PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Long crank and engine cold issues
  2. Nissan Maxima 2000 exhaust leak sound? (with vid)
  3. VIAS vacuum lines
  4. How do my spark plugs look?
  5. 6th Gen Seat Swap
  6. I've ordered 22's. Have clearance questions
  7. What would you do....
  8. Gen 4 5-speed swap into a 5th Gen Max
  9. Keyless entry works when ign on/good!
  10. P0141, p0155, p0161, p0154 all at once???
  11. Got an old design Beck/Arnley front valve cover
  12. Intermintent starting
  13. Gas & Brake Pedal Clearance
  14. How much is this car worth?
  15. Radiator question?
  16. 2000 Nissan maxima start only in Neutral
  17. Gap the spark plugs or leave them alone?
  18. 2000 maxima starting / running issues
  19. Why do we need a PCV if there is a breather hose?
  20. 75MM TB, bore IM elbow?
  21. 4 gen to 5th gen part swap questions.
  22. 2001 i30 - Overdue oil change causes misfire?
  23. Rebuilding an alternator, anyone done it?
  24. flywheel questions
  25. ac bypass...any negative effects with heat?
  26. All gen 5 owners should boycott Nintendo Switch!
  27. Bad news with MAF - need some help
  28. Tis the season for cam/crank sensors...
  29. 2000 Infinit I-30 Motor Mounts
  30. 5th gen issues and problems that I'm having
  31. Performance upgrade
  32. ABS light with new sensors
  33. Seafoaming My 02 Maxima Se, Vacuum Hose help
  34. How hard is the upper radiator support to replace?
  35. automatic transmission wont shift into any gear
  36. Gas smell
  37. 02 maxima coolant leak
  38. Part within part identification help.
  39. Battery and Brake Light On
  40. 5th gen IRS swap
  41. Serpentine Belt squeaking after change
  42. 01 maxima SE rear beam install.
  43. P0335 Code
  44. Black Friday/Cyber Monday 2017 - Deals Start Now!
  45. doors/mirrors
  46. Ball joint boot ripped
  47. 2002 valve cover/gasket replacement questions
  48. Humming noise at speed and only left hand turns
  49. TransGo Transmission Rebuild Kit Question
  50. Which Tires?
  51. overheating problem
  52. Coolant leak
  53. Codes/PO171
  54. Extreme rear wheel tire wear
  55. Key fob only unlocks/locks at certain times in certain places...it is not the key fob
  56. 2001 Maxima 20th Anniversary Radiator Support Advice and General
  57. Sluggish acceleration/loss of power could it be the catalytic converter??
  58. Nightmarish 700 mile drive home after buying
  59. Hose??
  60. Before purchasing this Maxima...
  61. Looking to get 18" rims on my 02 Max
  62. Black headlights with stock hid
  63. What is the "G" in GLE
  64. question about front brake upgrade
  65. Rarest Parts for a Maxima
  66. Best Exhaust Setup/Exhaust Question
  67. 2002 maxima gle electrical problems!
  68. Grinding? Noise While Accelerating
  69. 2000 Maxima 3.0 Ignition Condensor
  70. Heat only working when under load
  71. VIAS Solenoid
  72. 02 maxima loss of power
  73. How best to put her to bed one final time?
  74. Car shutdown while running/driving?!?
  75. 2003 Maxima Throttle Problems
  76. Trouble starting / Need HELP
  77. Can anyone help !!!!!
  78. Engine sounds like a vacuum cleaner motor
  79. Why is the 5th gen Maxima impossible to sell?
  80. Road Trip
  81. Ignition locked after using a new dealer cut unprogrammed key.. how can this be fixed
  82. Vacuum leak after intake removal
  83. Gasoline Odor & Code P1800 VIAS control Solenoid
  84. Loud rattle at stratup
  85. Impressed with the high mileage idle
  86. High Horsepower 5th Gen - Video
  87. Divers door won't lock
  88. Start and stall fixed with fuse pull
  89. p1448...Mechanic says "what?"
  90. 2003 nissan maxima issues
  91. Quick question
  92. Motor mounts
  93. new purchase advice
  94. Ping Problems! Tried everything....
  95. Adding Factory Fog Lights
  96. Solid bucket lifters ...ticking noise (02 maxima)
  97. 5th gen exhaust video
  98. Brake caliper seizing - possible issue with ABS system
  99. Won't crank
  100. P0172 and PO430 codes
  101. Easier Way to Change Rear Spark Plugs...
  102. Huge power loss, in straight line!
  103. I'm back with a 2002 GLE..alternator issue...
  104. Ticking noise 02 mama
  105. 2002 Headlight Adjuster Broken
  106. 2 Catch Cans?
  107. air bag light
  108. 5th gen maxima sunroof moonroof adjustment
  109. 02/03 cooling fan part numbers
  110. What is needed to swap from manual to Automatic. (Endurance Racing)
  111. Headlight problem
  112. odd squealing noise !!!
  113. How to Test Electronic EGR Valve - FSM Factory Service Manual info needed
  114. Blower Motor puzzler
  115. Bank 1 Front Sensor 1 - Which one is that on RockAuto?
  116. Talk to me about precats and P0430/P0420.
  117. sad dieing max
  118. 350z intake on a 2002 i35/maxima build
  119. Battery and brake light flashing
  120. New guy here... 00maxima gle
  121. Just when you fix one thing...
  122. Rear valve cover surprise
  123. Rough idle, slight miss at idle, after new plugs and wires
  124. Brakes sticking, replaced caliper, bracket, pads, still sticking
  125. air bag light
  126. JUst hit 250,000 MIles in my I35
  127. 2001 Maxima Dies While Driving
  128. Rear valve cover and RTV application
  129. Thinking about buying a maxima
  130. Crashed my 5th gen... is it worth saving?? or swapping?
  131. 02 body feels like a boat ride
  132. Question about o2 simulators
  133. does anyone know the part #
  134. 2001 Nissan Maxima Manual Transmission Dipstick?
  135. Straight pipe too loud please help
  136. 2002 SE windshield wipers
  137. 2002 SE Trailing Arm Bushings
  138. Bleeding Brakes Advice?
  139. how to make pinging go away???
  140. Weird HVAC question - Fan won't turn off now...
  141. Interior Bulb Guide on '02
  142. No throttle response
  143. Interchangeable Parts between 4th GEN & 5.0 GEN
  144. What is this hole for and why is it missing.
  145. Why does p01800 keep showing up
  146. Questions to ask prior to buying?
  147. P0740 - TCC Solenoid Question
  148. 2002 gle with chattering valve issue!
  149. Overheating of Nissan Maxima 2001
  150. Anyone tried LED in their Foglights?
  151. 2002 Maxima Engine Blew - Engine Swap Options?
  152. 2003 very high pitch whine after driving
  153. Looking for Photos
  154. Need Help ASAP 2002 Maxima AT 4 Speed
  155. No power steering at High RPM
  156. Turbo HR Swap Putting Down Some Numbers
  157. NWP BBTB 75MM with P2135 code
  158. Help Jerky shifting wont go above 2500 rpm
  159. Auto Shifting Issue
  160. Map Sensor in the damnedest place
  161. Front Strut Replacement
  162. 2000 nissan maxima sunroof issue tried reset; (
  163. I promise you I did my research... won't start.
  164. Infiniti i30t IACV issue?
  165. Fuel sender or gauge?
  166. 2002 5.5Gen - Pull Engine from Top or Drop at the Bottom?
  167. Replacing inner timing chain case
  168. harmonic balancer failed.
  169. I need help
  170. Exhaust pipe question
  171. 02 gle center console teardown
  172. Looking to buy another 03
  173. E brake
  174. Will Warpspeed y pipe fit correctly with Cattman headers?
  175. Gen 5 02 Maxima found headers but hella pricy will Altima headers fit Maxima setup?.
  176. 02' maxima relay problem
  177. Seized rear caliper piston
  178. Rear hub
  179. AUX Input in NON Bose?
  180. Im begining to hate nissan.
  181. Music
  182. Seized rear caliper piston
  183. B-Pillar Vibration
  184. AE blank key
  185. O2 Extenders & CEL
  186. Will 2009 engine fit into a 2000 maxima?
  187. Stalling idle issue
  188. Need recommendation (Headlight Bulbs)
  189. 2000 Maxima: Where is the pressure switch for the AC Compressor?
  190. Aftermarket "OEM equivalant" Thermostat
  191. Selling the AE Max, bought an Audi S3
  192. Electrical a.c. issue
  193. PO420 .....which O2 sensor?
  194. Climate control issues
  195. Something in the sky or far away is controlling my cars ECU
  196. Cant fix Nissan maxima rear suspension noise
  197. Fuel pump problem. Installed correctly?
  198. Fog lights not working
  199. LED light bar
  200. 2000 V6 engine issue
  201. 5gen stainless clutch line on a 5.5 gen
  202. New (junkyard) ECM, new IACV, new TPS, still P0505
  203. 5 gens on rims photo drop
  204. Radiator fans always running once car warms up.
  205. The shop pulled these codes, any ideas?
  206. Just getting into cars. Engine swap?
  207. 5th gen Maxima sunroof problems
  208. 2002 Max 6 speed - RIP
  209. Code p0420
  210. First Post - Crank Pulley OR?
  211. P0430 Code On then Off Then On Again
  212. Steering Wheels Shakes at Highway Speeds
  213. Let's talk Rebuilds vs Swaps
  214. New Ksport Kontrol coilovers.
  215. Door removal
  216. Clutch Creaking
  217. I always wondered how these work. Video explains it in detail.
  218. Maxed out tention pully
  219. Cooling issues
  220. So I guess I can't jack the car up from the front anymore
  221. 5.5th Gen Bogging and Engine Haulting After Clutch and Trans Swap
  222. Benefits of a Test Pipe
  223. p0430 bank 2, o2b1s2 zero volts
  224. Freezer's 5.7 gen swap
  225. swapping my 2002 nissan maxima with 06
  226. Crank but no starting - Maxima 2000 model
  227. alternator upgrade questions
  228. 6th gen front brakes VS. Powerstop.
  229. Street Tuning a 5.5 Gen on E85 - Happy 4th of July!
  230. hello everyone im considering 5.5 gen headlights need some info
  231. Overheated, now has issuses with running
  232. Correct assembly order, rear suspension components
  233. 2002 wont start
  234. I tired because I didn't get the solution!!!!!
  235. Extended wheel studs?
  236. How to make an Automatic backfire
  237. ECM Servicing & Testing
  238. Hard Shift and Jerk on transmission
  239. A/C and RPM surge problem.
  240. Buying a Used Transmission
  241. Questions about the 5 & 5.5 Gen manual transmission
  242. coils
  243. Cooling fan problem
  244. Best replacement axles?
  245. Alternate possibilities besides IACV/ECU for P0505
  246. hella horn install...positive or negative...
  247. Swap Standard HVAC to Climate Control?
  248. 2004 Intake on 2002?
  249. Please help me ASAP
  250. Loud clunking sound after lowering my car
