PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Drove through water....HELP!
  2. New Converter?
  3. What is this?
  4. Will a bad MAF cause hard starting?
  5. What do worn motor mounts look like?
  6. IS there a write up for a auto to manual conversion for a 2k max!?
  7. How long should a manual transmission last?
  8. Request Pic of Installed frt sway bar end links on car
  9. electrical parts for headlights...WHERE TO BUY??
  10. Seafoam - yay or nay
  11. Buying electriclal parts
  12. HELP car wont run!
  13. Calipers
  14. Rear windows
  15. Need the min rotor thickness for stillen drilled rotors
  16. Eyelids...to paint or not to paint
  17. Please post pics of your wheels. Looking for maybe Volk GT-C Face 1's??
  18. clicking sound at 2000 RPMs
  19. MimoUSA F1 fenders
  20. Airbag code B6
  21. 02 sensor wire
  22. On the verge of selling my max...
  23. who has vfac?
  24. Hesitation Problem
  25. replacing radiator
  26. Time for a major tune-up
  27. Getting to Bank 2 Sensor 2 (b2s2) Cali
  28. Check engine light was removed from 5.5 gen
  29. Just got a 5th gen
  30. Injen or Stillen?
  31. Whirring sound before and after turning key and off engine. VIDEO
  32. A little help plz..
  33. Cleaning 5.5 gen throttle Body - with pics
  34. license plate lights r out
  35. Really strange noise
  36. Reflash for O2 issue, whats that going to cost?
  37. Make Custom Headlights (AE)
  38. VIAS fix in progress!
  39. my second time at the track vids
  40. CV shaft nut will not stay tight
  41. no interior lights
  42. Rear Valance? Pic inside
  43. Dumped Axle back, With vids
  44. Searching for 5th gen Maxima video, Supercharged and really loud
  45. alternator problem...maybe?
  46. WTB: 01 yellow fog tint overlay
  47. shock question oem
  48. I found this lastnight
  49. Clutch Rattle
  50. car surges or hesitates while accelerating hard
  51. just venting...but HEY THERES PICS!
  52. Just installed CAI- Do I need to do idle relearn?
  53. Redlinegoods shift boots...
  54. MOOG ball joints and rod ends
  55. Magic sponges
  56. MT Gear lube?
  57. HID upgrade better than expect in stock housing
  58. Maxima boredom
  59. Rattling
  60. Used Wheel speed sensor
  61. A Maxima is a Maxima
  62. cant drive stick
  63. Roof Spoiler Pics.. Any??
  64. alternator bolt WTF
  65. please help my cruise control won't work
  66. Jdub Side skirts
  67. A/C Squeaking badly...
  68. Removal of front and rear driver's side door panels
  69. Lightweight Flywheel Noise ?????
  70. engine starts then dies
  71. Knuckle Removal
  72. Is it my brake fluid?
  73. Anyone ever seen this bumper?
  74. 2k>2k3 interior swap
  75. 2001 Max SRS Light Flashing: Code saying Passenger Seatbelt Sensor?
  76. Wiper Problems Part 2
  77. Will man motor mounts fit auto cars.
  78. Engine Cover Emblem Needed
  79. What is your Opinion? Buy this car?
  80. are body parts interchangable?
  81. clueless on piggyback
  82. Ipod configuration 2002 Maxima Se NO CD CHG BUTTON OR CHANGER
  83. Best suspension setup for our Maximas?
  84. tokico illuminas off a sc300..
  85. I need help!!! car running in limp mode
  86. I need help!!! car running in limp mode
  87. Intermittent brake light problem
  88. Seafoam is a wonderful product!
  89. 5.5 headlight mod
  90. Illuminas Installed
  91. Where does this hoes connect to?
  92. Load dependent rumble
  93. Need definitive answer on coolant type...
  94. Strange alignment issue(car pulls either way)
  95. 3M Headlight Restoration
  96. Where to buy..
  97. Rear Strut Boot
  98. Would this change my exhaust sound?
  99. Wheel bearing woes
  100. Funny Story
  101. Gutting pre-cats bad for your car ??
  102. Need help disabling factory alarm.
  103. NWP Spacers on 2000
  104. how do u wire subs into the bose system
  105. TOKICO Illumina Shocks
  106. Extremely loud cluck and rusty metal sound
  107. nwp spacer reapplication
  108. Insurance Model Description
  109. Steering wheel vibration at high speeds... several things done... what else to do?
  110. steering wheel "wobbles"
  111. Need pics asap > Evap system...
  112. paint job?
  113. RPMs dropping lower then usual..
  114. What should i look out for
  115. Dead clutch pedal
  116. (A few issues) I hate my car
  117. gas thieving rant
  118. Engine Disaster
  119. New Window Problem... 01 Maxima
  120. Gauge Cluster question
  121. Final Upgrade for the Summer?
  122. Am i upgrading or Down grading???
  123. Confused about SSIM..Spacers...block plate.
  124. Whining noise coming from engine
  125. ECU AND FOG LIGHT QUESTION
  126. 5.5 gen grey lustre
  127. Burnt Steering Wheel
  128. Wire problem
  129. Nismo Thermostat?
  130. Air bag light blinks
  131. How long is my max gonna last?
  132. Hot restart no start problem
  133. Wheel Bearings problems?
  134. engine may be shot or bad crank pulley
  135. illumina impressions after a few months
  136. Driver side Window Issue
  137. Ground Wire Diagram and/or Ground Wire Kits
  138. Intake Swap!
  139. Carbon fiber hood
  140. bad balljoints?
  141. OEM keyless remote isnt working
  142. Questions about HID Highs and Fogs
  143. EVAP codes GONE! but now two new codes :( O2 sensor(s) help/thoughts? easyto replace?
  144. Suspension Plans for 2010 – Tokico Blues, mounts, and what else?
  145. whats the difference between 4th gen max LSD tranny and 01 AE LSD
  146. Oil Cooler issues??
  147. HID conversion issues. help?
  148. Unique Transponder Key Question...
  149. struts
  150. Transmission fluid
  151. I remember when my car used to get good gas milage...
  152. New ES Control Arm Bushings installed today
  153. Ur kidding me...No write up for auto trans Replacement?
  154. Sell AT for MT? Is this worth it?
  155. The MAF and I
  156. cruise control set light blinks sometimes
  157. security light stayed on
  158. Wheel bearing help needed
  159. Please help with grinding issue!
  160. Help Needed about Bushing!!!!
  161. Black or Frost Interior
  162. How to replace wiper switch
  163. Power steering suprise
  164. My Auto Tranny is Rediculous!!
  165. The Auto Trunk Lock Kaput
  166. P1130 CEL Code
  167. i need help please
  168. Advice on some 5.5gen headlight work
  169. bad alternator belt
  170. ABS Light and 350z rims?
  171. underbody molding
  172. Clearance/Marker Lamp Keeps Blowing!?
  173. Will a 6th gen axle work on my 5.5 gen?
  174. CATBACK help
  175. Aftermarket clutch/fidanza combo chatter
  176. Car still pulls to the left and worse under hard acceleration.
  177. who has halo's
  178. ebay replacement D2R xenon bulbs
  179. VQ35DE problems
  180. Quick question about buying o2 sensor
  181. Passenger side axle question
  182. WHAT MADE YOU BECOME A MAXIMA FANATIC???
  183. heavy vibration under accleration, please help!
  184. I have weird headlights.
  185. Timing chain replacement
  186. Just a question out of curiousity...
  187. Tail Light/Stop Light Wiring
  188. STS MOD! JUST FINISHED. WOWWWW
  189. power door locks, rear defrost, dome light don't work
  190. Which H3 fog bulbs are you using today?
  191. Punctured tie rod end
  192. Well got a SES......when it rains it pours!
  193. Not a big fan of body kits, but...
  194. ABS light
  195. Smoke Problem...anyone???
  196. Idle Air Relearn..same on all 5/5.5 gens?
  197. WTB Maxima, pillar speaker, drivers seat, front grille emblem
  198. a\c issue
  199. EYE LIDS OR NO EYE LIDS THATS THE QUESTION
  200. funny wheel problem while driving
  201. Berk Intakes
  202. p1572 and metal sound mean seized caliper?
  203. $150 to put on brake pads????
  204. KYB GR-2's and H&R springs installed
  205. Noticed some clicking
  206. Any of you guys try the Rain-X Latitude or Bosch Icon windshield wiper blades?
  207. what would u pay?
  208. How to beat the CEL fiasco in 5th gens for car inspections
  209. Driver's door locked, latch rusted. How to open?
  210. VQ Removal Procedure
  211. 5th gen drl module
  212. Got a Problem
  213. Fog light Rewire Problem?
  214. WTB exhaust w/connecting pipe and .....
  215. 1/4 rust repair
  216. Stalling and bucking issues
  217. Changing Front passenger Driveshaft
  218. anyone know how to eliminate knock sensor?
  219. Ride Height Adjustment Options...Coilover or Shock
  220. 2003 SE Maxima auto tranny slip questions
  221. Clicking/ Scraping Noise When Turning Right
  222. Overheating Part 2
  223. rotten midpipe
  224. Prep for paint help
  225. Stock 5.5 Grille Paint Code?
  226. Megan Racing OE-S... Anyone else waiting???
  227. Driver's 1 touch - doesn't
  228. Quick, dumb PCV valve question
  229. 5th Gen Exhaust Opinions
  230. My parking lights have a mind of their own!!
  231. A question to anyone here using Cryo rotors.
  232. 3.5 liter engine
  233. SPRINGS.....wut u think
  234. Cabin air filter
  235. Changed axles now struts?
  236. Best Strut mounts?
  237. Transmission/clutch issue? 6spd
  238. Can this be done?
  239. Swirl Control system
  240. Overheating, but before I buy a new radiator...
  241. 5th gen tire question
  242. Quick Tailight situation
  243. Has anyone tried these LED Tails?
  244. exhaust rattle...not a ypipe rattle
  245. TANNY PROBLEM!!!
  246. GoldLine Springs
  247. The origin of most CEL, O2 sensor, CAT problems is coolant leak?
  248. Brake Job Turned Nightmare!!!
  249. maintenance schedule for maxima
  250. Sunroof stuck open
