- 2002 Headlight Help
- Is it time to drop collision and comprehensive?
- is this an org members ride?
- Fuel Injector Pintles
- wht is going on with my max.....?
- Please, Need help diagnosing rattle. Video included
- if youre near LA this weekend or atlanta this spring, come support my wife!
- 2000 maxima rear main seal
- 02 Maxima SE - Intermittent knock in drive
- Taking off the rear camshaft position sensor on a 2002 Nissan Maxima!!
- HID Bulb or Ballast bad??
- Issue with HID Fog Light Color
- Remove Keyfob Programming??
- Installing a aftermarket radio is a b$#$%
- MAF Sensor Issues
- Pre-cat gutted question
- Painting Rear Bumper (Crack)
- I love when my Maxima...
- 2002 maxima camshaft intall issue???
- 'Buzzing' sound at idle, shift into gear and noise goes away.
- Switch the switch.?
- Car wobbles over 10mph
- Gas & brake pedals too close
- my maxipad <3
- 2000 maxima axle seals leaking
- O2 Simulators or Non-Foulers?
- Ralco or Stillen
- NEED HELP!! EGR problem
- New to the Forums here fellas... Few questions on my mods.
- Whining noise from belt area
- Replacing rusted fuel filler tube. Possible with gas in tank?
- Strange oil leak w/pics + video
- Tranny swap out
- Slow cranking, but battery is fine
- 2000 maxima se no power locks
- 6 speed + amsoil = cold scrapes/grinds?
- Race Time
- 4sp into 13s
- Pics and info of Factory Double DIN replacements
- I want purple fog lights on my black Max, which one of these will work.
- intake mid-pipes?
- Muffler Rattle-Curtis Hitch
- 2 cats
- Engine stalling
- Was this ever really an option?????
- 2002 Engine Wiring Harness
- Aftermarket exhaust
- Rumbling when cold
- cracked bumper
- TSB's and Recalls Inquiry on 2001 SE
- P0300, p0303 & p0305
- 95-03 Cattman Headers/Y-pipes in production, order now with little wait!
- Apexi Safc-ll
- Does anybody have a 2002 Grey Maxima SE tinted?
- Whose Maxima did I end up with?
- Need to Replace Radiator
- 00 01 OEM radio in a 02 03
- Lights OUT!? HELPP!!!
- Sway bar end links ... OUCHHHHHHHHHHH
- Hard Start/ Starting issues
- Got a hell of a deal today...
- rack and pinion problems??/ Steering wheel won't stay straight
- Aftermarket radio can't connect with stock bose amp right?
- fuel bypass cut off valve missing
- My MAX wont start.
- Stillen Lip on Sale!!
- Rad went for a dump today.
- Who knows which KYB Shocks/Struts are best
- Fitment
- oh joy, hit a deer last weekend. are ebay OEM style HID headlights ok?
- Stock non-bose unit slowly dying ? Anyone use ASWC for steering controls ?
- Taking off performance parts before I sell Maxima
- TCS off, SES, and SLIP light on.
- Engine shutting off while driving
- engine for my 2003
- codr p0300 multiple random misfire
- Code P0300
- Throttlebody and UM
- Power steering pressure hose
- Fog Lights
- Resurrection
- Fuel Octane Questions
- traction control light and TC off light stay on
- Shifting weird from 1st to 2nd (auto)
- Timing chains
- Change both axles, car now wobbles under accel.
- Fog Light Replacement? (H3, what color is usuable)
- Possible culprits for minor hesitation?
- Love My Car!
- car steamed and rad fan issue ?
- Timing chain rattle
- 02 SE, 120k miles... Replace timing chain??
- question
- Odd window problem...
- Pics of Your Installed TWM STS
- Radiator Cap
- Whistling noise.
- tranny swap
- Who'd be interested in CXJ V1 spacers?
- Is it reliable and worth it?
- My dash lights, dome lights, and auto door locks wont work.
- 01 MAXIMA GLE solenoid & air intake control valve issues??? plzzz help
- Clutch bleed by pressurizing master reservoir
- Rear Main Oil Seal
- Power steering issue?
- After 3 years, my Max is back on the road.
- Anybody looking for a 06 3.5 engine with 70k with a spun rod. Text me 973 610 1386.
- Windows opening up automatically, locking and unlocking as well, and alarm going off
- Introducing...
- Clutch Repair Advice?
- Problem: Engine starts and stalls - fine after a while
- GLE Tail Light Question
- p1320 primary ignition signal
- Alpine White vs. Mineral White
- Valve cover gasket kit quality?
- Cylinder 5 Misfire, possible fuel injector problem?
- wtf is goin on?
- Where would be the best place to buy both fog light assemblies (Canada)
- Manual swap questions
- clutch master cylinder?
- Knocking noise startup
- Time for some new bushings ...
- Maxima Rant
- 2000 Maxima Codes
- Valve noise
- Will 2009 Heated memory Maxima seats be able to go into my 2003 with modifcation?
- Sunroof Deflector wanted for 2003 GLE
- Did any white 5.5's ever come with black leather interior?
- P0300 Solutions?
- Faulty fuel system
- My wife just named my car.
- Clip on E-Brake
- Gas Rationing NYC
- considering used engines
- clicking sound when rpm decreases
- Need Some Help P0174
- 5.5 Clutch Replacement
- Y Pipe Emissions Test Question
- RPM surging when lightly touching gas
- dumb question: part # for tail lights...
- Help needed ses on. college student
- Coilovers.
- Igniter Sytem Circuit Malfunction
- Start up rough idle...
- Definitive opinions on Power Steering Pressure Hose?
- little exhaust video.
- 2002 Maxima Engine Tick
- Metal flakes in gear oil.
- Blown Tranny after axle install- Sears Auto.
- WTH is wrong with my steering
- Something fell off I think...
- 02 03 Aftermarket Manual Transmission 6Spd Mount
- gas pedal
- Pls help my 2000 maxima has high fuel consumption, yet no code
- 02 Maxima - Possible engine leak?
- Car shaking randomly
- SAFC NEO TPS problems help
- Spring movement on Iac
- check engine light on with abs and traction control lights. Abs code 87
- Testing Waters... Brand new Stillen kit front, back and sides
- p1401 where is EGR temp connector
- IAC Testing
- Car stalls with AC/heater on.
- So my axle seal replacement skills.. Not so good
- Knock noise from rear
- Climate fan/defrost only start working when I hit hard bump
- My drl project
- Question?
- Anyone else have their sending unit go bad?
- scraping noise from rear passenger side
- where is the blower motor relay?
- added led lights under door handles
- Lowering Springs
- Cooling Fans Not Working
- Will this part fit my maxima?
- AC Compressor question
- Engine Running Rough
- What the Hell??
- Weird RPM, noise, then smooth
- Blew the Clutch Right Off the Compressor
- Fix one thing and a new code shows up !!
- Bose Replacement Ideas/Suggestions
- Lighting issues
- car heat up no warm air, already change the thermostat twice
- blower fan motor ... Mobil 1 and Amsoil Transmission fluid
- Track Days
- The best way to recolor my interior?
- 6mt smoother shifting less 3rd grind anyone?
- 2001 infiniti i30 - idle problem?
- 5th Gen SRI
- best place to buy the back wheel bearing assembly
- blower mtr fuse keep burnt, help needed!
- Windshiled Wiper Problems
- quick question, regarding headlights and fogs
- shimming input shaft bearings
- What about this 2002 w/ 85k as a beater?
- fixing to go crazy
- Replacing 02 Sensors for MPG
- 2000-2001? Good Choice?
- piaa fogs
- blower motor might be dead
- Fabrication Thread
- So I plasti dipped the wheels
- help!!
- Need a little advice/help!
- code P0134
- headlight problem
- convince me to buy a 2002 nissan maxima se
- Bad installation of suspension parts, or bad parts.
- Difference in the 2 MAFs ...
- 2000Max rough idle and stalls
- Oil leak from valve timing solenoid?
- privat vulcan rims
- replace motor or fix old one
- WTB 00-01 coolant pipe/crossover
- Need help finding the front end noise 01
- Its going to be a long weekend...
- need a quality front engine mount
- Why is the Warpspeed ypipe build quality so bad?
- P/N That comes out of front valve cover to rear
- Car alarm system does not activate...panic button works
- How do you know?
- 2000 Timing Chain Rattle When Cold
- 2002 GLE Strut Replacement Advice
- Will the motor from one year go in another year
- scraping noise ? From engine pulley area. 2001
- Rust below engine support and front bumper
- Aftermarket Radio Help
- Swapping out Steering wheel in I35
- Ignition Noise in Radio
- rear trailing arm bushing swap ..?
- Radiator Question! Koyo for a manual transmission
- Do Non-HLSD axels work for a HLSD Trans?
- Parking light issue... Bad ground?
- 2000 i30t valve cover gasket replacemenr
- Cattman Performance gen5 headers/y-pipes/cats going into production, time to order!
- knocking noise when hiting a bump or pothol
- P0335 Crankshaft Position Sensor
- 01 maxima se issue
- replacing radiator on 2000Max
- Ecm
- Is it worth anything?
- Muffler.
- Rear Bumper Retaining Studs
- Roof Wing
- 2001 GLE Airbag light flashes code 6
- Engine revs REAL high at startup
- Oil light for one second on startup.
- My Bye Bye Maxima.org Thread
- change my 2000 maxima seat with 2002 seat
