PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Need to replace struts ... Need Help
  2. 5th generation idle issue
  3. 2002 Maxima SE 6 Speed Issues
  4. Question about ECM Programming
  5. New Member - 5th gen 2000 Maxima SE
  6. Dealer says might need new computer
  7. airbag light code
  8. OBD II Monitors Not Ready
  9. Bosal pre-cat and need for gasket?
  10. Engine problems 2002 3.5 Maxima
  11. obviously I'm too damn stupid to figure it out myself
  12. Help on steering noise
  13. Looking 4 Headlight Mod Specialist/person..
  14. When will I learn...
  15. Weird electical issue. Horn honks when connected to Data Link
  16. Is it a new clutch i need?
  17. 32 days later and no rebuilt coilover strut from Tein yet
  18. 01 Overheating. both hoses Hot n Hard
  19. 2002 Headlight question
  20. Help! Replaced ECM&IACV Now..
  21. Please i need help with these codes P1130 and P0105
  22. SRS single out exhaust piping size question.
  23. Whats the best way to change the plug in cylider #3 on the VQ35
  24. Do you think a door will fit inside?
  25. Test Pipe Smell That Bad?
  26. Needing some advice on problem with clutch/transmission.
  27. Megan catback bad rattle
  28. egr tube question
  29. accident help how much?
  30. RPM Gauge not working after engine install
  31. Replace Middle Air vent question
  32. Totaled or not? Pics
  33. Searched and still confused
  34. 2001 AE getting 12-16 mpg
  35. 2003 Maxima
  36. Test pipe
  37. Starting issue
  38. A real Tune-Up!
  39. Looking for your opinions.
  40. Need picture of 2000 maxima ECU traces
  41. Should I buy these struts/shocks?
  42. Coolant leak (unusual place/unusual car)
  43. A look inside at the 20AE muffler internals
  44. Rough Idle when Cold - not all the time
  45. High beam mysteriously not working
  46. need help i dont know what i can be???
  47. Tint window question
  48. wilwood calipers noisy, I wanna jump off a bridge
  49. Master Window Switch LED Problem?
  50. maxima died on highway need help
  51. Last few hours to jump on this stuff.
  52. Replacing transmission bearings
  53. Last few hours to jump on this stuff.
  54. 2002 Maxima GLE // Sway bar link and bushing replacement
  55. conflicted
  56. looking at 2002 Maxima
  57. Loose E-brake
  58. 200 Maxima Radiator replacement
  59. seats and heated steering wheel
  60. Power Steering Cooler
  61. will 20th anniversay headlights work in a gle maxima
  62. accident total or not
  63. VSS Wire 03 maxima Pioneer's AVIC-X940B
  64. A (probably) new muffler/resonator question!
  65. No power
  66. 00-01 Fog light Lexus Capsule retrofit
  67. Stalls after startup
  68. OBX Header Collector Hits Rear Motor Mount
  69. 2000 Maxima CV Joints
  70. Radiator Rest Rust
  71. LED Interior lights yes it is blue..
  72. Trying to piece together mods.
  73. How difficult will these be to install?
  74. Goodbye old friend
  75. Car vibrating when braking - rotors
  76. Cam Position Sensor?
  77. cattman version 2 headers
  78. 01 i30 brake grinding, high idle
  79. Creaking sound from suspension/shaking
  80. AC Clutch noise
  81. What should I buy next?
  82. Help I wanted to change my belts
  83. P0051 Heated Oxygen Sensor Heater (Bank 2 - Sensor 1) Upstream
  84. HIDs ruined headlight seal HELP!
  85. Clunking vibration from the drive shaft?
  86. Can a 2003 5 speed auto tranny be put in a 2000 with a 3.0?
  87. Maxima wierd transmission problem!!!
  88. Engine Rumble 02 maxima
  89. New member: 2003 Maxima SE
  90. ses light comes and go's, comes and go's
  91. 02 Maxima Valvle Cover, Clutch - Fly wheel, Timing Chain, Rotors replacment
  92. clutch slave or hose?
  93. [weird] was on but now its off service engine light
  94. Opinions please?
  95. question about 5.5 motor mount
  96. Part compatibility between 5th and 5.5 gens
  97. 5.5 gen coils on 5 gen?
  98. "Money shifted" my max, what to check for?
  99. New struts, Trailing arm bushings and brake pads
  100. 01 Maxima Timing Control
  101. loosing Brake Fluid no visable leaks
  102. 2000 Infiniti I30 tranny issues?
  103. My 2000 Maxima needs WORK!
  104. weekend work
  105. FYI & someone please explain this to me...
  106. Strange occurance-long...
  107. New guy
  108. Valve cover gasket issue
  109. stupid mistake
  110. P0430 and knock
  111. Whistling WOT 6spd... Gear whine?
  112. Squeaky problem
  113. LMGT4 Rim Offset
  114. Limit performance while retaining good milage
  115. Lower control ball joint problem
  116. Just installed nice decal Windshield sticker
  117. 5th Gen: What did you do to your 5th Gen today?
  118. new brakes installed. brakes still suck wtf?
  119. caliper relocation bracket for 5th gen Maxima
  120. 5th Gen Lost Archives (eye candy)
  121. Wobble when on the brakes
  122. Burning oil
  123. oil pan o rings
  124. starter question
  125. 2000 maxima part out
  126. New Clutch Hydraulics
  127. front end rattle/clunks
  128. What Is The Safest Method To Drill Out Screws For Stereo Bracket?
  129. Cat delete question
  130. Manual Tranny Purring
  131. What's it worth?
  132. Sunroof can not close completely
  133. can't pass inspection
  134. Strut/lowering springs ?
  135. d2 coilover height question
  136. Walker Catalytic Converter for 5th Gen (Bank 1)
  137. Possible Axle replacement?
  138. WTB front Engine mount MT 95-03
  139. Junkyard 02 Headlight Projector
  140. Leaky AC Evaporator Maybe?- Any How-to or advice?
  141. Had rough idle so replaced my plugs, only have the rough idle return :(
  142. knock sensor (p0325)
  143. WTF Sturt bar not compatible with lsd??
  144. NISMO Grille on 2001 SE?
  145. Hid questions
  146. In Fail safe mode and will not come out
  147. How do I remove rear rotor?
  148. I'm smelling oil comin out my heater vents
  149. Driver Clearance Lamp Not Working, Pass Light Works
  150. Long time to shift
  151. new HID Ballas changed color...
  152. Latest Maxima G Tech Dyno Pull
  153. 2000 Max voltage issue
  154. Dragging out of first gear.
  155. Megan EZ Street Coilovers?
  156. Flex Pipe Replacement
  157. What To Do To My Stock 01 Maxima SE?
  158. What axle to buy
  159. Maxima 2002 AC not cold
  160. Engine issue?
  161. motor making noise from the bottom
  162. Low rough idle and stalling. P0505 IACV
  163. steering wheel wobble at higher speeds
  164. FEL-PRO rear main same as NISSAN
  165. Intake Manifold removal questions...
  166. P0430
  167. knock sensor (p0325)
  168. Name of this part?
  169. nissan maxima (cefiro) 2001 A33 GV torque
  170. Rack & Pinion Replacement Cost (5.5 Gen)
  171. My new little 1/2 tag.
  172. HID bulb 8000k 9003/Hi/Low beam
  173. Door hinge adjustment
  174. P0037 Diagnosis
  175. knocking noise at idle inside cabin only.
  176. Hard time starting
  177. Lubricating TOB through the tranny opening.
  178. Which Vaccum Lines are needed in Intake Midpipe?
  179. Brake Question
  180. Megan Coilovers
  181. Bose speakers install on non bose car
  182. Codes, Lights, and a diagnostic: Someone please check my work!
  183. Installing LED strip lights
  184. If you are thinking of JIC Coilovers I got something to show you...
  185. Shifter Bushings :)
  186. castrol offshore Antifreaze in Max?
  187. Also a Nightmare For Maximas Pt.2
  188. Horrible oil consumption
  189. Swapping Engine, Which nissans have same engine?
  190. New starter making metal noise sound
  191. 2nd-3rd shift
  192. electrical...
  193. modify rear main seal retainer
  194. replacement engine question
  195. Major Tune Up - 2002 SE - What to do first?
  196. How do you guys deal with this all the time?
  197. Help: Drivers side window switch
  198. hard down shifting coming to a stop
  199. Whirring noise that is speed dependent but not bearings or tires
  200. SES light on for over a year..randomly disappears?
  201. leak in 5 M/T 2000
  202. Ground control coilovers?
  203. Need QUICK help
  204. 5th gen roof wing
  205. 02-03 rear calipers stuck
  206. newb performance mods
  207. Worth doing these re-learns?
  208. HAH TEIN REBUILD $250 bucks and 1-2 month wait
  209. ABS Wheel Speed Sensor
  210. front engine mount replacement
  211. tech question about valve timing control
  212. any 5.5 gen clear lens fog lights out there?
  213. OEM Bose worth anything?
  214. Oil cooler still leaks after o-ring replacement
  215. Compressor engaging but blowing hot air
  216. 02 Max, EGR Valve senor.... or not??
  217. Rebuilt or used Manual Trans?
  218. Tein Coilovers DONT suck (Review)
  219. bad luck with rear main seal
  220. How do you remove side fender?
  221. manual tranny replacement suggestions
  222. New Starter = Car Won't Start
  223. Maintenance @ 250,000 miles
  224. Eternal Battery Light?
  225. Any free mods?
  226. Check out this patch someone did on my oil pan. It's so fun finding things like this.
  227. brakes pulsate
  228. What cold / SRI are still left for the maxima?
  229. All Exhaust Rattle Clunk Fix
  230. 2001 Maxima AE Mirror, Painted Piece
  231. FCP Suspension Parts
  232. Went through another Axle again.....
  233. 2000 I-30 with "Service Engine Soon" light on
  234. ECM Replacement
  235. Is this Maxima worth the hassle?
  236. free short throw mod fail..
  237. Did you lower for looks or performance?
  238. vq35de block question
  239. 01 Maxima Major Positive camber.
  240. Maverick4189's 4AT to 6MTw/HLSD Swap Thread
  241. 2001 nissan maxima gle
  242. RPM's shoot up and drop down while driving
  243. 5.5 Gen fuel pressure regulator
  244. wont rev past 2k rpm
  245. First time Nissan Maxima SE owner!
  246. 2002 Nissan Maxima Fuel Level problem
  247. Wheel spindle?
  248. SES LIGHT ON P0430 code
  249. Bent flex plate? (Video)
  250. a question for you smarty pants, but doesnt relate to nissan
