- cold start screech 5th gen
- Clutch job on a 5.5 gen ... Parts list required please.
- OEM vs Aftermarket Springs
- A final word please , Stainless steel clutch line or keep factory line design ?
- climate control backlights - just died
- Not much luck so far
- IACV + ECU Question
- my Vq30dek hates hot weather help please!
- Adjusting Clutch pedal
- 2k maxima weapon-r install issues
- crossmember delete?
- Code 1464?
- 5 or 6 speed Shift knobs
- question about our lowered cars - all the opinions appreciated
- manually pulling CEL on an 01 and what the code means ?
- This dealer sucks at selling a 5.5 gen
- Transmission?
- Leaking fluid
- 3.0 in a 5.5?
- RTV silicone for lower oil pan
- Maxima Madness
- Need Recommendations
- Clutch installed ! Here's my story.
- TSB MAF replacement question
- gear switching being rough at times
- Fighting Vibration
- How To Tap Into Fuel Pump..?
- Swapping airbox; will it fit?
- pics of iconic ae rear lip with stillen side skirtss
- noise coming before and after new tires
- LED blinker problems with anybody?
- power leather seats help
- Coolant leak - Can not find the actual leak !
- 5.5 STANCE FEATURED ON A SITE/// NICE
- Catalytic converter temperature
- '06 engine into my '02
- BOP installation. What do i do with the hoses?
- Hydrolics or clutch to blame ?
- CAM sensor shot after 5 months ?!?!
- Ebay find of the day.
- 55 vs 35 Watt HID's
- Form? or Function?
- bailing out for a soft landing
- Spare Keys at Home Depot
- Heads and the VIAS Gasket name?
- How long does a starter last?
- Stripped aluminum bolt holes, upper air intake
- Accessing the inner quarter panel
- Replacing clutch soon ... Please I need your advice
- IDLING/RADIATOR STEAM ISSUE
- What does ATF smell like?
- 2002-2003 Maxxtuning replica lip feeler thread
- LED changeout. Opinions/reviews?
- whats the belt size
- looking for EGR DIY or anyone with insight.
- Unnerving mystery vibration noise - Details and sound file inside
- I need a MAF adapter for filter. Because the plastic one i had broke
- Can a bad clutch affect acceleration ? (no slippage by the way)
- Does anyone have a link or write up on CLUTCH DIY?
- Another coolant leak!
- 5th-gen Ebay halo projectors - halos died... both of them.... what to do?
- PS Jerky when cold
- Clutch install almost done!
- Need help. Bad idle. Any ideas?
- P1320 Ignition Signal
- good websites to buy parts for the maxima online?
- She only CLICKs once!
- Turbo Timer vs Oil Cooler
- Exhaust leak firewall bank.
- Bent reat axles beam. :-(
- Who has cleaned the NWP spacers?
- Ionic Dynamics needs installed pics of: Roof spoilers, trunks & AE valance.
- difference in struts?
- Could It Have Got Much Worse ?
- Megan Racing Performance
- Nasty Sulfur Smell!!!!
- Tuning questions
- Replacing Pre-cat(P0430) Need To know exactly what to get.
- Factory nav....to factory bose 6 disc??
- $3.5k in mostly front-end work, unexplained vibration. Help!
- 5th Generation Rust Belt Blues...
- SE Gauge ?
- JWT... Extended revs?? why not
- MAF: DaveB, Dealer or EBay?
- Engine Rattle
- Will an ECU from a 5th gen max work in a 2001 infiniti i30?
- Is the NWP intake manifold Kit worth Buying?
- O2 sensors
- not another vias thread!
- ECU running options
- noise coming from rear?
- Timing tensioner
- What is the exact name of A/T in Maxima 2001?
- air bag light issue
- Two questions about paint..
- $4 Wheelhop Washer Mod
- Quick Q ~ What colour/Terminal is the Trigger for the BOSE UNIT?
- The DIY subframe collar thread
- 1320 error, with odd issue (and yes Ive searched)
- Lower front radiator support replacement?
- Are the instrument cluster bulbs "paired"?
- This is what came out of my radiator.
- Alignment problem?
- radiator cooling fan motor disected - 8 pics
- car boggs on launch
- 2" engine and trans lift and axle balance.
- Straightening Rear Beam/Axle?
- wont rev past 2500 rpms
- Reccomended Spark Plugs 2k GLE
- How is this for a cooling fan idea?
- P2128; P2138... anyone else?
- Fuel door cover
- Moving to California, What do I need?
- Wheel question
- ebay find :facepalm:
- Gremlins in my headrest?
- very low timing?
- Intake noise when cold - Thoughts?
- car audio help/questions
- Struts!
- Cam Position is Off
- Light rattle from engine compartment on decel
- Exhaust Rattle 2002 Maxima
- Engine Hesitation: videos included: Experts pls step in
- Flip Key
- 5.5 gen Subframe Collars Review
- Need softer ride for me 2003 Maxima SLE.Alternatives to OEM GXE/GLE struts & springs?
- Pulling the intake manifold isn't *that* hard
- Stock clutch mileage
- Driver's side wiper arm
- hood wont open
- Changing Inner tie rod
- P0335 crankshaft position sensor "A" circuit
- key stuck in ignition
- Maxima Rear Badge Font
- Thermostat removal?
- Need new pads and rotors...suggestions?
- If you're Max is paid off and doesn't have full coverage insurance... alarm?
- Bolted a bunch of stuff on..with pics!
- 2000/2001 Catalytic differences???
- p0021 any ideas?
- 136k Mechanical Revival
- Vaccum line?
- Alternator Dying....
- I want some maxima owners opinions on this.......
- OVERHEATING!!! AHHH
- Stock Intakes 4th, 5th and 5.5 gen
- 5.5 gen electronic climate control swap
- Couple new AE pics. Drool now or later.
- Are the Rubber boots on Front Shocks Needed?
- Cylinder 1 misfire p0301
- cam chain question
- VIAS
- Need Help Guys!
- Idle problem when engine is warm
- QUESTION ON BBK
- P0300 Code, New Coils?
- 2K GLE Hood Lift supports from StrongArm
- Replacement headlight and foglight lens?
- Fixing power loss/coping with terrible drag times
- 6 speed wont crank!!!please i need you guys
- CAI question
- Dash & AC Control LED'S Installed.
- DE-K
- BRAKE RECOMMENDATIONS???
- 02 maxima 6MT HLSD vs. 05 Altima SER autotragic
- Anyone know/have a metal aftermarket stereo kit?
- rattle and clunk
- performance
- Arrggg!! Replaced engine, still have issues!
- Yup, it was the rings on the front bank.
- Max burning oil?? 2003
- Craigslist find of the day-a good one!
- LED Gauges ~ Hi Res Photos and Vid
- Time for a new engine
- 6speed axles vs automatic axles
- Chattering noise after flywheel and clutch install
- Rear rotor/pads suggestions
- Looking for a quiet Exhaust....??
- rip my maxima
- 95-99 vs 01 compressor
- Apexi wiring questions...
- TRANNY OUT AGAIN.... SMH.. STEP IN
- Adding heated mirrors to 02. Relay?
- moog lca bushing?
- Anyone running 17 x 8 with 25 offset?
- timing advance question
- helpppp ac not working
- Would someone clarify to my about ECU update ?
- leak
- Pulled out my ECU and found this...
- OBX headers installed, RPM needle bouncing around...?
- Hard Power Steering
- craiglist find of the day lol
- Rear-ended, then chased the b*stard. What should I do about damage?
- Transmission grinding noise
- See what GAB Mod does to your Smog. gotta see this
- Please help with localizing A/T Error - solenoid valves?
- Wider rear tire size on 18" 350z rim
- Lowered 6spd, reverse noise???
- Interior pieces for sale (light grey)
- Y-Pipe/Header Information 2000-2003
- Pulled 5 codes w/o check engine light
- Rebuild the engine?
- Valve Body
- p1448 Evap Vent won't go away
- Rear of maximas always lower than the front?
- How to remove the side line on a maxima 2002 ?
- Rear shock mount clarification
- Exhaust too LOUD!!!
- Code P0505 (IACV issue?)
- Flatspot after ypipe: need help
- So you want to raise the rev limiter on your non SSIM 3.5
- has anyone ever thought about V8.
- Thanks to NmexMax for the Sticky work!
- Bad miss in infiniti i30
- Brake Fluid Reservoir Screen
- Oil In Ignition Coil?
- Sincity Max: The Birth and Death of a Legend
- Maxima Destroyed
- Right headlamp not working
- Anyone tried the switchblade w/ transponder key on ebay?
- Group Buy for Cattman Y-Pipe?
- Quick question
- NWP VIAS Plate and Oil Discovery
- Where to get OEM black splash guards for maxima 2002 ?
- Opinion on Borla muffler?
- SES + TC OFF + SLIP(+ check AT flashes on start)
- Bogging acceleration
- Vibrating gas pedal over un-even pavement on highway?
- starting up
- Power steering high pressure hose, flange nut
- Gforce lip
- Rust spots...
- Dead Battery (5 moths old) Good Alt?
- Motor Mount
- Custom Turn Signal mirrors. Ideas Please.
- Roof Spoiler pics **POST UP**
- Need you guys help.
- Looking for pics of battery tray and fuse block
- 02 Maxima Salvage?
- Is it possible to fit 02-03 headlights on a 01?
- Carpet I need CARPET
- progress rear sway bar?
- Difference between European and American Maxima
- question is this normal
- A/C Clutch interchangeability?
- megan racing coilover review
- STRANGE NOISE WHEN BACKING UP
- Cutting out when driving??
