- Tranny Shot?
- Code p0420 here and then gone...
- Removing an AE Lip Kit
- front jdm spoiler
- 2002 maxima hi flow cat
- 2002 maxima apexi safc II
- P1102 code, but not sure if that's the problem need help!
- 02 max- new-ish pads on new rotors?
- Max giving me SEL P0051, any help?
- 2000SE parking brake question
- Code: P1800 with VIAS BOP installed
- Just what I need, another problem.
- help
- Help with 01 Maxima Codes 1706 and 0171, and car won't idle
- Are the 2002 and 2003 ECU's the same?
- 2002 Maxima 6speed For Sale...
- Just my luck, roof spoiler or no?
- Clutch Bleeding Procedure through mini oil pump can?
- Headlight wiring?
- I had a CAM position sensor issue fixed it, engine back in limp
- Steering Rack Differences
- Help !! HID
- VQ35DE (2002-2003) Ignition Timing Question
- 2000 SE - Transmission bit the dust. How much to rebuild?
- P0171 now p0172????
- Bose Stereo Replacement Question
- Supercharger w/ auto trans question
- 2001 i30..batter light on, brake light (no e-brake on), etc..help!!!
