- Horrible Handling!!
- Has anyone tried put a faux Wood steering wheel?
- Mechanic around Vernon,CT
- will these tires work?
- Nav CD noise
- Coolant leak near oil dipstick
- How reliable is the '02 and '03 vs. '00 and '01?
- Why are my back brakes wearing out so fast?
- Cross member motor mounts - liquid filled. Both?
- For those that have Blacked-out Grills/Headlights
- Headlights just wont come clean.
- Power Steering Pressure Sensor Contraption Leak?
- Raxles does not offer passenger side axle for my car???
- 2000 Maxima GLE burning coil packs, anyone had this issue before?
- Braking Gurus: Please step in - possible caliper problem?
- Brakes Labor costs
- rear door stuck closed
- Low voltage at idle
- damaged passenger side axle.. best option?
- What is this thing on my 5th Gen?
- C-ya guys later, it was nice
- VAFC-II Stuff
- PSA - Beware of Dorman LCAs
- Replaced ECU and Motor Mount Blew Out
- How many in. are your tires, and can you chirp them??
- Blinking SES light and lots of other problems
- Should these wheels fit???
- Where can I buy Door Hinge???
- Timing Chain
- LTB Stage II + Subframe Collars?
- Tie rod help?
- clunk when turning steering wheel.
- Knocking Noise
- New Maxima and a few questions!
- good body parts - I35 right fender needed
- Need help diagnosing hard start/rough idle after sitting few days...
- Dome Light LED - I'm thoroughly confused
- Passenger side axle
- New Problem Sounds Like MAF let me know what you guys think...
- 3.5l radiators
- installing catman CALI spec full system
- Custom Map/Dome Light - more light in cabin
- I'm searching for a link.
- Header wrap
- You guys are not going to believe this
- 2000 v6 maxima, wobble pulley???!?!?!
- FML got ran off the road
- new clutch question
- Engine Whining and Smoke
- Front Jack Point Question
- Uneven airbag gap how to fix!!
- 5.5 Bump Stops/H-techs-- To Cut or Not to Cut?
- what Struts and Springs you recommend (500$)
- How do I know if my car is lowered?
- HID problem
- horriable sound coming from rear of the car, help!
- Bubbles don't stop coming out of Radiator
- 01 OEM CD Changer Question
- Removing Side Face Vents
- 5th Gen Max -- 245/40/18's or 245/45/18's???
- strut question
- Vin location on VQ30DE-K?
- Preferred aftermarket tie rod end brand?
- Removing Paint from Rims
- 99 AC Compressor on a 5th Gen
- "00 Ignition/tumbler switch replacement questions
- HELP: New fan isn't working
- Two different Moog outer tie rod ends?
- Front and Rear Suspension Replacement
- New to the Org.
- Got bit by dreade seized rear caliper syndrome
- ABS Light on - how to diagnose which component is at fault?
- New 5.5 Fogs 4Sale on Ebay!
- trunk button on new fob doesnt work, does it have to be programmed?
- what size tire to run on a 18in rim with 2in drop
- Trans Problems Help Please 2000 AT
- bumping noise when turning left please help!!!
- cattman 3 inch catback vs. exhaust cut-out
- knock sensor ?
- Rear tires are cupping
- So, I just got a new radiator...
- lucas power steering stop leak, has anyone used it?
- post pics of KILLER 5/5.5 GENS
- abs not working
- Performance decreases after warming up
- suspension pricing
- nwp spacers+vias block-off plate=problem
- Oh joy!
- Hawk HPS Shims
- Clutch problems
- Brake Light Stays On
- Nissan, Renault and Mercedes Make Major Announcment
- Trunk Sub Floor
- Pre-cat heat shield quick fix
- HID fogs 2003 max
- Steering or suspension issue?
- Clutch Question
- photoshopped rims, whadaya think
- hid bulb turned violet
- Aero Turbine Muffler and Resonator
- wr intake
- Clutch Replacement???
- Non-LSD Vs LSD tranny
- belt squeaks loud on startup
- If you have gone through a MAF or two...come in
- Broke off engine mount bolt in tranny
- WTF - eBay engine mount bolt hole too small?
- P0335 crank position sensor problem
- HELP!!! Transmission wont shift anymore...
- fuse question
- Do I need to have a shop press in new bearings?
- Which transgo kit?
- Need Help!!! P0444
- Lightweight brake rotors?
- replaced IACV now have P0505
- Quieting down the car: center resonator or new muffler?
- HELP! can get the strut nut off
- Titanium Edition wheel color code?
- New type of Overheating problem
- stock springs and shocks for the winter
- Snag in suspension install
- Rear sensors for a great price.
- Radiator split
- No fire... NEED HELP
- Engine Mount
- Weird rear brake issue... Help!
- and this is goodbye
- how to remove map light console on 00-01 maxima
- Idle Problem When A/C On
- New Struts for my 5.5 and a random sound?
- Wobble in steering wheel
- Window motor/regulator problem?
- Car won't start
- Installing my Locking Hood Pins
- is there a way to test IACV???
- 20% Tints all around [PICS]
- 02 wont start
- DE-K Auto to 5-speed ECU swap
- what is the widest tire size on Stock 02 maxima rims?
- reverse glow gauges mod ..
- Strange Rasp at Certain RPMs
- SRS Light...
- Radiator Fan Harness question
- Pic Request: White 5.5gen w/ painted black grill
- Exhaust help
- Question to the fellow 5 speed 5th genners..
- Beck Arnley Control Arms
- GFORCE Performance chip
- Who's had a tranny rebuild?
- Video of car on dyno. Cut-out open
- VIAS Woes
- Where do you put your HID ballasts ?
- Swamped my car on Friday
- i got bored so i did this
- Little Plastic Hole Plug - What? Where?
- Ksport ProComp Front Big Brake Kit
- 5.5gen EU Installation
- Getting a misfire code for cyl#6; which cylinder is 6?
- what do you guys hate about your 5th gen?
- Hardware for Y Pipe
- Oem Front Hardware Kit $59 - Ridiculous
- Bearing Replacement project: Need parts help
- Where to get PS hose for < $0.2k?
- klunking noises are back
- Rear brake pad clip tightness
- Can't get used to this 5-speed ...
- Power Driver's Seat Keeps Getting Stuck
- Rear Caliper Bleeding Problem
- Matching ecu numbers
- Wheel Bearing Seal??
- another clutch/flywheel thread
- Tie Rod question
- Cheap eBay Fogs
- 178K miles and still runnning strong.
- Shift knob replacement
- HID help
- Need Help: Replacing CV Axle
- 2009 vq35 swap in 2003
- Cross Threaded Power Steering Pump where Pressure Hose Connects
- P0011, P0021, Smoke, and no power
- Aftermarket HID Flickering at Idle: Help Needed
- Skunk smell from right front wheel well...
- Quick question quick answer? ABS
- Fuel gauge calibration?
- looking to make the car sit even
- For those who use Amsoil EoA oil filters.
- 3 month old starter goes..rrrrrreeeeeeee!!!
- Do I need an alignment after net end-links?
- blaZt + NDSII
- Pulling Codes-No CEL-6 Ready-since headers
- Lowered - Finally!!!
- Rear driver side speaker not working??
- Wheel Balancing Questions: Need some feedback
- Evap Solenoid Tuck -- anyone done this?
- Lost ignition coil bolt. Need to know what size replacement
- Locked keys in the car....AGAIN
- 5 SPEED TO 6 SPEED HELP
- Replace Radiator/Thermo then no start!
- checking oil
- Aftermarket headlight seems to be fogging up
- Extra tab on Hawk HPS Pad???
- no power after 3500 rpm.. whats wrong?
- Back to the Orange blinker mod
- Hot start issue - start the car when engine is hot, it will stall
- Need a shift solenoid B for an 01
- Aftermarket OEM Fog Lights
- p1102
- noob
- Tranny issue?
- fight to solve the p0300 code!!
- Good Manual Transmission Fluid
- One day Special Cattman Sale - Friday the 13th in GD forum
- Clutch pedal falling to the floor - cant disengage gears! WTF?
- Paint gurus please step in
- Upper Radiator Hose Leak & Spark Plug change
- Clutch Replacment
- rough start, blinking CEL
- new motor time?
- Transmission 4th gear?
- Megan Exhaust from JM Autoracing
- Rear Brake Lockup?!?!
- Antifreeze &/or oil sprayed on my engine?
- MAF gone wrong?
- Racingline Rear Strut Tower Brace (RSTB) - Design Thread
- Replaced VIAS solenoid, '04 Valve Covers & Spark Plugs
- ABS Light on and off and low power. Hmmm
- Changing 02 sensor.. Need help
- What color to paint my wheels?
- How-To/DIY: Simple Engine Bay Radiator Fan Switch for Drag Racing
- Drill Hole In Ignition Key?
- ECM fried by IACV
- Car is over heating.
- Duplicolor Caliper Paint Kit
- 2003 maxima 6 speed shuts off while driving!!
- Air conditioner temp is only 54 degrees
- Issues? Tranny? TQ Conv? Wtf???
- brakes grinding but new!
- Thermostat problem on my 2000 Maxima?
- Ordered a radiator for manual but might have received one for auto? Still okay?
- Problems removing TB
- Radiator Fan Function Questions
- Replace rear caliper
- P0335= faster car?
- change struts = fail
- 2.5" SS Mandrel Bent B-Pipe gains? Is it worth it?
- 2002 Maxima SE 6sp 131K...help on purchasing
- replaced with a used transmission, engine idle has problem
- ABS = Ign Coil issue??? Step in please
- bulb help
- Blower motor issue?
