- 2002 exhaust on a 2000?
- Hard Steering
- LED Lights
- Any body modded rear windows??
- ES Rear Trailing arm Bushings = PITA!!
- Question about "Banks"
- Cat Converter ?
- Trunk Wont Close-Help Please
- Delayed Throttle Response
- anyone have any knowledge of these?
- Life Expectancy for Stock Muffler
- 2000 Maxima SE and broken wheel studs
- Shifter Question
- 235/55 17" on an 03 Max any sqeals?
- Nissan Maxima Remix!
- Car will not start....help needed!
- Is an A/F controller absolutely necessary with headers?
- Adding OEM navigation
- Gauge Pod Question
- CD player is oddly messing up, can anyone help?
- heated steering wheel interchange from a non heated wheel
- where can i get triple gauge pod???
- Good oil supply solution?
- 02 max died a fiery death
- Missed shift..Went from 2nd to 1st....
- Ebay projectors turned yellow (pics inside)
- Programing Keyfob
- Door Molding
- Compass says C?
- 02 factory NAV system ?s
- Power Steering Leak - how to repair?
- 2003 Clear Side Marker Install Question
- what wire to tap into?
- VAFCII, where to mount?????
- need help badly
- tire size help
- ABS light is on Please Help
- 2000 I30 Hesitation/Loss of Power
- Engine/front-end noises...
- Engine Control Relay is buzzing, battery is dead... please help!
- How much for a oil pan replacement?
- Trick of removing the Center Armrest Console?
- Tail Light Question
- Accelerator Pedal Position Sensor Bad?
- help with my vafc2
- is it worth it?
- Installed some hid but having trouble help please!!
- 5.5 Gen 6spd Clutch/Flywheel Trouble
- Gas Smell?????????
- Non JB-Weld VIAS fix
- Question Regarding Fidanza flywheel for 2000 & 2001 maxima
- What is the deal?!?
- Bolts for the MAF Sensor
- Officially Joined the H&R/Illumina Club
- Popping out of 1st
- Check out Da New Wheels!
- Will 6th Gen. seats fit in 5.5 gen?
- Another "reprogram ECU for new MAF" question
- Removed my IM butterfly valve
- for people installing 02-03 tails in a 00-01 max
- Timing advance...who has it?
- Dealer charging me 720 bucks to replace Power Steering Pump
- HLSD? How do you know?
- A part near the tranny that seems to be leaking?,not sure what it is (pics inside)
- Anyone who has replaced front strut mounts, please step in.
- Help, Clunking
- maxima and I35steering wheel interchangeability
- 2000 SE Engine 'Stumbles?'
- Well VIAS Solenoid crapped out on me. Bypassed VIAS...
- How many 2k2 Blk/Blk 6MT where made?
- Where Can I Buy Tokico Illuminas?
- 2000 SE, engine knock, no code plus weird groan
- Tokico Illuminas Installed...results
- angel eyes, best brand and prices??
- Installing spacers stripped out studs
- CD stuck in 2002 non-Bose...
- Sway Bar Bushings
- Hid conversion in 2k headlights
- Moog Sway Bar Link
- ViS CF hood or ABS cf hood?
- Rear Brakes
- Steering Gear Box Leaking
- HELP~DID engine swap~ odo/spedo does not WORK!
- 2000-01 Grill Size same as 2002-2003?
- Question on Front Struts
- Wow, replaced main ground wire
- Possible ECU Problem??
- Gone for a while, Replaced the Maxima
- How to remove front grill?
- Time to buy rims
- oil cooler problem
- maf
- Regional Meet (Nov.) Poll in S.E. Forum
- How-to change O2 Sensor (Bank 2 Sensor 1) SES Code P1147/0139
- Thingking about to have fire extinguisher.
- Loud Fan Rattle
- How hard is it to fix a noisy fan?
- threads chewed up wen takin out o2
- All Aluminum Radiator???
- help...small crack in radiator
- 5.5 gen 4 speed > 6th gen 5 speed auto swap
- a little help with the emission spec... did the search, just want to make sure...
- 01 AE Redline Shift boot?
- Clock/Alarm In Center Dash
- Thanks ORG
- New Plugs & Coils, still getting P0300 - Help!
- tranny
- Air Conditioner Using Extra Gas?
- Question for O2 sim users...
- Having Problems With Car Again
- Question about AFR with headers...
- Sunlit sand car, opinions w/ painted wheels?
- P0032 and P0037 any other ideas?
- Anybody got a carfax account?
- 5.5 short shifter
- P0720 Sensor Location w/ Link 2 pix.
- 2001 SE 5MT has a huge bog after ~4500rpms, culprits?
- Cleaning AC Vents
- 2003 Auto Shifter
- Brake caliper rubbing
- Trouble code p720
- group buys
- will a 5th gen bose hu fit a 03 infiniti i35.
- Codes p1706 on a 6MT
- Bigger TE wheels
- rear view mirror
- Big PROBLEM!!! please help.
- Lifetime Warranty Break pads
- Fuse box layout....
- That infinti sound..
- Replacing sparkplugs on a 2k2+ -- Some questions
- Weird Growling Sound, Please Read
- Car Overheats When AC Is On
- Just bought a max and inherited problems
- rebuilt trans 6 times, in 8 months
- CHeck these MAX's out...I might be back...
- Question About Knock Sensor
- Megan Racing cat back
- Wheelskins Steering wheel cover
- Tranasgo shift kits
- Tranny fluid has metal in it
- ULTIMAX BRAKE DISC SET anyone?
- Cattman Y pipe
- Weird clicking on rear axel - 2000 SE
- Officially Joined the Eibach/Illumina Club...
- Wheel Spacers
- NEED a contact for brushed aluminum dash kits..help?!
- Bose Headunit and Temperature Display Goes off when head lights are on??
- swap 5spd for 6spd?
- 698 dollars to fix wheel bearings?
- Pedal Learning Procedures Q
- power
- Broke MY LinkaGe... PICS.
- Window gutters: need educated advice
- Suspension loose
- how to install unorthodox pulley? can anyone help.
- 5.5 gen stalks in 5th gen...
- Keyless entry?
- New and improved SPW FSTB
- Fog light Disassembly
- Speed Sensor location help - Picture attached
- Throw Out Bearing.... who has replaced this?
- A very tricky situation - help!
- Clutch ...
- Vehicle Speed Sensor
- Service Engine Soon....P1147 & P0139 Code?
- New Noise
- Lets go green (H.I.D.)
- Used Auto...yuck..
- headlight issues, brights and daytime lights work
- Suspension is Coming ! =D Few Qs
- H-Techs new or used with stock?
- Absolutely WEIRD... Electrical Gurus, Step Inside.
- Car died on the beach trip today...
- Question About sunroof buttons/maplight console???
- After wheel alignment car still pulls to the right
- 2k Dies Upon start
- Air Filter Dealer Parts Alert 16546-V0100 16546-0Z000
- Tranny sounds like a damn roots blower....
- How do I install Eibach Camber Kit?
- Aftermarket 2000-2003 clear taillights!!
- Chrome-dome bulbs for cleared turn signal lenses are in. (chrome dome)
- My car sat in a garage for 30 days...
- REAR Shock mounts ...should i replace them?
- oil pressure adapter
- tranny issues
- The positive and negative about clear corners
- Knock Sensor
- noise with SE-R rims!!! HELP!!
- Progress w/ Illuminas - anyone have that?
- Speedometer at times, does not work froom 0-15
- Interpret Codes
- AT Transmission Flush
- Installed Rear Brakes, Dissapointed
- Blacking out side markers?
- Rear brakes but no shims - any probs?
- Quick Question???????????
- Places to buy cheaper 5th gen parts
- took out the bose radio and some lights don't work
- Bleeding the clutch
- Need quick help electrical problem
- 6th Gen upgrade... Front Brake Pad Retainers... 6th gen vs 5th gen
- The 100k Day
- Coolant leak
- Rear Caliper Seizing bleh
- looking for the write up on how to rewire bumper lights
- Auto Dimming mirror
- cv axles replacment
- 5.5 Gen Vehicle Speed Sensor
- How To: Reset Airbag
- What is this nasty sound?
- just bought 2k3 17x7 oem wheels! now need suggestions for tires
- AC Temp Control Problems
- cf front lip
- Cylinder 5 Misfired Detected
- How much HP & TQ does A/C & P/S is rubbing ?
- Few Questions, =)
- Cattman True cai
- Help! my A/C buttons arent lit anymore :(
- ABS TCS SLIP lights are on
- Memory Seat Question
- Tokico dust boots?
- Battery Relocation / True Cold Air Intake
- wiring lights for trailer?
- 2003 Blk SE Feeler. How much?
- How-To stickies...
- New throne ;)
- Thermostat replacement- 5th Gen
- New Warpspeed Y-Pipe......Rumbling and Vibrations on Acceleration???
- Any advise on air conditioner compressor replacement? (2000)
- Mitchell Ondemand5
- New Air Filter. Tranny/Acceleration problems!
- A strange problem when starting my car, help
- help suspension question
- Replacement HID bulbs
- Car not going straight
- A couple problems with HID kit
- Easy way to re-aim fogs?
- Issue when starting
- eibach rear vs tein s tech rear spring.
- Car doesn't drive straight over bumps, pulls left or right......
- Whistling noise when accelerating
- steering wheel vibrates while driving
- Bad battery or alternator?
- My car won't start
- greddy obx quality
- inline oil filter for transmission...anyone had done this?
- Need some help with projector ligts
- Odd hissing/rattling sound after installing apexi filter
