- 1-2-D shifting?
- Drop Resistor Mod for Auto Tranny, Expriences?
- what is the best way to reduce brake dust...
- Help Please!
- check engine light
- Ground Control
- Differential Bearings
- where to get a nice SPOILER ?
- Changed knock sensor HOLY CRAP! The diff!!!
- 1995 lower ball joints / control arm
- E-Bay CAI intall problem......please help.
- Is your Max reliable?
- Intermittant Start on 95 Maxima
- tail light and intake question
- Painted Chinese Letters on Bezel
- clunk type noise......help needed
- I'm Experiencing A Humming Sound
- yes another headlight question
- Is the auto kickdown piont adjustable ?
- clutch fluid and CV joint help!!
- any good mechanics in VA?
- Passenger Door Light
- problems with suspension
- dash kits??
- compression in engine
- I finally got one
- bumper scratches up
- VERY interesting...read because your ignition coil could be next!!!!!!!!
- Got the transmission back on...but...
- Max blown up in S.W.A.T. movie
- sand paper grade
- problems starting
- Gonna check coils, but radio shack multimeter good enough?
- Just installed CAI, Need opinions...
- HIDs worth it?
- 99 maxima tire question
- Fuel injectors???
- Does 97 front bumper fit a 96?
- Getting new lights (the works) I need some info and opinions
- Warpspeed or Cattman Y-pipe
- Installing a K&N filter...
- CarFax Check Please
- Transmission problem
- bad gas mileage
- Squeaky Springs (or some part of suspension)??
- Bah.. Venting Mode
- installed 2k3 SE muffler
- Not starting when hot -Please Help-
- Sarona Body Kit
- Check Out These Spanking New Exel GT- 7/17" Rims On My Max!
- Replacement Clutch Question
- differential bearings on 95SE
- ABS light
- New pics of my car
- Review: Rota Sub-Zero & KYB Struts & Kuhmo 712
- What is the size of stock rotors for 4th gens?
- jus got a 95max
- POLL : L/100km on 4th Gens ... ... ...
- Problem w/ fuel injector. Spitting too much gas at once.
- How to replace a hub...DIY or Shop work only?
- The piece on the rear glass?
- Engine Swap.....
- altezzas split at seam!!!
- throtle cable tightening
- alternator/AC belt change?
- my top end was 118-120?
- How often do you need to get your timing chain service?????
- Funny noise
- Sprint or H and r?!?!
- vehicle speed sensor and TCU signal to ECU, need to fix?
- What Should I Get Next!!!!
- Resetting ECU?
- Procarparts intake similar to place race or injen?
- Focus ZX3 v. 1997 Max
- horsepower?
- selling max need opinions
- Intake Leaking Oil?? (PICS)
- e-brake light randomly comes on...
- just got my budget cat and b-pipe (pics)
- top speed Problems
- Lighting Question
- need brake's
- thump thump, bump bump at redlight
- time to mod!!!!!!
- knock sensor and coolant temp. sensor
- Question regarding Shocks/Struts
- help diagnose: bumping noise with speed
- Variable Intake Runner Length Manifold Kit
- apc headlights
- y-pipe identification?
- Missing clips
- Adjusting foglight aim
- Any1 Still Have Their Stock SE-Limited Rims?
- Removing the Bezel
- Groaning from Front Dr side 4 months after suspension install. Help!
- 95-99 Nissan Maxima Greddy SP Style Muffler
- maxima
- Alignment after installing springs and struts?
- intake and exhaust
- remote ignition
- clutch replacement
- Still leaking axel even after 3 seals??
- Has Anyone Done the Stock Intake Mod?
- Is flywheel worth it?
- Does anyone have copies of my SC'ed Maxima movies clips?
- using the key to roll down windows
- YAY!!! i got my HID conversion kit today...
- half roof spoiler on my car (w/o trunk spoiler)
- do you have any pics of Reflective tint?
- 3rd gear trap small??
- Catback Exhaust and Pop charger...
- Post pics of your dash kits....
- Where to get the sensor or switch that is over my Drier Can (A/C)
- Need a R/H axle shaft
- engine mount
- Where To Buy K&n Filter
- Changing 96 SE Gauge Cluster Bulbs Question
- CAI options?
- Chirping 3rd gear with a stock clutch and 361K miles.....wait there is a downside
- Motivational Rear Mounts @ $125 = RIP OFF
- [B]Technical Service Bulletins for 1996 Maxima[/B]
- ??Mid Pipe??
- High Beem LED
- Any 4th gens with 5th gen 17s and stillen kits here?
- 5sp conv. Park/neutral switch and reverse light
- 97 grill on a 96....also headlight swap
- Help with indiglo gauges!! Im screwed??
- Just installed a JDM 5spd tranny=smooth!
- Overseas SMX Maxima.....?
- engine knock under acceleration
- is gl 5 amsoil 75W-90 synthetic gear fluid
- Who worries about their car getting stolen/vandalized?
- throwing yet another code 0705
- making a fog light place grill
- Small Problem: Rear License Plate Lights
- Need some parts for '97...
- Speed Limiter
- my exhaust vs. the police
- Why --> Manual shifter hard to move!!
- Steer Wheel Question.....
- Jwt
- traded in maxima and got new car! :)
- auto shifter VERY STIFF- ideas?
- New Frankencar!!
- Synthetic MT Oil WOW!
- Lowering Springs or coil overs 2 drop??
- 0104 & 0504 codes!!
- Question on 97 climate control
- K&N filter VS generic filter
- ECU Broken?
- ACC illumination failed -- have to switch whole unit?
- Overhaul
- Weird car ish.........
- need help getting dash face plate off
- 97-98 frankencar intake must go
- anyone with 95-97 5 speeds
- Intermittent Starter problems
- maxima meets? MA area
- anyone have 225/45/17 w/sprint springs????
- o2 sensors where are they?
- HOw much do you think it would cost to replace a steering knuckle?
- How much of a difference when i get new KNOCK SENSOR
- Help me pass smog!!!
- Locked out of 4th!!!
- Suggestions needed...
- My engine stalls for some reason
- Pics of my new CHrome Gauge Rings :)
- Brake recommendations/stopping power questions
- Spark plugs
- axel nut
- Hi
- 6 coils, none firing
- gauge cluster! help!!!
- What to do to the maxima?
- Shifter Installation Problem
- Interior heating/cooling fan
- bad rear 02 sensor, knock sensor and a timing chain rattle?
- Took out blower fan now AIRBAG LIGHT blinking
- Theives Urrrrh
- Proof that the JWT/MEVI combo works...
- Pull the Mileage from ECU.......
- rear disc brakes on '99 Maxima
- catback exhaust & Y pipe recommendations
- 96 Maxima SE - O/D blinking on start, MIL light on and rough subsequent shifting
- Raced a mini cooper S!!!!
- Budget Y, CM test pipe installed
- Raise rev limit to 7000 rpm or 7200 rpm?
- clear bumper light
- How to clean JWT pop charger properly?
- carfax
- help me!! car dying out
- having lots of hesitation
- Instructions On Installing Hood Pin Anyone???
- Those who've seen the valvetrain
- Just got my maxima, had a few questions?
- Help! Broke my friends max!
- Anyone bought a "K&n" filter off of ebay
- My dyno - should I keep stock cat or test pipe
- New Pirelli tires, CANT keep the back end from fishtailing?? why?
- Upgrading Suspension this weekend, have some questions
- clear diamond cut bumper lights
- code 10 3 Help!!!!
- Flat spot in 2nd gear
- I need help. O/D light blinking after 5 speed conversion. Any ideas welcome!
- E36 BMW lights on a 4th Gen Maxima ??
- CAI, How do i install it ??
- Hazard And Defrost Buttons -- Lights Went Out
- Knock Sensor 97 Maxima
- Stinger Battery..Will it Fit??
- damnit, cracked a fog...
- ECU Alone worth it?
- woohoo!!
- FOG lights
- Chirping/squeaking from front right
- ALRIGHT! One last time guys...what about the budget y-pipe?
- Who has 95 or 96 ECU in their 97 or 98 ?
- Torque For Spark Plugs
- AC not working for 1, 2, and 3 setting help
- Short Throw Shifter
- Maxima+me+3\4 tank+UPS=3380lbs
- MEVI...use a relay, or no?
- Is the front of the engine the right or left side?
- 95-99 maxima skyline body kit and phase ll fenders
- Best place to mount ballats and starter for aftermarket HID lights?
- YIKES!! hte knocking noise is BACK!!
- power steering pump, what to do
- O2 Sensor Codes and other simple questions
- Line Pressure (Dropping) Resistor Specs
- Progress springs with gr2?
- LED Turn Signal Mirrors
- Car got totaled...
- Brake light on
- Rear spoiler brake light
- My ECU Changed Its Mind!! Help!
- Running a little rich after Y-pipe install
- is this muffler a good buy?
- Help: Airbag Cover!
- Input on Gen 2 Altezzas
- Ghost Code
- car back from shop...is this normal?
- can someone take a look at this auction and tell me if it's worth 5 bucks
- Marble VQ painted Cover....
- MUAHAHAHAHAHAHAHAHAHAHAHAHAHA! got pulled over today!
- More proof of SR20 Powered Maximas
- Belt making sounds...Help
- Checked ecu for codes today!! Im ****ed
- crimson blaze?
- ok deal? suspension question
- Still getting 0302 even after mechanic claims he cleaned EGR tube.
