- anyone use autolumination?
- Weight Reduction - What to remove?
- looking for that old thread concerning the rear axle
- Window motors or regulators? Or..
- weird accelerator surging problem?
- manual swap question
- i know this is dumb but i need help
- Vias problem was causing ANNOYING WHINE?!!
- Strut mount advice.. KYB or OEM
- KYB or OEM Strut Mounts
- pulley fitment question...
- How to definitively tell if your 6 spd has HLSD or not
- WOOD GRAIN INTERIOR
- Where to get Grill emblem?
- Lenses for our fogs
- Hesitation After Warming up
- cleaned up my Max (pics)
- 5.5 Gen Headlight Removal w/ Data Dots...'lil help, please...
- Lifter tap/misfire + safety mode active + SES light on
- what can it be ?
- 6mt problem
- Audio has suddenly upped the suck factor
- Anyone did this thing before?
- Folding Mirror Pinout (The answer you've been looking for)
- IACV crapshoot - to swap or not to swap, that is the question
- Annoying whine (video included)
- look what i bought today
- Car runs but dies when you press throtle
- octane rating higher than 91 bad too?
- Strut questions (not modifications...buying)
- What is the bulb number for the amber/clear corner on 5.5gen headlight?
- After replacing axle, car vibrates
- Cruise INOP, reverse lights on, speedo off
- 2.5" or 3" Electric Cutout?
- Does the GAB decrease power in hot weather?
- Strut mount comfort?/ Replacment
- Is there a lifespan...
- Has anyone put I35 seats in rear of 02-03 Max?
- Accident today :(
- interesting find while adjusting headlight aim
- 2 tranny's in 2 weeks WTF
- Replacing 2001 VQ30DE A/T Radiator
- Struts Shocks springs Installation Price?
- NO HEAT
- HID options poll
- Question
- P1800 code and NWP VIAS Plate
- Cali-Fed adapter question
- MAF sensor Replacement
- quick test pipe questionn
- The connection for the ECU
- 235/55R17's
- P0300 what are the different fixes
- vias repair question
- This has me a tad worried - P0021+smoke
- Front Brake Issues
- Who has a NWP VIAS block plate on their 5.5 gen?
- best prices for tein s tech??
- Time for some new spark plugs. Suggestions?
- AT S4.1 & S5 Style Grille for Us?
- Real wire mesh grille
- Turnin wheel causes rpm to raise?!?!?!
- Is this sticking out too much?
- Does the 5th gen SE muffler, oval tip, slip off or is it welded in place?
- Wheel gurus please advise!!
- Searching for y-pipe. Which do you recommend?
- Just bought my Tein S-techs
- Y-Pipe Problem
- P1126 code on a 2001 Maxima
- Umnitza Predator Orion V2 = SUCKS.
- NEED: HEADERS/ Y-PIPE INSTALL INSTRUCTION WITH PICS
- 3.5 intake manifold toque & pattern?
- 2003 HID lamp housing dust cover
- Noise under hood while turning?
- Tranny slipping. Need some help please/advice!!
- another ebay thread?
- what order would you fix this...
- Going to replace shocks..do the front or rear first?
- Plug n Play HID Issue
- Anyone on monroe sensatrac
- Bye Bye Maxima and great forum!!!
- Help Diagnosing whining 5 speed tranny
- Steering rack install...without y-pipe or crossmember removal
- Struts bad? brakes bad? HELP
- dome light picture request
- good quiet muffler combine with budget y-pipe and megan racing b-pipe...
- Clarion or Pioneer
- Advice W/ change or suspension Parts
- 00 window ? and key flob
- Has anyone tryed this?
- Front windshield fogging - any ideas?
- Emergency Brake
- Rocker Cover Tightening
- hesitation
- What is recommended? AFC Neo, VAFC2 or what?
- 25mm wheel spacers?
- 02 Maxima I think I found the oil leak!
- weird idle problem?
- Checking and Replacing motors mounts
- Good God, it Works!!!!
- Is it worth to fix it??
- Stock Alarm & Security Issue
- s14 240sx or 02 maxima
- 17x8 +4 17x9 +14 5x114 would fit 5.5 gen?
- Window motor removal pictures
- Check out these wheels!!
- OEM Muffler Replacement Q's
- ABS Speed Sensor replacement cost...(grab a brown bag for vomit)
- max owners with staggered wheels
- ebay radiator?
- Fog light problem
- Stumped!!!! NO horn No Steering wheel controls SRS light
- Bad Cat?
- Lots of road noise
- ebay grille
- Not another spring thread...
- will need a 02 sensor???
- Are these rotors repairable?
- Auto Headlights.
- How to get rid of Warspeed y rattle ?
- Blacking Out Headlights Today!
- Shes goin into the Stealership... i need some advice..
- Y-Pipe or 3" cat-back?
- Coolant empty, but no coolant in the oil
- Fitment Question
- Do these fans ever shut off?
- Looking for some parts..best website
- Trac light, Check Engine, Slip light on but, NO CODES?
- Rotating noise from front passenger wheel
- 235/55/17 on stock GLE rims?
- Clutch Noise? Please help
- Did i f#$% up my alternator
- Squealing noise. What is it???
- Removing dust shields?
- MAF question
- How do you get G35 sound on 5.5 max?
- Slow front windows!
- 6-spd clutch binds when hot
- OEM HID Bulbs? the difference in oem colors... VS age of bulb w/ PICS
- Engine ticking
- Belt issues
- 00vi n00b
- 02 Maxima SE items on E-bay.
- Anyone painted their own Stillen Lip (polyurethane)
- 20's on my maxima, will i run into any problemm???
- Mustang rims on a Maxima
- Steering Rack differences in 5th gen Maxes/I30s/I35s
- In-dash 6-CD changer issue
- Break fluid leak
- 245/50/18 on a 5.5 Gen Maxima
- P0172, P0175 Codes. Car modded and I know it runs rich after 3200rpm
- Rear Hubs
- e-manage blue can't rev pass 2200
- FINALLY DID IT!!! BLACKED OUT
- Ebay Exhaust
- P1065 ECM Power Supply Circuit
- Timing advance in MA
- PCV valve Replacement Gone Bad
- Bose head unit cuts out
- Borla muffler
- 03 Valve Problem
- f/s set of rotors
- Car died today... for the first time with 180k miles
- How to make your own intake on 5th gen
- VQ30DE-K VIAS
- RE: Camber Plates
- Interior LED bulb ?
- Removing offset from rims..
- fuel pump relay location
- Head gasket replace = $2000?
- Home made intake
- How to install rear Stillen lip
- Tensioner
- grill for my 03
- Is getting a extended warranty worth it?
- AT to 6MT swap?
- It's time for this episode of..."What's busted?"
- Alternator install
- The Definite LED Lighting Reliability Thread
- stillen front grill
- 350z clutch questions. Possible to use the 370z clutch??
- Did STS Mod. Now hard to get into reverse
- Tein SS Coilovers
- SSV4 Suprastick 5.5 gen worst mod
- help<<issue with my maxx newb<
- Fitment question
- Painting side skirts
- Clutch on the way out?
- Headers / test pip / catback??
- 2002 Se Suspension Suggestions
- Who uses O2 sim on an '03? Problems?
- Brightened My Gauges
- Inhibitor Relay = Starter Relay?
- volume adjusts on its own
- new exhaust today..bolt size?
- Question about Fuel Pump
- Ebay HID kit....whats good?
- A/C Bypass Accessory Belt Part Number? (size)
- Maxima crash test video
- Struts
- oil in vias area (intake manifold)
- 2k1 Motor mount option...
- Check out all my LED mods!
- issues with starter
- airbag light flashing
- HELP!!!
- Need HELP Please!
- good ebay found!
- Ideas for speaker install
- I'm back after 5 years!!! From 1997 SE to 2003 SE
- question about a Y PIPE
- Black interior pictures
- custom intake
- ABS LIGHT ON?
- I want an I35
- So my car stalled at the drive thru today
- Installed NWP block plate.... DAMN that IM is dirty
- Fixed Bose left side cutout!
- Banging noise from under the car around trans area
- Couple questions...
- 55w HID Harness
- anyone had this problem?
- Hit dip during turn now noise over rough road?
- Videos of my flooring it in my brothers max (Problem)
- new alternator bad?
- Gear whine?
- Turn signal and hazards no longer work
- TRANNY PROBLEMS please help
- Fog Lights: OEM vs after-market ???
- help with emanage blue
- Mobil1 Synthetic ATF
- Snapped ABS wheel speed sensor bolt, looking for opinions
- Great!! Not another oil catch can thread!!
- Good deal
- Sunroof Problem
- Interchange seats?
- Weird BOSE Radio Problem
- ? about es motor mounts
- Today's adventure...motor mounts(pics)
- Beep to lock/unlock - Installed with pics and video
- Turbo Automatic...Won't move in reverse
- Maxspeed springs w/ stock struts v. Tein SS coilovers - My impressions
- Sidemarker rewire to blink with signal....
- Is bedding modern brake pads still needed?
- maxima=pathfinder?
- 5.5gen Pulley Install - Annoying Problem!!
- Transmission Flush
- Is this a dead battery or something else?
- 5 to 5.5 gen fogs
- off/on front vibration
